[GRASS-SVN] r59045 - grass/trunk/raster/r.li/r.li.cwed
svn_grass at osgeo.org
Fri Feb 14 05:08:31 PST 2014
Author: mmetz
Date: 2014-02-14 05:08:30 -0800 (Fri, 14 Feb 2014)
New Revision: 59045
grass/trunk/raster/r.li/r.li.cwed/cwed.c
r.li.cwed: fix segfault
Modified: grass/trunk/raster/r.li/r.li.cwed/cwed.c
--- grass/trunk/raster/r.li/r.li.cwed/cwed.c 2014-02-14 13:04:50 UTC (rev 59044)
+++ grass/trunk/raster/r.li/r.li.cwed/cwed.c 2014-02-14 13:08:30 UTC (rev 59045)
@@ -83,27 +83,19 @@
double *result)
double indice = 0; /* the result */
struct Cell_head hd;
int i = 0;
int file_fd = -1;
int l; /*number of read byte */
int ris = 0;
char *file;
char *strFile;
char row[NMAX]; /* to read the file */
char **bufRighe; /* contains every valid file row */
char separatore; /* separator to split a string */
long totCoppie = 0; /* number of cells pair */
long totRow = 0; /* of the file */
long tabSize = 10; /* array length */
Coppie *cc = NULL; /* here store the pair of cell with the weight. these information are in the file */
@@ -243,8 +235,7 @@
- /*else
- * num = 1 ---> in the line there is only 1 token
+ /* else num = 1 ---> in the line there is only 1 token
* I ignore this line
@@ -291,7 +282,6 @@
int calculate(int fd, struct area_entry *ad, Coppie * cc, long totCoppie,
double *result)
double indice = 0;
double somma = 0;
double area = 0;
@@ -299,14 +289,17 @@
int i = 0, j;
int mask_fd = -1;
int masked = FALSE;
- int *mask_corr, *mask_sup;
+ int *mask_corr = NULL;
+ /* TODO: mask_sup */
- CELL *buf_corr, *buf_sup;
+ CELL *buf_corr, *buf_sup, *buf_null;
CELL prevCell, corrCell, supCell;
generic_cell c1;
generic_cell c2;
+ if (ad->rl < 2)
+ G_fatal_error(_("Row cache is too small"));
/* open mask if needed */
if (ad->mask == 1) {
@@ -321,34 +314,25 @@
return RLI_ERRORE;
- mask_sup = G_malloc(ad->cl * sizeof(int));
- if (mask_sup == NULL) {
- G_fatal_error("malloc mask_sup failed");
- return RLI_ERRORE;
masked = TRUE;
- buf_sup = Rast_allocate_c_buf();
- if (buf_sup == NULL) {
- G_fatal_error("malloc buf_sup failed");
+ buf_null = Rast_allocate_c_buf();
+ if (buf_null == NULL) {
+ G_fatal_error("malloc buf_null failed");
return RLI_ERRORE;
c1.t = CELL_TYPE;
c2.t = CELL_TYPE;
- buf_corr = Rast_allocate_c_buf();
- if (buf_corr == NULL) {
- G_fatal_error("error malloc buf_corr");
+ /*the first time buf_sup is all null */
+ Rast_set_c_null_value(buf_null + ad->x, ad->cl);
+ buf_sup = buf_null;
- Rast_set_c_null_value(buf_sup + ad->x, ad->cl); /*the first time buf_sup is all null */
for (j = 0; j < ad->rl; j++) { /* for each row */
- buf_corr = RLI_get_cell_raster_row(fd, j + ad->y, ad); /* read row of raster */
+ /* read row of raster */
+ buf_corr = RLI_get_cell_raster_row(fd, j + ad->y, ad);
if (j > 0) { /* not first row */
buf_sup = RLI_get_cell_raster_row(fd, j - 1 + ad->y, ad);
@@ -371,7 +355,7 @@
if (!(Rast_is_null_value(&corrCell, CELL_TYPE))) {
supCell = buf_sup[i + ad->x];
- /* calculate how many edge the cell has */
+ /* calculate how many edges the cell has */
if (((!Rast_is_null_value(&prevCell, CELL_TYPE))) &&
(corrCell != prevCell)) {
@@ -397,14 +381,10 @@
return RLI_ERRORE;
- prevCell = buf_corr[i + ad->x];
+ prevCell = corrCell;
- if (masked)
- mask_sup = mask_corr;
/* calcolo dell'indice */
if (area == 0)
indice = -1;
@@ -421,11 +401,12 @@
*result = indice;
if (masked) {
+ close(mask_fd);
G_free(mask_corr);
- G_free(mask_sup);
- G_free(buf_sup);
+ G_free(buf_null);
return RLI_OK;
@@ -433,7 +414,6 @@
int calculateD(int fd, struct area_entry *ad, Coppie * cc, long totCoppie,
double *result)
double indice = 0;
double somma = 0;
double area = 0;
@@ -441,16 +421,18 @@
int i = 0, j;
int mask_fd = -1;
int masked = FALSE;
- DCELL *buf_corr, *buf_sup;
+ DCELL *buf_corr, *buf_sup, *buf_null;
DCELL prevCell, corrCell, supCell;
generic_cell c1;
generic_cell c2;
+ if (ad->rl < 2)
if ((mask_fd = open(ad->mask_name, O_RDONLY, 0755)) < 0) {
@@ -464,31 +446,25 @@
return RLI_ERRORE;
- G_fatal_error("malloc mask_corr failed");
masked = TRUE;
- buf_sup = Rast_allocate_d_buf();
+ buf_null = Rast_allocate_d_buf();
return RLI_ERRORE;
c1.t = DCELL_TYPE;
c2.t = DCELL_TYPE;
- buf_corr = Rast_allocate_d_buf();
+ Rast_set_d_null_value(buf_null + ad->x, ad->cl);
- Rast_set_d_null_value(buf_sup + ad->x, ad->cl); /*the first time buf_sup is all null */
- buf_corr = RLI_get_dcell_raster_row(fd, j + ad->y, ad); /* read row of raster */
+ buf_corr = RLI_get_dcell_raster_row(fd, j + ad->y, ad);
buf_sup = RLI_get_dcell_raster_row(fd, j - 1 + ad->y, ad);
@@ -535,14 +511,10 @@
- if (masked)
if (area == 0)
indice = -1;
@@ -558,9 +530,12 @@
*result = indice;
if (masked) {
+ close(mask_fd);
G_free(mask_corr);
- G_free(mask_sup);
+ G_free(buf_null);
return RLI_OK;
@@ -569,7 +544,6 @@
int calculateF(int fd, struct area_entry *ad, Coppie * cc, long totCoppie,
double *result)
double indice = 0;
double somma = 0;
double area = 0;
@@ -577,16 +551,18 @@
int i = 0, j;
int mask_fd = -1;
int masked = FALSE;
- FCELL *buf_corr, *buf_sup;
+ FCELL *buf_corr, *buf_sup, *buf_null;
FCELL prevCell, corrCell, supCell;
generic_cell c1;
generic_cell c2;
+ if (ad->rl < 2)
@@ -600,36 +576,27 @@
return RLI_ERRORE;
masked = TRUE;
/* allocate and inizialize buffers */
- buf_sup = Rast_allocate_f_buf();
+ buf_null = Rast_allocate_f_buf();
return RLI_ERRORE;
- Rast_set_f_null_value(buf_sup + ad->x, ad->cl); /*the first time buf_sup is all null */
+ Rast_set_f_null_value(buf_null + ad->x, ad->cl);
- buf_corr = Rast_allocate_f_buf();
- G_fatal_error("malloc buf_corr failed");
c1.t = FCELL_TYPE;
c2.t = FCELL_TYPE;
- buf_corr = RLI_get_fcell_raster_row(fd, j + ad->y, ad); /* read row of raster */
- if (j > 0) { /* not first row */
+ buf_corr = RLI_get_fcell_raster_row(fd, j + ad->y, ad);
+ if (j > 0) {
+ /* not first row */
buf_sup = RLI_get_fcell_raster_row(fd, j - 1 + ad->y, ad);
/*read mask if needed */
@@ -655,14 +622,13 @@
int r = 0;
- c1.val.dc = corrCell;
- c2.val.dc = prevCell;
+ c1.val.fc = corrCell;
+ c2.val.fc = prevCell;
r = updateCoppia(cc, c1, c2, totCoppie);
if (r == RLI_ERRORE)
return RLI_ERRORE;
if ((!(Rast_is_null_value(&supCell, FCELL_TYPE))) &&
(corrCell != supCell)) {
int r = 0;
@@ -675,14 +641,10 @@
- if (masked)
if (area == 0)
indice = -1;
@@ -698,9 +660,12 @@
*result = indice;
if (masked) {
+ close(mask_fd);
G_free(mask_corr);
- G_free(mask_sup);
+ G_free(buf_null);
return RLI_OK;
