[GRASS-SVN] r58916 - grass/branches/develbranch_6/lib/display
svn_grass at osgeo.org
Thu Feb 6 16:49:00 PST 2014
Author: hamish
Date: 2014-02-06 16:48:59 -0800 (Thu, 06 Feb 2014)
New Revision: 58916
grass/branches/develbranch_6/lib/display/popup.c
rendering tweaks to get border line to align with fill box, and better match box size to text string length
Modified: grass/branches/develbranch_6/lib/display/popup.c
--- grass/branches/develbranch_6/lib/display/popup.c 2014-02-07 00:14:24 UTC (rev 58915)
+++ grass/branches/develbranch_6/lib/display/popup.c 2014-02-07 00:48:59 UTC (rev 58916)
@@ -92,7 +92,7 @@
char *panel;
int dots_per_line, dots_per_char, height, width;
- /* Figure the number of options and the max length of options */
+ /* Figure the number of options and the max string length of options */
max_len = 0;
for (n_options = 0; options[n_options] != NULL; n_options++) {
len = strlen(options[n_options]);
@@ -103,24 +103,25 @@
/* Figure the dots per line and dots_per_char */
height = R_screen_bot() - R_screen_top();
width = R_screen_rite() - R_screen_left();
- dots_per_line = height * percent_per_line / 100;
- dots_per_char = width / (max_len + 2);
+ dots_per_line = height * percent_per_line / 100.;
+ dots_per_char = width / (max_len + 2.);
/* we want the box to fit into window horizontally */
+ t = R_screen_bot() - (R_screen_bot() - R_screen_top()) * top / 100.;
+ l = R_screen_left() + (R_screen_rite() - R_screen_left()) * left / 100.;
- t = R_screen_bot() - (R_screen_bot() - R_screen_top()) * top / 100;
- l = R_screen_left() + (R_screen_rite() - R_screen_left()) * left / 100;
/* Figure the bottom and right of the window */
- text_size = (int)(.8 * (float)dots_per_line);
+ text_size = (int)(.8 * dots_per_line);
if (text_size > dots_per_char)
text_size = dots_per_char;
text_raise = (dots_per_line - text_size + 1) / 2;
if (text_raise == 0)
text_raise = 1;
- b = Y_BORDER + t + dots_per_line * n_options;
- r = 2 * X_BORDER + l + text_size * max_len;
+ b = Y_BORDER + t + (dots_per_line * n_options) + 1;
+ r = 2 * X_BORDER + l + (text_size * 0.8) * max_len;
/* Adjust, if necessary, to make sure window is all on screen */
if (t < R_screen_top()) {
b = b + (R_screen_top() - t);
@@ -164,11 +165,11 @@
/* Draw border */
R_standard_color(text_colr);
- R_move_abs(l + 1, t + 1);
- R_cont_abs(r - 1, t + 1);
+ R_move_abs(l + 0, t + 0);
+ R_cont_abs(r - 1, t + 0);
R_cont_abs(r - 1, b - 1);
- R_cont_abs(l + 1, b - 1);
- R_cont_abs(l + 1, t + 1);
+ R_cont_abs(l + 0, b - 1);
+ R_cont_abs(l + 0, t + 0);
/* Prepare for text */
R_text_size(text_size, text_size);
@@ -195,16 +196,18 @@
int n;
R_get_location_with_pointer(&x, &y, &button);
- if (x > r
- || x < l || y < t + Y_BORDER + dots_per_line || y > b - Y_BORDER)
+ if (x > r || x < l
+ || y < t + Y_BORDER + dots_per_line || y > b - Y_BORDER)
continue;
n = y - t - Y_BORDER;
if (n % dots_per_line == 0)
continue;
+ /* cleanup */
R_panel_restore(panel);
R_panel_delete(panel);
return (n / dots_per_line);
