[GRASS-SVN] r63631 - in grass/branches/releasebranch_7_0: . gui/wxpython/psmap scripts/d.rast.edit scripts/i.in.spotvgt scripts/r.fillnulls scripts/r.mask scripts/v.rast.stats testsuite/raster
Fri Dec 19 14:19:21 PST 2014
Author: neteler
Date: 2014-12-19 14:19:21 -0800 (Fri, 19 Dec 2014)
New Revision: 63631
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/gui/wxpython/psmap/dialogs.py
   grass/branches/releasebranch_7_0/gui/wxpython/psmap/utils.py
   grass/branches/releasebranch_7_0/scripts/d.rast.edit/d.rast.edit.py
   grass/branches/releasebranch_7_0/scripts/i.in.spotvgt/i.in.spotvgt.py
   grass/branches/releasebranch_7_0/scripts/r.fillnulls/r.fillnulls.py
   grass/branches/releasebranch_7_0/scripts/r.mask/r.mask.py
   grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.py
   grass/branches/releasebranch_7_0/testsuite/raster/raster_md5test.sh
update g.region/g.rename calls to use new element names (#2409) (trunk, r63630)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,
 63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279,63281,63283,63287,63290,63292,63297,63302,63307,63315,63319,63327,63330,63332,63339,63342,63345,63362,63367,63391,63393,63408-63409,63416-63417,63425,63427,63429,63431,63433,63448,63451,63453,63457,63459,63464-63470,63473,63482,63497,63505,63508,63510,63515,63521-63524,63526,63536-63537,63551-63552,63554,63556,63558-63559,63562,63570,63576,63582,63589-63593,63602,63616,63624,63626,63628
   + /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,
 63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279,63281,63283,63287,63290,63292,63297,63302,63307,63315,63319,63327,63330,63332,63339,63342,63345,63362,63367,63391,63393,63408-63409,63416-63417,63425,63427,63429,63431,63433,63448,63451,63453,63457,63459,63464-63470,63473,63482,63497,63505,63508,63510,63515,63521-63524,63526,63536-63537,63551-63552,63554,63556,63558-63559,63562,63570,63576,63582,63589-63593,63602,63616,63624,63626,63628,63630
Modified: grass/branches/releasebranch_7_0/gui/wxpython/psmap/dialogs.py
--- grass/branches/releasebranch_7_0/gui/wxpython/psmap/dialogs.py	2014-12-19 22:17:15 UTC (rev 63630)
+++ grass/branches/releasebranch_7_0/gui/wxpython/psmap/dialogs.py	2014-12-19 22:19:21 UTC (rev 63631)
@@ -1014,7 +1014,7 @@
                 mapFrameDict['center'] = self.center[0]
                 # set region
                 if self.mapType == 'raster':
-                    RunCommand('g.region', rast = mapFrameDict['map'])
+                    RunCommand('g.region', raster = mapFrameDict['map'])
                 if self.mapType == 'vector':
                     raster = self.instruction.FindInstructionByType('raster')
                     if raster:
@@ -1024,9 +1024,9 @@
                     if rasterId:
-                        RunCommand('g.region', vect = mapFrameDict['map'], rast = self.instruction[rasterId]['raster'])
+                        RunCommand('g.region', vector = mapFrameDict['map'], raster = self.instruction[rasterId]['raster'])
                     else:
-                        RunCommand('g.region', vect = mapFrameDict['map'])
+                        RunCommand('g.region', vector = mapFrameDict['map'])
Modified: grass/branches/releasebranch_7_0/gui/wxpython/psmap/utils.py
--- grass/branches/releasebranch_7_0/gui/wxpython/psmap/utils.py	2014-12-19 22:17:15 UTC (rev 63630)
+++ grass/branches/releasebranch_7_0/gui/wxpython/psmap/utils.py	2014-12-19 22:19:21 UTC (rev 63631)
@@ -203,11 +203,11 @@
         res = ''
         if mapType == 'raster':
             try:
-                res = grass.read_command("g.region", flags = 'gu', rast = map)
+                res = grass.read_command("g.region", flags = 'gu', raster = map)
             except grass.ScriptError:
                 pass
         elif mapType == 'vector':
-            res = grass.read_command("g.region", flags = 'gu', vect = map)
+            res = grass.read_command("g.region", flags = 'gu', vector = map)
         currRegionDict = grass.parse_key_val(res, val_type = float)
     elif scaleType == 1 and region: # saved region
         res = grass.read_command("g.region", flags = 'gu', region = region)
Modified: grass/branches/releasebranch_7_0/scripts/d.rast.edit/d.rast.edit.py
--- grass/branches/releasebranch_7_0/scripts/d.rast.edit/d.rast.edit.py	2014-12-19 22:17:15 UTC (rev 63630)
+++ grass/branches/releasebranch_7_0/scripts/d.rast.edit/d.rast.edit.py	2014-12-19 22:19:21 UTC (rev 63631)
@@ -471,7 +471,7 @@
     def initialize(self):
 	grass.use_temp_region()
-	run('g.region', rast = self.inmap)
+	run('g.region', raster = self.inmap)
 	reg = grass.region()
 	for k, f in wind_keys.values():
@@ -526,7 +526,7 @@
 	outf.close()
 	p.wait()
 	run('r.patch', input = (self.tempmap, self.outmap), output = self.outmap, overwrite = True)
 	run('r.colors', map = self.outmap, rast = self.inmap)
 	run('g.remove', flags = 'f', type = 'rast', name = self.tempmap)
Modified: grass/branches/releasebranch_7_0/scripts/i.in.spotvgt/i.in.spotvgt.py
--- grass/branches/releasebranch_7_0/scripts/i.in.spotvgt/i.in.spotvgt.py	2014-12-19 22:17:15 UTC (rev 63630)
+++ grass/branches/releasebranch_7_0/scripts/i.in.spotvgt/i.in.spotvgt.py	2014-12-19 22:19:21 UTC (rev 63631)
@@ -175,13 +175,13 @@
     # switch to a temporary region
-    grass.run_command('g.region', rast = name, quiet = True)
+    grass.run_command('g.region', raster = name, quiet = True)
     grass.message(_("Remapping digital numbers to NDVI..."))
     tmpname = "%s_%s" % (name, pid)
     grass.mapcalc("$tmpname = 0.004 * $name - 0.1", tmpname = tmpname, name = name)
-    grass.run_command('g.remove', type='rast', name=name, quiet=True, flags='f')
-    grass.run_command('g.rename', rast = (tmpname, name), quiet = True)
+    grass.run_command('g.remove', type = 'rast', name = name, quiet = True, flags = 'f')
+    grass.run_command('g.rename', raster = (tmpname, name), quiet = True)
     # write cmd history:
     grass.raster_history(name)
Modified: grass/branches/releasebranch_7_0/scripts/r.fillnulls/r.fillnulls.py
--- grass/branches/releasebranch_7_0/scripts/r.fillnulls/r.fillnulls.py	2014-12-19 22:17:15 UTC (rev 63630)
+++ grass/branches/releasebranch_7_0/scripts/r.fillnulls/r.fillnulls.py	2014-12-19 22:19:21 UTC (rev 63631)
@@ -106,7 +106,7 @@
         grass.run_command('g.remove', quiet=True, flags='bf', type='rast', name=tmp_rmaps)
     if usermask and mapset:
         if grass.find_file(usermask, mapset = mapset)['file']:
-            grass.run_command('g.rename', quiet = True, rast = (usermask, 'MASK'), overwrite = True)
+            grass.run_command('g.rename', quiet = True, raster = (usermask, 'MASK'), overwrite = True)
 def main():
     global usermask, mapset, tmp_rmaps, tmp_vmaps
@@ -139,7 +139,7 @@
     if grass.find_file('MASK', mapset = mapset)['file']:
         usermask = "usermask_mask." + unique
         grass.message(_("A user raster mask (MASK) is present. Saving it..."))
-        grass.run_command('g.rename', quiet = quiet, rast = ('MASK',usermask))
+        grass.run_command('g.rename', quiet = quiet, raster = ('MASK',usermask))
     #check if method is rst to use v.surf.rst
     if method == 'rst':
@@ -171,7 +171,7 @@
         if usermask:
             grass.message(_("Restoring user mask (MASK)..."))
             try:
-                grass.run_command('g.rename', quiet=quiet, rast=(usermask, 'MASK'))
+                grass.run_command('g.rename', quiet=quiet, raster = (usermask, 'MASK'))
             except CalledModuleError:
                 grass.warning(_("Failed to restore user MASK!"))
             usermask = None
@@ -242,7 +242,7 @@
             # zoom to specific hole with a buffer of two cells around the hole to remove rest of data
             try:
-                                  vect=holename + '_pol', align=input,
+                                  vector=holename + '_pol', align=input,
                                   w = 'w-%d' % (edge * 2 * ew_res),
                                   e = 'e+%d' % (edge * 2 * ew_res),
                                   n = 'n+%d' % (edge * 2 * ns_res),
@@ -333,18 +333,18 @@
             # append hole result to interpolated version later used to patch into original DEM
             if first:
                 tmp_rmaps.append(filling)
-                grass.run_command('g.region', align = input, rast = holename + '_dem', quiet = quiet)
+                grass.run_command('g.region', align = input, raster = holename + '_dem', quiet = quiet)
                 grass.mapcalc("$out = if(isnull($inp), null(), $dem)",
                                 out = filling, inp = holename, dem = holename + '_dem')
                 first = False
             else:
                 tmp_rmaps.append(filling + '_tmp')
-                grass.run_command('g.region', align = input, rast = (filling, holename + '_dem'), quiet = quiet)
+                grass.run_command('g.region', align = input, raster = (filling, holename + '_dem'), quiet = quiet)
                 grass.mapcalc("$out = if(isnull($inp), if(isnull($fill), null(), $fill), $dem)",
                                 out = filling + '_tmp', inp = holename, dem = holename + '_dem', fill = filling)
                 try:
-                                      rast=(filling + '_tmp', filling),
+                                      raster=(filling + '_tmp', filling),
                                       overwrite=True, quiet=quiet)
                     grass.fatal(_("abandoned. Removing temporary maps, restoring user mask if needed:"))
@@ -403,7 +403,7 @@
     if usermask:
         try:
+            grass.run_command('g.rename', quiet=quiet, raster=(usermask, 'MASK'))
         usermask = None
Modified: grass/branches/releasebranch_7_0/scripts/r.mask/r.mask.py
--- grass/branches/releasebranch_7_0/scripts/r.mask/r.mask.py	2014-12-19 22:17:15 UTC (rev 63630)
+++ grass/branches/releasebranch_7_0/scripts/r.mask/r.mask.py	2014-12-19 22:19:21 UTC (rev 63631)
@@ -162,7 +162,7 @@
         if invert:
             global tmp
             tmp = "r_mask_%d" % os.getpid()
-            grass.run_command('g.rename', rast = ('MASK', tmp), quiet = True)
+            grass.run_command('g.rename', raster = ('MASK', tmp), quiet = True)
             grass.message(_("Creating inverted raster MASK..."))
             grass.mapcalc("MASK = if(isnull($tmp), 1, null())", tmp = tmp)
             grass.verbose(_("Inverted raster MASK created"))
Modified: grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.py
--- grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.py	2014-12-19 22:17:15 UTC (rev 63630)
+++ grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.py	2014-12-19 22:19:21 UTC (rev 63631)
@@ -74,7 +74,7 @@
     grass.run_command('g.remove', type='rast', name='MASK', quiet=True, flags='f', stderr=nuldev)
     if mask_found:
         grass.message(_("Restoring previous MASK..."))
-        grass.run_command('g.rename', rast=(tmpname + "_origmask", 'MASK'),
+        grass.run_command('g.rename', raster=(tmpname + "_origmask", 'MASK'),
                           quiet=True)
 #    for f in [tmp, tmpname, sqltmp]:
 #        grass.try_remove(f)
@@ -125,7 +125,7 @@
     mask_found = bool(grass.find_file('MASK', 'cell')['file'])
     if mask_found:
         grass.message(_("Raster MASK found, temporarily disabled"))
-        grass.run_command('g.rename', rast=('MASK', tmpname + "_origmask"),
+        grass.run_command('g.rename', raster=('MASK', tmpname + "_origmask"),
                           quiet=True)
     # save current settings:
Modified: grass/branches/releasebranch_7_0/testsuite/raster/raster_md5test.sh
--- grass/branches/releasebranch_7_0/testsuite/raster/raster_md5test.sh	2014-12-19 22:17:15 UTC (rev 63630)
+++ grass/branches/releasebranch_7_0/testsuite/raster/raster_md5test.sh	2014-12-19 22:19:21 UTC (rev 63631)
@@ -57,7 +57,7 @@
 if test -f $LOCATION/cell/MASK
 then
  echo "A user raster mask (MASK) is present. Saving it..."
- g.rename MASK,$USERMASK > /dev/null
+ g.rename raster=MASK,$USERMASK > /dev/null
 fi
 finalcleanup()
@@ -69,7 +69,7 @@
  if test -f $LOCATION/cell/$USERMASK ; then
   echo "Restoring user MASK"
   g.remove -f type=rast name=MASK > /dev/null
-  g.rename $USERMASK,MASK > /dev/null
+  g.rename raster=$USERMASK,MASK > /dev/null
  fi
