[GRASS-SVN] r63717 - in grass/trunk/vector: v.net v.net.alloc v.net.allpairs v.net.bridge v.net.centrality v.net.components v.net.connectivity v.net.distance v.net.flow v.net.iso v.net.path v.net.salesman v.net.spanningtree v.net.steiner v.net.timetable v.overlay v.select
svn_grass at osgeo.org
Wed Dec 24 04:19:38 PST 2014
Author: martinl
Date: 2014-12-24 04:19:38 -0800 (Wed, 24 Dec 2014)
New Revision: 63717
grass/trunk/vector/v.net.alloc/main.c
grass/trunk/vector/v.net.alloc/v.net.alloc.html
grass/trunk/vector/v.net.allpairs/main.c
grass/trunk/vector/v.net.allpairs/v.net.allpairs.html
grass/trunk/vector/v.net.bridge/main.c
grass/trunk/vector/v.net.centrality/main.c
grass/trunk/vector/v.net.components/main.c
grass/trunk/vector/v.net.connectivity/main.c
grass/trunk/vector/v.net.distance/main.c
grass/trunk/vector/v.net.distance/v.net.distance.html
grass/trunk/vector/v.net.flow/main.c
grass/trunk/vector/v.net.iso/main.c
grass/trunk/vector/v.net.iso/v.net.iso.html
grass/trunk/vector/v.net.path/main.c
grass/trunk/vector/v.net.path/v.net.path.html
grass/trunk/vector/v.net.salesman/main.c
grass/trunk/vector/v.net.salesman/v.net.salesman.html
grass/trunk/vector/v.net.spanningtree/main.c
grass/trunk/vector/v.net.steiner/main.c
grass/trunk/vector/v.net.steiner/v.net.steiner.html
grass/trunk/vector/v.net.timetable/main.c
grass/trunk/vector/v.net/args.c
grass/trunk/vector/v.net/v.net.html
grass/trunk/vector/v.overlay/main.c
grass/trunk/vector/v.overlay/v.overlay.html
grass/trunk/vector/v.select/args.c
v.net modules: alayer -> arc_layer and nlayer -> node_layer (#2409)
Modified: grass/trunk/vector/v.net/args.c
--- grass/trunk/vector/v.net/args.c 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net/args.c 2014-12-24 12:19:38 UTC (rev 63717)
@@ -51,13 +51,13 @@
opt->action->descriptions = desc;
opt->afield_opt = G_define_standard_option(G_OPT_V_FIELD);
- opt->afield_opt->key = "alayer";
+ opt->afield_opt->key = "arc_layer";
opt->afield_opt->gisprompt = "new,layer,layer";
opt->afield_opt->label = _("Arc layer");
opt->afield_opt->guisection = _("Arcs");
opt->nfield_opt = G_define_standard_option(G_OPT_V_FIELD);
- opt->nfield_opt->key = "nlayer";
+ opt->nfield_opt->key = "node_layer";
opt->nfield_opt->answer = "2";
opt->nfield_opt->gisprompt = "new,layer,layer";
opt->nfield_opt->label = _("Node layer");
@@ -107,7 +107,7 @@
opt->tucfield->label = _("Layer with unique categories used in turntable");
opt->tucfield->description =
_
- ("Layer with unique categories for every line in alayer and point on every node. "
+ ("Layer with unique categories for every line in arc_layer and point on every node. "
" The categories are used in turntable. Format: layer number[/layer name]. "
"Required for operation 'turntable'.");
opt->tucfield->answer = "4";
Modified: grass/trunk/vector/v.net/v.net.html
--- grass/trunk/vector/v.net/v.net.html 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net/v.net.html 2014-12-24 12:19:38 UTC (rev 63717)
@@ -81,7 +81,7 @@
<p>
The <em>turntable</em> operation creates a turntable
with the costs for every possible
-turn on every possible node (intersection, crossroad) in given layer (alayer).
+turn on every possible node (intersection, crossroad) in given layer (arc_layer).
U-turns are taken in account too.
Turntable is created in <b>tlayer</b> and <b>tuclayer</b>.
Building the turntable allows you to model e.g. trafic code, where some turns
@@ -89,7 +89,7 @@
If features in analyzed network are changed, the turntable must be created again
(e.g. it includes v.net connect operation).
Turntable name consists of output vector map name + "_turntable_" + "t" + "_" + tlayer +
- "_" + "tuc" + "_" + tuclayer + "_" + "a" + "_" + alayer e. g. roads_turntable_t_3_tuc_4_a_1
+ "_" + "tuc" + "_" + tuclayer + "_" + "a" + "_" + arc_layer e. g. roads_turntable_t_3_tuc_4_a_1
<p>These modules are able to work with the turntable:
<em><a href="v.net.alloc.html">v.net.alloc</a></em>,
Modified: grass/trunk/vector/v.net.alloc/main.c
--- grass/trunk/vector/v.net.alloc/main.c 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.alloc/main.c 2014-12-24 12:19:38 UTC (rev 63717)
@@ -83,7 +83,7 @@
"layer for this categories is given by nlayer option");
- afield_opt->key = "alayer";
+ afield_opt->key = "arc_layer";
afield_opt->answer = "1";
afield_opt->required = YES;
@@ -95,7 +95,7 @@
type_opt->label = _("Arc type");
- nfield_opt->key = "nlayer";
+ nfield_opt->key = "node_layer";
nfield_opt->required = YES;
Modified: grass/trunk/vector/v.net.alloc/v.net.alloc.html
--- grass/trunk/vector/v.net.alloc/v.net.alloc.html 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.alloc/v.net.alloc.html 2014-12-24 12:19:38 UTC (rev 63717)
@@ -63,7 +63,7 @@
v.net myroads points=centernodes out=myroads_net op=connect thresh=200
# allocate, specifying range of center cats (easier to catch all):
-v.net.alloc myroads_net out=myroads_net_alloc ccats=1-100000 nlayer=2
+v.net.alloc myroads_net out=myroads_net_alloc ccats=1-100000 node_layer=2
# report categories
v.category myroads_net_alloc option=report
@@ -99,7 +99,7 @@
g.copy vect=roads,myroads
# create lines map connecting points to network
-v.net myroads points=centernodes out=myroads_net op=connect thresh=500 alayer=1 nlayer=2
+v.net myroads points=centernodes out=myroads_net op=connect thresh=500 arc_layer=1 node_layer=2
# set up costs
@@ -131,7 +131,7 @@
v.db.update myroads_net_time layer=3 col=bcost val="length / speed * 60"
# subnetwork allocation with fastest paths
-v.net.alloc in=myroads_net_time alayer=3 nlayer=2 afcol=cost abcol=bcost out=myroads_net_alloc_time ccats=1-3
+v.net.alloc in=myroads_net_time arc_layer=3 node_layer=2 afcol=cost abcol=bcost out=myroads_net_alloc_time ccats=1-3
</pre></div>
To display the result, run for example:
Modified: grass/trunk/vector/v.net.allpairs/main.c
--- grass/trunk/vector/v.net.allpairs/main.c 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.allpairs/main.c 2014-12-24 12:19:38 UTC (rev 63717)
@@ -69,13 +69,13 @@
map_out = G_define_standard_option(G_OPT_V_OUTPUT);
afield_opt->guisection = _("Selection");
nfield_opt->guisection = _("Selection");
Modified: grass/trunk/vector/v.net.allpairs/v.net.allpairs.html
--- grass/trunk/vector/v.net.allpairs/v.net.allpairs.html 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.allpairs/v.net.allpairs.html 2014-12-24 12:19:38 UTC (rev 63717)
@@ -6,7 +6,7 @@
<h2>NOTES</h2>
-An attribute table is created and linked to layer <em>alayer</em>. The
+An attribute table is created and linked to layer <em>arc_layer</em>. The
table contains four columns: <em>cat</em>, <em>from_cat</em>,
<em>to_cat</em>, <em>cost</em>.
Each <em>cat</em> entry denotes the category of the shortest path from
Modified: grass/trunk/vector/v.net.bridge/main.c
--- grass/trunk/vector/v.net.bridge/main.c 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.bridge/main.c 2014-12-24 12:19:38 UTC (rev 63717)
@@ -55,13 +55,13 @@
afield_opt->guisection = _("Cost");
nfield_opt->guisection = _("Cost");
Modified: grass/trunk/vector/v.net.centrality/main.c
--- grass/trunk/vector/v.net.centrality/main.c 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.centrality/main.c 2014-12-24 12:19:38 UTC (rev 63717)
@@ -104,13 +104,13 @@
map_in = G_define_standard_option(G_OPT_V_INPUT);
Modified: grass/trunk/vector/v.net.components/main.c
--- grass/trunk/vector/v.net.components/main.c 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.components/main.c 2014-12-24 12:19:38 UTC (rev 63717)
@@ -78,13 +78,13 @@
Modified: grass/trunk/vector/v.net.connectivity/main.c
--- grass/trunk/vector/v.net.connectivity/main.c 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.connectivity/main.c 2014-12-24 12:19:38 UTC (rev 63717)
@@ -59,13 +59,13 @@
Modified: grass/trunk/vector/v.net.distance/main.c
--- grass/trunk/vector/v.net.distance/main.c 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.distance/main.c 2014-12-24 12:19:38 UTC (rev 63717)
@@ -75,7 +75,7 @@
@@ -87,7 +87,7 @@
atype_opt->guisection = _("Cost");
Modified: grass/trunk/vector/v.net.distance/v.net.distance.html
--- grass/trunk/vector/v.net.distance/v.net.distance.html 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.distance/v.net.distance.html 2014-12-24 12:19:38 UTC (rev 63717)
@@ -48,10 +48,10 @@
<p><div class="code"><pre>
# connect schools to streets as layer 2
-v.net input=streets_wake points=schools_wake output=streets_net1 operation=connect thresh=400 alayer=1 nlayer=2
+v.net input=streets_wake points=schools_wake output=streets_net1 operation=connect thresh=400 arc_layer=1 node_layer=2
# connect hospitals to streets as layer 3
-v.net input=streets_net1 points=hospitals output=streets_net2 operation=connect thresh=400 alayer=1 nlayer=3
+v.net input=streets_net1 points=hospitals output=streets_net2 operation=connect thresh=400 arc_layer=1 node_layer=3
# inspect the result
v.category in=streets_net2 op=report
Modified: grass/trunk/vector/v.net.flow/main.c
--- grass/trunk/vector/v.net.flow/main.c 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.flow/main.c 2014-12-24 12:19:38 UTC (rev 63717)
@@ -65,13 +65,13 @@
Modified: grass/trunk/vector/v.net.iso/main.c
--- grass/trunk/vector/v.net.iso/main.c 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.iso/main.c 2014-12-24 12:19:38 UTC (rev 63717)
@@ -98,7 +98,7 @@
cost_opt->description = _("Costs for isolines");
@@ -110,7 +110,7 @@
Modified: grass/trunk/vector/v.net.iso/v.net.iso.html
--- grass/trunk/vector/v.net.iso/v.net.iso.html 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.iso/v.net.iso.html 2014-12-24 12:19:38 UTC (rev 63717)
@@ -135,7 +135,7 @@
# define iso networks using traveling time:
-v.net.iso input=myroads_net_time output=myroads_net_iso_time alayer=3 nlayer=2 afcol=cost abcol=bcost ccats=1-100000 costs=1,2,5
+v.net.iso input=myroads_net_time output=myroads_net_iso_time arc_layer=3 node_layer=2 afcol=cost abcol=bcost ccats=1-100000 costs=1,2,5
</pre></div>
Modified: grass/trunk/vector/v.net.path/main.c
--- grass/trunk/vector/v.net.path/main.c 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.path/main.c 2014-12-24 12:19:38 UTC (rev 63717)
@@ -48,7 +48,7 @@
output_opt = G_define_standard_option(G_OPT_V_OUTPUT);
@@ -60,7 +60,7 @@
Modified: grass/trunk/vector/v.net.path/v.net.path.html
--- grass/trunk/vector/v.net.path/v.net.path.html 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.path/v.net.path.html 2014-12-24 12:19:38 UTC (rev 63717)
@@ -114,7 +114,7 @@
-v.net myroads points=startend out=myroads_net op=connect thresh=500 alayer=1 nlayer=2
+v.net myroads points=startend out=myroads_net op=connect thresh=500 arc_layer=1 node_layer=2
# set up costs
@@ -148,10 +148,10 @@
# ... the 'start' and 'end' nodes have category number 1 and 2
# Shortest path: ID as first number, then cat1 and cat2
-echo "1 1 2" | v.net.path myroads_net_time alayer=3 nlayer=2 out=mypath
+echo "1 1 2" | v.net.path myroads_net_time arc_layer=3 node_layer=2 out=mypath
# Fastest path: ID as first number, then cat1 and cat2
-echo "1 1 2" | v.net.path myroads_net_time alayer=3 nlayer=2 afcol=cost abcol=bcost out=mypath_time
+echo "1 1 2" | v.net.path myroads_net_time arc_layer=3 node_layer=2 afcol=cost abcol=bcost out=mypath_time
</pre></div>
Modified: grass/trunk/vector/v.net.salesman/main.c
--- grass/trunk/vector/v.net.salesman/main.c 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.salesman/main.c 2014-12-24 12:19:38 UTC (rev 63717)
@@ -143,7 +143,7 @@
"(layer is specified by nlayer)");
@@ -155,7 +155,7 @@
nfield_opt->label = _("Node layer (used for cities)");
Modified: grass/trunk/vector/v.net.salesman/v.net.salesman.html
--- grass/trunk/vector/v.net.salesman/v.net.salesman.html 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.salesman/v.net.salesman.html 2014-12-24 12:19:38 UTC (rev 63717)
@@ -115,7 +115,7 @@
# find the fastest path
-v.net.salesman myroads_net_time alayer=3 nlayer=2 afcol=cost abcol=bcost ccats=1-6 out=mysalesman_time
+v.net.salesman myroads_net_time arc_layer=3 node_layer=2 afcol=cost abcol=bcost ccats=1-6 out=mysalesman_time
</pre></div>
Modified: grass/trunk/vector/v.net.spanningtree/main.c
--- grass/trunk/vector/v.net.spanningtree/main.c 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.spanningtree/main.c 2014-12-24 12:19:38 UTC (rev 63717)
@@ -54,13 +54,13 @@
Modified: grass/trunk/vector/v.net.steiner/main.c
--- grass/trunk/vector/v.net.steiner/main.c 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.steiner/main.c 2014-12-24 12:19:38 UTC (rev 63717)
@@ -361,12 +361,12 @@
tfield_opt = G_define_standard_option(G_OPT_V_FIELD);
- tfield_opt->key = "nlayer";
+ tfield_opt->key = "node_layer";
tfield_opt->answer = "2";
tfield_opt->label = _("Node layer (used for terminals)");
Modified: grass/trunk/vector/v.net.steiner/v.net.steiner.html
--- grass/trunk/vector/v.net.steiner/v.net.steiner.html 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.steiner/v.net.steiner.html 2014-12-24 12:19:38 UTC (rev 63717)
@@ -80,10 +80,10 @@
v.db.update myroads_net_time layer=3 col=cost val="length / speed * 60"
# shortest path
-v.net.steiner myroads_net_time alayer=3 nlayer=2 tcats=1-6 out=mysteiner_distance
+v.net.steiner myroads_net_time arc_layer=3 node_layer=2 tcats=1-6 out=mysteiner_distance
# fastest path
-v.net.steiner myroads_net_time alayer=3 nlayer=2 acol=cost tcats=1-6 out=mysteiner_time
+v.net.steiner myroads_net_time arc_layer=3 node_layer=2 acol=cost tcats=1-6 out=mysteiner_time
</pre></div>
Modified: grass/trunk/vector/v.net.timetable/main.c
--- grass/trunk/vector/v.net.timetable/main.c 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.net.timetable/main.c 2014-12-24 12:19:38 UTC (rev 63717)
@@ -269,13 +269,13 @@
Modified: grass/trunk/vector/v.overlay/main.c
--- grass/trunk/vector/v.overlay/main.c 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.overlay/main.c 2014-12-24 12:19:38 UTC (rev 63717)
@@ -70,7 +70,7 @@
field_opt[0] = G_define_standard_option(G_OPT_V_FIELD);
field_opt[0]->label = _("Layer number or name (vector map A)");
- field_opt[0]->key = "alayer";
+ field_opt[0]->key = "arc_layer";
type_opt[0] = G_define_standard_option(G_OPT_V_TYPE);
type_opt[0]->label = _("Feature type (vector map A)");
Modified: grass/trunk/vector/v.overlay/v.overlay.html
--- grass/trunk/vector/v.overlay/v.overlay.html 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.overlay/v.overlay.html 2014-12-24 12:19:38 UTC (rev 63717)
@@ -37,7 +37,7 @@
<em>b_</em>) corresponding to <b>ainput</b> and <b>binput</b> map.
<p>
If the <i>second</i> number of the <b>olayer</b> option is greater than 0, then the
-categories of <b>ainput</b> in layer <b>alayer</b> are transferred to
+categories of <b>ainput</b> in layer <b>arc_layer</b> are transferred to
the output layer with the second number.
<p>
If the <i>third</i> number of the <b>olayer</b> option is greater than 0, then the
Modified: grass/trunk/vector/v.select/args.c
--- grass/trunk/vector/v.select/args.c 2014-12-24 11:27:05 UTC (rev 63716)
+++ grass/trunk/vector/v.select/args.c 2014-12-24 12:19:38 UTC (rev 63717)
@@ -14,7 +14,7 @@
parm->field[0] = G_define_standard_option(G_OPT_V_FIELD);
parm->field[0]->label = _("Layer number (vector map A)");
- parm->field[0]->key = "alayer";
+ parm->field[0]->key = "arc_layer";
parm->field[0]->guisection = _("Selection");
parm->type[0] = G_define_standard_option(G_OPT_V_TYPE);
