[GRASS-SVN] r63580 - grass/branches/releasebranch_7_0/scripts/i.pansharpen
svn_grass at osgeo.org
Wed Dec 17 07:48:26 PST 2014
Author: neteler
Date: 2014-12-17 07:48:26 -0800 (Wed, 17 Dec 2014)
New Revision: 63580
grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.html
grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py
i.pansharpen: update parameters of IHS module calls (trac #2409)
Modified: grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.html
--- grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.html 2014-12-17 15:48:18 UTC (rev 63579)
+++ grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.html 2014-12-17 15:48:26 UTC (rev 63580)
@@ -157,6 +157,7 @@
# display at 14.25m
g.region rast=lsat7_2002_ihs_red -p
+d.erase
d.rgb r=lsat7_2002_ihs_red g=lsat7_2002_ihs_green b=lsat7_2002_ihs_blue
# compare before/after (RGB support in "Advanced"):
Modified: grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py
--- grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py 2014-12-17 15:48:18 UTC (rev 63579)
+++ grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py 2014-12-17 15:48:26 UTC (rev 63580)
@@ -183,12 +183,12 @@
# transform RGB channels into IHS color space
grass.message(_("Transforming to IHS color space..."))
grass.run_command('i.rgb.his', overwrite=True,
- red_input=ms3,
- green_input=ms2,
- blue_input=ms1,
- hue_output="tmp%s_hue" % pid,
- intensity_output="tmp%s_int" % pid,
- saturation_output="tmp%s_sat" % pid)
+ red=ms3,
+ green=ms2,
+ blue=ms1,
+ hue="tmp%s_hue" % pid,
+ intensity="tmp%s_int" % pid,
+ saturation="tmp%s_sat" % pid)
# pan/intensity histogram matching using linear regression
target = "tmp%s_int" % pid
@@ -198,12 +198,12 @@
# substitute pan for intensity channel and transform back to RGB color space
grass.message(_("Transforming back to RGB color space and sharpening..."))
grass.run_command('i.his.rgb', overwrite=True,
- hue_input="tmp%s_hue" % pid,
- intensity_input="%s" % panmatch,
- saturation_input="tmp%s_sat" % pid,
- red_output="%s_red" % out,
- green_output="%s_green" % out,
- blue_output="%s_blue" % out)
+ intensity="%s" % panmatch,
+ saturation="tmp%s_sat" % pid,
+ red="%s_red" % out,
+ green="%s_green" % out,
+ blue="%s_blue" % out)
# Cleanup
grass.run_command('g.remove', flags='f', quiet=True, type='rast',
