[GRASS-SVN] r63599 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Thu Dec 18 13:08:50 PST 2014
Author: mmetz
Date: 2014-12-18 13:08:49 -0800 (Thu, 18 Dec 2014)
New Revision: 63599
grass/trunk/lib/vector/Vlib/ascii.c
Vlib: enhance ascii export
Modified: grass/trunk/lib/vector/Vlib/ascii.c
--- grass/trunk/lib/vector/Vlib/ascii.c 2014-12-18 20:29:05 UTC (rev 63598)
+++ grass/trunk/lib/vector/Vlib/ascii.c 2014-12-18 21:08:49 UTC (rev 63599)
@@ -339,7 +339,7 @@
int field, const struct cat_list *Clist, const char* where,
const char **column_names, int header)
- int ltype, ctype, i, cat, n_lines, line, left, right, found;
+ int ltype, ctype, i, cat, line, left, right, found;
double *xptr, *yptr, *zptr, x, y;
static struct line_pnts *Points;
struct line_cats *Cats, *ACats;
@@ -388,7 +388,7 @@
/* get the region */
G_get_window(&window);
- count = n_lines = ncats = 0;
+ count = ncats = 0;
xstring = ystring = zstring = NULL;
cats = NULL;
@@ -423,17 +423,18 @@
const char *col_name;
int len_all = 0;
+ db_set_string(&dbstring, Fi->table);
+ if (db_describe_table(driver, &dbstring, &Table) != DB_OK) {
+ G_warning(_("Unable to describe table <%s>"), Fi->table);
+ return -1;
+ ncols = db_get_table_number_of_columns(Table);
+ columns = (char **) G_malloc((ncols + 1) * sizeof(char *));
if (column_names[0] && strcmp(column_names[0], "*") == 0) {
/* all columns */
- db_set_string(&dbstring, Fi->table);
- if (db_describe_table(driver, &dbstring, &Table) != DB_OK) {
- G_warning(_("Unable to describe table <%s>"), Fi->table);
- return -1;
- ncols = db_get_table_number_of_columns(Table);
- columns = (char **) G_malloc(ncols * sizeof(char *));
icol = 0;
for (i = 0; i < ncols; i++) {
col_name = db_get_column_name(db_get_table_column(Table, i));
@@ -442,26 +443,46 @@
columns[icol++] = G_store(col_name);
columns[icol] = NULL;
- db_zero_string(&dbstring);
- db_free_table(Table);
- Table = NULL;
else {
- ncols = 0;
- while (column_names[ncols])
- ncols++;
+ int j;
- columns = (char **) G_malloc((ncols + 1) * sizeof(char *));
icol = 0;
- for (i = 0; i < ncols; i++) {
- col_name = column_names[i];
+ i = 0;
+ while (column_names[i]) {
/* key column skipped */
- if (strcmp(Fi->key, col_name) != 0)
- columns[icol++] = G_store(col_name);
+ if (strcmp(Fi->key, column_names[i]) != 0) {
+ found = 0;
+ for (j = 0; j < ncols; j++) {
+ col_name = db_get_column_name(db_get_table_column(Table, j));
+ if (strcmp(col_name, column_names[i]) == 0) {
+ columns[icol++] = G_store(col_name);
+ found = 1;
+ break;
+ if (!found) {
+ G_warning(_("Column <%s> does not exist"),
+ column_names[i]);
+ G_important_message(_("Available columns:"));
+ G_important_message("%s", col_name);
+ G_warning(_("Export cancelled"));
+ db_close_database(driver);
+ db_shutdown_driver(driver);
+ return -1;
+ i++;
+ db_zero_string(&dbstring);
+ db_free_table(Table);
+ Table = NULL;
if (columns[0]) {
/* selected columns only */
@@ -503,6 +524,29 @@
+ if (format == GV_ASCII_FORMAT_POINT && header) {
+ /* print header */
+ if (Map->head.with_z)
+ fprintf(ascii, "east%snorth%sheight%scat", fs, fs, fs);
+ else
+ fprintf(ascii, "east%snorth%scat", fs, fs);
+ if (columns) {
+ for (i = 0; columns[i]; i++) {
+ if (db_select_value
+ (driver, Fi->table, Fi->key, cat,
+ columns[i], &value) < 0)
+ G_fatal_error(_("Unable to select record from table <%s> (key %s, column %s)"),
+ Fi->table, Fi->key, columns[i]);
+ if (columns[i])
+ fprintf(ascii, "%s%s", fs, columns[i]);
+ else
+ fprintf(ascii, "%s", columns[i]); /* can not happen */
+ fprintf(ascii, "\n");
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
ACats = Vect_new_cats_struct();
@@ -514,7 +558,7 @@
Vect_rewind(Map);
- n_skipped = line = 0;
+ count = n_skipped = line = 0;
while (TRUE) {
ltype = Vect_read_next_line(Map, Points, Cats);
if (ltype == -1 ) { /* failure */
@@ -637,30 +681,6 @@
Vect_field_cat_get(Cats, field, fcats);
- /* print header */
- if (header && count < 1) {
- count++;
- if (Map->head.with_z)
- fprintf(ascii, "east%snorth%sheight%scat", fs, fs, fs);
- else
- fprintf(ascii, "east%snorth%scat", fs, fs);
- if (columns) {
- for (i = 0; columns[i]; i++) {
- if (db_select_value
- (driver, Fi->table, Fi->key, cat,
- columns[i], &value) < 0)
- G_fatal_error(_("Unable to select record from table <%s> (key %s, column %s)"),
- Fi->table, Fi->key, columns[i]);
- if (columns[i])
- fprintf(ascii, "%s%s", fs, columns[i]);
- else
- fprintf(ascii, "%s", columns[i]); /* can not happen */
- fprintf(ascii, "\n");
if (Map->head.with_z && ver == 5) {
if (region_flag) {
if ((window.top < Points->z[0]) ||
@@ -676,7 +696,6 @@
fprintf(ascii, "%s%s%s", xstring, fs, ystring);
if (fcats->n_values > 0 && cat > -1) {
if (fcats->n_values > 1) {
G_warning(_("Feature has more categories. Only one category (%d) "
@@ -815,11 +834,12 @@
continue;
/* Well-Known Text */
Vect_sfa_line_astext(Points, ltype, Vect_is_3d(Map), dp, ascii);
+ count++;
else {
G_fatal_error(_("Unknown format"));
- n_lines++;
+ count++;
if (format == GV_ASCII_FORMAT_WKT) {
@@ -860,6 +880,8 @@
Vect_sfa_line_astext(Points, GV_BOUNDARY, 0, dp, ascii); /* boundary is always 2D */
fprintf(ascii, ")\n");
+ count++;
@@ -871,7 +893,7 @@
Vect_destroy_cats_struct(Cats);
Vect_destroy_cats_struct(ACats);
- return n_lines;
+ return count;
int srch(const void *pa, const void *pb)
