[GRASS-SVN] r58915 - grass/trunk/lib/python/temporal
Thu Feb 6 16:14:24 PST 2014
Author: huhabla
Date: 2014-02-06 16:14:24 -0800 (Thu, 06 Feb 2014)
New Revision: 58915
   grass/trunk/lib/python/temporal/pythontemporallib.dox
   grass/trunk/lib/python/temporal/temporal_vector_algebra.py
Do not create PyGRASS module instances at import time.
Modified: grass/trunk/lib/python/temporal/pythontemporallib.dox
--- grass/trunk/lib/python/temporal/pythontemporallib.dox	2014-02-06 22:45:32 UTC (rev 58914)
+++ grass/trunk/lib/python/temporal/pythontemporallib.dox	2014-02-07 00:14:24 UTC (rev 58915)
@@ -72,7 +72,6 @@
 space time datasets are defined here:
 - python::temporal::aggregation
-- python::temporal::create
 - python::temporal::extract
 - python::temporal::factory
 - python::temporal::open_stds
Modified: grass/trunk/lib/python/temporal/temporal_vector_algebra.py
--- grass/trunk/lib/python/temporal/temporal_vector_algebra.py	2014-02-06 22:45:32 UTC (rev 58914)
+++ grass/trunk/lib/python/temporal/temporal_vector_algebra.py	2014-02-07 00:14:24 UTC (rev 58915)
@@ -433,12 +433,6 @@
 from temporal_vector_operator import *
 from temporal_algebra import *
-m_overlay = pygrass.Module('v.overlay', quiet=True, run_=False)
-m_rename = pygrass.Module('g.rename', quiet=True, run_=False)
-m_patch = pygrass.Module('v.patch', quiet=True, run_=False)
-m_mremove = pygrass.Module('g.mremove', quiet=True, run_=False)
-m_buffer = pygrass.Module('v.buffer', quiet=True, run_=False)
 class TemporalVectorAlgebraLexer(TemporalAlgebraLexer):
@@ -493,25 +487,7 @@
     # Get the tokens from the lexer class
     tokens = TemporalVectorAlgebraLexer.tokens
-    def remove_intermediate_vector_maps(self):
-        """! Removes the intermediate vector maps.
-        if self.names != {}:
-            namelist = self.names.values()
-            max = 100
-            chunklist = [namelist[i:i + max] for i in range(0, len(namelist), max)]
-            for chunk in chunklist:
-                stringlist = ",".join(chunk)
-                if self.debug:
-                    print "g.mremove vect=%s"%(stringlist)
-                if self.run:
-                    m = copy.deepcopy(m_mremove)
-                    m.inputs["vect"].value = stringlist
-                    m.flags["f"].value = True
-                    m.run()
     # Setting equal precedence level for select and hash operations.
     precedence = (
         ('left', 'T_SELECT_OPERATOR', 'T_SELECT', 'T_NOT_SELECT'), # 1
@@ -522,6 +498,12 @@
     def __init__(self, pid=None, run=False, debug=True, spatial = False):
         TemporalAlgebraParser.__init__(self, pid, run, debug, spatial)
+        self.m_overlay = pygrass.Module('v.overlay', quiet=True, run_=False)
+        self.m_rename = pygrass.Module('g.rename', quiet=True, run_=False)
+        self.m_patch = pygrass.Module('v.patch', quiet=True, run_=False)
+        self.m_mremove = pygrass.Module('g.mremove', quiet=True, run_=False)
+        self.m_buffer = pygrass.Module('v.buffer', quiet=True, run_=False)
     def parse(self, expression, stdstype = 'strds', basename = None):
         self.lexer = TemporalVectorAlgebraLexer()
         self.lexer.build()
@@ -533,9 +515,26 @@
         self.expression = expression
         self.parser.parse(expression)
     ######################### Temporal functions ##############################
+    def remove_intermediate_vector_maps(self):
+        """! Removes the intermediate vector maps.
+        if self.names != {}:
+            namelist = self.names.values()
+            max = 100
+            chunklist = [namelist[i:i + max] for i in range(0, len(namelist), max)]
+            for chunk in chunklist:
+                stringlist = ",".join(chunk)
+                if self.debug:
+                    print "g.mremove vect=%s"%(stringlist)
+                if self.run:
+                    m = copy.deepcopy(self.m_mremove)
+                    m.inputs["vect"].value = stringlist
+                    m.flags["f"].value = True
+                    m.run()
     def eval_toperator(self, operator, comparison = False):
         """!This function evaluates a string containing temporal operations.
@@ -740,7 +739,7 @@
                             mapset = map_i.get_mapset()
                             # Change map name to given basename.
                             newident = self.basename + "_" + str(count)
-                            m = copy.deepcopy(m_rename)
+                            m = copy.deepcopy(self.m_rename)
                             m.inputs["vect"].value = (map_i.get_name(),newident)
                             m.flags["overwrite"].value = grass.overwrite()
                             m.run()
@@ -751,16 +750,15 @@
                             register_list.append(map_i)
                     else:
                 if len(register_list) > 0:
                     # Open connection to temporal database.
                     dbif, connected = init_dbif(dbif=self.dbif)
                     # Create result space time dataset.
                     resultstds = open_new_space_time_dataset(t[1], self.stdstype, \
        'absolute', t[1], t[1], \
-        None, None, \
-        overwrite = grass.overwrite(),
-        dbif=dbif)
+        "temporal vector algebra", dbif=dbif,
+        overwrite = grass.overwrite())
                     for map_i in register_list:
                         # Check if modules should be executed from command list.
                         if "cmd_list" in dir(map_i):
@@ -850,7 +848,7 @@
     def create_overlay_operations(self, maplistA, maplistB, relations, temporal, function):
         """!Create the spatial overlay operation commad list
            @param maplistA A list of map objects
            @param maplistB A list of map objects
            @param relations The temporal relationships that must be fullfilled as list of strings
@@ -860,7 +858,7 @@
            @return Return the list of maps with overlay commands
         topolist = self.get_temporal_topo_list(maplistA, maplistB, topolist = relations)
         # Select operation name.
         if function == "&":
             opname = "and"
@@ -911,7 +909,7 @@
                             mapbinput = map_j.get_id()
                             # Create module command in PyGRASS for v.overlay and v.patch.
                             if opname != "disor":
-                                m = copy.deepcopy(m_overlay)
+                                m = copy.deepcopy(self.m_overlay)
                                 m.run_ = False
                                 m.inputs["operator"].value = opname
                                 m.inputs["ainput"].value = str(mapainput)
@@ -920,7 +918,7 @@
                             else:
                                 patchinput = str(mapainput) + ',' + str(mapbinput)
-                                m = copy.deepcopy(m_patch)
+                                m = copy.deepcopy(self.m_patch)
                                 m.run_ = False
                                 m.inputs["input"].value = patchinput
                                 m.outputs["output"].value = name
@@ -973,7 +971,7 @@
                     buff_type = "line"
                 elif t[1] == "buff_a":
                     buff_type = "area"
-                m = copy.deepcopy(m_buffer)
+                m = copy.deepcopy(self.m_buffer)
                 m.run_ = False
                 m.inputs["type"].value = buff_type
                 m.inputs["input"].value = str(map_i.get_id())
