[GRASS-SVN] r58858 - in grass/branches/releasebranch_6_4/raster/r.li: . r.li.setup
svn_grass at osgeo.org
Mon Feb 3 13:08:44 PST 2014
Author: neteler
Date: 2014-02-03 13:08:33 -0800 (Mon, 03 Feb 2014)
New Revision: 58858
grass/branches/releasebranch_6_4/raster/r.li/Makefile
grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/area_query
grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/r.li.setup.main
grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/square_query
r.li.setup: backport of minor fixes from devbr6
Modified: grass/branches/releasebranch_6_4/raster/r.li/Makefile
--- grass/branches/releasebranch_6_4/raster/r.li/Makefile 2014-02-03 21:06:14 UTC (rev 58857)
+++ grass/branches/releasebranch_6_4/raster/r.li/Makefile 2014-02-03 21:08:33 UTC (rev 58858)
@@ -13,9 +13,9 @@
r.li.padsd \
r.li.patchdensity \
r.li.patchnum \
- r.li.richness \
r.li.pielou \
r.li.renyi \
+ r.li.richness \
r.li.setup \
r.li.shannon \
r.li.shape \
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/area_query
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/area_query 2014-02-03 21:06:14 UTC (rev 58857)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/area_query 2014-02-03 21:08:33 UTC (rev 58858)
@@ -1,10 +1,11 @@
#!/bin/sh
# the next line restarts using wish \
- exec $GRASS_WISH "$0" "$@"
+ exec "$GRASS_WISH" "$0" "$@"
-#Simply ask if the selected area is ok or not and save the answer in the
-#environment variable env(name)
+# Simply ask if the selected area is ok or not and save the
+# answer in the environment variable "env(name)"
wm title . "Select this area"
wm minsize . 250 100
label .label -text "Is this area ok?"
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/r.li.setup.main
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/r.li.setup.main 2014-02-03 21:06:14 UTC (rev 58857)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/r.li.setup.main 2014-02-03 21:08:33 UTC (rev 58858)
@@ -4,7 +4,7 @@
# Read the COPYING file that comes with GRASS for details.
lappend auto_path $env(GISBASE)/bwidget
package require -exact BWidget 1.2.1
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/square_query
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/square_query 2014-02-03 21:06:14 UTC (rev 58857)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/square_query 2014-02-03 21:08:33 UTC (rev 58858)
@@ -3,11 +3,12 @@
+# the answer in the environment variable "env(name)"
global env
