[GRASS-SVN] r63472 - grass/trunk/lib/python/pygrass
svn_grass at osgeo.org
Wed Dec 10 08:54:07 PST 2014
Author: zarch
Date: 2014-12-10 08:54:06 -0800 (Wed, 10 Dec 2014)
New Revision: 63472
grass/trunk/lib/python/pygrass/utils.py
pygrass: add function to handle local and system path in modules
Modified: grass/trunk/lib/python/pygrass/utils.py
--- grass/trunk/lib/python/pygrass/utils.py 2014-12-10 11:21:38 UTC (rev 63471)
+++ grass/trunk/lib/python/pygrass/utils.py 2014-12-10 16:54:06 UTC (rev 63472)
@@ -286,6 +286,22 @@
return path
+def set_path(modulename, dirname, path='.'):
+ import sys
+ """Set sys.path looking in the the local directory GRASS directories."""
+ pathlib = os.path.join(path, dirname)
+ if os.path.exists(pathlib):
+ # we are running the script from the script directory
+ sys.path.append(os.path.abspath(path))
+ else:
+ # running from GRASS GIS session
+ from grass.pygrass.utils import get_lib_path
+ path = get_lib_path(modulename, dirname)
+ if path is None:
+ raise ImportError("Not able to find the path %s directory." % path)
+ sys.path.append(path)
def split_in_chunk(iterable, lenght=10):
"""Split a list in chunk.
