[GRASS-SVN] r63630 - in grass/trunk: gui/wxpython/lmgr gui/wxpython/psmap raster/r.mapcalc/testsuite scripts/d.rast.edit scripts/i.in.spotvgt scripts/r.fillnulls scripts/r.mask scripts/v.rast.stats testsuite/raster
Fri Dec 19 14:17:15 PST 2014
Author: neteler
Date: 2014-12-19 14:17:15 -0800 (Fri, 19 Dec 2014)
New Revision: 63630
   grass/trunk/gui/wxpython/lmgr/datacatalog.py
   grass/trunk/gui/wxpython/psmap/dialogs.py
   grass/trunk/gui/wxpython/psmap/utils.py
   grass/trunk/raster/r.mapcalc/testsuite/const_map_test.sh
   grass/trunk/scripts/d.rast.edit/d.rast.edit.py
   grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
   grass/trunk/scripts/r.fillnulls/r.fillnulls.py
   grass/trunk/scripts/r.mask/r.mask.py
   grass/trunk/scripts/v.rast.stats/v.rast.stats.py
   grass/trunk/testsuite/raster/raster_md5test.sh
update g.region/g.rename calls to use new element names (#2409)
Modified: grass/trunk/gui/wxpython/lmgr/datacatalog.py
--- grass/trunk/gui/wxpython/lmgr/datacatalog.py	2014-12-19 21:55:37 UTC (rev 63629)
+++ grass/trunk/gui/wxpython/lmgr/datacatalog.py	2014-12-19 22:17:15 UTC (rev 63630)
@@ -352,11 +352,11 @@
             label = _("Renaming") + " " + string + " ..."
             self.showNotification.emit(message=label)
             if (self.GetItemText(self.selected_type)=='vector'):
-                renamed = RunCommand('g.rename', vect=string)
+                renamed = RunCommand('g.rename', vector=string)
             elif (self.GetItemText(self.selected_type)=='raster'):
-                renamed = RunCommand('g.rename', rast=string)
+                renamed = RunCommand('g.rename', raster=string)
             else:
-                renamed = RunCommand('g.rename', rast3d=string)
+                renamed = RunCommand('g.rename', raster3d=string)
             if (renamed==0):
                 self.SetItemText(self.selected_layer,self.new_name)
                 label = "g.rename "+self.GetItemText(self.selected_type)+"="+string+"   -- completed"
Modified: grass/trunk/gui/wxpython/psmap/dialogs.py
--- grass/trunk/gui/wxpython/psmap/dialogs.py	2014-12-19 21:55:37 UTC (rev 63629)
+++ grass/trunk/gui/wxpython/psmap/dialogs.py	2014-12-19 22:17:15 UTC (rev 63630)
@@ -1014,7 +1014,7 @@
                 mapFrameDict['center'] = self.center[0]
                 # set region
                 if self.mapType == 'raster':
-                    RunCommand('g.region', rast = mapFrameDict['map'])
+                    RunCommand('g.region', raster = mapFrameDict['map'])
                 if self.mapType == 'vector':
                     raster = self.instruction.FindInstructionByType('raster')
                     if raster:
@@ -1024,9 +1024,9 @@
                     if rasterId:
-                        RunCommand('g.region', vect = mapFrameDict['map'], rast = self.instruction[rasterId]['raster'])
+                        RunCommand('g.region', vector = mapFrameDict['map'], raster = self.instruction[rasterId]['raster'])
                     else:
-                        RunCommand('g.region', vect = mapFrameDict['map'])
+                        RunCommand('g.region', vector = mapFrameDict['map'])
Modified: grass/trunk/gui/wxpython/psmap/utils.py
--- grass/trunk/gui/wxpython/psmap/utils.py	2014-12-19 21:55:37 UTC (rev 63629)
+++ grass/trunk/gui/wxpython/psmap/utils.py	2014-12-19 22:17:15 UTC (rev 63630)
@@ -203,11 +203,11 @@
         res = ''
         if mapType == 'raster':
             try:
-                res = grass.read_command("g.region", flags = 'gu', rast = map)
+                res = grass.read_command("g.region", flags = 'gu', raster = map)
             except grass.ScriptError:
                 pass
         elif mapType == 'vector':
-            res = grass.read_command("g.region", flags = 'gu', vect = map)
+            res = grass.read_command("g.region", flags = 'gu', vector = map)
         currRegionDict = grass.parse_key_val(res, val_type = float)
     elif scaleType == 1 and region: # saved region
         res = grass.read_command("g.region", flags = 'gu', region = region)
Modified: grass/trunk/raster/r.mapcalc/testsuite/const_map_test.sh
--- grass/trunk/raster/r.mapcalc/testsuite/const_map_test.sh	2014-12-19 21:55:37 UTC (rev 63629)
+++ grass/trunk/raster/r.mapcalc/testsuite/const_map_test.sh	2014-12-19 22:17:15 UTC (rev 63630)
@@ -52,7 +52,7 @@
 if test -f $LOCATION/cell/MASK
 then
  echo "A user raster mask (MASK) is present. Saving it..."
- g.rename MASK,$USERMASK > /dev/null
+ g.rename raster=MASK,$USERMASK > /dev/null
 fi
 finalcleanup()
@@ -64,7 +64,7 @@
  if test -f $LOCATION/cell/$USERMASK ; then
   echo "Restoring user MASK"
   g.remove -f type=raster name=MASK > /dev/null
-  g.rename $USERMASK,MASK > /dev/null
+  g.rename raster=$USERMASK,MASK > /dev/null
  fi
@@ -112,7 +112,7 @@
 then
  check_exit_status $?
 fi
Modified: grass/trunk/scripts/d.rast.edit/d.rast.edit.py
--- grass/trunk/scripts/d.rast.edit/d.rast.edit.py	2014-12-19 21:55:37 UTC (rev 63629)
+++ grass/trunk/scripts/d.rast.edit/d.rast.edit.py	2014-12-19 22:17:15 UTC (rev 63630)
@@ -471,7 +471,7 @@
     def initialize(self):
 	grass.use_temp_region()
-	run('g.region', rast = self.inmap)
+	run('g.region', raster = self.inmap)
 	reg = grass.region()
 	for k, f in wind_keys.values():
@@ -526,7 +526,7 @@
 	outf.close()
 	p.wait()
 	run('r.patch', input = (self.tempmap, self.outmap), output = self.outmap, overwrite = True)
 	run('r.colors', map = self.outmap, rast = self.inmap)
 	run('g.remove', flags = 'f', type = 'rast', name = self.tempmap)
Modified: grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
--- grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py	2014-12-19 21:55:37 UTC (rev 63629)
+++ grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py	2014-12-19 22:17:15 UTC (rev 63630)
@@ -175,13 +175,13 @@
     # switch to a temporary region
-    grass.run_command('g.region', rast = name, quiet = True)
+    grass.run_command('g.region', raster = name, quiet = True)
     grass.message(_("Remapping digital numbers to NDVI..."))
     tmpname = "%s_%s" % (name, pid)
     grass.mapcalc("$tmpname = 0.004 * $name - 0.1", tmpname = tmpname, name = name)
-    grass.run_command('g.remove', flags = 'f', type = 'rast', name = name, quiet = True)
-    grass.run_command('g.rename', rast = (tmpname, name), quiet = True)
+    grass.run_command('g.remove', type = 'rast', name = name, quiet = True, flags = 'f')
+    grass.run_command('g.rename', raster = (tmpname, name), quiet = True)
     # write cmd history:
     grass.raster_history(name)
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2014-12-19 21:55:37 UTC (rev 63629)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2014-12-19 22:17:15 UTC (rev 63630)
@@ -106,7 +106,7 @@
         grass.run_command('g.remove', quiet = True, flags = 'fb', type = 'rast', name = tmp_rmaps)
     if usermask and mapset:
         if grass.find_file(usermask, mapset = mapset)['file']:
-            grass.run_command('g.rename', quiet = True, rast = (usermask, 'MASK'), overwrite = True)
+            grass.run_command('g.rename', quiet = True, raster = (usermask, 'MASK'), overwrite = True)
 def main():
     global usermask, mapset, tmp_rmaps, tmp_vmaps
@@ -139,7 +139,7 @@
     if grass.find_file('MASK', mapset = mapset)['file']:
         usermask = "usermask_mask." + unique
         grass.message(_("A user raster mask (MASK) is present. Saving it..."))
-        grass.run_command('g.rename', quiet = quiet, rast = ('MASK',usermask))
+        grass.run_command('g.rename', quiet = quiet, raster = ('MASK',usermask))
     #check if method is rst to use v.surf.rst
     if method == 'rst':
@@ -171,7 +171,7 @@
         if usermask:
             grass.message(_("Restoring user mask (MASK)..."))
             try:
-                grass.run_command('g.rename', quiet=quiet, rast=(usermask, 'MASK'))
+                grass.run_command('g.rename', quiet=quiet, raster = (usermask, 'MASK'))
             except CalledModuleError:
                 grass.warning(_("Failed to restore user MASK!"))
             usermask = None
@@ -242,7 +242,7 @@
             # zoom to specific hole with a buffer of two cells around the hole to remove rest of data
             try:
-                                  vect=holename + '_pol', align=input,
+                                  vector=holename + '_pol', align=input,
                                   w = 'w-%d' % (edge * 2 * ew_res),
                                   e = 'e+%d' % (edge * 2 * ew_res),
                                   n = 'n+%d' % (edge * 2 * ns_res),
@@ -333,18 +333,18 @@
             # append hole result to interpolated version later used to patch into original DEM
             if first:
                 tmp_rmaps.append(filling)
-                grass.run_command('g.region', align = input, rast = holename + '_dem', quiet = quiet)
+                grass.run_command('g.region', align = input, raster = holename + '_dem', quiet = quiet)
                 grass.mapcalc("$out = if(isnull($inp), null(), $dem)",
                                 out = filling, inp = holename, dem = holename + '_dem')
                 first = False
             else:
                 tmp_rmaps.append(filling + '_tmp')
-                grass.run_command('g.region', align = input, rast = (filling, holename + '_dem'), quiet = quiet)
+                grass.run_command('g.region', align = input, raster = (filling, holename + '_dem'), quiet = quiet)
                 grass.mapcalc("$out = if(isnull($inp), if(isnull($fill), null(), $fill), $dem)",
                                 out = filling + '_tmp', inp = holename, dem = holename + '_dem', fill = filling)
                 try:
-                                      rast=(filling + '_tmp', filling),
+                                      raster=(filling + '_tmp', filling),
                                       overwrite=True, quiet=quiet)
                     grass.fatal(_("abandoned. Removing temporary maps, restoring user mask if needed:"))
@@ -403,7 +403,7 @@
     if usermask:
         try:
+            grass.run_command('g.rename', quiet=quiet, raster=(usermask, 'MASK'))
         usermask = None
Modified: grass/trunk/scripts/r.mask/r.mask.py
--- grass/trunk/scripts/r.mask/r.mask.py	2014-12-19 21:55:37 UTC (rev 63629)
+++ grass/trunk/scripts/r.mask/r.mask.py	2014-12-19 22:17:15 UTC (rev 63630)
@@ -166,7 +166,7 @@
         if invert:
             global tmp
             tmp = "r_mask_%d" % os.getpid()
-            grass.run_command('g.rename', rast = ('MASK', tmp), quiet = True)
+            grass.run_command('g.rename', raster = ('MASK', tmp), quiet = True)
             grass.message(_("Creating inverted raster MASK..."))
             grass.mapcalc("MASK = if(isnull($tmp), 1, null())", tmp = tmp)
             grass.verbose(_("Inverted raster MASK created"))
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py	2014-12-19 21:55:37 UTC (rev 63629)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py	2014-12-19 22:17:15 UTC (rev 63630)
@@ -76,7 +76,7 @@
                       name='MASK', quiet=True, stderr=nuldev)
     if mask_found:
         grass.message(_("Restoring previous MASK..."))
-        grass.run_command('g.rename', rast=(tmpname + "_origmask", 'MASK'),
+        grass.run_command('g.rename', raster=(tmpname + "_origmask", 'MASK'),
                           quiet=True)
 #    for f in [tmp, tmpname, sqltmp]:
 #        grass.try_remove(f)
@@ -127,7 +127,7 @@
     mask_found = bool(grass.find_file('MASK', 'cell')['file'])
     if mask_found:
         grass.message(_("Raster MASK found, temporarily disabled"))
-        grass.run_command('g.rename', rast=('MASK', tmpname + "_origmask"),
+        grass.run_command('g.rename', raster=('MASK', tmpname + "_origmask"),
                           quiet=True)
     # save current settings:
Modified: grass/trunk/testsuite/raster/raster_md5test.sh
--- grass/trunk/testsuite/raster/raster_md5test.sh	2014-12-19 21:55:37 UTC (rev 63629)
+++ grass/trunk/testsuite/raster/raster_md5test.sh	2014-12-19 22:17:15 UTC (rev 63630)
@@ -57,7 +57,7 @@
 then
 fi
 finalcleanup()
@@ -69,7 +69,7 @@
  fi
