[GRASS-SVN] r63733 - grass/trunk/vector/v.net.visibility
svn_grass at osgeo.org
Wed Dec 24 06:55:01 PST 2014
Author: martinl
Date: 2014-12-24 06:55:01 -0800 (Wed, 24 Dec 2014)
New Revision: 63733
grass/trunk/vector/v.net.visibility/v.net.visibility.html
v.net.visibility: manual cosmetics (syntax issues)
Modified: grass/trunk/vector/v.net.visibility/v.net.visibility.html
--- grass/trunk/vector/v.net.visibility/v.net.visibility.html 2014-12-24 14:53:17 UTC (rev 63732)
+++ grass/trunk/vector/v.net.visibility/v.net.visibility.html 2014-12-24 14:55:01 UTC (rev 63733)
@@ -36,7 +36,7 @@
The resulting map containing the visibility graph is given in the output map.
<p>
If you need to add additional points to compute a shortest path
-between them afterwards you can use the <em>coordinates</em> parameter, e.g.:
+between them afterwards you can use the <b>coordinates</b> parameter, e.g.:
<div class="code"><pre>
coordinates=25556200,6686400,25556400,6686600
</pre></div>
@@ -45,7 +45,7 @@
you can give as many points as you need. They will be added to the
visibility graph and edges from them will be computed. You can
always add those points after computing the visibility graph. Simply
-use the <em>visibility</em> parameter. The input will be the original
+use the <b>visibility</b> parameter. The input will be the original
vector map, the vis will be the computed visibility graph and the
output the new visibility graph which will be the vis + the new
points given with coordinate (edges will be computed as well).
