[GRASS-SVN] r63828 - in grass/trunk: general/g.proj general/g.region general/g.setproj raster/r.external raster/r.in.gdal vector/v.in.ogr
svn_grass at osgeo.org
Mon Dec 29 09:10:33 PST 2014
Author: martinl
Date: 2014-12-29 09:10:32 -0800 (Mon, 29 Dec 2014)
New Revision: 63828
grass/trunk/general/g.proj/create.c
grass/trunk/general/g.region/main.c
grass/trunk/general/g.setproj/main.c
grass/trunk/raster/r.external/window.c
grass/trunk/raster/r.in.gdal/main.c
grass/trunk/vector/v.in.ogr/main.c
update modules to r63827
Modified: grass/trunk/general/g.proj/create.c
--- grass/trunk/general/g.proj/create.c 2014-12-29 17:09:54 UTC (rev 63827)
+++ grass/trunk/general/g.proj/create.c 2014-12-29 17:10:32 UTC (rev 63828)
@@ -57,8 +57,8 @@
(old_cellhd.proj != cellhd.proj)) {
/* Recreate the default, and current window files if projection
* number or zone have changed */
- G__put_window(&cellhd, "", "DEFAULT_WIND");
- G__put_window(&cellhd, "", "WIND");
+ G_put_element_window(&cellhd, "", "DEFAULT_WIND");
+ G_put_element_window(&cellhd, "", "WIND");
G_message(_("Default region was updated to the new projection, but if you have "
"multiple mapsets `g.region -d` should be run in each to update the "
"region from the default"));
Modified: grass/trunk/general/g.region/main.c
--- grass/trunk/general/g.region/main.c 2014-12-29 17:09:54 UTC (rev 63827)
+++ grass/trunk/general/g.region/main.c 2014-12-29 17:10:32 UTC (rev 63828)
@@ -756,7 +756,7 @@
if ((name = parm.save->answer)) {
temp_window = window;
G_adjust_Cell_head3(&temp_window, 0, 0, 0);
- if (G__put_window(&temp_window, "windows", name) < 0)
+ if (G_put_element_window(&temp_window, "windows", name) < 0)
G_fatal_error(_("Unable to set region <%s>"), name);
@@ -768,7 +768,7 @@
if (flag.savedefault->answer) {
if (strcmp(G_mapset(), "PERMANENT") == 0) {
- G__put_window(&window, "", "DEFAULT_WIND");
+ G_put_element_window(&window, "", "DEFAULT_WIND");
else {
G_fatal_error(_("Unable to change default region. "
Modified: grass/trunk/general/g.setproj/main.c
--- grass/trunk/general/g.setproj/main.c 2014-12-29 17:09:54 UTC (rev 63827)
+++ grass/trunk/general/g.setproj/main.c 2014-12-29 17:10:32 UTC (rev 63828)
@@ -639,7 +639,7 @@
G_free_key_value(in_unit_keys);
} /* if */
- if (G__put_window(&cellhd, "", "DEFAULT_WIND") < 0)
+ if (G_put_element_window(&cellhd, "", "DEFAULT_WIND") < 0)
G_fatal_error(_("Unable to write to DEFAULT_WIND region file"));
fprintf(stderr,
_("\nProjection information has been recorded for this location\n\n"));
Modified: grass/trunk/raster/r.external/window.c
--- grass/trunk/raster/r.external/window.c 2014-12-29 17:09:54 UTC (rev 63827)
+++ grass/trunk/raster/r.external/window.c 2014-12-29 17:10:32 UTC (rev 63828)
@@ -89,7 +89,7 @@
cur_wind.east = cur_wind.west + cur_wind.cols * cur_wind.ew_res;
- G__put_window(&cur_wind, "", "DEFAULT_WIND");
+ G_put_element_window(&cur_wind, "", "DEFAULT_WIND");
G_message(_("Default region for this location updated"));
G_put_window(&cur_wind);
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c 2014-12-29 17:09:54 UTC (rev 63827)
+++ grass/trunk/raster/r.in.gdal/main.c 2014-12-29 17:10:32 UTC (rev 63828)
@@ -780,7 +780,7 @@
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2014-12-29 17:09:54 UTC (rev 63827)
+++ grass/trunk/vector/v.in.ogr/main.c 2014-12-29 17:10:32 UTC (rev 63828)
@@ -1632,7 +1632,7 @@
