[GRASS-SVN] r63827 - in grass/trunk: include/defs lib/gis
svn_grass at osgeo.org
Mon Dec 29 09:09:54 PST 2014
Author: martinl
Date: 2014-12-29 09:09:54 -0800 (Mon, 29 Dec 2014)
New Revision: 63827
grass/trunk/include/defs/gis.h
grass/trunk/lib/gis/make_loc.c
grass/trunk/lib/gis/make_mapset.c
grass/trunk/lib/gis/put_window.c
libgis: G__put_window() -> G_put_element_window()
Modified: grass/trunk/include/defs/gis.h
--- grass/trunk/include/defs/gis.h 2014-12-29 16:50:16 UTC (rev 63826)
+++ grass/trunk/include/defs/gis.h 2014-12-29 17:09:54 UTC (rev 63827)
@@ -588,7 +588,7 @@
/* put_window.c */
int G_put_window(const struct Cell_head *);
-int G__put_window(const struct Cell_head *, const char *, const char *);
+int G_put_element_window(const struct Cell_head *, const char *, const char *);
/* putenv.c */
void G_putenv(const char *, const char *);
Modified: grass/trunk/lib/gis/make_loc.c
--- grass/trunk/lib/gis/make_loc.c 2014-12-29 16:50:16 UTC (rev 63826)
+++ grass/trunk/lib/gis/make_loc.c 2014-12-29 17:09:54 UTC (rev 63827)
@@ -75,8 +75,8 @@
G__setenv("MAPSET", "PERMANENT");
/* Create the default, and current window files */
- G__put_window(wind, "", "DEFAULT_WIND");
- G__put_window(wind, "", "WIND");
+ G_put_element_window(wind, "", "DEFAULT_WIND");
+ G_put_element_window(wind, "", "WIND");
/* Write out the PROJ_INFO, and PROJ_UNITS if available. */
if (proj_info != NULL) {
Modified: grass/trunk/lib/gis/make_mapset.c
--- grass/trunk/lib/gis/make_mapset.c 2014-12-29 16:50:16 UTC (rev 63826)
+++ grass/trunk/lib/gis/make_mapset.c 2014-12-29 17:09:54 UTC (rev 63827)
@@ -83,7 +83,7 @@
G__setenv("MAPSET", mapset_name);
/* Copy default window/regions to new mapset */
- G__put_window(&default_window, "", "WIND");
+ G_put_element_window(&default_window, "", "WIND");
/* And switch back to original environment */
G_switch_env();
Modified: grass/trunk/lib/gis/put_window.c
--- grass/trunk/lib/gis/put_window.c 2014-12-29 16:50:16 UTC (rev 63826)
+++ grass/trunk/lib/gis/put_window.c 2014-12-29 17:09:54 UTC (rev 63827)
@@ -15,9 +15,9 @@
#include <grass/gis.h>
- * \brief Writes the database region (window)
+ * \brief Writes the region (window)
- * Writes the database region file (WIND) in the user's current mapset
+ * Writes the region file (WIND) in the user's current mapset
* or when environmental variable \c WIND_OVERRIDE is set,
* it writes the region to file specified by \c WIND_OVERRIDE variable.
@@ -26,7 +26,7 @@
* Otherwise the whole GRASS session is affected.
* \warning When environmental variable \c WIND_OVERRIDE is not set,
- * this routine actually changes the database region.
+ * this routine actually changes the region.
* So in this case it should only be called by modules which the user knows
* will change the region. It is probably fair to say that only the
* \gmod{g.region} should call this routine unless \c WIND_OVERRIDE is set.
@@ -45,17 +45,17 @@
char *wind = getenv("WIND_OVERRIDE");
- return wind ? G__put_window(window, "windows", wind)
- : G__put_window(window, "", "WIND");
+ return wind ? G_put_element_window(window, "windows", wind)
+ : G_put_element_window(window, "", "WIND");
- * \brief Write the database region
+ * \brief Write the region
* from region.
- * <b>Warning:</b> Since this routine actually changes the database
+ * <b>Warning:</b> Since this routine actually changes the
* region, it should only be called by modules which the user knows
* <tt>g.region</tt> should call this routine.
@@ -69,7 +69,7 @@
* \sa G_put_window()
-int G__put_window(const struct Cell_head *window, const char *dir, const char *name)
+int G_put_element_window(const struct Cell_head *window, const char *dir, const char *name)
FILE *fd;
