[GRASS-SVN] r63732 - in grass/branches/releasebranch_7_0: . vector/v.net.path
svn_grass at osgeo.org
Wed Dec 24 06:53:17 PST 2014
Author: martinl
Date: 2014-12-24 06:53:17 -0800 (Wed, 24 Dec 2014)
New Revision: 63732
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/vector/v.net.path/v.net.path.html
update v.net.path manual (syntax issues)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62190,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750-62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62828,62831,62838,62845,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,
63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63275-63276,63279,63281,63283,63287,63290,63292,63297,63302,63304-63307,63315,63319,63327,63330,63332,63339,63342,63345,63362,63367,63379,63389,63391,63393,63402,63408-63409,63416-63417,63425,63427,63429,63431,63433,63448,63451,63453,63457,63459,63464-63470,63473,63482,63497,63505,63508,63510,63515,63521-63524,63526,63536-63537,63551-63552,63554,63556,63558-63559,63562,63570,63576,63582,63589-63593,63602,63604,63608-63609,63616,63618,63624,63626,63628,63630,63634,63639,63642,63644,63650,63652,63656,63679,63685,63689,63691,63693,63695,63698,63700-63702,63704,63706-63707,63709,63711,63713,63715,63717-63718,63721
-63727
+ /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62190,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750-62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62828,62831,62838,62845,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,
-63727,63731
Modified: grass/branches/releasebranch_7_0/vector/v.net.path/v.net.path.html
--- grass/branches/releasebranch_7_0/vector/v.net.path/v.net.path.html 2014-12-24 14:51:58 UTC (rev 63731)
+++ grass/branches/releasebranch_7_0/vector/v.net.path/v.net.path.html 2014-12-24 14:53:17 UTC (rev 63732)
@@ -9,9 +9,9 @@
as costs to traverse a length unit (e.g. meter) of the segment.
For example, if the speed limit is 100 km / h, the cost to traverse a
10 km long road segment must be calculated as
-<br>
+<div class="code"><pre>
length / speed = 10 km / (100 km/h) = 0.1 h.
-<br>
+</pre></div>
Supported are cost assignments for both arcs and nodes,
and also different costs for both directions of a vector line.
For areas, costs will be calculated along boundary lines.
@@ -19,7 +19,7 @@
The input vector needs to be prepared with <tt>v.net operation=connect</tt>
in order to connect points representing center nodes to the network.
-<p>Nodes and arcs can be closed using cost = -1.
+<p>Nodes and arcs can be closed using <tt>cost = -1</tt>.
<p>Least cost paths are written to the output vector map with an
attached attribute table.
<p>Nodes can be
@@ -52,23 +52,23 @@
The attribute table will contain the following attributes:
<ul>
- <li>cat - path unique category assigned by module</li>
- <li>id - path id (read from input)</li>
- <li>fcat - from point category</li>
- <li>tcat - to point category</li>
- <li>sp - result status:
+ <li><tt>cat</tt> - path unique category assigned by module</li>
+ <li><tt>id</tt> - path id (read from input)</li>
+ <li><tt>fcat</tt> - from point category</li>
+ <li><tt>tcat</tt> - to point category</li>
+ <li><tt>sp</tt> - result status:
<ul>
<li> 0 - OK, path found</li>
<li> 1 - node is not reachable</li>
<li> 2 - point of given category does not exist</li>
</ul>
- <li>cost - travelling costs (on the network, not to/from network)</li>
- <li>fdist - the distance from first point to the network</li>
- <li>tdist - the distance from the network to second point</li>
+ <li><tt>cost</tt> - travelling costs (on the network, not to/from network)</li>
+ <li><tt>fdist</tt> - the distance from first point to the network</li>
+ <li><tt>tdist</tt> - the distance from the network to second point</li>
</ul>
<h2>NOTES</h2>
-Nodes and arcs can be closed using cost = -1.
+Nodes and arcs can be closed using <tt>cost = -1</tt>.
<p>If the cost columns <b>arc_column</b>, <b>arc_backward_column</b> and <b>node_column</b> are not
specified, the length of network segments is measured and
zero costs are assumed for nodes.
@@ -78,15 +78,18 @@
the columns 'max_speed' and 'length' are required. The correct fastest
path can then be found by specifying <tt>arc_column=length/max_speed</tt>. If not yet
existing, the column containing the line length ("length") has to added to the
-attributes table using <em>v.to.db</em>.
+attributes table using <em><a href="v.to.db.html">v.to.db</a></em>.
<h2>EXAMPLE</h2>
Shortest (red) and fastest (blue) path between two digitized nodes (Spearfish):
-<p><img src="vnetpath.png" alt="v.net.path example" border="1">
+<p>
+<center>
+<img src="vnetpath.png" alt="v.net.path example" border="1">
+</center>
-<p><div class="code"><pre>
# Spearfish
echo "1|601955.1|4916944.9|start
@@ -158,17 +161,20 @@
<h2>SEE ALSO</h2>
-<em><a href="d.path.html">d.path</a></em>,
-<em><a href="v.net.html">v.net</a></em>,
-<em><a href="v.net.alloc.html">v.net.alloc</a></em>,
-<em><a href="v.net.iso.html">v.net.iso</a></em>,
-<em><a href="v.net.salesman.html">v.net.salesman</a></em>,
-<em><a href="v.net.steiner.html">v.net.steiner</a></em>,
-<em><a href="v.to.db.html">v.to.db</a></em>
+<em>
+ <a href="d.path.html">d.path</a>,
+ <a href="v.net.html">v.net</a>,
+ <a href="v.net.alloc.html">v.net.alloc</a>,
+ <a href="v.net.iso.html">v.net.iso</a>,
+ <a href="v.net.salesman.html">v.net.salesman</a>,
+ <a href="v.net.steiner.html">v.net.steiner</a>,
+ <a href="v.to.db.html">v.to.db</a>
+</em>
-<h2>AUTHOR</h2>
+<h2>AUTHORS</h2>
Radim Blazek, ITC-Irst, Trento, Italy<br>
Documentation: Markus Neteler, Markus Metz
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
