[GRASS-SVN] r63581 - grass/trunk/vector/v.in.ascii
svn_grass at osgeo.org
Thu Dec 18 00:28:20 PST 2014
Author: mmetz
Date: 2014-12-18 00:28:20 -0800 (Thu, 18 Dec 2014)
New Revision: 63581
grass/trunk/vector/v.in.ascii/local_proto.h
grass/trunk/vector/v.in.ascii/main.c
grass/trunk/vector/v.in.ascii/points.c
v.in.ascii: add text delimiter
Modified: grass/trunk/vector/v.in.ascii/local_proto.h
--- grass/trunk/vector/v.in.ascii/local_proto.h 2014-12-17 15:48:26 UTC (rev 63580)
+++ grass/trunk/vector/v.in.ascii/local_proto.h 2014-12-18 08:28:20 UTC (rev 63581)
@@ -5,10 +5,10 @@
#include <grass/gis.h>
#include <grass/dbmi.h>
-int points_analyse(FILE *, FILE *, char *, int *, int *, int *, int *, int **,
+int points_analyse(FILE *, FILE *, char *, char *, int *, int *, int *, int *, int **,
int **, int, int, int, int, int, int, int);
int points_to_bin(FILE *, int, struct Map_info *, dbDriver *,
- char *, char *, int, int *, int, int, int, int, int);
+ char *, char *, char *, int, int *, int, int, int, int, int);
#endif /* __LOCAL_PROTO_H__ */
Modified: grass/trunk/vector/v.in.ascii/main.c
--- grass/trunk/vector/v.in.ascii/main.c 2014-12-17 15:48:26 UTC (rev 63580)
+++ grass/trunk/vector/v.in.ascii/main.c 2014-12-18 08:28:20 UTC (rev 63581)
@@ -27,17 +27,36 @@
#define A_DIR "dig_ascii"
+static char *get_td(const struct Option *option)
+ char* sep;
+ if (option->answer == NULL)
+ return NULL;
+ if (strcmp(option->answer, "doublequote") == 0)
+ sep = G_store("\"");
+ else if (strcmp(option->answer, "singlequote") == 0)
+ sep = G_store("\'");
+ else
+ sep = G_store(option->answer);
+ return sep;
int main(int argc, char *argv[])
FILE *ascii;
struct GModule *module;
- struct Option *old, *new, *delim_opt, *columns_opt, *xcol_opt,
- *ycol_opt, *zcol_opt, *catcol_opt, *format_opt, *skip_opt;
+ struct Option *old, *new, *delim_opt, *tdelim_opt, *columns_opt,
+ *xcol_opt, *ycol_opt, *zcol_opt, *catcol_opt,
+ *format_opt, *skip_opt;
int xcol, ycol, zcol, catcol, format, skip_lines;
struct Flag *zcoorf, *t_flag, *e_flag, *noheader_flag, *notopol_flag,
*region_flag, *ignore_flag;
char *table;
- char *fs;
+ char *fs, *td;
char *desc;
int zcoor = WITHOUT_Z, make_table;
@@ -78,6 +97,13 @@
delim_opt = G_define_standard_option(G_OPT_F_SEP);
delim_opt->guisection = _("Input format");
+ tdelim_opt = G_define_standard_option(G_OPT_F_SEP);
+ tdelim_opt->key = "text";
+ tdelim_opt->label = "text delimiter";
+ tdelim_opt->answer = "doublequote";
+ tdelim_opt->description = _("Special characters: doublequote, singlequote");
+ tdelim_opt->guisection = _("Input format");
skip_opt = G_define_option();
skip_opt->key = "skip";
skip_opt->type = TYPE_INTEGER;
@@ -210,6 +236,7 @@
ascii = G_open_option_file(old);
fs = G_option_to_separator(delim_opt);
+ td = get_td(tdelim_opt);
/* check dimension */
if (zcoorf->answer) {
@@ -245,7 +272,7 @@
unlink(tmp);
- points_analyse(ascii, tmpascii, fs, &rowlen, &ncols, &minncols,
+ points_analyse(ascii, tmpascii, fs, td, &rowlen, &ncols, &minncols,
&nrows, &coltype, &collen, skip_lines, xcol, ycol,
zcol, catcol, region_flag->answer, ignore_flag->answer);
@@ -258,7 +285,7 @@
G_message(_("Number of columns: %d"), ncols);
- G_message(_("Number of rows: %d"), nrows);
+ G_message(_("Number of rows: %d"), nrows);
/* check column numbers */
if (xcol >= minncols) {
@@ -501,7 +528,7 @@
table = NULL;
- points_to_bin(tmpascii, rowlen, &Map, driver, table, fs, nrows,
+ points_to_bin(tmpascii, rowlen, &Map, driver, table, fs, td, nrows,
coltype2, xcol, ycol, zcol, catcol, skip_lines);
if (driver) {
Modified: grass/trunk/vector/v.in.ascii/points.c
--- grass/trunk/vector/v.in.ascii/points.c 2014-12-17 15:48:26 UTC (rev 63580)
+++ grass/trunk/vector/v.in.ascii/points.c 2014-12-18 08:28:20 UTC (rev 63581)
@@ -51,7 +51,7 @@
* column_length: column lengths (string only)
-int points_analyse(FILE * ascii_in, FILE * ascii, char *fs,
+int points_analyse(FILE * ascii_in, FILE * ascii, char *fs, char *td,
int *rowlength, int *ncolumns, int *minncolumns,
int *nrows, int **column_type, int **column_length,
int skip_lines, int xcol, int ycol, int zcol, int catcol,
@@ -118,7 +118,7 @@
/* no G_chop() as first/last column may be empty fs=tab value */
G_debug(3, "row %d : %d chars", row, (int)strlen(buf));
- tokens = G_tokenize(buf, fs);
+ tokens = G_tokenize2(buf, fs, td);
ntokens = G_number_of_tokens(tokens);
if (ntokens == 0) {
continue;
@@ -313,8 +313,8 @@
* Note: column types (both in header or coldef) must be supported by driver
int points_to_bin(FILE * ascii, int rowlen, struct Map_info *Map,
- dbDriver * driver, char *table, char *fs, int nrows,
- int *coltype, int xcol, int ycol, int zcol,
+ dbDriver * driver, char *table, char *fs, char *td,
+ int nrows, int *coltype, int xcol, int ycol, int zcol,
int catcol, int skip_lines)
char *buf, buf2[4000];
@@ -367,7 +367,7 @@
G_debug(4, "row: %s", buf);
G_chop(tokens[xcol]);
