[GRASS-SVN] r59046 - grass/trunk/raster/r.li/r.li.dominance
svn_grass at osgeo.org
Fri Feb 14 05:09:20 PST 2014
Author: mmetz
Date: 2014-02-14 05:09:19 -0800 (Fri, 14 Feb 2014)
New Revision: 59046
grass/trunk/raster/r.li/r.li.dominance/dominance.c
r.li.dominance: sync to r.li.shannon
Modified: grass/trunk/raster/r.li/r.li.dominance/dominance.c
--- grass/trunk/raster/r.li/r.li.dominance/dominance.c 2014-02-14 13:08:30 UTC (rev 59045)
+++ grass/trunk/raster/r.li/r.li.dominance/dominance.c 2014-02-14 13:09:19 UTC (rev 59046)
@@ -22,6 +22,8 @@
#include "../r.li.daemon/avl.h"
#include "../r.li.daemon/daemon.h"
+/* template is shannon */
int calculate(int fd, struct area_entry *ad, double *result);
int calculateD(int fd, struct area_entry *ad, double *result);
int calculateF(int fd, struct area_entry *ad, double *result);
@@ -55,20 +57,14 @@
return calculateIndex(conf->answer, dominance, NULL, raster->answer,
output->answer);
int dominance(int fd, char **par, struct area_entry *ad, double *result)
int ris = RLI_OK;
double indice = 0;
- struct Cell_head hd;
- Rast_get_cellhd(ad->raster, "", &hd);
switch (ad->data_type) {
case CELL_TYPE:
@@ -90,28 +86,24 @@
G_fatal_error("data type unknown");
return RLI_ERRORE;
if (ris != RLI_OK)
- return RLI_ERRORE;
+ return RLI_ERRORE;
*result = indice;
return RLI_OK;
CELL *buf;
CELL corrCell;
- CELL precCell;
int i, j;
- int mask_fd = -1, *mask_buf;
+ int mask_fd = -1, *mask_buf = NULL;
int ris = 0;
int masked = FALSE;
int a = 0; /* a=0 if all cells are null */
@@ -119,7 +111,6 @@
long m = 0;
long tot = 0;
long zero = 0;
- long totCorr = 0;
double indice = 0;
double somma = 0;
@@ -128,18 +119,24 @@
double t;
double logaritmo;
+ generic_cell cc;
avl_tree albero = NULL;
AVL_table *array;
- generic_cell cc;
cc.t = CELL_TYPE;
+ if (ad->y + ad->rl > Rast_window_rows())
+ G_fatal_error("Region dimensions are wrong: n rows %d > %d",
+ ad->y + ad->rl, Rast_window_rows());
+ if (ad->x + ad->cl > Rast_window_cols())
+ G_fatal_error("Region dimensions are wrong; n cols %d > %d",
+ ad->x + ad->cl, Rast_window_cols());
/* open mask if needed */
if (ad->mask == 1) {
if ((mask_fd = open(ad->mask_name, O_RDONLY, 0755)) < 0)
return RLI_ERRORE;
- mask_buf = G_malloc(ad->cl * sizeof(int));
+ mask_buf = G_malloc(Rast_window_cols() * sizeof(int));
if (mask_buf == NULL) {
G_fatal_error("malloc mask_buf failed");
return RLI_ERRORE;
@@ -147,9 +144,10 @@
masked = TRUE;
- Rast_set_c_null_value(&precCell, 1);
+ /*for each row */
+ for (j = 0; j < ad->rl; j++) {
+ buf = RLI_get_cell_raster_row(fd, j + ad->y, ad);
- for (j = 0; j < ad->rl; j++) { /* for each row */
if (masked) {
if (read(mask_fd, mask_buf, (ad->cl * sizeof(int))) < 0) {
G_fatal_error("mask read failed");
@@ -157,7 +155,6 @@
- buf = RLI_get_cell_raster_row(fd, j + ad->y, ad);
for (i = 0; i < ad->cl; i++) { /* for each cell in the row */
area++;
corrCell = buf[i + ad->x];
@@ -169,97 +166,50 @@
if (!(Rast_is_null_value(&corrCell, CELL_TYPE))) {
a = 1;
- if (Rast_is_null_value(&precCell, cc.t)) {
- precCell = corrCell;
- if (corrCell != precCell) {
- if (albero == NULL) {
- cc.val.c = precCell;
- albero = avl_make(cc, totCorr);
- G_fatal_error("avl_make error");
+ if (albero == NULL) {
+ cc.val.c = corrCell;
+ albero = avl_make(cc, 1);
+ G_fatal_error("avl_make error");
+ m++;
+ else {
+ ris = avl_add(&albero, cc, 1);
+ switch (ris) {
+ case AVL_ERR:
+ G_fatal_error("avl_add error");
return RLI_ERRORE;
- /* TODO missing?: else - see r.li.simpson/simpson.c */
- m++;
- else {
- ris = avl_add(&albero, cc, totCorr);
- switch (ris) {
- case AVL_ERR:
- G_fatal_error("avl_add error");
- case AVL_ADD:
- m++;
- break;
- case AVL_PRES:
- break;
- default:
- G_fatal_error("avl_add unknown error");
+ case AVL_ADD:
+ m++;
+ break;
+ case AVL_PRES:
+ break;
+ default:
+ G_fatal_error("avl_add unknown error");
- totCorr = 1;
- else {
- totCorr++;
} /* end for */
} /* end for */
/*last closing */
- if (a != 0) {
+ if (a != 0 && albero != NULL) {
- m++;
- else {
- switch (ris) {
- case AVL_ERR:
- case AVL_ADD:
- m++;
- break;
- case AVL_PRES:
- break;
- default:
- array = G_malloc(m * sizeof(AVL_tableRow));
+ array = G_malloc(m * sizeof(AVL_tableRow *));
if (array == NULL) {
G_fatal_error("malloc array failed");
return RLI_ERRORE;
@@ -267,8 +217,7 @@
tot = avl_to_array(albero, zero, array);
if (tot != m) {
- G_warning
- ("avl_to_array unaspected value. the result could be wrong");
+ G_warning("avl_to_array unaspected value. the result could be wrong");
return RLI_ERRORE;
@@ -280,21 +229,25 @@
somma = somma + (percentuale * logaritmo);
+ G_free(array);
if (m != 0)
indice = log((double)m) + somma;
else
indice = 0;
- G_free(array);
- else /*if a is 0, that is all cell are null, i put index=-1 */
+ else
+ /*if a is 0, that is all cell are null, i put index=-1 */
indice = (double)(-1);
+ *result = indice;
- if (masked)
+ if (masked) {
+ close(mask_fd);
G_free(mask_buf);
+ avl_destroy(albero);
- *result = indice;
return RLI_OK;
@@ -303,10 +256,9 @@
DCELL *buf;
DCELL corrCell;
- DCELL precCell;
int i, j;
int ris = 0;
int masked = FALSE;
@@ -314,7 +266,6 @@
long m = 0;
long tot = 0;
long zero = 0;
- long totCorr = 0;
double indice = 0;
double somma = 0;
@@ -323,14 +274,19 @@
double t;
double logaritmo;
+ generic_cell cc;
AVL_table *array;
- generic_cell cc;
cc.t = DCELL_TYPE;
@@ -343,9 +299,10 @@
masked = TRUE;
- Rast_set_d_null_value(&precCell, 1);
+ /*for each row */
+ buf = RLI_get_dcell_raster_row(fd, j + ad->y, ad);
if (masked) {
@@ -353,8 +310,6 @@
- buf = RLI_get_dcell_raster_row(fd, j + ad->y, ad);
for (i = 0; i < ad->cl; i++) { /* for each dcell in the row */
area++;
@@ -366,98 +321,48 @@
if (!(Rast_is_null_value(&corrCell, DCELL_TYPE))) {
a = 1;
- if (Rast_is_null_value(&precCell, DCELL_TYPE)) {
+ cc.val.dc = corrCell;
- cc.val.dc = precCell;
+ m++;
+ else {
+ switch (ris) {
+ case AVL_ERR:
return RLI_ERRORE;
- m++;
- else {
- switch (ris) {
- case AVL_ERR:
- case AVL_ADD:
- m++;
- break;
- case AVL_PRES:
- break;
- default:
+ case AVL_ADD:
+ m++;
+ break;
+ case AVL_PRES:
+ break;
+ default:
- totCorr = 1;
- else {
- totCorr++;
} /*close for */
} /*close for */
- if (masked) {
- G_free(mask_buf);
- /*last closing */
- if (a != 0) {
- m++;
- else {
- cc.val.fc = precCell;
- switch (ris) {
- case AVL_ERR:
- case AVL_ADD:
- m++;
- break;
- case AVL_PRES:
- break;
- default:
+ /*last closing */
return RLI_ERRORE;
@@ -489,9 +394,13 @@
*result = indice;
+ if (masked) {
+ close(mask_fd);
+ G_free(mask_buf);
return RLI_OK;
@@ -501,10 +410,9 @@
FCELL *buf;
FCELL corrCell;
- FCELL precCell;
int i, j;
int ris = 0;
int masked = FALSE;
@@ -512,7 +420,6 @@
long m = 0;
long tot = 0;
long zero = 0;
- long totCorr = 0;
double indice = 0;
double somma = 0;
@@ -521,14 +428,19 @@
double t;
double logaritmo;
+ generic_cell cc;
AVL_table *array;
- generic_cell cc;
cc.t = FCELL_TYPE;
@@ -541,11 +453,10 @@
masked = TRUE;
+ /*for each row */
+ buf = RLI_get_fcell_raster_row(fd, j + ad->y, ad);
- Rast_set_f_null_value(&precCell, 1);
if (masked) {
@@ -553,13 +464,9 @@
- buf = RLI_get_fcell_raster_row(fd, j + ad->y, ad);
for (i = 0; i < ad->cl; i++) { /* for each fcell in the row */
area++;
if (masked && mask_buf[i + ad->x] == 0) {
Rast_set_f_null_value(&corrCell, 1);
area--;
@@ -567,94 +474,47 @@
if (!(Rast_is_null_value(&corrCell, FCELL_TYPE))) {
a = 1;
- if (Rast_is_null_value(&precCell, FCELL_TYPE)) {
+ cc.val.fc = corrCell;
+ m++;
+ else {
+ switch (ris) {
+ case AVL_ERR:
return RLI_ERRORE;
- m++;
- else {
- switch (ris) {
- case AVL_ERR:
- case AVL_ADD:
- m++;
- break;
- case AVL_PRES:
- break;
- default:
+ case AVL_ADD:
+ m++;
+ break;
+ case AVL_PRES:
+ break;
+ default:
- totCorr = 1;
- else {
- totCorr++;
/*last closing */
- if (a != 0) {
- m++;
- else {
- switch (ris) {
- case AVL_ERR:
- case AVL_ADD:
- m++;
- break;
- case AVL_PRES:
- break;
- default:
@@ -663,8 +523,7 @@
if (tot != m) {
- G_warning
return RLI_ERRORE;
@@ -676,22 +535,24 @@
+ G_free(array);
if (m != 0)
else
indice = 0;
- G_free(array);
- indice = (double)(-1);
+ else
+ indice = (double)(-1);
+ *result = indice;
if (masked) {
+ close(mask_fd);
G_free(mask_buf);
- *result = indice;
return RLI_OK;
