[GRASS-SVN] r63734 - in grass/branches/releasebranch_7_0: . vector/v.net.visibility
Wed Dec 24 06:55:42 PST 2014
Author: martinl
Date: 2014-12-24 06:55:42 -0800 (Wed, 24 Dec 2014)
New Revision: 63734
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/vector/v.net.visibility/v.net.visibility.html
v.net.visibility: manual cosmetics (syntax issues)
                  (merge r63733 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62190,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750-62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62828,62831,62838,62845,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,
 63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63275-63276,63279,63281,63283,63287,63290,63292,63297,63302,63304-63307,63315,63319,63327,63330,63332,63339,63342,63345,63362,63367,63379,63389,63391,63393,63402,63408-63409,63416-63417,63425,63427,63429,63431,63433,63448,63451,63453,63457,63459,63464-63470,63473,63482,63497,63505,63508,63510,63515,63521-63524,63526,63536-63537,63551-63552,63554,63556,63558-63559,63562,63570,63576,63582,63589-63593,63602,63604,63608-63609,63616,63618,63624,63626,63628,63630,63634,63639,63642,63644,63650,63652,63656,63679,63685,63689,63691,63693,63695,63698,63700-63702,63704,63706-63707,63709,63711,63713,63715,63717-63718,63721
 -63727,63731
   + /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62190,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750-62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62828,62831,62838,62845,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,
 -63727,63731,63733
Modified: grass/branches/releasebranch_7_0/vector/v.net.visibility/v.net.visibility.html
--- grass/branches/releasebranch_7_0/vector/v.net.visibility/v.net.visibility.html	2014-12-24 14:55:01 UTC (rev 63733)
+++ grass/branches/releasebranch_7_0/vector/v.net.visibility/v.net.visibility.html	2014-12-24 14:55:42 UTC (rev 63734)
@@ -36,7 +36,7 @@
 The resulting map containing the visibility graph is given in the output map.
 <p>
 If you need to add additional points to compute a shortest path
-between them afterwards you can use the <em>coordinates</em> parameter, e.g.:
+between them afterwards you can use the <b>coordinates</b> parameter, e.g.:
 <div class="code"><pre>
 coordinates=25556200,6686400,25556400,6686600
 </pre></div>
@@ -45,7 +45,7 @@
 you can give as many points as you need. They will be added to the
 visibility graph and edges from them will be computed. You can
 always add those points after computing the visibility graph. Simply
-use the <em>visibility</em> parameter. The input will be the original
+use the <b>visibility</b> parameter. The input will be the original
 vector map, the vis will be the computed visibility graph and the
 output the new visibility graph which will be the vis + the new
 points given with coordinate (edges will be computed as well).
