[GRASS-SVN] r63629 - in grass/branches/releasebranch_7_0: . display/d.barscale/thumbnails display/d.geodesic display/d.his display/d.path display/d.rhumbline display/d.vect display/d.vect.chart general/g.list general/g.region gui/wxpython/gcp gui/wxpython/mapdisp gui/wxpython/psmap gui/wxpython/rlisetup imagery/i.atcorr imagery/i.atcorr/test_suite imagery/i.cluster imagery/i.fft imagery/i.pca imagery/i.segment imagery/i.smap imagery/i.vi lib/cairodriver lib/pngdriver lib/psdriver lib/python/pygrass/modules/grid lib/python/temporal misc/m.nviz.image misc/m.nviz.script ps/ps.map raster/r.carve raster/r.clump raster/r.contour raster/r.cost raster/r.cost/test_suite raster/r.drain/tests raster/r.external raster/r.grow.distance raster/r.his raster/r.horizon raster/r.in.lidar raster/r.lake raster/r.latlong raster/r.li raster/r.li/r.li.daemon raster/r.li/r.li.dominance raster/r.li/r.li.edgedensity raster/r.li/r.li.mpa raster/r.li/r.li.mps raster/r.li/r.li.padcv raster/r.li/r.li.padrange raster/r.li/r.li.padsd raster/r.li/r.li.patchdensity raster/r.li/r.li.patchnum raster/r.li/r.li.pielou raster/r.li/r.li.renyi raster/r.li/r.li.richness raster/r.li/r.li.shannon raster/r.li/r.li.shape raster/r.li/r.li.simpson raster/r.mapcalc/test_suite raster/r.mode raster/r.out.gdal raster/r.out.ppm raster/r.out.ppm3 raster/r.param.scale raster/r.patch raster/r.proj raster/r.quantile raster/r.random raster/r.reclass raster/r.regression.line raster/r.regression.multi raster/r.resamp.bspline raster/r.resamp.interp raster/r.resamp.rst raster/r.resamp.stats raster/r.shaded.relief raster/r.sim/r.sim.water raster/r.stats/test_suite raster/r.stream.extract raster/r.sun raster/r.sunmask raster/r.surf.area raster/r.surf.contour raster/r.terraflow raster/r.texture raster/r.thin raster/r.tile raster/r.to.rast3elev raster/r.to.vect raster/r.univar raster/r.viewshed raster/r.volume raster/r.water.outlet raster/r.what scripts/d.correlate scripts/d.polar scripts/d.shadedmap scripts/d.to. rast scripts/d.vect.thematic scripts/db.univar scripts/i.colors.enhance scripts/i.oif scripts/i.pansharpen scripts/i.spectral scripts/i.tasscap scripts/r.blend scripts/r.colors.stddev scripts/r.fillnulls scripts/r.grow scripts/r.mask scripts/r.out.xyz scripts/r.reclass.area scripts/r.rgb scripts/v.db.droprow scripts/v.db.univar scripts/v.db.update scripts/v.krige scripts/v.rast.stats temporal temporal/t.rast.accumulate vector/v.drape vector/v.label.sa vector/v.lrs/v.lrs.create vector/v.lrs/v.lrs.label vector/v.lrs/v.lrs.segment vector/v.lrs/v.lrs.where vector/v.mkgrid vector/v.neighbors vector/v.net.alloc vector/v.net.path vector/v.net.salesman vector/v.net.steiner vector/v.net.visibility vector/v.normal vector/v.overlay vector/v.random vector/v.sample vector/v.surf.rst vector/v.to.db vector/v.transform vector/v.univar vector/v.voronoi vector/v.what.rast vector/v.what.rast3
svn_grass at osgeo.org
Fri Dec 19 13:55:37 PST 2014
Author: neteler
Date: 2014-12-19 13:55:37 -0800 (Fri, 19 Dec 2014)
New Revision: 63629
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/display/d.barscale/thumbnails/README
grass/branches/releasebranch_7_0/display/d.geodesic/d.geodesic.html
grass/branches/releasebranch_7_0/display/d.his/d.his.html
grass/branches/releasebranch_7_0/display/d.path/d.path.html
grass/branches/releasebranch_7_0/display/d.rhumbline/d.rhumbline.html
grass/branches/releasebranch_7_0/display/d.vect.chart/d.vect.chart.html
grass/branches/releasebranch_7_0/display/d.vect/d.vect.html
grass/branches/releasebranch_7_0/general/g.list/g.list.html
grass/branches/releasebranch_7_0/general/g.region/g.region.html
grass/branches/releasebranch_7_0/general/g.region/main.c
grass/branches/releasebranch_7_0/gui/wxpython/gcp/manager.py
grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py
grass/branches/releasebranch_7_0/gui/wxpython/psmap/instructions.py
grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/functions.py
grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/g.gui.rlisetup.html
grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/sampling_frame.py
grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/wizard.py
grass/branches/releasebranch_7_0/imagery/i.atcorr/i.atcorr.html
grass/branches/releasebranch_7_0/imagery/i.atcorr/test_suite/README.txt
grass/branches/releasebranch_7_0/imagery/i.cluster/i.cluster.html
grass/branches/releasebranch_7_0/imagery/i.fft/i.fft.html
grass/branches/releasebranch_7_0/imagery/i.pca/i.pca.html
grass/branches/releasebranch_7_0/imagery/i.segment/i.segment.html
grass/branches/releasebranch_7_0/imagery/i.smap/i.smap.html
grass/branches/releasebranch_7_0/imagery/i.vi/i.vi.html
grass/branches/releasebranch_7_0/lib/cairodriver/cairodriver.html
grass/branches/releasebranch_7_0/lib/pngdriver/pngdriver.html
grass/branches/releasebranch_7_0/lib/psdriver/psdriver.html
grass/branches/releasebranch_7_0/lib/python/pygrass/modules/grid/grid.py
grass/branches/releasebranch_7_0/lib/python/temporal/stds_import.py
grass/branches/releasebranch_7_0/misc/m.nviz.image/m.nviz.image.html
grass/branches/releasebranch_7_0/misc/m.nviz.script/m.nviz.script.html
grass/branches/releasebranch_7_0/ps/ps.map/ps.map.html
grass/branches/releasebranch_7_0/raster/r.carve/r.carve.html
grass/branches/releasebranch_7_0/raster/r.clump/r.clump.html
grass/branches/releasebranch_7_0/raster/r.contour/r.contour.html
grass/branches/releasebranch_7_0/raster/r.cost/r.cost.html
grass/branches/releasebranch_7_0/raster/r.cost/test_suite/profile.sh
grass/branches/releasebranch_7_0/raster/r.drain/tests/test.r.drain.sh
grass/branches/releasebranch_7_0/raster/r.external/r.external.html
grass/branches/releasebranch_7_0/raster/r.grow.distance/r.grow.distance.html
grass/branches/releasebranch_7_0/raster/r.his/r.his.html
grass/branches/releasebranch_7_0/raster/r.horizon/r.horizon.html
grass/branches/releasebranch_7_0/raster/r.in.lidar/r.in.lidar.html
grass/branches/releasebranch_7_0/raster/r.lake/r.lake.html
grass/branches/releasebranch_7_0/raster/r.latlong/r.latlong.html
grass/branches/releasebranch_7_0/raster/r.li/TODO
grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.c
grass/branches/releasebranch_7_0/raster/r.li/r.li.dominance/r.li.dominance.html
grass/branches/releasebranch_7_0/raster/r.li/r.li.edgedensity/r.li.edgedensity.html
grass/branches/releasebranch_7_0/raster/r.li/r.li.html
grass/branches/releasebranch_7_0/raster/r.li/r.li.mpa/r.li.mpa.html
grass/branches/releasebranch_7_0/raster/r.li/r.li.mps/r.li.mps.html
grass/branches/releasebranch_7_0/raster/r.li/r.li.padcv/r.li.padcv.html
grass/branches/releasebranch_7_0/raster/r.li/r.li.padrange/r.li.padrange.html
grass/branches/releasebranch_7_0/raster/r.li/r.li.padsd/r.li.padsd.html
grass/branches/releasebranch_7_0/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
grass/branches/releasebranch_7_0/raster/r.li/r.li.patchnum/r.li.patchnum.html
grass/branches/releasebranch_7_0/raster/r.li/r.li.pielou/r.li.pielou.html
grass/branches/releasebranch_7_0/raster/r.li/r.li.renyi/r.li.renyi.html
grass/branches/releasebranch_7_0/raster/r.li/r.li.richness/r.li.richness.html
grass/branches/releasebranch_7_0/raster/r.li/r.li.shannon/r.li.shannon.html
grass/branches/releasebranch_7_0/raster/r.li/r.li.shape/r.li.shape.html
grass/branches/releasebranch_7_0/raster/r.li/r.li.simpson/r.li.simpson.html
grass/branches/releasebranch_7_0/raster/r.li/r.li.testing_nc_asc.sh
grass/branches/releasebranch_7_0/raster/r.li/r.li.testing_sp_mov.sh
grass/branches/releasebranch_7_0/raster/r.mapcalc/test_suite/README
grass/branches/releasebranch_7_0/raster/r.mode/r.mode.html
grass/branches/releasebranch_7_0/raster/r.out.gdal/r.out.gdal.html
grass/branches/releasebranch_7_0/raster/r.out.ppm/r.out.ppm.html
grass/branches/releasebranch_7_0/raster/r.out.ppm3/r.out.ppm3.html
grass/branches/releasebranch_7_0/raster/r.param.scale/r.param.scale.html
grass/branches/releasebranch_7_0/raster/r.patch/r.patch.html
grass/branches/releasebranch_7_0/raster/r.proj/r.proj.html
grass/branches/releasebranch_7_0/raster/r.quantile/r.quantile.html
grass/branches/releasebranch_7_0/raster/r.random/r.random.html
grass/branches/releasebranch_7_0/raster/r.reclass/r.reclass.html
grass/branches/releasebranch_7_0/raster/r.regression.line/r.regression.line.html
grass/branches/releasebranch_7_0/raster/r.regression.multi/r.regression.multi.html
grass/branches/releasebranch_7_0/raster/r.resamp.bspline/r.resamp.bspline.html
grass/branches/releasebranch_7_0/raster/r.resamp.interp/r.resamp.interp.html
grass/branches/releasebranch_7_0/raster/r.resamp.rst/BUGS
grass/branches/releasebranch_7_0/raster/r.resamp.rst/r.resamp.rst.html
grass/branches/releasebranch_7_0/raster/r.resamp.stats/r.resamp.stats.html
grass/branches/releasebranch_7_0/raster/r.shaded.relief/r.shaded.relief.html
grass/branches/releasebranch_7_0/raster/r.sim/r.sim.water/r.sim.water.html
grass/branches/releasebranch_7_0/raster/r.sim/r.sim.water/spearfish.sh
grass/branches/releasebranch_7_0/raster/r.stats/test_suite/profile.sh
grass/branches/releasebranch_7_0/raster/r.stream.extract/r.stream.extract.html
grass/branches/releasebranch_7_0/raster/r.sun/r.sun.html
grass/branches/releasebranch_7_0/raster/r.sunmask/r.sunmask.html
grass/branches/releasebranch_7_0/raster/r.surf.area/r.surf.area.html
grass/branches/releasebranch_7_0/raster/r.surf.contour/r.surf.contour.html
grass/branches/releasebranch_7_0/raster/r.terraflow/r.terraflow.html
grass/branches/releasebranch_7_0/raster/r.texture/r.texture.html
grass/branches/releasebranch_7_0/raster/r.thin/r.thin.html
grass/branches/releasebranch_7_0/raster/r.tile/r.tile.html
grass/branches/releasebranch_7_0/raster/r.to.rast3elev/r.to.rast3elev.html
grass/branches/releasebranch_7_0/raster/r.to.vect/r.to.vect.html
grass/branches/releasebranch_7_0/raster/r.univar/r.univar.html
grass/branches/releasebranch_7_0/raster/r.viewshed/r.viewshed.html
grass/branches/releasebranch_7_0/raster/r.volume/r.volume.html
grass/branches/releasebranch_7_0/raster/r.water.outlet/r.water.outlet.html
grass/branches/releasebranch_7_0/raster/r.what/r.what.html
grass/branches/releasebranch_7_0/scripts/d.correlate/d.correlate.html
grass/branches/releasebranch_7_0/scripts/d.polar/d.polar.html
grass/branches/releasebranch_7_0/scripts/d.shadedmap/d.shadedmap.html
grass/branches/releasebranch_7_0/scripts/d.to.rast/d.to.rast.html
grass/branches/releasebranch_7_0/scripts/d.vect.thematic/d.vect.thematic.html
grass/branches/releasebranch_7_0/scripts/db.univar/db.univar.html
grass/branches/releasebranch_7_0/scripts/i.colors.enhance/i.colors.enhance.html
grass/branches/releasebranch_7_0/scripts/i.oif/i.oif.html
grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.html
grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py
grass/branches/releasebranch_7_0/scripts/i.spectral/i.spectral.html
grass/branches/releasebranch_7_0/scripts/i.tasscap/i.tasscap.html
grass/branches/releasebranch_7_0/scripts/r.blend/r.blend.html
grass/branches/releasebranch_7_0/scripts/r.colors.stddev/r.colors.stddev.html
grass/branches/releasebranch_7_0/scripts/r.fillnulls/r.fillnulls.html
grass/branches/releasebranch_7_0/scripts/r.grow/r.grow.html
grass/branches/releasebranch_7_0/scripts/r.mask/r.mask.html
grass/branches/releasebranch_7_0/scripts/r.out.xyz/r.out.xyz.html
grass/branches/releasebranch_7_0/scripts/r.reclass.area/r.reclass.area.html
grass/branches/releasebranch_7_0/scripts/r.rgb/r.rgb.html
grass/branches/releasebranch_7_0/scripts/v.db.droprow/v.db.droprow.html
grass/branches/releasebranch_7_0/scripts/v.db.univar/v.db.univar.html
grass/branches/releasebranch_7_0/scripts/v.db.update/v.db.update.html
grass/branches/releasebranch_7_0/scripts/v.krige/v.krige.html
grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.html
grass/branches/releasebranch_7_0/temporal/
grass/branches/releasebranch_7_0/temporal/t.rast.accumulate/t.rast.accumulate.html
grass/branches/releasebranch_7_0/vector/v.drape/spearfish.pov
grass/branches/releasebranch_7_0/vector/v.label.sa/v.label.sa.html
grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.create/v.lrs.create.html
grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.label/v.lrs.label.html
grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.segment/v.lrs.segment.html
grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.where/v.lrs.where.html
grass/branches/releasebranch_7_0/vector/v.mkgrid/v.mkgrid.html
grass/branches/releasebranch_7_0/vector/v.neighbors/v.neighbors.html
grass/branches/releasebranch_7_0/vector/v.net.alloc/v.net.alloc.html
grass/branches/releasebranch_7_0/vector/v.net.path/v.net.path.html
grass/branches/releasebranch_7_0/vector/v.net.salesman/v.net.salesman.html
grass/branches/releasebranch_7_0/vector/v.net.steiner/v.net.steiner.html
grass/branches/releasebranch_7_0/vector/v.net.visibility/v.net.visibility.html
grass/branches/releasebranch_7_0/vector/v.normal/v.normal.html
grass/branches/releasebranch_7_0/vector/v.overlay/v.overlay.html
grass/branches/releasebranch_7_0/vector/v.random/v.random.html
grass/branches/releasebranch_7_0/vector/v.sample/v.sample.html
grass/branches/releasebranch_7_0/vector/v.surf.rst/v.surf.rst.html
grass/branches/releasebranch_7_0/vector/v.to.db/v.to.db.html
grass/branches/releasebranch_7_0/vector/v.transform/v.transform.html
grass/branches/releasebranch_7_0/vector/v.univar/v.univar.html
grass/branches/releasebranch_7_0/vector/v.voronoi/v.voronoi.html
grass/branches/releasebranch_7_0/vector/v.what.rast/v.what.rast.html
grass/branches/releasebranch_7_0/vector/v.what.rast3/v.what.rast3.html
update g.region calls to use new element names (#2409) (trunk, r63628)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,
63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279,63281,63283,63287,63290,63292,63297,63302,63307,63315,63319,63327,63330,63332,63339,63342,63345,63362,63367,63391,63393,63408-63409,63416-63417,63425,63427,63429,63431,63433,63448,63451,63453,63457,63459,63464-63470,63473,63482,63497,63505,63508,63510,63515,63521-63524,63526,63536-63537,63551-63552,63554,63556,63558-63559,63562,63570,63576,63582,63589-63593,63602,63616,63624,63626
+ /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,
63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279,63281,63283,63287,63290,63292,63297,63302,63307,63315,63319,63327,63330,63332,63339,63342,63345,63362,63367,63391,63393,63408-63409,63416-63417,63425,63427,63429,63431,63433,63448,63451,63453,63457,63459,63464-63470,63473,63482,63497,63505,63508,63510,63515,63521-63524,63526,63536-63537,63551-63552,63554,63556,63558-63559,63562,63570,63576,63582,63589-63593,63602,63616,63624,63626,63628
Modified: grass/branches/releasebranch_7_0/display/d.barscale/thumbnails/README
--- grass/branches/releasebranch_7_0/display/d.barscale/thumbnails/README 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/display/d.barscale/thumbnails/README 2014-12-19 21:55:37 UTC (rev 63629)
@@ -7,7 +7,7 @@
export GRASS_RENDER_TRUECOLOR=TRUE
export GRASS_RENDER_WIDTH=300
export GRASS_RENDER_HEIGHT=300
-g.region rast=elevation
+g.region raster=elevation
for STYLE in classic line solid hollow full_checker part_checker mixed_checker tail_checker up_ticks down_ticks both_ticks arrow_ends
do
Modified: grass/branches/releasebranch_7_0/display/d.geodesic/d.geodesic.html
--- grass/branches/releasebranch_7_0/display/d.geodesic/d.geodesic.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/display/d.geodesic/d.geodesic.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -30,7 +30,7 @@
(demolocation dataset):
<div class="code"><pre>
-g.region vect=country_boundaries -p
+g.region vector=country_boundaries -p
d.mon wx0
d.vect country_boundaries type=area
d.geodesic coordinates=55:58W,33:18S,26:43E,60:37N \
Modified: grass/branches/releasebranch_7_0/display/d.his/d.his.html
--- grass/branches/releasebranch_7_0/display/d.his/d.his.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/display/d.his/d.his.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -107,7 +107,7 @@
<h3>Spearfish dataset</h3>
-g.region rast=elevation.dem
+g.region raster=elevation.dem
r.shaded.relief map=elevation.dem shad=elev.shad_relf
d.mon wx0
d.his h=elevation.dem i=elev.shad_relf brighten=50
Modified: grass/branches/releasebranch_7_0/display/d.path/d.path.html
--- grass/branches/releasebranch_7_0/display/d.path/d.path.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/display/d.path/d.path.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -24,7 +24,7 @@
Interactive shortest path routing on road network (North Carolina sample dataset):
-g.region vect=roadsmajor -p
+g.region vector=roadsmajor -p
d.vect roadsmajor
d.path roadsmajor coordinates=668646.15,224447.16,668348.83,235894.02
</pre></div>
Modified: grass/branches/releasebranch_7_0/display/d.rhumbline/d.rhumbline.html
--- grass/branches/releasebranch_7_0/display/d.rhumbline/d.rhumbline.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/display/d.rhumbline/d.rhumbline.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -24,7 +24,7 @@
d.mon wx0
d.rhumbline coordinates=55:58W,33:18S,26:43E,60:37N \
Modified: grass/branches/releasebranch_7_0/display/d.vect/d.vect.html
--- grass/branches/releasebranch_7_0/display/d.vect/d.vect.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/display/d.vect/d.vect.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -83,7 +83,7 @@
<p>3D points, 3D lines and 3D polygons colorized according to z height:
-g.region rast=elevation.10m
+g.region raster=elevation.10m
r.random input=elevation.10m n=5000 vector=random3d -d
d.mon start=x0
# display as black points
Modified: grass/branches/releasebranch_7_0/display/d.vect.chart/d.vect.chart.html
--- grass/branches/releasebranch_7_0/display/d.vect.chart/d.vect.chart.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/display/d.vect.chart/d.vect.chart.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -48,7 +48,7 @@
sample dataset:
-g.region rast=erode.index -p
+g.region raster=erode.index -p
r.to.vect -s input=erode.index output=erode_index type=area
v.extract input=erode_index output=erode_index_ctrds type=centroid
d.rast aspect
Modified: grass/branches/releasebranch_7_0/general/g.list/g.list.html
--- grass/branches/releasebranch_7_0/general/g.list/g.list.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/general/g.list/g.list.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -161,7 +161,7 @@
List all raster maps starting with "tmp_" whose region overlaps with
the region of "test" raster map:
-g.region rast=test save=test_region
+g.region raster=test save=test_region
g.list type=rast pattern='tmp_*' region=test_region
</pre></div>
Modified: grass/branches/releasebranch_7_0/general/g.region/g.region.html
--- grass/branches/releasebranch_7_0/general/g.region/g.region.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/general/g.region/g.region.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -126,19 +126,14 @@
<h3>Additional parameter information:</h3>
<dl>
-<dt><b>3dview=</b><em>name</em>
-<dd>Make current region settings same as those in the named
-3dview file, which holds the region that was current when
-the 3dview was saved.
<dt><b>zoom=</b><em>name</em>
<dd>Shrink current region settings to the smallest region
encompassing all non-NULL data in the named raster map
layer that fall inside the user's current region. In this
way you can tightly zoom in on isolated clumps within a
bigger map.
-<p>If the user also includes the <b>rast=</b><em>name</em>
+<p>If the user also includes the <b>raster=</b><em>name</em>
option on the command line, <b>zoom=</b><em>name</em> will
set the current region settings to the smallest region
encompassing all non-NULL data in the named <b>zoom</b> map
@@ -154,7 +149,7 @@
existing region edges outward to the edges of the next
nearest cell in the named raster map - not to the named
map's edges. To perform the latter function, use the
-<b>rast=</b><em>name</em> option.
+<b>raster=</b><em>name</em> option.
</dl>
@@ -222,7 +217,7 @@
<dt><span class="code"><tt>
-g.region rast=soils
+g.region raster=soils
</tt></span>
<dd> This form will make the current region settings
@@ -232,7 +227,7 @@
<p>
-g.region rast=soils zoom=soils
+g.region raster=soils zoom=soils
</tt></span>
<dd> This form will first look up the cell header file for
@@ -240,7 +235,7 @@
current region setting, and then shrink the region down to
the smallest region which still encompasses all non-NULL
data in the map layer <em>soils</em>. Note that if the
-parameter <em>rast=soils</em> were not specified, the
+parameter <em>raster=soils</em> were not specified, the
zoom would shrink to encompass all non-NULL data values in
the soils map that were located within the <i>current region</i>
settings.
@@ -248,7 +243,7 @@
<p>
-g.region -up rast=soils
+g.region -up raster=soils
</tt></span>
<dd> The <b>-u</b> option suppresses the re-setting of the
Modified: grass/branches/releasebranch_7_0/general/g.region/main.c
--- grass/branches/releasebranch_7_0/general/g.region/main.c 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/general/g.region/main.c 2014-12-19 21:55:37 UTC (rev 63629)
@@ -450,7 +450,7 @@
Rast3d_region_to_cell_head(&win, &window);
- /* vect= */
+ /* vector= */
if (parm.vect->answer) {
int first = 0;
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gcp/manager.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gcp/manager.py 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gcp/manager.py 2014-12-19 21:55:37 UTC (rev 63629)
@@ -15,7 +15,7 @@
- manager::EditGCP
- manager::GrSettingsDialog
-(C) 2006-2012 by the GRASS Development Team
+(C) 2006-2014 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -673,9 +673,9 @@
try:
# set computational region to match selected map and zoom display to region
if maptype == 'raster':
- p = RunCommand('g.region', 'rast=src_map')
+ p = RunCommand('g.region', 'raster=src_map')
elif maptype == 'vector':
- p = RunCommand('g.region', 'vect=src_map')
+ p = RunCommand('g.region', 'vector=src_map')
if p.returncode == 0:
print 'returncode = ', str(p.returncode)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py
--- grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py 2014-12-19 21:55:37 UTC (rev 63629)
@@ -681,7 +681,7 @@
return
# set region for composite
grass.use_temp_region()
- returncode, messages = RunCommand('g.region', rast=tmpName + '.red',
+ returncode, messages = RunCommand('g.region', raster=tmpName + '.red',
quiet=True, getErrorMsg=True)
if not returncode == 0:
grass.del_temp_region()
Modified: grass/branches/releasebranch_7_0/gui/wxpython/psmap/instructions.py
--- grass/branches/releasebranch_7_0/gui/wxpython/psmap/instructions.py 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/gui/wxpython/psmap/instructions.py 2014-12-19 21:55:37 UTC (rev 63629)
@@ -551,9 +551,9 @@
if self.instruction['scaleType'] == 0: #match map
map = self.instruction['map']
if self.instruction['mapType'] == 'raster':
- comment = "# g.region rast=%s nsres=%s ewres=%s\n" % (map, region['nsres'], region['ewres'])
+ comment = "# g.region raster=%s nsres=%s ewres=%s\n" % (map, region['nsres'], region['ewres'])
else:
- comment = "# g.region vect=%s\n" % (map)
+ comment = "# g.region vector=%s\n" % (map)
elif self.instruction['scaleType'] == 1:# saved region
region = self.instruction['region']
comment = "# g.region region=%s\n" % region
Modified: grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/functions.py
--- grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/functions.py 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/functions.py 2014-12-19 21:55:37 UTC (rev 63629)
@@ -10,6 +10,7 @@
from grass.script import core as grass
from core.gcmd import GError
class SamplingType:
KMVWINC = samplingtype=moving, regionbox=keyboard, shape=circle
@@ -82,12 +83,12 @@
tmp_vect = "tmp_{rast}".format(rast=outrast)
grass.run_command('v.extract', input=vect, output=tmp_vect, cats=cat,
overwrite=True, quiet=True)
- grass.run_command('g.region', vect=tmp_vect, align=origrast)
+ grass.run_command('g.region', vector=tmp_vect, align=origrast)
grass.run_command('v.to.rast', input=vect, output=outrast, use='cat',
cats=cat, overwrite=True, quiet=True)
- grass.run_command('g.remove', type='vector', name=tmp_vect, quiet=True, flags='f')
+ grass.run_command('g.remove', flags='f', type='vector',
+ name=tmp_vect, quiet=True)
def obtainAreaVector(outrast):
"""Create the string for configuration file"""
reg = grass.region()
Modified: grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/g.gui.rlisetup.html
--- grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/g.gui.rlisetup.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/g.gui.rlisetup.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -276,7 +276,7 @@
<p>
Now an anaysis can be performed using one of the analytical modules, e.g.
-g.region rast=forests -p
+g.region raster=forests -p
r.li.patchdensity input=forests conf=movwindow7 output=forests_p_dens7
r.univar forests_p_dens7
</pre></div>
@@ -314,7 +314,7 @@
<p>
-g.region rast=lsat7_2002_40 -p
+g.region raster=lsat7_2002_40 -p
r.li.shannon input=lsat7_2000_40 conf=whole_region output=lsat7_2000_40_shannon
</pre></div>
Modified: grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/sampling_frame.py
--- grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/sampling_frame.py 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/sampling_frame.py 2014-12-19 21:55:37 UTC (rev 63629)
@@ -258,7 +258,7 @@
value=1, use='val')
wx.EndBusyCursor()
- grass.run_command('g.region', vect=tmpvector)
+ grass.run_command('g.region', vector=tmpvector)
region = grass.region()
marea = MaskedArea(region, rasterName)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/wizard.py
--- grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/wizard.py 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/wizard.py 2014-12-19 21:55:37 UTC (rev 63629)
@@ -140,7 +140,7 @@
# Temporarily aligning region resolution to $RASTER resolution
# keep boundary settings
- grass.run_command('g.region', rast=self.startpage.rast)
+ grass.run_command('g.region', raster=self.startpage.rast)
self.gregion = grass.region()
self.SF_NSRES = self.gregion['nsres']
self.SF_EWRES = self.gregion['ewres']
@@ -236,7 +236,7 @@
coordinate=[xcenter, ycenter], quiet=True)
def getSamplingType(self):
"""Obtain the sampling type"""
@@ -349,7 +349,7 @@
SamplingType.MUNITSC]:
# get the raster region into rastregion
rastregion = grass.region()
s_n = rastregion['n']
s_w = rastregion['w']
Modified: grass/branches/releasebranch_7_0/imagery/i.atcorr/i.atcorr.html
--- grass/branches/releasebranch_7_0/imagery/i.atcorr/i.atcorr.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/imagery/i.atcorr/i.atcorr.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -615,7 +615,7 @@
The example is based on the North Carolina sample dataset (GMT -5 hours).
First we set the computational region to the satellite map, e.g. channel 4:
</pre></div>
It is important to verify the available metadata for the sun position which
Modified: grass/branches/releasebranch_7_0/imagery/i.atcorr/test_suite/README.txt
--- grass/branches/releasebranch_7_0/imagery/i.atcorr/test_suite/README.txt 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/imagery/i.atcorr/test_suite/README.txt 2014-12-19 21:55:37 UTC (rev 63629)
@@ -11,7 +11,7 @@
# import raw Landsat channel 4:
r.in.gdal ETM4_400x400.raw out=ETM4_400x400.raw -o
# set region to this map
-g.region rast=ETM4_400x400.raw
+g.region raster=ETM4_400x400.raw
# create synthetic DEM, close to sea level
r.mapcalc "atcorr_dem = 10.0"
Modified: grass/branches/releasebranch_7_0/imagery/i.cluster/i.cluster.html
--- grass/branches/releasebranch_7_0/imagery/i.cluster/i.cluster.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/imagery/i.cluster/i.cluster.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -219,7 +219,7 @@
a LANDSAT subscene in North Carolina:
-g.region rast=lsat7_2002_10 -p
+g.region raster=lsat7_2002_10 -p
# store VIZ, NIR, MIR into group/subgroup
i.group group=my_lsat7_2002 subgroup=my_lsat7_2002 \
Modified: grass/branches/releasebranch_7_0/imagery/i.fft/i.fft.html
--- grass/branches/releasebranch_7_0/imagery/i.fft/i.fft.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/imagery/i.fft/i.fft.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -26,11 +26,11 @@
North Carolina example:
-g.region rast=lsat7_2002_70
+g.region raster=lsat7_2002_70
i.fft input=lsat7_2002_70 real=lsat7_2002_70.real imaginary=lsat7_2002_70.imag
# set region to resulting FFT output map (due to new FFT coordinate space):
-g.region rast=lsat7_2002_70.real -p
+g.region raster=lsat7_2002_70.real -p
d.mon x0
d.rast lsat7_2002_70.real
d.rast lsat7_2002_70.imag
Modified: grass/branches/releasebranch_7_0/imagery/i.pca/i.pca.html
--- grass/branches/releasebranch_7_0/imagery/i.pca/i.pca.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/imagery/i.pca/i.pca.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -53,7 +53,7 @@
Using Landsat imagery in the North Carolina sample dataset:
i.pca in=lsat7_2002_10,lsat7_2002_20,lsat7_2002_30,lsat7_2002_40,lsat7_2002_50,lsat7_2002_70 \
out=lsat7_2002_pca
Modified: grass/branches/releasebranch_7_0/imagery/i.segment/i.segment.html
--- grass/branches/releasebranch_7_0/imagery/i.segment/i.segment.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/imagery/i.segment/i.segment.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -122,7 +122,7 @@
input ortho photograph).
-g.region -p rast=ortho_2001_t792_1m n=220446 s=220075 e=639151 w=638592
+g.region -p raster=ortho_2001_t792_1m n=220446 s=220075 e=639151 w=638592
</pre></div>
Try out a low threshold and check the results.
@@ -162,7 +162,7 @@
<p>Set the region to match the entire map(s) in the group.
-g.region -p rast=ortho_2001_t792_1m at PERMANENT
+g.region -p raster=ortho_2001_t792_1m at PERMANENT
</pre></div>
<p>
Modified: grass/branches/releasebranch_7_0/imagery/i.smap/i.smap.html
--- grass/branches/releasebranch_7_0/imagery/i.smap/i.smap.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/imagery/i.smap/i.smap.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -147,7 +147,7 @@
Supervised classification of LANDSAT
Modified: grass/branches/releasebranch_7_0/imagery/i.vi/i.vi.html
--- grass/branches/releasebranch_7_0/imagery/i.vi/i.vi.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/imagery/i.vi/i.vi.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -253,7 +253,7 @@
<!-- todo: check if i.landsat.toar use is needed for NC data -->
-g.region rast=lsat5_1987_30 -p
+g.region raster=lsat5_1987_30 -p
i.vi red=lsat5_1987_30 viname=ndvi output=lsat5_1987.ndvi nir=lsat5_1987_40
r.colors lsat5_1987.ndvi color=ndvi
</pre></div>
Modified: grass/branches/releasebranch_7_0/lib/cairodriver/cairodriver.html
--- grass/branches/releasebranch_7_0/lib/cairodriver/cairodriver.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/lib/cairodriver/cairodriver.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -95,7 +95,7 @@
export GRASS_RENDER_HEIGHT=800
export GRASS_RENDER_FILE_READ=TRUE
d.rast map=elevation
d.vect map=streams width=1 color=blue fcolor=aqua type=area,line
d.vect map=roadsmajor width=2
@@ -111,7 +111,7 @@
export GRASS_RENDER_WIDTH=800
# activate vector font
d.font Vera
d.vect map=roadsmajor layer=1 display=shape attrcolumn=ROAD_NAME lcolor=0:90:255
@@ -126,7 +126,7 @@
</pre></div>
Modified: grass/branches/releasebranch_7_0/lib/pngdriver/pngdriver.html
--- grass/branches/releasebranch_7_0/lib/pngdriver/pngdriver.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/lib/pngdriver/pngdriver.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -67,7 +67,7 @@
export GRASS_RENDER_IMMEDIATE=png
d.rast elevation
d.vect roadsmajor color=red
</pre></div>
Modified: grass/branches/releasebranch_7_0/lib/psdriver/psdriver.html
--- grass/branches/releasebranch_7_0/lib/psdriver/psdriver.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/lib/psdriver/psdriver.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -57,7 +57,7 @@
export GRASS_RENDER_IMMEDIATE=ps
d.rast elevation
</pre></div>
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/grid/grid.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/grid/grid.py 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/grid/grid.py 2014-12-19 21:55:37 UTC (rev 63629)
@@ -353,7 +353,7 @@
inputs[key] = mapnames[key]
cmd['inputs'] = inputs.items()
# set the region to the tile
- sub.Popen(['g,region', 'rast=%s' % key], env=env).wait()
+ sub.Popen(['g,region', 'raster=%s' % key], env=env).wait()
else:
# set the computational region
lcmd = ['g.region', ]
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/stds_import.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/stds_import.py 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/stds_import.py 2014-12-19 21:55:37 UTC (rev 63629)
@@ -97,7 +97,7 @@
# Set the computational region from the last map imported
if set_current_region is True:
- gscript.run_command("g.region", rast=name)
+ gscript.run_command("g.region", raster=name)
@@ -121,7 +121,7 @@
Modified: grass/branches/releasebranch_7_0/misc/m.nviz.image/m.nviz.image.html
--- grass/branches/releasebranch_7_0/misc/m.nviz.image/m.nviz.image.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/misc/m.nviz.image/m.nviz.image.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -11,7 +11,7 @@
Render elevation map in a 3D space.
m.nviz.image elevation_map=elevation output=elev perspective=15
</pre></div>
Modified: grass/branches/releasebranch_7_0/misc/m.nviz.script/m.nviz.script.html
--- grass/branches/releasebranch_7_0/misc/m.nviz.script/m.nviz.script.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/misc/m.nviz.script/m.nviz.script.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -85,7 +85,7 @@
the scene, run the following:
d.rast elevation.dem
m.nviz.script -ik input=elevation.dem output=nviz.script dist=2400 ht=1220 frames=1000
</pre></div>
Modified: grass/branches/releasebranch_7_0/ps/ps.map/ps.map.html
--- grass/branches/releasebranch_7_0/ps/ps.map/ps.map.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/ps/ps.map/ps.map.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -1576,7 +1576,7 @@
# First set the region
- g.region rast=soils
+ g.region raster=soils
# Generate comment file (or use text editor)
echo "Spearfish (SD) soils" > soil.cmt
Modified: grass/branches/releasebranch_7_0/raster/r.carve/r.carve.html
--- grass/branches/releasebranch_7_0/raster/r.carve/r.carve.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.carve/r.carve.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -21,7 +21,7 @@
-g.region rast=elevation -p
+g.region raster=elevation -p
r.carve rast=elevation vect=streams out=carve_dem width=20 depth=5
</pre></div>
Modified: grass/branches/releasebranch_7_0/raster/r.clump/r.clump.html
--- grass/branches/releasebranch_7_0/raster/r.clump/r.clump.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.clump/r.clump.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -38,7 +38,7 @@
report area sizes for each lake individually rather by waterbody type:
-g.region rast=lakes -p
+g.region raster=lakes -p
# report sizes by waterbody type
r.report lakes units=h
Modified: grass/branches/releasebranch_7_0/raster/r.contour/r.contour.html
--- grass/branches/releasebranch_7_0/raster/r.contour/r.contour.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.contour/r.contour.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -40,7 +40,7 @@
<p>
-g.region rast=elev_lid792_1m -p
+g.region raster=elev_lid792_1m -p
r.contour input=elev_lid792_1m output=elev_lid792_1m_contours minlevel=100 maxlevel=150 step=10
</pre></div>
Modified: grass/branches/releasebranch_7_0/raster/r.cost/r.cost.html
--- grass/branches/releasebranch_7_0/raster/r.cost/r.cost.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.cost/r.cost.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -217,7 +217,7 @@
(example for Spearfish region):
- g.region rast=roads -p
+ g.region raster=roads -p
r.mapcalc "area.one = 1"
r.cost -k input=area.one output=distance start_rast=roads
d.rast distance
Modified: grass/branches/releasebranch_7_0/raster/r.cost/test_suite/profile.sh
--- grass/branches/releasebranch_7_0/raster/r.cost/test_suite/profile.sh 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.cost/test_suite/profile.sh 2014-12-19 21:55:37 UTC (rev 63629)
@@ -1,5 +1,5 @@
# NC dataset
r.mapcalc 'one = 1'
CMD="r.cost -k in=one start_points=school_copy output=cost.test --o"
Modified: grass/branches/releasebranch_7_0/raster/r.drain/tests/test.r.drain.sh
--- grass/branches/releasebranch_7_0/raster/r.drain/tests/test.r.drain.sh 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.drain/tests/test.r.drain.sh 2014-12-19 21:55:37 UTC (rev 63629)
@@ -5,7 +5,7 @@
export GRASS_OVERWRITE=1
r.in.ascii testascii_nc.asc out=testascii
-g.region rast=testascii -p
+g.region raster=testascii -p
d.mon wx0
sleep 2
Modified: grass/branches/releasebranch_7_0/raster/r.external/r.external.html
--- grass/branches/releasebranch_7_0/raster/r.external/r.external.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.external/r.external.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -29,7 +29,7 @@
# import of all channels (each channel will become a GRASS raster map):
r.external /home/user/data/maps/059100.tif out=ortho
-g.region rast=ortho.3 -p
+g.region raster=ortho.3 -p
d.rgb r=ortho.1 g=ortho.2 b=ortho.3
r.composite r=ortho.1 g=ortho.2 b=ortho.3 output=ortho.rgb
</pre></div>
Modified: grass/branches/releasebranch_7_0/raster/r.grow.distance/r.grow.distance.html
--- grass/branches/releasebranch_7_0/raster/r.grow.distance/r.grow.distance.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.grow.distance/r.grow.distance.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -64,7 +64,7 @@
A) Distance from the streams network (North Carolina sample dataset):
-g.region rast=streams_derived -p
+g.region raster=streams_derived -p
r.grow.distance input=streams_derived distance=dist_from_streams
</pre></div>
@@ -76,7 +76,7 @@
<p>
B) Distance from sea in meters in latitude-longitude location:
-g.region rast=sea -p
+g.region raster=sea -p
r.grow.distance -m input=sea distance=dist_from_sea_geodetic metric=geodesic
</pre></div>
Modified: grass/branches/releasebranch_7_0/raster/r.his/r.his.html
--- grass/branches/releasebranch_7_0/raster/r.his/r.his.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.his/r.his.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -90,7 +90,7 @@
Recreate the following <em>d.his</em> command using <em>r.his</em>:
-g.regiopn rast=elevation
+g.region -p raster=elevation
r.shaded.relief map=elevation shad=elev.shad_relf
d.his h=elevation i=elev.shad_relf brighten=50
</pre></div>
Modified: grass/branches/releasebranch_7_0/raster/r.horizon/r.horizon.html
--- grass/branches/releasebranch_7_0/raster/r.horizon/r.horizon.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.horizon/r.horizon.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -142,7 +142,7 @@
of horizon angles CCW from East):
r.horizon elevation=elevation direction=215 step=0 bufferzone=200 \
coordinates=638871.6,223384.4 maxdistance=5000
</pre></div>
Modified: grass/branches/releasebranch_7_0/raster/r.in.lidar/r.in.lidar.html
--- grass/branches/releasebranch_7_0/raster/r.in.lidar/r.in.lidar.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.in.lidar/r.in.lidar.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -207,7 +207,7 @@
# set the computational region automatically, resol. for binning is 5m
r.in.lidar -e -o input=points.las resolution=5 output=lidar_dem_mean
-g.region rast=lidar_dem_mean -p
+g.region raster=lidar_dem_mean -p
r.univar lidar_dem_mean
</pre></div>
Modified: grass/branches/releasebranch_7_0/raster/r.lake/r.lake.html
--- grass/branches/releasebranch_7_0/raster/r.lake/r.lake.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.lake/r.lake.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -86,7 +86,7 @@
Example of small flooding along a street (North Carolina sample dataset):
# water accumulation next to street dam
r.lake elev_lid792_1m coordinates=638759.3,220264.1 water_level=113.4 lake=flooding
Modified: grass/branches/releasebranch_7_0/raster/r.latlong/r.latlong.html
--- grass/branches/releasebranch_7_0/raster/r.latlong/r.latlong.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.latlong/r.latlong.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -14,7 +14,7 @@
<h2>EXAMPLE</h2>
r.latlong input=elevation output=latitude
</pre></div>
Modified: grass/branches/releasebranch_7_0/raster/r.li/TODO
--- grass/branches/releasebranch_7_0/raster/r.li/TODO 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/TODO 2014-12-19 21:55:37 UTC (rev 63629)
@@ -15,7 +15,7 @@
# TODO: change the examples to North Carolina wherever possible:
# Spearfish tests
-g.region rast=landcover.30m -p
+g.region raster=landcover.30m -p
r.mapcalc "forests = if(landcover.30m >= 41 && landcover.30m <= 43,1,null())"
d.mon wx0
d.rast forests
@@ -61,7 +61,7 @@
echo "SAMPLINGFRAME 0|0|1|1
SAMPLEAREA 0.0|0.0|1.0|1.0" > $HOME/.grass7/r.li/landsat_test
r.li.shannon input=lsat7_2002_40 conf=landsat_test output=landsat_shannon
--> Result written to ASCII file <$HOME/.grass7/r.li/output/landsat_shannon>
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.c
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.c 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.c 2014-12-19 21:55:37 UTC (rev 63629)
@@ -413,7 +413,7 @@
char maskname[GNAME_MAX] = {'\0'};
msg m;
- /* Get the window setting. g.region rast=<input raster> */
+ /* Get the window setting. g.region raster=<input raster> */
/* ? same as cellhd above ? */
/* no. the current window might be different */
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.dominance/r.li.dominance.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.dominance/r.li.dominance.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.dominance/r.li.dominance.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -35,7 +35,7 @@
Forest map (Spearfish sample dataset) example:
r.li.dominance input=forests conf=movwindow7 out=forests_dominance_mov7
r.univar forests_dominance_mov7
@@ -44,7 +44,7 @@
Forest map (North Carolina sample dataset) example:
-g.region rast=landclass96 -p
+g.region raster=landclass96 -p
r.mapcalc "forests = if(landclass96 == 5, 1, null() )"
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.edgedensity/r.li.edgedensity.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.edgedensity/r.li.edgedensity.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.edgedensity/r.li.edgedensity.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -56,7 +56,7 @@
r.li.edgedensity input=forests conf=movwindow7 out=forests_edgedens_mov7
r.univar forests_edgedens_mov7
@@ -65,7 +65,7 @@
r.li.edgedensity input=forests conf=movwindow7 out=forests_edgedensity_mov7
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -81,7 +81,7 @@
<ol>
<li> set the region settings to the "<tt>geology</tt>" raster map:
- g.region rast=geology -p
+ g.region raster=geology -p
</pre></div>
<li> run <em>r.li.patchdensity</em>:
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.mpa/r.li.mpa.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.mpa/r.li.mpa.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.mpa/r.li.mpa.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -43,7 +43,7 @@
r.li.mpa input=forests conf=movwindow7 out=forests_mpa_mov7
r.univar forests_mpa_mov7
@@ -52,7 +52,7 @@
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.mps/r.li.mps.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.mps/r.li.mps.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.mps/r.li.mps.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -45,7 +45,7 @@
r.li.mps input=forests conf=movwindow7 out=forests_mps_mov7
r.univar forests_mps_mov7
@@ -54,7 +54,7 @@
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.padcv/r.li.padcv.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.padcv/r.li.padcv.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.padcv/r.li.padcv.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -35,7 +35,7 @@
r.li.padcv input=forests conf=movwindow7 out=forests_padcv_mov7
r.univar forests_padcv_mov7
@@ -44,7 +44,7 @@
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.padrange/r.li.padrange.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.padrange/r.li.padrange.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.padrange/r.li.padrange.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -37,7 +37,7 @@
r.li.padrange input=forests conf=movwindow7 out=forests_padrange_mov7
r.univar forests_padrange_mov7
@@ -46,7 +46,7 @@
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.padsd/r.li.padsd.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.padsd/r.li.padsd.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.padsd/r.li.padsd.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -37,7 +37,7 @@
r.li.padsd input=forests conf=movwindow7 out=forests_padsd_mov7
r.univar forests_padsd_mov7
@@ -46,7 +46,7 @@
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.patchdensity/r.li.patchdensity.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.patchdensity/r.li.patchdensity.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -40,7 +40,7 @@
<p>
Example for Spearfish forest areas:
# extract forested areas:
r.category landcover.30m
r.mapcalc "forests = if(landcover.30m >= 41 && landcover.30m <= 43, 1, null())"
@@ -57,7 +57,7 @@
r.li.patchdensity input=forests conf=movwindow7 out=forests_patchdensity_mov7
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.patchnum/r.li.patchnum.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.patchnum/r.li.patchnum.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.patchnum/r.li.patchnum.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -31,7 +31,7 @@
r.li.patchnum input=forests conf=movwindow7 out=forests_patchnum_mov7
r.univar forests_patchnum_mov7
@@ -40,7 +40,7 @@
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.pielou/r.li.pielou.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.pielou/r.li.pielou.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.pielou/r.li.pielou.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -34,7 +34,7 @@
r.li.pielou input=forests conf=movwindow7 out=forests_pielou_mov7
r.univar forests_pielou_mov7
@@ -43,7 +43,7 @@
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.renyi/r.li.renyi.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.renyi/r.li.renyi.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.renyi/r.li.renyi.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -37,7 +37,7 @@
r.li.renyi input=forests conf=movwindow7 out=forests_renyi_mov7_a06 alpha=0.6
r.univar forests_renyi_mov7_a06
@@ -46,7 +46,7 @@
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.richness/r.li.richness.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.richness/r.li.richness.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.richness/r.li.richness.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -37,7 +37,7 @@
r.li.richness input=forests conf=movwindow7 out=forests_richness_mov7
r.univar forests_richness_mov7
@@ -46,7 +46,7 @@
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.shannon/r.li.shannon.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.shannon/r.li.shannon.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.shannon/r.li.shannon.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -35,7 +35,7 @@
r.li.shannon input=forests conf=movwindow7 out=forests_shannon_mov7
r.univar forests_shannon_mov7
@@ -44,7 +44,7 @@
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.shape/r.li.shape.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.shape/r.li.shape.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.shape/r.li.shape.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -36,7 +36,7 @@
r.li.shape input=forests conf=movwindow7 out=forests_shape_mov7
r.univar forests_shape_mov7
@@ -45,7 +45,7 @@
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.simpson/r.li.simpson.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.simpson/r.li.simpson.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.simpson/r.li.simpson.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -34,7 +34,7 @@
r.li.simpson input=forests conf=movwindow7 out=forests_simpson_mov7
r.univar forests_simpson_mov7
@@ -43,7 +43,7 @@
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.testing_nc_asc.sh
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.testing_nc_asc.sh 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.testing_nc_asc.sh 2014-12-19 21:55:37 UTC (rev 63629)
@@ -11,7 +11,7 @@
# North Carolina location:
RASTER_MAP=landclass96
#r.to.vect in=basin_50K output=basin_50K feature=area
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.testing_sp_mov.sh
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.testing_sp_mov.sh 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.testing_sp_mov.sh 2014-12-19 21:55:37 UTC (rev 63629)
@@ -14,7 +14,7 @@
MOVINGWINDOW" > $HOME/.grass7/r.li/movwindow7
MEASURE="dominance edgedensity mpa mps padcv padrange padsd patchdensity patchnum pielou richness shannon shape simpson"
Modified: grass/branches/releasebranch_7_0/raster/r.mapcalc/test_suite/README
--- grass/branches/releasebranch_7_0/raster/r.mapcalc/test_suite/README 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.mapcalc/test_suite/README 2014-12-19 21:55:37 UTC (rev 63629)
@@ -4,7 +4,7 @@
#### r.blend for 3-in-1 testing
#spearfish
-g.region rast=elevation.10m res=5
+g.region raster=elevation.10m res=5
export GRASS_VERBOSE=0
Modified: grass/branches/releasebranch_7_0/raster/r.mode/r.mode.html
--- grass/branches/releasebranch_7_0/raster/r.mode/r.mode.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.mode/r.mode.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -33,7 +33,7 @@
Mode of K-factor (erosion) for Spearfish fields:
-g.region rast=fields -p
+g.region raster=fields -p
r.mode base=fields cover=soils.Kfactor output=K.by.farm.mode
r.univar K.by.farm.mode
</pre></div>
Modified: grass/branches/releasebranch_7_0/raster/r.out.gdal/r.out.gdal.html
--- grass/branches/releasebranch_7_0/raster/r.out.gdal/r.out.gdal.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.out.gdal/r.out.gdal.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -19,7 +19,7 @@
module)
<p>As with most GRASS raster modules, the current region extents and region
resolution are used, and a MASK is respected if present.
-Use <em><a href="g.region.html">g.region</a></em>'s "align=", or "rast="
+Use <em><a href="g.region.html">g.region</a></em>'s "align=", or "raster="
options if you need to realign the region settings to match the original
map's before export.
@@ -164,33 +164,33 @@
<h3>Export the integer raster basin_50K map to GeoTIFF format:</h3>
-g.region rast=basin_50K -p
+g.region raster=basin_50K -p
r.out.gdal input=basin_50K output=basin_50K.tif
</pre></div>
<p>
<h3>Export a DCELL raster map in GeoTIFF format suitable for ESRI software:</h3>
r.out.gdal in=elevation output=elevation.tif createopt="PROFILE=GeoTIFF,TFW=YES"
</pre></div>
<p>
<h3>Export a raster map in "Deflate" compressed GeoTIFF format:</h3>
r.out.gdal in=elevation output=elevation.tif createopt="COMPRESS=DEFLATE"
</pre></div>
<p>
<h3>Export R,G,B imagery bands in GeoTIFF format suitable for ESRI software:</h3>
i.group group=nc_landsat_rgb input=lsat7_2002_30,lsat7_2002_20,lsat7_2002_10
-g.region rast=lsat7_2002_30 -p
+g.region raster=lsat7_2002_30 -p
r.out.gdal in=nc_landsat_rgb output=nc_landsat_rgb.tif type=Byte \
createopt="PROFILE=GeoTIFF,INTERLEAVE=PIXEL,TFW=YES"
</pre></div>
<p>
<h3>Export the floating point raster elevation map to ERDAS/IMG format:</h3>
r.out.gdal input=elevation output=elelevation.img format=HFA type=Float32
</pre></div>
@@ -199,7 +199,7 @@
g.list group
i.group group=tm7 subgroup=tm7 input=tm7_10,tm7_20,tm7_30,tm7_40,tm7_50,tm7_60,tm7_70
i.group -l tm7
-g.region rast=tm7_10 -p
+g.region raster=tm7_10 -p
r.out.gdal tm7 output=lsat_multiband.tif
gdalinfo lsat_multiband.tif
</pre></div>
Modified: grass/branches/releasebranch_7_0/raster/r.out.ppm/r.out.ppm.html
--- grass/branches/releasebranch_7_0/raster/r.out.ppm/r.out.ppm.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.out.ppm/r.out.ppm.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -4,7 +4,7 @@
at the pixel resolution of the CURRENTLY DEFINED REGION.
To get the resolution and region settings of the raster map, run:<p>
-g.region -p rast=[mapname]
+g.region -p raster=[mapname]
</pre></div>
<p>
Modified: grass/branches/releasebranch_7_0/raster/r.out.ppm3/r.out.ppm3.html
--- grass/branches/releasebranch_7_0/raster/r.out.ppm3/r.out.ppm3.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.out.ppm3/r.out.ppm3.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -9,7 +9,7 @@
<p>To get the full area and resolutin of the raster map, run:
-g.region rast=[mapname]
+g.region raster=[mapname]
</pre></div>
<p>before running <em>r.out.ppm3</em>.
Modified: grass/branches/releasebranch_7_0/raster/r.param.scale/r.param.scale.html
--- grass/branches/releasebranch_7_0/raster/r.param.scale/r.param.scale.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.param.scale/r.param.scale.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -73,7 +73,7 @@
The next commands will create a geomorphological map of the Spearfish region:
-g.region rast=elevation.10m -p
+g.region raster=elevation.10m -p
r.param.scale in=elevation.10m output=morphology param=feature size=9
</pre></div>
Modified: grass/branches/releasebranch_7_0/raster/r.patch/r.patch.html
--- grass/branches/releasebranch_7_0/raster/r.patch/r.patch.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.patch/r.patch.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -63,7 +63,7 @@
program can be used:
-g.region rast=map1[,map2[,...]]
+g.region raster=map1[,map2[,...]]
</pre></div>
<p>
@@ -104,7 +104,7 @@
MAPS=`g.list type=rast sep=, pat="map_*"`
-g.region rast=$MAPS
+g.region raster=$MAPS
r.patch in=$MAPS out=mosaic
</pre></div>
<br>
Modified: grass/branches/releasebranch_7_0/raster/r.proj/r.proj.html
--- grass/branches/releasebranch_7_0/raster/r.proj/r.proj.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.proj/r.proj.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -261,7 +261,7 @@
# bounds map, and align the resolution to the desired cell resolution of the
# final, reprojected raster map:
-g.region vect=bounds_reprojected res=5 -a
+g.region vector=bounds_reprojected res=5 -a
# Now reproject the raster into the target location
Modified: grass/branches/releasebranch_7_0/raster/r.quantile/r.quantile.html
--- grass/branches/releasebranch_7_0/raster/r.quantile/r.quantile.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.quantile/r.quantile.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -8,14 +8,14 @@
Calculation of elevation quantiles (printed to standard-out):
r.quantile input=elevation percentiles=0.1,1,10,25,50,75,90,99,99.9
</pre></div>
The output of <em>r.quantile</em> can be used for quantile classification:
r.quantile elevation quantiles=5 -r --quiet | r.recode elevation \
out=elev_quant5 rules=-
</pre></div>
Modified: grass/branches/releasebranch_7_0/raster/r.random/r.random.html
--- grass/branches/releasebranch_7_0/raster/r.random/r.random.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.random/r.random.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -71,7 +71,7 @@
Spearfish region, result stored in 2D vector map:
r.random elevation.10m vector=elevrand n=100
v.db.select elevrand
v.univar elevrand col=value type=point
@@ -83,7 +83,7 @@
result stored in 3D vector map:
r.random -d elevation.10m cover=landcover.30m vector=luserand3d n=100
# data output (value: elevation, covervalue: landuse class):
Modified: grass/branches/releasebranch_7_0/raster/r.reclass/r.reclass.html
--- grass/branches/releasebranch_7_0/raster/r.reclass/r.reclass.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.reclass/r.reclass.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -46,7 +46,7 @@
<p>To convert a reclass map to a regular raster map layer, set your
geographic region settings to match the settings in the header for the
-reclass map (with "<tt>g.region rast=reclass_map</tt>", or
+reclass map (with "<tt>g.region raster=reclass_map</tt>", or
viewable by running <em><a href="r.info.html">r.info</a></em>)
and then run <em><a href="r.resample.html">r.resample</a></em>.
Modified: grass/branches/releasebranch_7_0/raster/r.regression.line/r.regression.line.html
--- grass/branches/releasebranch_7_0/raster/r.regression.line/r.regression.line.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.regression.line/r.regression.line.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -17,14 +17,14 @@
Comparison of the old and the new DEM in Spearfish:
r.regression.line map1=elevation.dem map2=elevation.10m
</pre></div>
<p>
Using the script style flag AND <em>eval</em> to make results
available in the shell:
eval `r.regression.line -g map1=elevation.dem map2=elevation.10m`
echo $a
479.615
Modified: grass/branches/releasebranch_7_0/raster/r.regression.multi/r.regression.multi.html
--- grass/branches/releasebranch_7_0/raster/r.regression.multi/r.regression.multi.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.regression.multi/r.regression.multi.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -72,7 +72,7 @@
Multiple regression with soil K-factor and elevation, aspect, and slope
(North Carolina dataset). Output maps are the residuals and estimates:
-g.region rast=soils_Kfactor -p
+g.region raster=soils_Kfactor -p
r.regression.multi mapx=elevation,aspect,slope mapy=soils_Kfactor \
residuals=soils_Kfactor.resid estimates=soils_Kfactor.estim
</pre></div>
Modified: grass/branches/releasebranch_7_0/raster/r.resamp.bspline/r.resamp.bspline.html
--- grass/branches/releasebranch_7_0/raster/r.resamp.bspline/r.resamp.bspline.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.resamp.bspline/r.resamp.bspline.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -72,7 +72,7 @@
# interpolate NULL cells
r.resamp.bspline -n input=input_raster output=interpolated_nulls method=bicubic
# set region to area with NULL cells, align region to input map
-g.region rast=input -p
+g.region raster=input -p
# patch original map and interpolated NULLs
r.patch input=input_raster,interpolated_nulls output=input_raster_gapfilled
</pre></div>
@@ -85,7 +85,7 @@
a complete elevation map:
-g.region rast=elev_srtm_30m -p
+g.region raster=elev_srtm_30m -p
d.mon wx0
d.histogram elev_srtm_30m
Modified: grass/branches/releasebranch_7_0/raster/r.resamp.interp/r.resamp.interp.html
--- grass/branches/releasebranch_7_0/raster/r.resamp.interp/r.resamp.interp.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.resamp.interp/r.resamp.interp.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -44,7 +44,7 @@
-g.region rast=elev_state_500m -p
+g.region raster=elev_state_500m -p
g.region res=250 -ap
r.resamp.interp input=elev_state_500m output=elev_state_250m
</pre></div>
Modified: grass/branches/releasebranch_7_0/raster/r.resamp.rst/BUGS
--- grass/branches/releasebranch_7_0/raster/r.resamp.rst/BUGS 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.resamp.rst/BUGS 2014-12-19 21:55:37 UTC (rev 63629)
@@ -5,7 +5,7 @@
Resolution bug:
r.resamp.rst N46E011.meters.90 el=N46E011.meters.1425 ew=14.25 ns=14.25
-GRASS 5.7.cvs:/nfsmnt/levi0/ssi/srtm_DEM90m_egm96geoid/original > g.region rast=N46E011.meters.1425 -p
+GRASS 5.7.cvs:/nfsmnt/levi0/ssi/srtm_DEM90m_egm96geoid/original > g.region raster=N46E011.meters.1425 -p
projection: 1 (UTM)
zone: 32
datum: WGS84
Modified: grass/branches/releasebranch_7_0/raster/r.resamp.rst/r.resamp.rst.html
--- grass/branches/releasebranch_7_0/raster/r.resamp.rst/r.resamp.rst.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.resamp.rst/r.resamp.rst.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -100,13 +100,13 @@
# set computation region to original map (30m)
-g.region rast=elevation.dem -p
+g.region raster=elevation.dem -p
# resample to 15m
r.resamp.rst input=elevation.dem ew_res=15 ns_res=15 elevation=elev15
# set computation region to resulting map
-g.region rast=elev15 -p
+g.region raster=elev15 -p
# verify
r.univar elev15 -g
Modified: grass/branches/releasebranch_7_0/raster/r.resamp.stats/r.resamp.stats.html
--- grass/branches/releasebranch_7_0/raster/r.resamp.stats/r.resamp.stats.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.resamp.stats/r.resamp.stats.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -30,7 +30,7 @@
-g.region rast=el_D782_6m -p
+g.region raster=el_D782_6m -p
g.region res=20 -ap
# from 6m to 20m: weighted resampling -w
r.resamp.stats -w input=el_D782_6m output=el_D782_20m
Modified: grass/branches/releasebranch_7_0/raster/r.shaded.relief/r.shaded.relief.html
--- grass/branches/releasebranch_7_0/raster/r.shaded.relief/r.shaded.relief.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.shaded.relief/r.shaded.relief.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -53,7 +53,7 @@
dataset location is used to hillshade the elevation map:
r.shaded.relief input=elevation output=elevation.shaded
</pre></div>
Modified: grass/branches/releasebranch_7_0/raster/r.sim/r.sim.water/r.sim.water.html
--- grass/branches/releasebranch_7_0/raster/r.sim/r.sim.water/r.sim.water.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.sim/r.sim.water/r.sim.water.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -140,7 +140,7 @@
Spearfish region:
r.slope.aspect elevation=elevation.10m dx=elev_dx dy=elev_dy
# synthetic maps
Modified: grass/branches/releasebranch_7_0/raster/r.sim/r.sim.water/spearfish.sh
--- grass/branches/releasebranch_7_0/raster/r.sim/r.sim.water/spearfish.sh 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.sim/r.sim.water/spearfish.sh 2014-12-19 21:55:37 UTC (rev 63629)
@@ -7,7 +7,7 @@
dem=elevation.10m
output=simwe
-g.region rast=${output}
+g.region raster=${output}
g.region n=4920800 s=4917800 w=602500 e=606000
g.region -p
Modified: grass/branches/releasebranch_7_0/raster/r.stats/test_suite/profile.sh
--- grass/branches/releasebranch_7_0/raster/r.stats/test_suite/profile.sh 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.stats/test_suite/profile.sh 2014-12-19 21:55:37 UTC (rev 63629)
@@ -1,6 +1,6 @@
#spearfish
MAP=elevation.10m
-g.region rast=$MAP
CMD="r.stats -a $MAP"
time $CMD
Modified: grass/branches/releasebranch_7_0/raster/r.stream.extract/r.stream.extract.html
--- grass/branches/releasebranch_7_0/raster/r.stream.extract/r.stream.extract.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.stream.extract/r.stream.extract.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -160,7 +160,7 @@
# set region
-g.region -p rast=elev_ned_30m at PERMANENT
+g.region -p raster=elev_ned_30m at PERMANENT
# calculate flow accumulation
r.watershed ele=elev_ned_30m at PERMANENT acc=elevation.10m.acc
Modified: grass/branches/releasebranch_7_0/raster/r.sun/r.sun.html
--- grass/branches/releasebranch_7_0/raster/r.sun/r.sun.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.sun/r.sun.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -255,7 +255,7 @@
North Carolina example (considering also cast shadows):
# calculate horizon angles (to speed up the subsequent r.sun calculation)
r.horizon elevation=elevation step=30 bufferzone=200 basename=horangle \
@@ -277,7 +277,7 @@
in non-leap years):
-g.region rast=elev_ned_30m -p
+g.region raster=elev_ned_30m -p
# considering cast shadows
r.sun elevation=elev_ned_30m linke_value=2.5 albedo_value=0.2 day=172 \
Modified: grass/branches/releasebranch_7_0/raster/r.sunmask/r.sunmask.html
--- grass/branches/releasebranch_7_0/raster/r.sunmask/r.sunmask.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.sunmask/r.sunmask.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -64,7 +64,7 @@
# set the region to a place near Raleigh (NC)
# compute only sun position and no output map
r.sunmask -s elev_lid792_1m year=2012 month=2 \
Modified: grass/branches/releasebranch_7_0/raster/r.surf.area/r.surf.area.html
--- grass/branches/releasebranch_7_0/raster/r.surf.area/r.surf.area.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.surf.area/r.surf.area.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -43,7 +43,7 @@
<h2>EXAMPLES</h2>
r.surf.area map=elevation units=hectares
Null value area ignored in calculation: 0.000000
Modified: grass/branches/releasebranch_7_0/raster/r.surf.contour/r.surf.contour.html
--- grass/branches/releasebranch_7_0/raster/r.surf.contour/r.surf.contour.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.surf.contour/r.surf.contour.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -71,7 +71,7 @@
sample data set):
# get minimum elevation value
r.univar elevation
Modified: grass/branches/releasebranch_7_0/raster/r.terraflow/r.terraflow.html
--- grass/branches/releasebranch_7_0/raster/r.terraflow/r.terraflow.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.terraflow/r.terraflow.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -151,7 +151,7 @@
Example for small area in NC dataset:
r.terraflow elevation=elev_lid792_1m filled=elev_lid792_1m_filled \
direction=elev_lid792_1m_direction swatershed=elev_lid792_1m_swatershed \
accumulation=elev_lid792_1m_accumulation tci=elev_lid792_1m_tci
@@ -175,14 +175,14 @@
Spearfish sample data set:
r.terraflow elev=elevation.10m filled=elevation10m.filled \
dir=elevation10m.mfdir swatershed=elevation10m.watershed \
accumulation=elevation10m.accu tci=elevation10m.tci
</pre></div>
accumulation=elevation10m.accu tci=elevation10m.tci d8cut=500 memory=800 \
Modified: grass/branches/releasebranch_7_0/raster/r.texture/r.texture.html
--- grass/branches/releasebranch_7_0/raster/r.texture/r.texture.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.texture/r.texture.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -103,7 +103,7 @@
Calculation of Angular Second Moment of B/W orthophoto (North Carolina data set):
-g.region rast=ortho_2001_t792_1m -p
+g.region raster=ortho_2001_t792_1m -p
# set grey level color table 0% black 100% white
r.colors ortho_2001_t792_1m color=grey
# extract grey levels
Modified: grass/branches/releasebranch_7_0/raster/r.thin/r.thin.html
--- grass/branches/releasebranch_7_0/raster/r.thin/r.thin.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.thin/r.thin.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -67,7 +67,7 @@
the 10m resolution DEM by <em>r.watershed</em>, run:
# create flow accumulation map
r.watershed elevation=elevation accumulation=accum_50K thresh=50000
# extract streams from flow accumulation map
Modified: grass/branches/releasebranch_7_0/raster/r.tile/r.tile.html
--- grass/branches/releasebranch_7_0/raster/r.tile/r.tile.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.tile/r.tile.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -17,7 +17,7 @@
Retiling example for the North Carolina DEM:
# rows: 1350
# cols: 1500
Modified: grass/branches/releasebranch_7_0/raster/r.to.rast3elev/r.to.rast3elev.html
--- grass/branches/releasebranch_7_0/raster/r.to.rast3elev/r.to.rast3elev.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.to.rast3elev/r.to.rast3elev.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -25,7 +25,7 @@
Simple Spearfish sample data set example
g.region res=200 res3=200 t=2000 b=0 tbres=20 -p
# Write the values of raster map soils based on the elevation of elevation.10m
Modified: grass/branches/releasebranch_7_0/raster/r.to.vect/r.to.vect.html
--- grass/branches/releasebranch_7_0/raster/r.to.vect/r.to.vect.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.to.vect/r.to.vect.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -66,7 +66,7 @@
<p>
Random sampling of points:
# random sampling of points (note that r.random also writes vector points)
r.random elevation raster_output=elevrand1000 n=1000
r.to.vect input=elevrand1000 output=elevrand1000 type=point
@@ -81,7 +81,7 @@
<p>
Vectorization of streams in watershed basins map:
r.watershed elev=elevation stream=elev.streams thresh=50000
r.to.vect -s input=elev.streams output=elev_streams type=line
# drop "label" column which is superfluous in this example
@@ -96,7 +96,7 @@
<p>
Vectorization of simplified landuse class map:
# we smooth corners of area features
r.to.vect -s input=landclass96 output=my_landclass96 type=area
v.colors my_landclass96 color=random
Modified: grass/branches/releasebranch_7_0/raster/r.univar/r.univar.html
--- grass/branches/releasebranch_7_0/raster/r.univar/r.univar.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.univar/r.univar.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -45,7 +45,7 @@
-g.region rast=basin -p
+g.region raster=basin -p
# check basin IDs
r.category basin
Modified: grass/branches/releasebranch_7_0/raster/r.viewshed/r.viewshed.html
--- grass/branches/releasebranch_7_0/raster/r.viewshed/r.viewshed.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.viewshed/r.viewshed.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -178,7 +178,7 @@
above ground:
r.viewshed input=elev_lid792_1m output=elev_lid792_1m_viewshed \
coordinates=638728.087167,220609.261501 observer_elevation=5.0
</pre></div>
@@ -202,7 +202,7 @@
of a mountain:
r.viewshed input=elevation.10m output=viewshed \
coordinates=598869,4916642 mem=800
</pre></div>
Modified: grass/branches/releasebranch_7_0/raster/r.volume/r.volume.html
--- grass/branches/releasebranch_7_0/raster/r.volume/r.volume.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.volume/r.volume.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -70,7 +70,7 @@
# compute volume
r.volume input=elevation clump=geology_30m
Modified: grass/branches/releasebranch_7_0/raster/r.water.outlet/r.water.outlet.html
--- grass/branches/releasebranch_7_0/raster/r.water.outlet/r.water.outlet.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.water.outlet/r.water.outlet.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -32,7 +32,7 @@
Carolina sample dataset</a> region:
# the watershed outlet position should be placed on a stream (from
# accumulation map):
r.watershed elev_lid792_1m thresh=5000 accum=accum_5K drain=draindir_5K output=basin_5K
Modified: grass/branches/releasebranch_7_0/raster/r.what/r.what.html
--- grass/branches/releasebranch_7_0/raster/r.what/r.what.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/raster/r.what/r.what.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -33,7 +33,7 @@
maximum input line length (e.g. 4096 characters).
-g.region rast=landuse96_28m,aspect -p
+g.region raster=landuse96_28m,aspect -p
r.what map=landuse96_28m,aspect coordinates=633614.08,224125.12,632972.36,225382.87 -f
633614.08|224125.12||2|Low Intensity Developed|209.5939|209 degrees ccw from east
@@ -48,7 +48,7 @@
each community college:
-g.region rast=boundary_county_500m -p
+g.region raster=boundary_county_500m -p
r.what map=boundary_county_500m points=comm_colleges
145096.859150|154534.264884||39
@@ -65,7 +65,7 @@
row. Example: query North Carolina county number for each community college:
r.what map=boundary_county_500m points=comm_colleges \
separator=comma output=result.csv -n
Modified: grass/branches/releasebranch_7_0/scripts/d.correlate/d.correlate.html
--- grass/branches/releasebranch_7_0/scripts/d.correlate/d.correlate.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/d.correlate/d.correlate.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -19,7 +19,7 @@
Scatterplot of two LANDSAT TM7 channels (North Carolina sample dataset):
<p><div class="code"><pre>
d.correlate map=lsat7_2002_30,lsat7_2002_40
</pre></div>
Modified: grass/branches/releasebranch_7_0/scripts/d.polar/d.polar.html
--- grass/branches/releasebranch_7_0/scripts/d.polar/d.polar.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/d.polar/d.polar.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -40,7 +40,7 @@
North Carolina sample dataset location is generated:
-g.region rast=aspect -p
+g.region raster=aspect -p
d.polar aspect
</pre></div>
Modified: grass/branches/releasebranch_7_0/scripts/d.shadedmap/d.shadedmap.html
--- grass/branches/releasebranch_7_0/scripts/d.shadedmap/d.shadedmap.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/d.shadedmap/d.shadedmap.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -18,7 +18,7 @@
dataset location is used to hillshade the <tt>elevation</tt> map:
d.shadedmap reliefmap=aspect drapemap=elevation
</pre></div>
@@ -27,7 +27,7 @@
raster map for later use:
r.colors -e map=elevation.10m color=haxby
r.shaded.relief elevation.10m
Modified: grass/branches/releasebranch_7_0/scripts/d.to.rast/d.to.rast.html
--- grass/branches/releasebranch_7_0/scripts/d.to.rast/d.to.rast.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/d.to.rast/d.to.rast.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -11,7 +11,7 @@
First, we add a couple of maps to layer manager:
d.rast map=lakes
d.vect map=roadsmajor width=4
Modified: grass/branches/releasebranch_7_0/scripts/d.vect.thematic/d.vect.thematic.html
--- grass/branches/releasebranch_7_0/scripts/d.vect.thematic/d.vect.thematic.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/d.vect.thematic/d.vect.thematic.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -66,7 +66,7 @@
# random sampling of elevation points:
v.random random npoints=200
v.db.addtable random column="el10 double precision"
# transfer elevations to attribute table of random points map:
@@ -89,7 +89,7 @@
North Carolina sample dataset example:
-g.region vect=nc_state
+g.region vector=nc_state
d.vect.thematic -l precip_30ynormals column=annual type=point
</pre></div>
Modified: grass/branches/releasebranch_7_0/scripts/db.univar/db.univar.html
--- grass/branches/releasebranch_7_0/scripts/db.univar/db.univar.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/db.univar/db.univar.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -17,7 +17,7 @@
(North Carolina sample dataset) and univariate statistics performed:
v.random output=samples n=100
v.db.addtable samples column="heights double precision"
v.what.rast samples raster=elevation colum=heights
Modified: grass/branches/releasebranch_7_0/scripts/i.colors.enhance/i.colors.enhance.html
--- grass/branches/releasebranch_7_0/scripts/i.colors.enhance/i.colors.enhance.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/i.colors.enhance/i.colors.enhance.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -34,7 +34,7 @@
North Carolina sample dataset example with Landsat data:
d.rgb blue=lsat7_2002_10 green=lsat7_2002_20 red=lsat7_2002_30
d.barscale at=55.3125,93.125 bcolor=white text_pos=over
Modified: grass/branches/releasebranch_7_0/scripts/i.oif/i.oif.html
--- grass/branches/releasebranch_7_0/scripts/i.oif/i.oif.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/i.oif/i.oif.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -54,7 +54,7 @@
i.oif input=lsat7_2002_10,lsat7_2002_20,lsat7_2002_30,lsat7_2002_40,lsat7_2002_50,lsat7_2002_70
</pre></div>
Modified: grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.html
--- grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -84,7 +84,7 @@
# R, G, B composite at 30m
-g.region rast=p034r032_7dt20010924_z13_10 -p
+g.region raster=p034r032_7dt20010924_z13_10 -p
d.rgb b=p034r032_7dt20010924_z13_10 g=lp034r032_7dt20010924_z13_20
r=p034r032_7dt20010924_z13_30
@@ -94,7 +94,7 @@
output=ihs321 method=ihs
# display at 15m
-g.region rast=ihs321_blue -p
+g.region raster=ihs321_blue -p
d.rgb b=ihs321_blue g=ihs321_green r=ihs321_red
</pre></div>
@@ -144,7 +144,7 @@
# original at 28m
d.mon wx0
d.rgb b=lsat7_2002_10 g=lsat7_2002_20 r=lsat7_2002_30
@@ -156,7 +156,7 @@
output=lsat7_2002_ihs
# display at 14.25m
-g.region rast=lsat7_2002_ihs_red -p
+g.region raster=lsat7_2002_ihs_red -p
d.erase
d.rgb r=lsat7_2002_ihs_red g=lsat7_2002_ihs_green b=lsat7_2002_ihs_blue
Modified: grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py
--- grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py 2014-12-19 21:55:37 UTC (rev 63629)
@@ -335,7 +335,7 @@
for ch in ['red', 'green', 'blue']:
grass.verbose(_("%s_%s") % (out, ch))
- grass.verbose(_("To visualize output, run: g.region -p rast=%s_red" % out))
+ grass.verbose(_("To visualize output, run: g.region -p raster=%s_red" % out))
grass.verbose(_("d.rgb r=%s_red g=%s_green b=%s_blue" % (out, out, out)))
grass.verbose(_("If desired, combine channels into a single RGB map with 'r.composite'."))
grass.verbose(_("Channel colors can be rebalanced using i.colors.enhance."))
Modified: grass/branches/releasebranch_7_0/scripts/i.spectral/i.spectral.html
--- grass/branches/releasebranch_7_0/scripts/i.spectral/i.spectral.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/i.spectral/i.spectral.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -13,7 +13,7 @@
Analysis of LANDSAT TM7 channels (North Carolina dataset):
i.spectral -g input=lsat7_2002_10,lsat7_2002_20,lsat7_2002_30,lsat7_2002_40,lsat7_2002_50,lsat7_2002_70 \
coordinates=636069,215440,637958,223393,633277,223605
</pre></div>
@@ -28,7 +28,7 @@
LIST=`g.list type=rast pattern="lsat7_2002_[1-5,7]0" separator=","`
i.spectral input=$LIST coordinates=637502.25,221744.25
</pre></div>
Modified: grass/branches/releasebranch_7_0/scripts/i.tasscap/i.tasscap.html
--- grass/branches/releasebranch_7_0/scripts/i.tasscap/i.tasscap.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/i.tasscap/i.tasscap.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -27,7 +27,7 @@
Calculation of TC maps from North Carolina Landsat 7 ETM scene:
i.tasscap sensor=landsat7_etm \
output=tasscap
Modified: grass/branches/releasebranch_7_0/scripts/r.blend/r.blend.html
--- grass/branches/releasebranch_7_0/scripts/r.blend/r.blend.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/r.blend/r.blend.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -10,7 +10,7 @@
r.blend first=aspect second=elevation output=elev_shade_blend
d.mon wx0
d.rgb blue=elev_shade_blend.b green=elev_shade_blend.g red=elev_shade_blend.r
Modified: grass/branches/releasebranch_7_0/scripts/r.colors.stddev/r.colors.stddev.html
--- grass/branches/releasebranch_7_0/scripts/r.colors.stddev/r.colors.stddev.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/r.colors.stddev/r.colors.stddev.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -17,7 +17,7 @@
North Carolina sample dataset location:
r.colors.stddev elevation
</pre></div>
Modified: grass/branches/releasebranch_7_0/scripts/r.fillnulls/r.fillnulls.html
--- grass/branches/releasebranch_7_0/scripts/r.fillnulls/r.fillnulls.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/r.fillnulls/r.fillnulls.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -66,7 +66,7 @@
d.mon wx0
# remove too low elevations (esp. lakes)
Modified: grass/branches/releasebranch_7_0/scripts/r.grow/r.grow.html
--- grass/branches/releasebranch_7_0/scripts/r.grow/r.grow.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/r.grow/r.grow.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -54,7 +54,7 @@
North Carolina sample dataset location is buffered:
r.grow input=lakes output=lakes_grown_50m radius=10
</pre></div>
Modified: grass/branches/releasebranch_7_0/scripts/r.mask/r.mask.html
--- grass/branches/releasebranch_7_0/scripts/r.mask/r.mask.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/r.mask/r.mask.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -62,7 +62,7 @@
univariate statistics of the elevation values for "lakes":
# set computation region to lakes raster map
# use lakes as MASK
r.mask raster=lakes
# get statistics for elevation pixels of lakes:
@@ -77,7 +77,7 @@
Creating a mask from selected categories in the North Carolina
'geology_30m' raster map:
-g.region rast=geology_30m -p
+g.region raster=geology_30m -p
r.category geology_30m
d.mon wx0
d.rast geology_30m
Modified: grass/branches/releasebranch_7_0/scripts/r.out.xyz/r.out.xyz.html
--- grass/branches/releasebranch_7_0/scripts/r.out.xyz/r.out.xyz.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/r.out.xyz/r.out.xyz.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -25,7 +25,7 @@
North Carolina sample dataset location is exported to CSV format.
r.out.xyz input=elev_lid792_1m output=elev_lid792_1m.csv separator=","
</pre></div>
@@ -36,7 +36,7 @@
<a href="http://grass.osgeo.org/sampledata/north_carolina/ortho2010_t792_subset_20cm.tif">color orthophoto</a>, here called "ortho2010_t792"):
-g.region rast=elev_lid792_1m res=1 -a -p
+g.region raster=elev_lid792_1m res=1 -a -p
r.out.xyz input=elev_lid792_1m,ortho2010_t792.red,ortho2010_t792.green,ortho2010_t792.blue \
separator=space output=pointcloud.asc
Modified: grass/branches/releasebranch_7_0/scripts/r.reclass.area/r.reclass.area.html
--- grass/branches/releasebranch_7_0/scripts/r.reclass.area/r.reclass.area.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/r.reclass.area/r.reclass.area.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -12,7 +12,7 @@
is filtered for large areas (removing smaller areas from the map):
-g.region rast=zipcodes -p
+g.region raster=zipcodes -p
r.report zipcodes unit=h
# extract only areas > 2000 ha, NULL otherwise:
r.reclass.area input=zipcodes output=zipcodes_larger2000ha greater=2000
Modified: grass/branches/releasebranch_7_0/scripts/r.rgb/r.rgb.html
--- grass/branches/releasebranch_7_0/scripts/r.rgb/r.rgb.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/r.rgb/r.rgb.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -6,7 +6,7 @@
<h2>EXAMPLE</h2>
r.rgb input=elevation
</pre></div>
Modified: grass/branches/releasebranch_7_0/scripts/v.db.droprow/v.db.droprow.html
--- grass/branches/releasebranch_7_0/scripts/v.db.droprow/v.db.droprow.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/v.db.droprow/v.db.droprow.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -16,7 +16,7 @@
Dropping all vector points without elevation attribute (North Carolina data set):<br>
v.random output=rand5k_elev n=5000
v.db.addtable map=rand5k_elev column="elevation double precision"
Modified: grass/branches/releasebranch_7_0/scripts/v.db.univar/v.db.univar.html
--- grass/branches/releasebranch_7_0/scripts/v.db.univar/v.db.univar.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/v.db.univar/v.db.univar.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -15,7 +15,7 @@
In this example, random points are sampled from the elevation map
Modified: grass/branches/releasebranch_7_0/scripts/v.db.update/v.db.update.html
--- grass/branches/releasebranch_7_0/scripts/v.db.update/v.db.update.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/v.db.update/v.db.update.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -26,7 +26,7 @@
v.db.select mylakes where="FTYPE IS NULL"
# display the lakes, show undefined FTYPE lakes in red
-g.region vect=mylakes
+g.region vector=mylakes
d.mon wx0
d.vect mylakes where="FTYPE NOT NULL" type=area col=blue
d.vect mylakes where="FTYPE IS NULL" type=area col=red
Modified: grass/branches/releasebranch_7_0/scripts/v.krige/v.krige.html
--- grass/branches/releasebranch_7_0/scripts/v.krige/v.krige.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/v.krige/v.krige.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -87,7 +87,7 @@
# reduce resolution for this example
-g.region rast=elevation -p res=100
+g.region raster=elevation -p res=100
v.random output=rand2k_elev n=2000
v.db.addtable map=rand2k_elev column="elevation double precision"
v.what.rast map=rand2k_elev rast=elevation column=elevation
Modified: grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.html
--- grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -40,7 +40,7 @@
g.copy vect=zipcodes_wake,myzipcodes_wake
# set computational region to DEM:
# calculate DEM statistics, upload to vector map table:
v.rast.stats myzipcodes_wake raster=elevation \
column_prefix=elev method=minimum,maximum,average,stddev,percentile \
Property changes on: grass/branches/releasebranch_7_0/temporal
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:62868,62873
/grass/trunk/temporal:59684,59915-59916,60017-60018,60024,60026,60173-60174,60213,60547-60548,60732-60733,60817,61031,61066,61071-61072,61083,61096,61141,61157-61158,61179-61180,61186,61191-61194,61215,61239-61243,61274-61275,61282-61288,61301,61429-61433,61455,61457,61732,61734,61759-61762,61806-61807,61848,61885,61955-61957,61983-61985,61997-62000,62016,62021-62022,62025,62111-62113,62120-62121,62179-62180,62182,62343,62361,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62594-62597,62603,62606,62608-62609,62613-62614,62616,62618,62625-62628,62631-62632,62635-62638,62640-62642,62644,62646-62649,62652,62654-62657,62666,62691,62703-62705,62709-62712,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62775,62785,62798,62800-62801,62803,62805,62812,62814-62815,62822,62824,62831,62838,62847,62856,62868,62871,62873,62875,62904,63035,63085,63087,63
089,63091,63093,63170,63327,63345,63391,63393,63554,63556,63590,63616
+ /grass/trunk:62868,62873
089,63091,63093,63170,63327,63345,63391,63393,63554,63556,63590,63616,63628
Modified: grass/branches/releasebranch_7_0/temporal/t.rast.accumulate/t.rast.accumulate.html
--- grass/branches/releasebranch_7_0/temporal/t.rast.accumulate/t.rast.accumulate.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/temporal/t.rast.accumulate/t.rast.accumulate.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -73,7 +73,7 @@
out=temperature_mean_1990_2000_daily_celsius extr=/tmp
# We need to set the region correctly
-g.region -p rast=`t.rast.list input=temperature_mean_1990_2000_daily_celsius column=name | tail -1`
+g.region -p raster=`t.rast.list input=temperature_mean_1990_2000_daily_celsius column=name | tail -1`
# We can zoom to the raster map
g.region -p zoom=`t.rast.list input=temperature_mean_1990_2000_daily_celsius column=name | tail -1`
Modified: grass/branches/releasebranch_7_0/vector/v.drape/spearfish.pov
--- grass/branches/releasebranch_7_0/vector/v.drape/spearfish.pov 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.drape/spearfish.pov 2014-12-19 21:55:37 UTC (rev 63629)
@@ -5,7 +5,7 @@
####### GRASS procedure:
#setup the region
-g.region vect=roads align=elevation.10m -p
+g.region vector=roads align=elevation.10m -p
#export the vector data
v.drape in=roads out=roads3d rast=elevation.10m
v.out.pov roads3d out=roads3d.pov
Modified: grass/branches/releasebranch_7_0/vector/v.label.sa/v.label.sa.html
--- grass/branches/releasebranch_7_0/vector/v.label.sa/v.label.sa.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.label.sa/v.label.sa.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -17,7 +17,7 @@
background=white size=250 font=Vera
# set region:
-g.region rast=lsat7_2002_10 -p
+g.region raster=lsat7_2002_10 -p
# display:
Modified: grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.create/v.lrs.create.html
--- grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.create/v.lrs.create.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.create/v.lrs.create.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -48,7 +48,7 @@
The result can be visualized:
-g.region vect=busroute n=n+100 s=s-100 w=w-100 e=e+100
+g.region vector=busroute n=n+100 s=s-100 w=w-100 e=e+100
d.mon x0
d.vect roads_net
d.vect busroute col=red width=2
Modified: grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.label/v.lrs.label.html
--- grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.label/v.lrs.label.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.label/v.lrs.label.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -11,7 +11,7 @@
v.lrs.label route_lrs rstable=route_lrs output=route_lrs_labels \
labels=labels col=red size=50 xoffset=100
-g.region vect=route_lrs n=n+100 s=s-100 -p
+g.region vector=route_lrs n=n+100 s=s-100 -p
d.erase
d.vect route_lrs
d.vect route_lrs_labels col=grey type=line
Modified: grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.segment/v.lrs.segment.html
--- grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.segment/v.lrs.segment.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.segment/v.lrs.segment.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -28,7 +28,7 @@
# new point on LRS
echo "P 7 22 4+180" | v.lrs.segment route_lrs out=route_lrs_new rstable=route_lrs
d.erase
# existing LRS
d.vect route_lrs
Modified: grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.where/v.lrs.where.html
--- grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.where/v.lrs.where.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.where/v.lrs.where.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -23,7 +23,7 @@
2|22|6.000000+188.112093
# verification
d.erase
d.vect route_lrs
d.vect busstops disp=attr attr=cat size=10 bg=white lcol=blue yref=bottom
Modified: grass/branches/releasebranch_7_0/vector/v.mkgrid/v.mkgrid.html
--- grass/branches/releasebranch_7_0/vector/v.mkgrid/v.mkgrid.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.mkgrid/v.mkgrid.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -80,7 +80,7 @@
based on the current region extent defined by the "elevation" map:
-g.region rast=elevation res=1000 -pa
+g.region raster=elevation res=1000 -pa
v.mkgrid type=point map=pointpattern
</pre></div>
<p>
@@ -93,7 +93,7 @@
# create first set of points, covering extent of "elevation" raster map
v.mkgrid type=point map=pointpattern1
# shift grid by half point distance (map units)
Modified: grass/branches/releasebranch_7_0/vector/v.neighbors/v.neighbors.html
--- grass/branches/releasebranch_7_0/vector/v.neighbors/v.neighbors.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.neighbors/v.neighbors.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -10,7 +10,7 @@
dataset):
-g.region vect=schools_wake res=100 -p -a
+g.region vector=schools_wake res=100 -p -a
v.neighbors input=schools_wake output=schools_wake_3000m method=count size=3000
d.mon wx0
Modified: grass/branches/releasebranch_7_0/vector/v.net.alloc/v.net.alloc.html
--- grass/branches/releasebranch_7_0/vector/v.net.alloc/v.net.alloc.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.net.alloc/v.net.alloc.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -60,7 +60,7 @@
# show result
-g.region vect=myroads_net
+g.region vector=myroads_net
d.mon x0
d.vect myroads_net layer=1
@@ -125,7 +125,7 @@
# show result
d.mon x0
d.vect myroads_net type=line layer=1
Modified: grass/branches/releasebranch_7_0/vector/v.net.path/v.net.path.html
--- grass/branches/releasebranch_7_0/vector/v.net.path/v.net.path.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.net.path/v.net.path.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -141,7 +141,7 @@
To display the result, run for example:
d.mon x0
d.vect myroads_net
# show shortest path
Modified: grass/branches/releasebranch_7_0/vector/v.net.salesman/v.net.salesman.html
--- grass/branches/releasebranch_7_0/vector/v.net.salesman/v.net.salesman.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.net.salesman/v.net.salesman.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -108,7 +108,7 @@
# Display the results
# shortest path
d.mon x0
Modified: grass/branches/releasebranch_7_0/vector/v.net.steiner/v.net.steiner.html
--- grass/branches/releasebranch_7_0/vector/v.net.steiner/v.net.steiner.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.net.steiner/v.net.steiner.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -90,7 +90,7 @@
# display the results
# shortest path
d.mon x0
Modified: grass/branches/releasebranch_7_0/vector/v.net.visibility/v.net.visibility.html
--- grass/branches/releasebranch_7_0/vector/v.net.visibility/v.net.visibility.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.net.visibility/v.net.visibility.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -62,7 +62,7 @@
A simple example (North Carolina sample data) showing how to use the module:
v.extract input=zipcodes_wake output=areas_7_11_25 cats=7,11,25
-g.region vect=zipcodes_wake
+g.region vector=zipcodes_wake
d.mon wx0
d.vect areas_7_11_25
v.net.visibility input=areas_7_11_25 output=graph
@@ -98,7 +98,7 @@
from it with the point 669547.97,208348.20 extra:
d.mon wx0
v.net.visibility input=zipcodes_wake output=graph
@@ -116,7 +116,7 @@
An example for connections of points (Spearfish):
v.net.visibility input=archsites output=graph
-g.region vect=archsites
+g.region vector=archsites
d.mon wx0
d.vect graph
d.vect archsites col=red
Modified: grass/branches/releasebranch_7_0/vector/v.normal/v.normal.html
--- grass/branches/releasebranch_7_0/vector/v.normal/v.normal.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.normal/v.normal.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -36,7 +36,7 @@
<em>random</em> vector points:
v.random random n=200
v.db.addtable random colum="elev double precision"
v.what.rast random rast=elevation column=elev
Modified: grass/branches/releasebranch_7_0/vector/v.overlay/v.overlay.html
--- grass/branches/releasebranch_7_0/vector/v.overlay/v.overlay.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.overlay/v.overlay.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -168,7 +168,7 @@
Using the North Carolina sample dataset, we clip the roads map to the area
of city of Raleigh, preserving road attributes in layer 1:
# extract Raleigh city:
v.extract in=zipcodes_wake out=raleigh \
Modified: grass/branches/releasebranch_7_0/vector/v.random/v.random.html
--- grass/branches/releasebranch_7_0/vector/v.random/v.random.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.random/v.random.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -32,7 +32,7 @@
<p>
Generate 20 random points with binary attribute (only 0 or 1):
-v.random output=binary_random n=20 zmin=0 zmax=1 column='binary INTEGER'
+v.random output=binary_random npoints=20 zmin=0 zmax=1 column='binary INTEGER'
</pre></div>
Generate 20 random 3d points with height attribute [0:20] and specific random seed:
@@ -42,32 +42,35 @@
Get 20 random samples from raster map:
-g.region -p rast=elevation
-v.random output=random_samples n=20
+v.random output=random_samples npoints=20
v.db.addtable map=random_samples layer=1 columns='cat INTEGER, sample DOUBLE PRECISION'
v.what.rast vector=random_samples raster=elevation at PERMANENT layer=1 column=sample
</pre></div>
Generate 20 random points and sample attribute data from geology (vector) map:
-g.region -p vect=geology
+g.region -p vector=geology
v.db.addtable map=random_samples layer=1 columns='cat integer, geology varchar(100)'
-v.what.vect vector=random_samples layer=1 column=geology qvector=geology at PERMANENT qlayer=1 qcolumn=label
+v.what.vect vector=random_samples layer=1 column=geology \
+ qvector=geology at PERMANENT qlayer=1 qcolumn=label
</pre></div>
Generate 20 random points in forested areas
-g.region -p rast=landclass96
+g.region -p raster=landclass96
r.to.vect -v input=landclass96 output=landclass96 type=area
-v.random input=landclass96 output=random_samples n=20 where="label = 'forest'"
+v.random input=landclass96 output=random_samples npoints=20 \
+ where="label = 'forest'"
</pre></div>
Generate 20 random points in each forest patch
-v.random input=landclass96 output=random_samples n=20 where="label = 'forest'" -a
+ where="label = 'forest'" -a
</pre></div>
Modified: grass/branches/releasebranch_7_0/vector/v.sample/v.sample.html
--- grass/branches/releasebranch_7_0/vector/v.sample/v.sample.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.sample/v.sample.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -34,7 +34,7 @@
# set computational region:
- g.region rast=elev_srtm_30m -p
+ g.region raster=elev_srtm_30m -p
# generate random points:
v.random output=random n=100
# add table with one column:
Modified: grass/branches/releasebranch_7_0/vector/v.surf.rst/v.surf.rst.html
--- grass/branches/releasebranch_7_0/vector/v.surf.rst/v.surf.rst.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.surf.rst/v.surf.rst.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -303,7 +303,7 @@
measures):
# random elevation extraction
r.random elevation.10m vector_output=elevrand n=200
v.info -c elevrand
Modified: grass/branches/releasebranch_7_0/vector/v.to.db/v.to.db.html
--- grass/branches/releasebranch_7_0/vector/v.to.db/v.to.db.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.to.db/v.to.db.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -97,7 +97,7 @@
v.db.addcolumn mysoils col="d double precision"
v.to.db mysoils option=fd column="d"
-g.region vect=mysoils res=50
+g.region vector=mysoils res=50
v.to.rast in=mysoils out=soils_fd type=area use=attr column=d
r.colors map=soils_fd color=gyr
Modified: grass/branches/releasebranch_7_0/vector/v.transform/v.transform.html
--- grass/branches/releasebranch_7_0/vector/v.transform/v.transform.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.transform/v.transform.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -63,7 +63,7 @@
v.db.addcolumn myarchsites col="zs double precision"
# set region to elevation map and fetch individual heights:
v.what.rast myarchsites rast=elevation.10m col=zs
# verify:
v.db.select myarchsites
Modified: grass/branches/releasebranch_7_0/vector/v.univar/v.univar.html
--- grass/branches/releasebranch_7_0/vector/v.univar/v.univar.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.univar/v.univar.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -26,7 +26,7 @@
The example is based on the North Carolina sample dataset:
v.random output=samples npoints=100
v.db.addtable map=samples columns="heights double precision"
v.what.rast map=samples rast=elevation column=heights
Modified: grass/branches/releasebranch_7_0/vector/v.voronoi/v.voronoi.html
--- grass/branches/releasebranch_7_0/vector/v.voronoi/v.voronoi.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.voronoi/v.voronoi.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -35,7 +35,7 @@
<h4>Voronoi diagram for points</h4>
This example uses the hospitals in the North Carolina dataset.
- g.region -p rast=elev_state_500m
+ g.region -p raster=elev_state_500m
v.voronoi in=hospitals out=hospitals_voronoi
</pre></div>
Modified: grass/branches/releasebranch_7_0/vector/v.what.rast/v.what.rast.html
--- grass/branches/releasebranch_7_0/vector/v.what.rast/v.what.rast.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.what.rast/v.what.rast.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -66,7 +66,7 @@
v.db.addtable pnts column="heights double precision"
# query raster map and upload values to vector table into specified column
v.what.rast map=pnts raster=elevation column=heights
# verify new attribute table:
Modified: grass/branches/releasebranch_7_0/vector/v.what.rast3/v.what.rast3.html
--- grass/branches/releasebranch_7_0/vector/v.what.rast3/v.what.rast3.html 2014-12-19 21:17:36 UTC (rev 63628)
+++ grass/branches/releasebranch_7_0/vector/v.what.rast3/v.what.rast3.html 2014-12-19 21:55:37 UTC (rev 63629)
@@ -25,13 +25,13 @@
<br>
# create new random 3d vector points map
-v.random -z output=pnts n=100 zmin=0 zmax=50
+v.random -z output=pnts npoints=100 zmin=0 zmax=50
# add new table, link to map
v.db.addtable map=pnts column="concentration double precision"
-g.region rast3d=plume -p
+g.region raster3d=plume -p
v.what.rast3 map=pnts raster3d=plume column=concentration
