[GRASS-SVN] r59047 - grass/trunk/raster/r.li/r.li.mpa
Fri Feb 14 05:10:49 PST 2014
Author: mmetz
Date: 2014-02-14 05:10:48 -0800 (Fri, 14 Feb 2014)
New Revision: 59047
   grass/trunk/raster/r.li/r.li.mpa/mpa.c
r.li.mpa: fix mask
Modified: grass/trunk/raster/r.li/r.li.mpa/mpa.c
--- grass/trunk/raster/r.li/r.li.mpa/mpa.c	2014-02-14 13:09:19 UTC (rev 59046)
+++ grass/trunk/raster/r.li/r.li.mpa/mpa.c	2014-02-14 13:10:48 UTC (rev 59047)
@@ -56,8 +56,6 @@
     return calculateIndex(conf->answer, meanPixelAttribute, NULL,
 			  raster->answer, output->answer);
@@ -65,10 +63,7 @@
     int ris = 0;
     double indice = 0;
-    struct Cell_head hd;
-    Rast_get_cellhd(ad->raster, "", &hd);
     switch (ad->data_type) {
     case CELL_TYPE:
@@ -96,27 +91,24 @@
 	return RLI_ERRORE;
     *result = indice;
     return RLI_OK;
 int calculate(int fd, struct area_entry *ad, double *result)
     CELL *buf;
     int i, j;
-    int mask_fd = -1, *mask_buf;
+    int mask_fd = -1, *mask_buf = NULL;
     int masked = FALSE;
     double area = 0;
     double indice = 0;
     double somma = 0;
     /* open mask if needed */
     if (ad->mask == 1) {
 	if ((mask_fd = open(ad->mask_name, O_RDONLY, 0755)) < 0) {
@@ -163,6 +155,7 @@
     *result = indice;
     if (masked) {
+	close(mask_fd);
 	G_free(mask_buf);
     return RLI_OK;
@@ -173,14 +166,13 @@
     DCELL *buf;
     int i, j;
     int masked = FALSE;
     double area = 0;
     double indice = 0;
     double somma = 0;
@@ -195,8 +187,6 @@
 	masked = TRUE;
     for (j = 0; j < ad->rl; j++) {	/*for each raster row */
 	buf = RLI_get_dcell_raster_row(fd, j + ad->y, ad);	/*read raster row */
@@ -220,7 +210,6 @@
     if (area == 0)
 	indice = (double)-1;
     else
@@ -228,6 +217,7 @@
     *result = indice;
     if (masked) {
+	close(mask_fd);
 	G_free(mask_buf);
     return RLI_OK;
@@ -238,14 +228,13 @@
     FCELL *buf;
     int i, j;
     int masked = FALSE;
     double area = 0;
     double indice = 0;
     double somma = 0;
@@ -260,8 +249,6 @@
 	masked = TRUE;
 	buf = RLI_get_fcell_raster_row(fd, j + ad->y, ad);	/*read raster row */
@@ -286,7 +273,6 @@
     if (area == 0)
     else
@@ -294,6 +280,7 @@
     *result = indice;
     if (masked) {
+	close(mask_fd);
 	G_free(mask_buf);
     return RLI_OK;
