[GRASS-SVN] r63574 - grass-addons/grass7/raster/r.basin
svn_grass at osgeo.org
Tue Dec 16 13:55:02 PST 2014
Author: neteler
Date: 2014-12-16 13:55:01 -0800 (Tue, 16 Dec 2014)
New Revision: 63574
grass-addons/grass7/raster/r.basin/r.basin.py
r.basin Addon: fix trailing white spaces
Modified: grass-addons/grass7/raster/r.basin/r.basin.py
--- grass-addons/grass7/raster/r.basin/r.basin.py 2014-12-16 21:22:06 UTC (rev 63573)
+++ grass-addons/grass7/raster/r.basin/r.basin.py 2014-12-16 21:55:01 UTC (rev 63574)
@@ -5,7 +5,7 @@
# MODULE: r.basin
# AUTHOR(S): Margherita Di Leo, Massimo Di Stefano
# PURPOSE: Morphometric characterization of river basins
-# COPYRIGHT: (C) 2010 by Margherita Di Leo & Massimo Di Stefano
+# COPYRIGHT: (C) 2010-2014 by Margherita Di Leo & Massimo Di Stefano
# dileomargherita at gmail.com
# This program is free software under the GNU General Public
@@ -13,6 +13,8 @@
# See the file COPYING that comes with GRASS
# for details.
+# TODO: does r.stream.snap's snap depend on the raster resolution? hardcoded 30 below
#%module
@@ -25,7 +27,7 @@
#%option G_OPT_R_ELEV
#% key: map
-#% description: Name of elevation raster map
+#% description: Name of elevation raster map
#% required: yes
#%end
@@ -38,7 +40,7 @@
#%end
#%option G_OPT_M_COORDS
-#% description: coordinates of the outlet (east,north)
+#% description: coordinates of the outlet (east,north)
#% required : yes
#%end
@@ -70,7 +72,6 @@
import os
import grass.script as grass
import math
-from numpy import array
from numpy import zeros
import csv
@@ -99,8 +100,8 @@
grass.fatal(_("Latitude-longitude locations are not supported"))
if in_proj['name'].lower() == 'xy_location_unprojected':
grass.fatal(_("xy-locations are not supported"))
- r_elevation = options['map'].split('@')[0]
+ r_elevation = options['map'].split('@')[0]
mapname = options['map'].replace("@"," ")
mapname = mapname.split()
mapname[0] = mapname[0].replace(".","_")
@@ -143,447 +144,447 @@
v_network = prefix+'_network'
v_ord_1 = prefix+'_ord_1'
global tmp
# Save current region
grass.read_command('g.region', flags = 'p', save = 'original')
# Watershed SFD
- grass.run_command('r.watershed', elevation = r_elevation,
- accumulation = r_accumulation,
- drainage = r_drainage,
- convergence = 5,
+ grass.run_command('r.watershed', elevation = r_elevation,
+ accumulation = r_accumulation,
+ drainage = r_drainage,
+ convergence = 5,
flags = 'am')
# Managing flag
if autothreshold :
resolution = grass.region()['nsres']
th = 1000000 / (resolution**2)
- grass.message( "threshold : %s" % th )
+ grass.message( "threshold : %s" % th )
else :
th = options['threshold']
# Stream extraction
- grass.run_command('r.stream.extract', elevation = r_elevation,
- threshold = th,
- d8cut = 1000000000,
- mexp = 0,
- stream_rast = r_stream_e,
+ grass.run_command('r.stream.extract', elevation = r_elevation,
+ threshold = th,
+ d8cut = 1000000000,
+ mexp = 0,
+ stream_rast = r_stream_e,
direction = r_drainage_e)
- try:
- # Delineation of basin
+ try:
+ # Delineation of basin
# Create outlet
- grass.write_command('v.in.ascii', output = v_outlet,
+ grass.write_command('v.in.ascii', output = v_outlet,
input = "-",
sep = ",",
stdin = "%s,9999" % (coordinates))
# Snap outlet to stream network
# TODO: does snap depend on the raster resolution? hardcoded 30 below
grass.run_command('r.stream.snap', input = v_outlet,
output = v_outlet_snap,
- radius = 30)
- grass.run_command('v.to.rast', input = v_outlet_snap,
- output = r_outlet,
- use = 'cat',
- type = 'point',
- layer = 1,
+ radius = 30)
+ grass.run_command('v.to.rast', input = v_outlet_snap,
+ output = r_outlet,
+ use = 'cat',
+ type = 'point',
+ layer = 1,
value = 1)
- grass.run_command('r.stream.basins', direction = r_drainage_e,
- basins = r_basin,
- points = v_outlet_snap)
+ grass.run_command('r.stream.basins', direction = r_drainage_e,
+ basins = r_basin,
+ points = v_outlet_snap)
grass.message( "Delineation of basin done" )
# Mask and cropping
elevation_name = r_elevation = r_elevation.split('@')[0]
grass.mapcalc("$r_mask = $r_basin / $r_basin",
r_mask = r_mask,
r_basin = r_basin)
grass.mapcalc("tmp = $r_accumulation / $r_mask",
r_accumulation = r_accumulation,
r_mask = r_mask)
grass.run_command('g.remove', flags='f', type='rast', name= r_accumulation, quiet = True)
grass.run_command('g.rename', rast = ('tmp',r_accumulation))
grass.mapcalc("tmp = $r_drainage / $r_mask",
r_drainage = r_drainage,
r_mask = r_mask)
grass.run_command('g.remove', flags='f', type='rast', name= r_drainage, quiet = True)
grass.run_command('g.rename', rast = ('tmp', r_drainage))
grass.mapcalc("$r_elevation_crop = $r_elevation * $r_mask",
r_mask = r_mask,
r_elevation = r_elevation,
r_elevation_crop = 'r_elevation_crop')
grass.mapcalc("tmp = $r_drainage_e * $r_mask",
r_mask = r_mask,
r_drainage_e = r_drainage_e)
grass.run_command('g.remove', flags='f', type='rast', name= r_drainage_e, quiet = True)
grass.run_command('g.rename', rast = ('tmp',r_drainage_e))
grass.mapcalc("tmp = $r_stream_e * $r_mask",
r_mask = r_mask,
r_stream_e = r_stream_e)
grass.run_command('g.remove', flags='f', type='rast', name= r_stream_e, quiet = True)
#grass.run_command('g.rename', rast = (r_stream_e,'streams'))
grass.run_command('g.rename', rast = ('tmp',r_stream_e))
- grass.run_command('r.thin', input = r_stream_e,
+ grass.run_command('r.thin', input = r_stream_e,
output = r_stream_e+'_thin')
- grass.run_command('r.to.vect', input = r_stream_e+'_thin',
- output = v_network,
+ grass.run_command('r.to.vect', input = r_stream_e+'_thin',
+ output = v_network,
type = 'line')
# Creation of slope and aspect maps
- grass.run_command('r.slope.aspect', elevation = 'r_elevation_crop',
- slope = r_slope,
+ grass.run_command('r.slope.aspect', elevation = 'r_elevation_crop',
+ slope = r_slope,
aspect = r_aspect)
# Basin mask (vector)
# Raster to vector
- grass.run_command('r.to.vect', input = r_basin,
- output = v_basin,
+ grass.run_command('r.to.vect', input = r_basin,
+ output = v_basin,
type = 'area',
flags = 'sv')
- # Add two columns to the table: area and perimeter
+ # Add two columns to the table: area and perimeter
grass.run_command('v.db.addcolumn', map = v_basin,
columns = 'area double precision')
columns = 'perimeter double precision')
- # Populate perimeter column
- grass.run_command('v.to.db', map = v_basin,
- type = 'line,boundary',
- layer = 1,
- qlayer = 1,
- option = 'perimeter',
- units = 'kilometers',
+ # Populate perimeter column
+ grass.run_command('v.to.db', map = v_basin,
+ type = 'line,boundary',
+ layer = 1,
+ qlayer = 1,
+ option = 'perimeter',
+ units = 'kilometers',
columns = 'perimeter')
# Read perimeter
- tmp = grass.read_command('v.to.db', map = v_basin,
- layer = 1,
- qlayer = 1,
+ tmp = grass.read_command('v.to.db', map = v_basin,
+ layer = 1,
+ qlayer = 1,
qcolumn = 'perimeter',
- flags = 'p')
- perimeter_basin = float(tmp.split('\n')[1].split('|')[1])
- # Populate area column
- layer = 1,
- qlayer = 1,
- option = 'area',
- columns = 'area')
+ flags = 'p')
+ perimeter_basin = float(tmp.split('\n')[1].split('|')[1])
+ # Populate area column
+ layer = 1,
+ qlayer = 1,
+ option = 'area',
+ columns = 'area')
# Read area
- layer = 1,
- qlayer = 1,
- option = 'area',
+ layer = 1,
+ qlayer = 1,
+ option = 'area',
qcolumn = 'area',
- flags = 'p')
- area_basin = float(tmp.split('\n')[1].split('|')[1])
+ flags = 'p')
+ area_basin = float(tmp.split('\n')[1].split('|')[1])
# Creation of order maps: strahler, horton, hack, shreeve
- grass.message( "Creating %s" % r_hack )
- grass.run_command('r.stream.order', stream_rast = r_stream_e,
- direction = r_drainage_e,
- strahler = r_strahler,
- shreve = r_shreve,
- horton = r_horton,
+ grass.message( "Creating %s" % r_hack )
+ grass.run_command('r.stream.order', stream_rast = r_stream_e,
+ direction = r_drainage_e,
+ strahler = r_strahler,
+ shreve = r_shreve,
+ horton = r_horton,
hack = r_hack)
- # Distance to outlet
- grass.run_command('r.stream.distance', stream_rast = r_outlet,
- flags = 'o',
+ # Distance to outlet
+ grass.run_command('r.stream.distance', stream_rast = r_outlet,
+ flags = 'o',
distance = r_distance)
# hypsographic curve
grass.message( "------------------------------" )
grass.run_command('r.hypso', map = 'r_elevation_crop',
image = os.path.join(directory,prefix), flags = 'ab')
# Width Function
grass.run_command('r.width.funct', map = r_distance,
image = os.path.join(directory,prefix))
# Creation of map of hillslope distance to river network
- grass.run_command("r.stream.distance", stream_rast = r_stream_e,
- direction = r_drainage,
- elevation = 'r_elevation_crop',
+ grass.run_command("r.stream.distance", stream_rast = r_stream_e,
+ direction = r_drainage,
+ elevation = 'r_elevation_crop',
distance = r_hillslope_distance)
# Mean elevation
- grass.run_command("r.stats.zonal", base = r_basin,
- cover = "r_elevation_crop",
+ grass.run_command("r.stats.zonal", base = r_basin,
+ cover = "r_elevation_crop",
method = "average",
output = r_height_average)
grass.message("r.stats.zonal done")
- mean_elev = float(grass.read_command('r.info', flags = 'r',
+ mean_elev = float(grass.read_command('r.info', flags = 'r',
map = r_height_average).split('\n')[0].split('=')[1])
- grass.message("r.info done")
- # In Grass, aspect categories represent the number degrees of east and they increase
- # counterclockwise: 90deg is North, 180 is West, 270 is South 360 is East.
+ grass.message("r.info done")
+ # In Grass, aspect categories represent the number degrees of east and they increase
+ # counterclockwise: 90deg is North, 180 is West, 270 is South 360 is East.
# The aspect value 0 is used to indicate undefined aspect in flat areas with slope=0.
# We calculate the number of degree from north, increasing counterclockwise.
grass.mapcalc("$r_aspect_mod = if($r_aspect == 0, 0, if($r_aspect > 90, 450 - $r_aspect, 90 - $r_aspect))",
r_aspect = r_aspect,
r_aspect_mod = r_aspect_mod)
grass.message("r.mapcalc done")
# Centroid and mean slope
- baricenter_slope_baricenter = grass.read_command("r.volume", input = r_slope,
- clump = r_basin)
- grass.message("r.volume done")
+ baricenter_slope_baricenter = grass.read_command("r.volume", input = r_slope,
+ clump = r_basin)
+ grass.message("r.volume done")
baricenter_slope_baricenter = baricenter_slope_baricenter.split()
mean_slope = baricenter_slope_baricenter[30]
# Rectangle containing basin
basin_east = baricenter_slope_baricenter[33]
basin_north = baricenter_slope_baricenter[34]
- info_region_basin = grass.read_command("g.region",
- vect = options['prefix']+'_'+mapname[0]+'_basin',
+ info_region_basin = grass.read_command("g.region",
+ vect = options['prefix']+'_'+mapname[0]+'_basin',
flags = 'm')
- grass.message("g.region done")
+ grass.message("g.region done")
dict_region_basin = dict(x.split('=', 1) for x in info_region_basin.split('\n') if '=' in x)
basin_resolution = float(dict_region_basin['nsres'])
- x_massimo = float(dict_region_basin['n']) + (basin_resolution * 10)
- x_minimo = float(dict_region_basin['w']) - (basin_resolution * 10)
- y_massimo = float(dict_region_basin['e']) + (basin_resolution * 10)
- y_minimo = float(dict_region_basin['s']) - (basin_resolution * 10)
- nw = dict_region_basin['w'], dict_region_basin['n']
- se = dict_region_basin['e'], dict_region_basin['s']
+# x_massimo = float(dict_region_basin['n']) + (basin_resolution * 10)
+# x_minimo = float(dict_region_basin['w']) - (basin_resolution * 10)
+# y_massimo = float(dict_region_basin['e']) + (basin_resolution * 10)
+# y_minimo = float(dict_region_basin['s']) - (basin_resolution * 10)
+ nw = dict_region_basin['w'], dict_region_basin['n']
+ se = dict_region_basin['e'], dict_region_basin['s']
grass.message("Rectangle containing basin done")
east1,north1 = coordinates.split(',')
east = float(east1)
north = float(north1)
- # Directing vector
+ # Directing vector
delta_x = abs(float(basin_east) - east)
delta_y = abs(float(basin_north) - north)
L_orienting_vect = math.sqrt((delta_x**2)+(delta_y**2)) / 1000
grass.message("Directing vector done")
- # Prevalent orientation
+ # Prevalent orientation
prevalent_orientation = math.atan(delta_y/delta_x)
grass.message("Prevalent orientation done")
- # Compactness coefficient
+ # Compactness coefficient
C_comp = perimeter_basin / ( 2 * math.sqrt( area_basin / math.pi))
grass.message("Compactness coefficient done")
- # Circularity ratio
+ # Circularity ratio
R_c = ( 4 * math.pi * area_basin ) / (perimeter_basin **2)
grass.message("Circularity ratio done")
# Mainchannel
grass.mapcalc("$r_mainchannel = if($r_hack==1,1,null())",
r_hack = r_hack,
r_mainchannel = r_mainchannel)
- grass.run_command("r.thin", input = r_mainchannel,
+ grass.run_command("r.thin", input = r_mainchannel,
output = r_mainchannel+'_thin')
- grass.run_command('r.to.vect', input = r_mainchannel+'_thin',
- output = v_mainchannel,
- type = 'line',
+ grass.run_command('r.to.vect', input = r_mainchannel+'_thin',
+ output = v_mainchannel,
+ type = 'line',
verbose = True)
# Get coordinates of the outlet (belonging to stream network)
grass.run_command('v.db.addtable', map = v_outlet_snap)
grass.run_command('v.db.addcolumn', map = v_outlet_snap,
columns="x double precision,y double precision" )
grass.run_command('v.to.db', map = v_outlet_snap,
option = "coor",
col = "x,y" )
- namefile = os.path.join(directory, prefix + '_outlet_coors.txt')
+ namefile = os.path.join(directory, prefix + '_outlet_coors.txt')
grass.run_command('v.out.ascii', input = v_outlet_snap,
output = namefile,
cats = 1,
format = "point")
- f = open(namefile)
+ f = open(namefile)
east_o, north_o, cat = f.readline().split('|')
- param_mainchannel = grass.read_command('v.what', map = v_mainchannel,
+ param_mainchannel = grass.read_command('v.what', map = v_mainchannel,
coordinates = '%s,%s' % (east_o,north_o),
distance = 5)
tmp = param_mainchannel.split('\n')[7]
mainchannel = float(tmp.split()[1]) / 1000 # km
# Topological Diameter
grass.mapcalc("$r_mainchannel_dim = -($r_mainchannel - $r_shreve) + 1",
r_mainchannel_dim = r_mainchannel_dim,
r_shreve = r_shreve,
- grass.run_command('r.thin', input = r_mainchannel_dim,
+ grass.run_command('r.thin', input = r_mainchannel_dim,
output = r_mainchannel_dim + '_thin')
- grass.run_command('r.to.vect', input = r_mainchannel_dim + '_thin',
- output = v_mainchannel_dim,
- type = 'line',
+ grass.run_command('r.to.vect', input = r_mainchannel_dim + '_thin',
+ output = v_mainchannel_dim,
+ type = 'line',
flags = 'v',
verbose = True)
try:
- D_topo1 = grass.read_command('v.info', map = v_mainchannel_dim,
- layer = 1,
+ D_topo1 = grass.read_command('v.info', map = v_mainchannel_dim,
+ layer = 1,
flags = 't')
D_topo = float(D_topo1.split('\n')[2].split('=')[1])
except:
D_topo = 1
grass.message( "Topological Diameter = WARNING" )
# Mean slope of mainchannel
grass.message("doing v.to.points")
grass.run_command('v.to.points',
- input = v_mainchannel_dim,
- output = v_mainchannel_dim+'_point',
+ input = v_mainchannel_dim,
+ output = v_mainchannel_dim+'_point',
type = 'line')
- vertex = grass.read_command('v.out.ascii', verbose = True,
+ vertex = grass.read_command('v.out.ascii', verbose = True,
input = v_mainchannel_dim+'_point').strip().split('\n')
nodi = zeros((len(vertex),4),float)
pendenze = []
for i in range(len(vertex)):
x, y = float(vertex[i].split('|')[0]) , float(vertex[i].split('|')[1])
- vertice1 = grass.read_command('r.what', verbose = True,
- map = 'r_elevation_crop',
+ vertice1 = grass.read_command('r.what', verbose = True,
+ map = 'r_elevation_crop',
coordinates = '%s,%s' % (x,y))
vertice = vertice1.replace('\n','').replace('||','|').split('|')
nodi[i,0],nodi[i,1], nodi[i,2] = float(vertice[0]), float(vertice[1]), float(vertice[2])
for i in range(0,len(vertex)-1,2):
dist = math.sqrt(math.fabs((nodi[i,0] - nodi[i+1,0]))**2 + math.fabs((nodi[i,1] - nodi[i+1,1]))**2)
deltaz = math.fabs(nodi[i,2] - nodi[i+1,2])
# Control to prevent float division by zero (dist=0)
- try:
- pendenza = deltaz / dist
+ try:
+ pendenza = deltaz / dist
pendenze.append(pendenza)
mainchannel_slope = sum(pendenze) / len(pendenze) * 100
except :
pass
# Elongation Ratio
R_al = (2 * math.sqrt( area_basin / math.pi) ) / mainchannel
# Shape factor
S_f = area_basin / mainchannel
- # Characteristic altitudes
- height_basin_average = grass.read_command('r.what', map = r_height_average ,
- cache = 500 ,
+ # Characteristic altitudes
+ height_basin_average = grass.read_command('r.what', map = r_height_average ,
+ cache = 500 ,
coordinates = '%s,%s' % (east_o , north_o ))
height_basin_average = height_basin_average.replace('\n','')
height_basin_average = float(height_basin_average.split('|')[-1])
- minmax_height_basin = grass.read_command('r.info', flags = 'r',
+ minmax_height_basin = grass.read_command('r.info', flags = 'r',
map = 'r_elevation_crop')
minmax_height_basin = minmax_height_basin.strip().split('\n')
min_height_basin, max_height_basin = float(minmax_height_basin[0].split('=')[-1]), float(minmax_height_basin[1].split('=')[-1])
- H1 = max_height_basin
+ H1 = max_height_basin
H2 = min_height_basin
HM = H1 - H2
# Concentration time (Giandotti, 1934)
t_c = ((4 * math.sqrt(area_basin)) + (1.5 * mainchannel)) / (0.8 * math.sqrt(HM))
# Mean hillslope length
- grass.run_command("r.stats.zonal", cover = r_stream_e,
- base = r_mask,
+ grass.run_command("r.stats.zonal", cover = r_stream_e,
+ base = r_mask,
method = "average",
output = r_average_hillslope)
mean_hillslope_length = float(grass.read_command('r.info', flags = 'r',
map = r_average_hillslope).split('\n')[0].split('=')[1])
# Magnitude
grass.mapcalc("$r_ord_1 = if($r_strahler==1,1,null())",
r_ord_1 = r_ord_1,
r_strahler = r_strahler)
- grass.run_command('r.thin', input = r_ord_1,
- output = r_ord_1+'_thin',
+ grass.run_command('r.thin', input = r_ord_1,
+ output = r_ord_1+'_thin',
iterations = 200)
- grass.run_command('r.to.vect', input = r_ord_1+'_thin',
- output = v_ord_1,
- type = 'line',
+ grass.run_command('r.to.vect', input = r_ord_1+'_thin',
+ output = v_ord_1,
+ type = 'line',
flags = 'v')
- magnitudo = float(grass.read_command('v.info', map = v_ord_1,
- layer = 1,
+ magnitudo = float(grass.read_command('v.info', map = v_ord_1,
+ layer = 1,
flags = 't').split('\n')[2].split('=')[1])
- # First order stream frequency
+ # First order stream frequency
FSF = magnitudo / area_basin
# Statistics
- stream_stats = grass.read_command('r.stream.stats', stream_rast = r_strahler,
+ stream_stats = grass.read_command('r.stream.stats', stream_rast = r_strahler,
elevation = 'r_elevation_crop' )
- print " ------------------------------ "
+ print " ------------------------------ "
print "Output of r.stream.stats: "
print stream_stats
stream_stats_summary = stream_stats.split('\n')[4].split('|')
stream_stats_mom = stream_stats.split('\n')[8].split('|')
- Max_order , Num_streams , Len_streams , Stream_freq = stream_stats_summary[0] , stream_stats_summary[1] , stream_stats_summary[2] , stream_stats_summary[5]
+ Max_order , Num_streams , Len_streams , Stream_freq = stream_stats_summary[0] , stream_stats_summary[1] , stream_stats_summary[2] , stream_stats_summary[5]
Bif_ratio , Len_ratio , Area_ratio , Slope_ratio = stream_stats_mom[0] , stream_stats_mom[1] , stream_stats_mom[2] , stream_stats_mom[3]
drainage_density = float(Len_streams) / float(area_basin)
# Cleaning up
grass.run_command('g.remove', flags='f', type='rast', name= 'r_elevation_crop', quiet = True)
grass.run_command('g.remove', flags='f', type='rast', name= r_height_average, quiet = True)
@@ -595,16 +596,16 @@
grass.run_command('g.remove', flags='f', type='rast', name= r_ord_1, quiet = True)
grass.run_command('g.remove', flags='f', type='rast', name= r_average_hillslope, quiet = True)
grass.run_command('g.remove', flags='f', type='rast', name= r_mainchannel_dim, quiet = True)
- grass.run_command('g.remove', flags='f', type='rast', name= r_outlet, quiet = True)
+ grass.run_command('g.remove', flags='f', type='rast', name= r_outlet, quiet = True)
grass.run_command('g.remove', flags='f', type='rast', name= r_basin, quiet = True)
grass.run_command('g.remove', flags='f', type='rast', name= prefix+'_mainchannel_thin', quiet = True)
grass.run_command('g.remove', flags='f', type='rast', name= prefix+'_mainchannel_dim_thin', quiet = True)
grass.run_command('g.remove', flags='f', type='rast', name= prefix+'_ord_1_thin', quiet = True)
- grass.run_command('g.remove', flags='f', type='rast', name= prefix+'_stream_e_thin', quiet = True)
+ grass.run_command('g.remove', flags='f', type='rast', name= prefix+'_stream_e_thin', quiet = True)
grass.run_command('g.remove', flags='f', type='vect', name= v_mainchannel_dim+'_point', quiet = True)
grass.run_command('g.remove', flags='f', type='vect', name= v_mainchannel_dim, quiet = True)
grass.run_command('g.remove', flags='f', type='vect', name= v_ord_1, quiet = True)
if nomap :
grass.run_command('g.remove', flags='f', type='vect', name= v_outlet, quiet = True)
grass.run_command('g.remove', flags='f', type='vect', name= v_basin, quiet = True)
@@ -619,7 +620,7 @@
grass.run_command('g.remove', flags='f', type='rast', name= r_distance, quiet = True)
grass.run_command('g.remove', flags='f', type='rast', name= r_hillslope_distance, quiet = True)
grass.run_command('g.remove', flags='f', type='rast', name= r_slope, quiet = True)
parametri_bacino = {}
@@ -656,14 +657,14 @@
parametri_bacino["Area_ratio"] = float(Area_ratio)
parametri_bacino["Slope_ratio"] = float(Slope_ratio)
parametri_bacino["drainage_density"] = float(drainage_density)
- parametri_bacino["FSF"] = float(FSF)
+ parametri_bacino["FSF"] = float(FSF)
# create .csv file
csvfile = os.path.join( directory, prefix + '_parameters.csv' )
with open(csvfile, 'w') as f:
writer = csv.writer(f)
- writer.writerow(['Morphometric parameters of basin :'])
+ writer.writerow(['Morphometric parameters of basin:'])
writer.writerow([' '])
writer.writerow(['Easting Centroid of basin'] + [basin_east])
writer.writerow(['Northing Centroid of basin'] + [basin_north])
@@ -697,48 +698,48 @@
writer.writerow(['Length Ratio (Horton)'] + [Len_ratio])
writer.writerow(['Area ratio (Horton)'] + [Area_ratio])
writer.writerow(['Slope ratio (Horton)'] + [Slope_ratio])
# Create summary (transposed)
csvfileT = os.path.join( directory, prefix + '_parametersT.csv' ) # transposed
with open(csvfileT, 'w') as f:
writer.writerow(['x'] +
['y'] +
- ['Easting_Centroid_basin'] +
+ ['Easting_Centroid_basin'] +
['Northing_Centroid_basin'] +
- ['Rectangle_containing_basin_N_W'] +
- ['Rectangle_containing_basin_S_E'] +
- ['Area_of_basin_km2'] +
- ['Perimeter_of_basin_km'] +
- ['Max_Elevation'] +
- ['Min_Elevation'] +
- ['Elevation_Difference'] +
- ['Mean_Elevation'] +
- ['Mean_Slope'] +
- ['Length_of_Directing_Vector_km'] +
- ['Prevalent_Orientation_deg_from_north_ccw'] +
- ['Compactness_Coefficient'] +
- ['Circularity_Ratio'] +
- ['Topological_Diameter'] +
- ['Elongation_Ratio'] +
- ['Shape_Factor'] +
- ['Concentration_Time_hr'] +
- ['Length_of_Mainchannel_km'] +
- ['Mean_slope_of_mainchannel_percent'] +
- ['Mean_hillslope_length_m'] +
- ['Magnitudo'] +
- ['Max_order_Strahler'] +
- ['Number_of_streams'] +
- ['Total_Stream_Length_km'] +
- ['First_order_stream_frequency'] +
- ['Drainage_Density_km_over_km2'] +
- ['Bifurcation_Ratio_Horton'] +
- ['Length_Ratio_Horton'] +
- ['Area_ratio_Horton'] +
+ ['Rectangle_containing_basin_N_W'] +
+ ['Rectangle_containing_basin_S_E'] +
+ ['Area_of_basin_km2'] +
+ ['Perimeter_of_basin_km'] +
+ ['Max_Elevation'] +
+ ['Min_Elevation'] +
+ ['Elevation_Difference'] +
+ ['Mean_Elevation'] +
+ ['Mean_Slope'] +
+ ['Length_of_Directing_Vector_km'] +
+ ['Prevalent_Orientation_deg_from_north_ccw'] +
+ ['Compactness_Coefficient'] +
+ ['Circularity_Ratio'] +
+ ['Topological_Diameter'] +
+ ['Elongation_Ratio'] +
+ ['Shape_Factor'] +
+ ['Concentration_Time_hr'] +
+ ['Length_of_Mainchannel_km'] +
+ ['Mean_slope_of_mainchannel_percent'] +
+ ['Mean_hillslope_length_m'] +
+ ['Magnitudo'] +
+ ['Max_order_Strahler'] +
+ ['Number_of_streams'] +
+ ['Total_Stream_Length_km'] +
+ ['First_order_stream_frequency'] +
+ ['Drainage_Density_km_over_km2'] +
+ ['Bifurcation_Ratio_Horton'] +
+ ['Length_Ratio_Horton'] +
+ ['Area_ratio_Horton'] +
['Slope_ratio_Horton'] )
writer.writerow([east_o]
+ [north_o]
- + [basin_east]
+ + [basin_east]
+ [basin_north]
+ [nw]
+ [se]
@@ -770,42 +771,38 @@
+ [Len_ratio]
+ [Area_ratio]
+ [Slope_ratio])
- # Import table "summary", attaches it to "outlet_snap", then drops it
+ # Import table "rbasin_summary", joins it to "outlet_snap", then drops it
+ grass.message("db.in.ogr: importing CSV table <%s>..." % csvfileT)
grass.run_command("db.in.ogr", input = csvfileT,
- output = "summary")
+ output = "rbasin_summary")
grass.run_command("v.db.join", map = v_outlet_snap,
- otable = "summary",
- column = "y",
- ocolumn = "y")
- grass.run_command("db.droptable", table = "summary",
- flags = 'f')
- grass.message( "\n" )
+ otable = "rbasin_summary",
+ column = "y",
+ ocolumn = "y")
+ grass.run_command("db.droptable", table = "rbasin_summary", flags = 'f')
+ grass.message( "\n" )
grass.message( "----------------------------------" )
grass.message( "Morphometric parameters of basin :" )
grass.message( "----------------------------------\n" )
grass.message( "Easting Centroid of basin : %s " % basin_east )
grass.message( "Northing Centroid of Basin : %s " % basin_north )
- grass.message( "Rectangle containing basin N-W : %s , %s " % nw )
+ grass.message( "Rectangle containing basin N-W : %s , %s " % nw )
grass.message( "Rectangle containing basin S-E : %s , %s " % se )
grass.message( "Area of basin [km^2] : %s " % area_basin )
grass.message( "Perimeter of basin [km] : %s " % perimeter_basin )
grass.message( "Max Elevation [m s.l.m.] : %s " % H1 )
grass.message( "Min Elevation [m s.l.m.]: %s " % H2 )
grass.message( "Elevation Difference [m]: %s " % HM )
- grass.message( "Mean Elevation [m s.l.m.]: %s " % mean_elev )
+ grass.message( "Mean Elevation [m s.l.m.]: %s " % mean_elev )
grass.message( "Mean Slope : %s " % mean_slope )
grass.message( "Length of Directing Vector [km] : %s " % L_orienting_vect )
grass.message( "Prevalent Orientation [degree from north, counterclockwise] : %s " % prevalent_orientation )
grass.message( "Compactness Coefficient : %s " % C_comp )
- grass.message( "Circularity Ratio : %s " % R_c )
+ grass.message( "Circularity Ratio : %s " % R_c )
grass.message( "Topological Diameter : %s " % D_topo )
grass.message( "Elongation Ratio : %s " % R_al )
grass.message( "Shape Factor : %s " % S_f )
@@ -823,19 +820,19 @@
grass.message( "Length Ratio (Horton) : %s " % Len_ratio )
grass.message( "Area ratio (Horton) : %s " % Area_ratio )
grass.message( "Slope ratio (Horton): %s " % Slope_ratio )
- grass.message( "------------------------------" )
+ grass.message( "------------------------------" )
grass.message( "Done!")
except:
grass.message( "An ERROR occurred running r.basin" )
grass.message( "Please check for error messages above or try with another pairs of outlet coordinates" )
- # Set region to original
+ # Set region to original
grass.read_command('g.region', flags = 'p', region = 'original')
grass.run_command('g.remove', flags = 'f', type = 'region', name = 'original')
