[GRASS-SVN] r63716 - in grass/branches/releasebranch_7_0: . lib/gis raster/r.sun
Wed Dec 24 03:27:05 PST 2014
Author: martinl
Date: 2014-12-24 03:27:05 -0800 (Wed, 24 Dec 2014)
New Revision: 63716
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/lib/gis/renamed_options
   grass/branches/releasebranch_7_0/raster/r.sun/main.c
   grass/branches/releasebranch_7_0/raster/r.sun/r.sun.html
r.sun: num_partitions -> npartitions (#2409)
       (merge r63715 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62190,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750-62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62828,62831,62838,62845,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,
 63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63275-63276,63279,63281,63283,63287,63290,63292,63297,63302,63304-63307,63315,63319,63327,63330,63332,63339,63342,63345,63362,63367,63379,63389,63391,63393,63402,63408-63409,63416-63417,63425,63427,63429,63431,63433,63448,63451,63453,63457,63459,63464-63470,63473,63482,63497,63505,63508,63510,63515,63521-63524,63526,63536-63537,63551-63552,63554,63556,63558-63559,63562,63570,63576,63582,63589-63593,63602,63604,63608-63609,63616,63618,63624,63626,63628,63630,63634,63639,63642,63644,63650,63652,63656,63679,63685,63689,63691,63693,63695,63698,63700-63702,63704,63706-63707,63709,63711,63713
   + /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62190,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750-62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62828,62831,62838,62845,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,
 63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63275-63276,63279,63281,63283,63287,63290,63292,63297,63302,63304-63307,63315,63319,63327,63330,63332,63339,63342,63345,63362,63367,63379,63389,63391,63393,63402,63408-63409,63416-63417,63425,63427,63429,63431,63433,63448,63451,63453,63457,63459,63464-63470,63473,63482,63497,63505,63508,63510,63515,63521-63524,63526,63536-63537,63551-63552,63554,63556,63558-63559,63562,63570,63576,63582,63589-63593,63602,63604,63608-63609,63616,63618,63624,63626,63628,63630,63634,63639,63642,63644,63650,63652,63656,63679,63685,63689,63691,63693,63695,63698,63700-63702,63704,63706-63707,63709,63711,63713,63715
Modified: grass/branches/releasebranch_7_0/lib/gis/renamed_options
--- grass/branches/releasebranch_7_0/lib/gis/renamed_options	2014-12-24 11:24:51 UTC (rev 63715)
+++ grass/branches/releasebranch_7_0/lib/gis/renamed_options	2014-12-24 11:27:05 UTC (rev 63716)
@@ -281,7 +281,7 @@
 r.sun|horizonstep:horizon_step
 r.sun|declin:declination
 r.sun|dist:distance_step
-r.sun|numpartitions:num_partitions
+r.sun|numpartitions:npartitions
 r.sun|civiltime:civil_time
 # r.surf.area
 r.surf.area|input:map
Modified: grass/branches/releasebranch_7_0/raster/r.sun/main.c
--- grass/branches/releasebranch_7_0/raster/r.sun/main.c	2014-12-24 11:24:51 UTC (rev 63715)
+++ grass/branches/releasebranch_7_0/raster/r.sun/main.c	2014-12-24 11:27:05 UTC (rev 63716)
@@ -492,7 +492,7 @@
 	_("Sampling distance step coefficient (0.5-1.5)");
     parm.numPartitions = G_define_option();
-    parm.numPartitions->key = "num_partitions";
+    parm.numPartitions->key = "npartitions";
     parm.numPartitions->type = TYPE_INTEGER;
     parm.numPartitions->answer = NUM_PARTITIONS;
     parm.numPartitions->required = NO;
Modified: grass/branches/releasebranch_7_0/raster/r.sun/r.sun.html
--- grass/branches/releasebranch_7_0/raster/r.sun/r.sun.html	2014-12-24 11:24:51 UTC (rev 63715)
+++ grass/branches/releasebranch_7_0/raster/r.sun/r.sun.html	2014-12-24 11:27:05 UTC (rev 63716)
@@ -230,11 +230,11 @@
 With a large number or columns and rows, <b>r.sun</b> can consume
 significant amount of memory. While output raster maps are not
-partitionable, the input raster maps are using the <em>num_partitions</em>
+partitionable, the input raster maps are using the <em>npartitions</em>
 parameter.
 In case of out of memory error (<tt>ERROR: G_malloc: out of memory</tt>), the
-<em>num_partitions</em> parameter can be used to run a segmented calculation
+<em>npartitions</em> parameter can be used to run a segmented calculation
 which consumes less memory during the computations.
 The amount of memory by <b>r.sun</b> is estimated as follows:
@@ -248,7 +248,7 @@
 memory_bytes = rows*cols*(IR*4 + horizon_steps + OR*4)
 # with input raster map partitioning:
-memory_bytes = rows*cols*((IR*4+horizon_steps)/num_partitions  + OR*4)
+memory_bytes = rows*cols*((IR*4+horizon_steps)/npartitions  + OR*4)
 </pre></div>
 <h2>EXAMPLES</h2>
