[GRASS-SVN] r63573 - grass-addons/grass7/raster/r.stream.stats
svn_grass at osgeo.org
Tue Dec 16 13:22:06 PST 2014
Author: neteler
Date: 2014-12-16 13:22:06 -0800 (Tue, 16 Dec 2014)
New Revision: 63573
grass-addons/grass7/raster/r.stream.stats/stats_print.c
r.stream.stats Addon: msg typos fixed
Modified: grass-addons/grass7/raster/r.stream.stats/stats_print.c
--- grass-addons/grass7/raster/r.stream.stats/stats_print.c 2014-12-16 20:24:54 UTC (rev 63572)
+++ grass-addons/grass7/raster/r.stream.stats/stats_print.c 2014-12-16 21:22:06 UTC (rev 63573)
@@ -19,7 +19,7 @@
stats_total.stream_frequency * 1000000);
fprintf(stdout, "\n");
- fprintf(stdout, "Stream ratios based on regresion coefficient:\n");
+ fprintf(stdout, "Stream ratios based on regression coefficient:\n");
fprintf(stdout, " Bif.rt. | Len.rt. | Area.rt. | Slo.rt. | Grd.rt. \n");
fprintf(stdout, " %7.4f | %7.4f | %8.4f | %7.4f | %7.4f\n",
stats_total.reg_bifur_ratio,
@@ -27,7 +27,7 @@
stats_total.reg_area_ratio,
stats_total.reg_slope_ratio, stats_total.reg_gradient_ratio);
- fprintf(stdout, "Avaraged stream ratios with standard deviations:\n");
+ fprintf(stdout, "Averaged stream ratios with standard deviations:\n");
stats_total.bifur_ratio,
@@ -100,12 +100,12 @@
int print_stats_total(void)
fflush(stdout);
- fprintf(stdout, "Catchment's characteristics (based on regresion): \n");
+ fprintf(stdout, "Catchment's characteristics (based on regression): \n");
fprintf(stdout, "Max order: %d \n", stats_total.order);
fprintf(stdout, "Total number of streams: %d \n", stats_total.stream_num);
fprintf(stdout, "Total stream length (km): %2.4f \n",
stats_total.sum_length / 1000);
- fprintf(stdout, "Total cachment area (km2): %2.4f \n",
+ fprintf(stdout, "Total catchment area (km2): %2.4f \n",
stats_total.sum_area / 1000000);
fprintf(stdout, "Drainage density: %2.4f\n",
stats_total.drainage_density * 1000);
