[GRASS-SVN] r63598 - grass-addons/grass7/imagery/i.spec.unmix
svn_grass at osgeo.org
Thu Dec 18 12:29:05 PST 2014
Author: neteler
Date: 2014-12-18 12:29:05 -0800 (Thu, 18 Dec 2014)
New Revision: 63598
grass-addons/grass7/imagery/i.spec.unmix/main.c
i.spec.unmix: fix indentation
Modified: grass-addons/grass7/imagery/i.spec.unmix/main.c
--- grass-addons/grass7/imagery/i.spec.unmix/main.c 2014-12-18 18:47:41 UTC (rev 63597)
+++ grass-addons/grass7/imagery/i.spec.unmix/main.c 2014-12-18 20:29:05 UTC (rev 63598)
@@ -68,12 +68,8 @@
vec_struct *b_gamma;
struct Cell_head region;
- // VEC *startvector, *A_times_startvector, *errorvector, *temp;
vec_struct *startvector, *A_times_startvector, *errorvector, *temp;
mat_struct *A, *A_tilde, *A_tilde_trans_mu, *A_tilde_trans;
mat_struct B, B_tilde, B_tilde_trans_mu;
struct GModule *module;
@@ -94,7 +90,7 @@
G_add_keyword(_("imagery"));
G_add_keyword(_("spectral unmixing"));
module->description =
- _("Perfroms Spectral mixture analysis of satellite/aerial images");
+ _("Performs Spectral mixture analysis of satellite/aerial images");
parm.group = G_define_standard_option(G_OPT_I_GROUP);
@@ -106,9 +102,6 @@
parm.matrixfile->description =
_("Matrix file containing spectral signatures");
parm.result = G_define_option();
parm.result->key = "result";
parm.result->description =
@@ -124,7 +117,6 @@
parm.iter->description = _("Raster map to hold number of iterations");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -159,16 +151,12 @@
/* go columnwise through matrix */
for (i = 0; i < A->cols; i++) {
vec_struct *Avector1, *Avector2;
double max1, max2;
Avector1 = G_matvect_get_column(A, i);
/* get the max. element of this vector */
max1 = G_vector_norm_maxval(Avector1, 1);
@@ -200,8 +188,7 @@
G_message("%s",
- _
- ("Checking linear dependencies (orthogonality check) of Matrix A..."));
+ _("Checking linear dependencies (orthogonality check) of Matrix A..."));
for (j = 0; j < A->cols; j++)
@@ -310,8 +297,7 @@
nrows = region.rows;
ncols = region.cols;
- G_message(_
- ("Calculating for %i x %i pixels (%i bands) = %i pixelvectors."),
+ G_message(_("Calculating for %i x %i pixels (%i bands) = %i pixelvectors."),
nrows, ncols, Ref.nfiles, (ncols * ncols));
for (row = 0; row < nrows; row++) {
@@ -344,8 +330,6 @@
/* add GAMMA for 1. constraint as last element */
G_matrix_set_element(b_gamma, 0, Ref.nfiles, GAMMA);
for (k = 0; k < A_tilde->cols; k++)
G_matrix_set_element(startvector, 0, k,
(1.0 / A_tilde->cols));
@@ -360,14 +344,11 @@
/* solve with iterative solution: */
while (fabs(change) > 0.0001) {
G_mat_vector_product(A_tilde, startvector,
A_times_startvector);
G_vector_sub(A_times_startvector, b_gamma, errorvector);
A_tilde_trans_mu =
@@ -382,11 +363,9 @@
if ((G_matrix_get_element(startvector, 0, k) < 0))
G_matrix_set_element(startvector, 0, k, 0);
/* Check the deviation */
double norm = G_vector_norm_euclid(errorvector);
change = deviation - norm;
deviation = norm;
@@ -398,12 +377,10 @@
vec_struct *fraction;
/* G_message("fcol %d and A->cols %d", startvector->dim, A->cols); */
- fraction = G_vector_init(A->cols,1, RVEC); /* length: no. of spectra */
+ fraction = G_vector_init(A->cols, 1, RVEC); /* length: no. of spectra */
error = deviation / G_vector_norm_euclid(b_gamma);
fraction = G_vector_copy(startvector, NO_COMPACT);
/* write result in full percent */
for (i = 0; i < A->cols; i++) /* no. of spectra */
result_cell[i][col] =
@@ -413,14 +390,10 @@
error_cell[col] = (CELL) (100 * error);
iter_cell[col] = iterations;
G_vector_free(fraction);
} /* end cols loop */
/* write the resulting rows into output files: */
Rast_put_c_row(resultfd[i], result_cell[i]);
@@ -431,8 +404,8 @@
if (iter_fd > 0)
Rast_put_c_row(iter_fd, iter_cell);
+ } /* rows loop */
- } /* rows loop */
G_percent(row, nrows, 2);
/* close files */
@@ -444,8 +417,6 @@
Rast_close(resultfd[i]);
/* make grey scale color table */
sprintf(result_name, "%s.%d", parm.result->answer, (i + 1));
sprintf(command, "r.colors map=%s color=rules <<EOF\n"
@@ -470,15 +441,10 @@
Rast_close(iter_fd);
G_matrix_free(A);
G_vector_free(errorvector);
G_vector_free(temp);
G_vector_free(b_gamma);
G_vector_free(startvector);
G_vector_free(A_times_startvector);
make_history(result_name, parm.group->answer, parm.matrixfile->answer);
