[GRASS-SVN] r63473 - grass/trunk/scripts/i.tasscap
svn_grass at osgeo.org
Wed Dec 10 12:09:37 PST 2014
Author: neteler
Date: 2014-12-10 12:09:37 -0800 (Wed, 10 Dec 2014)
New Revision: 63473
grass/trunk/scripts/i.tasscap/i.tasscap.py
i.tasscap: MODIS added; partial code rewrite by Leonardo Perathoner, Trento
Modified: grass/trunk/scripts/i.tasscap/i.tasscap.py
--- grass/trunk/scripts/i.tasscap/i.tasscap.py 2014-12-10 16:54:06 UTC (rev 63472)
+++ grass/trunk/scripts/i.tasscap/i.tasscap.py 2014-12-10 20:09:37 UTC (rev 63473)
@@ -3,10 +3,12 @@
# MODULE: i.tasscap
-# AUTHOR(S): Markus Neteler. neteler itc.it
+# AUTHOR(S): Agustin Lobo, Markus Neteler
# Converted to Python by Glynn Clements
+# Code improvements by Leonardo Perathoner
# PURPOSE: At-satellite reflectance based tasseled cap transformation.
-# COPYRIGHT: (C) 1997-2004,2008, 2014 by the GRASS Development Team
+# COPYRIGHT: (C) 1997-2014 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
@@ -30,7 +32,7 @@
# Compare discussion:
# http://adis.cesnet.cz/cgi-bin/lwgate/IMAGRS-L/archives/imagrs-l.log0211/date/article-14.html
-# Landsat8: Baig, M.H.A., Zhang, L., Shuai, T., Tong, Q., 2014. Derivation of a tasselled cap transformation
+# Landsat8: Baig, M.H.A., Zhang, L., Shuai, T., Tong, Q., 2014. Derivation of a tasselled cap transformation
# based on Landsat 8 at-satellite reflectance. Remote Sensing Letters 5, 423-431.
# doi:10.1080/2150704X.2014.915434
@@ -40,8 +42,6 @@
# expressed through transformed MODIS data.
# International Journal of Remote Sensing, Volume 28(22), Table 3
-# TODO: Check if these MODIS Tasseled Cap coefficients are different:
-# http://ieeexplore.ieee.org/xpls/abs_all.jsp?arnumber=1025776
#%Module
@@ -53,7 +53,7 @@
#% keywords: Tasseled Cap transformation
#%end
#%option G_OPT_R_INPUTS
-#% description: For Landsat4-7: bands 1, 2, 3, 4, 5, and 7; for Landsat8: bands 2, 3, 4, 5, 6, and 7
+#% description: For Landsat4-7: bands 1, 2, 3, 4, 5, 7; for Landsat8: bands 2, 3, 4, 5, 6, 7; for MODIS: bands 1, 2, 3, 4, 5, 6, 7
#%end
#%option G_OPT_R_BASENAME_OUTPUT
#% label: Name for output basename raster map(s)
@@ -64,8 +64,8 @@
#% description: Satellite sensor
#% required: yes
#% multiple: no
-#% options: landsat4_tm,landsat5_tm,landsat7_etm,landsat8,modis
-#% descriptions: landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules for Landsat 7 ETM;landsat8;Use transformation rules for Landsat 8;modis;Use transformation rules for MODIS
+#% options: landsat4_tm,landsat5_tm,landsat7_etm,landsat8_oli,modis
+#% descriptions: landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules for Landsat 7 ETM;landsat8_oli;Use transformation rules for Landsat 8 OLI;modis;Use transformation rules for MODIS
#%end
import grass.script as grass
@@ -90,26 +90,32 @@
[( 0.4395, 0.5945, 0.2460, 0.3918, 0.3506, 0.2136, 0.2678), # MODIS
(-0.4064, 0.5129,-0.2744,-0.2893, 0.4882,-0.0036,-0.4169),
( 0.1147, 0.2489, 0.2408, 0.3132,-0.3122,-0.6416,-0.5087)]]
+#satellite information
+satellites = ["landsat4_tm", 'landsat5_tm', 'landsat7_etm', 'landsat8_oli', 'modis']
+used_bands = [6,6,6,6,7]
+#components information
ordinals = ["first", "second", "third", "fourth"]
names = ["Brightness", "Greenness", "Wetness", "Haze"]
-def calc1(out, bands, k1, k2, k3, k4, k5, k7, k0 = 0):
- grass.mapcalc(
- "$out = $k1 * $band1 + $k2 * $band2 + $k3 * $band3 + $k4 * $band4 + $k5 * $band5 + $k7 * $band7 + $k0",
- out = out, k1 = k1, k2 = k2, k3 = k3, k4 = k4, k5 = k5, k7 = k7, k0 = k0, **bands)
- grass.run_command('r.colors', map = out, color = 'grey')
+def calc1bands6(out, bands, k1, k2, k3, k4, k5, k6, k0 = 0):
+ grass.mapcalc("$out = $k1 * $in1band + $k2 * $in2band + $k3 * $in3band + $k4 * $in4band + $k5 * $in5band + $k6 * $in6band + $k0",
+ out = out, k1 = k1, k2 = k2, k3 = k3, k4 = k4, k5 = k5, k6 = k6, k0 = k0, **bands)
-def calcN(outpre, bands, i, n):
- #grass.message(_("Landsat-%d...") % n)
+def calc1bands7(out, bands, k1, k2, k3, k4, k5, k6, k7):
+ grass.mapcalc("$out = $k1 * $in1band + $k2 * $in2band + $k3 * $in3band + $k4 * $in4band + $k5 * $in5band + $k6 * $in6band + $k7 * $in7band",
+ out = out, k1 = k1, k2 = k2, k3 = k3, k4 = k4, k5 = k5, k6 = k6, k7 = k7, **bands)
+def calcN(outpre, bands, satel):
+ i=satellites.index(satel)
+ grass.message(_("Satellite %s...") % satel)
for j, p in enumerate(parms[i]):
- out = "%s.%d" % (outpre, j + 1)
- ord = ordinals[j]
- if n == 4:
- name = ''
- else:
- name = " (%s)" % names[j]
- grass.message(_("Calculating %s TC component %s%s ...") % (ord, out, name))
- calc1(out, bands, *p)
+ out = "%s.%d" % (outpre, j + 1)
+ ord = ordinals[j]
+ name = " (%s)" % names[j]
+ grass.message(_("Calculating %s TC component %s%s ...") % (ord, out, name))
+ bands_num=used_bands[i]
+ eval("calc1bands%d(out, bands, *p)" % bands_num) #use combination function suitable for used number of bands
+ grass.run_command('r.colors', map = out, color = 'grey', quiet=True)
def main():
@@ -117,37 +123,21 @@
satellite = options['sensor']
output_basename = options['output']
inputs = options['input'].split(',')
- num_of_bands = 6
+ num_of_bands = used_bands[satellites.index(satellite)]
if len(inputs) != num_of_bands:
grass.fatal(_("The number of input raster maps (bands) should be %s") % num_of_bands)
- # this is here just for the compatibility with r.mapcalc expression
- # remove this if not really needed in new implementation
bands = {}
- for i, band in enumerate(inputs):
- band_num = i + 1
- if band_num == 6:
- band_num = 7
- bands['band' + str(band_num)] = band
+ for i, band in enumerate(inputs):
+ band_num = i + 1
+ bands['in' + str(band_num) + 'band'] = band
grass.debug(1, bands)
- if satellite == 'landsat4_tm':
- calcN(output_basename, bands, 0, 4)
- elif satellite == 'landsat5_tm':
- calcN(output_basename, bands, 1, 5)
- elif satellite == 'landsat7_etm':
- calcN(output_basename, bands, 2, 7)
- elif satellite == 'landsat8':
- calcN(output_basename, bands, 3, 8)
- elif satellite == 'modis':
- calcN(output_basename, bands, 4, 99)
- else:
- raise RuntimeError("Invalid satellite: " + satellite)
+ calcN(output_basename, bands, satellite) #core tasseled cap components computation
- grass.run_command('r.support', map = "%s.%d" % (output_basename, 1), description = "Tasseled Cap 1: brightness")
- grass.run_command('r.support', map = "%s.%d" % (output_basename, 2), description = "Tasseled Cap 2: greenness")
- grass.run_command('r.support', map = "%s.%d" % (output_basename, 3), description = "Tasseled Cap 3: wetness")
- grass.run_command('r.support', map = "%s.%d" % (output_basename, 4), description = "Tasseled Cap 4: atmospheric haze")
+ #assign "Data Description" field in all four component maps
+ for i, comp in enumerate(names):
+ grass.run_command('r.support', map = "%s.%d" % (output_basename, i+1), description = "Tasseled Cap %d: %s" % (i+1, comp))
grass.message(_("Tasseled Cap components calculated"))
