[GRASS-SVN] r59048 - grass/trunk/raster/r.li/r.li.mps
svn_grass at osgeo.org
Fri Feb 14 05:11:40 PST 2014
Author: mmetz
Date: 2014-02-14 05:11:39 -0800 (Fri, 14 Feb 2014)
New Revision: 59048
grass/trunk/raster/r.li/r.li.mps/mps.c
r.li.mps: fix segfault
Modified: grass/trunk/raster/r.li/r.li.mps/mps.c
--- grass/trunk/raster/r.li/r.li.mps/mps.c 2014-02-14 13:10:48 UTC (rev 59047)
+++ grass/trunk/raster/r.li/r.li.mps/mps.c 2014-02-14 13:11:39 UTC (rev 59048)
@@ -55,7 +55,6 @@
return calculateIndex(conf->answer, meanPatchSize, NULL, raster->answer,
output->answer);
@@ -91,7 +90,7 @@
if (ris != RLI_OK)
- return RLI_ERRORE;
+ return RLI_ERRORE;
*result = indice;
@@ -101,19 +100,17 @@
int calculate(int fd, struct area_entry *ad, struct Cell_head hd, double *result)
- CELL *buf;
- CELL *buf_sup;
+ CELL *buf, *buf_sup, *buf_null;
CELL corrCell;
CELL precCell;
CELL supCell;
int i, j;
- int mask_fd = -1, *mask_buf;
+ int mask_fd = -1, *mask_buf = NULL;
int ris = 0;
int masked = FALSE;
long npatch = 0;
long tot = 0;
long zero = 0;
@@ -123,6 +120,7 @@
long doppi = 0;
long *mask_patch_sup;
long *mask_patch_corr;
+ long *ltmp;
double indice = 0;
double area = 0; /*if all cells are null area=0 */
@@ -156,27 +154,23 @@
return RLI_ERRORE;
- buf_sup = Rast_allocate_c_buf();
- if (buf_sup == NULL) {
- G_fatal_error("malloc buf_sup failed");
+ buf_null = Rast_allocate_c_buf();
+ if (buf_null == NULL) {
+ G_fatal_error("malloc buf_null failed");
return RLI_ERRORE;
- buf = Rast_allocate_c_buf();
- if (buf == NULL) {
- G_fatal_error("malloc buf failed");
+ /*the first time buf_sup is all null */
+ Rast_set_c_null_value(buf_null, Rast_window_cols());
+ buf_sup = buf_null;
+ buf = buf_null;
- Rast_set_c_null_value(buf_sup + ad->x, ad->cl); /*the first time buf_sup is all null */
for (i = 0; i < ad->cl; i++) {
mask_patch_sup[i] = 0;
mask_patch_corr[i] = 0;
/*for each raster row */
for (j = 0; j < ad->rl; j++) {
if (j > 0) {
buf_sup = RLI_get_cell_raster_row(fd, j - 1 + ad->y, ad);
@@ -200,15 +194,9 @@
/*valid cell */
if (!(Rast_is_null_value(&corrCell, CELL_TYPE))) {
area++;
- if (i > 0)
- precCell = buf[i - 1 + ad->x];
- if (j == 0)
- Rast_set_c_null_value(&supCell, 1);
- else
- supCell = buf_sup[i + ad->x];
+ supCell = buf_sup[i + ad->x];
if (corrCell != precCell) {
if (corrCell != supCell) {
/*new patch */
@@ -346,7 +334,6 @@
else { /*current cell and previous cell are equal */
if ((corrCell == supCell) &&
(mask_patch_sup[i] != mask_patch_corr[i - 1])) {
int l;
@@ -368,19 +355,19 @@
else {
mask_patch_corr[i] = idCorr;
else { /*cell not to consider or cell is null */
+ precCell = corrCell;
+ ltmp = mask_patch_sup;
mask_patch_sup = mask_patch_corr;
+ mask_patch_corr = ltmp;
if (area != 0) {
if (albero == NULL) {
albero = avlID_make(idCorr, uno);
@@ -415,7 +402,6 @@
array = G_malloc(npatch * sizeof(avlID_tableRow));
if (array == NULL) {
G_fatal_error("malloc array failed");
@@ -454,29 +440,31 @@
else
indice = (double)(0);
*result = indice;
- if (masked)
+ if (masked) {
+ close(mask_fd);
G_free(mask_buf);
G_free(mask_patch_corr);
+ G_free(mask_patch_sup);
+ G_free(buf_null);
- /* G_free(buf_sup); */ /* <-- why not free it? */
+ avlID_destroy(albero);
return RLI_OK;
int calculateD(int fd, struct area_entry *ad, struct Cell_head hd, double *result)
- DCELL *buf;
- DCELL *buf_sup;
+ DCELL *buf, *buf_sup, *buf_null;
DCELL corrCell;
DCELL precCell;
DCELL supCell;
int i, j;
int ris = 0;
int masked = FALSE;
long npatch = 0;
@@ -488,17 +476,15 @@
long doppi = 0;
+ long *ltmp;
double indice = 0;
double areaCorrect = 0;
double EW_DIST1, EW_DIST2, NS_DIST1, NS_DIST2;
avlID_tree albero = NULL;
avlID_table *array;
/* open mask if needed */
if (ad->mask == 1) {
if ((mask_fd = open(ad->mask_name, O_RDONLY, 0755)) < 0)
@@ -523,20 +509,13 @@
return RLI_ERRORE;
- buf_sup = Rast_allocate_d_buf();
+ buf_null = Rast_allocate_d_buf();
- buf = Rast_allocate_d_buf();
+ Rast_set_d_null_value(buf_null, Rast_window_cols());
+ buf = buf_null;
- Rast_set_d_null_value(buf_sup + ad->x, ad->cl); /*the first time buf_sup is all null */
@@ -565,13 +544,8 @@
if (!(Rast_is_null_value(&corrCell, DCELL_TYPE))) {
area++;
- if (i > 0)
- if (j == 0)
- Rast_set_d_null_value(&supCell, 1);
- else
@@ -740,12 +714,14 @@
if (area != 0) {
@@ -780,7 +756,6 @@
@@ -823,31 +798,34 @@
*result = indice;
- if (masked)
+ if (masked) {
+ close(mask_fd);
G_free(mask_buf);
+ G_free(buf_null);
return RLI_OK;
int calculateF(int fd, struct area_entry *ad, struct Cell_head hd, double *result)
- FCELL *buf;
- FCELL *buf_sup;
+ FCELL *buf, *buf_sup, *buf_null;
FCELL corrCell;
FCELL precCell;
FCELL supCell;
int i, j;
int ris = 0;
int masked = FALSE;
long npatch = 0;
long tot = 0;
long zero = 0;
@@ -857,6 +835,7 @@
long doppi = 0;
+ long *ltmp;
double indice = 0;
@@ -864,11 +843,8 @@
avlID_table *array;
@@ -893,27 +869,19 @@
return RLI_ERRORE;
- buf_sup = Rast_allocate_f_buf();
+ buf_null = Rast_allocate_f_buf();
+ Rast_set_f_null_value(buf_null, Rast_window_cols());
+ buf = buf_null;
- buf = Rast_allocate_f_buf();
- Rast_set_f_null_value(buf_sup + ad->x, ad->cl); /*the first time buf_sup is all null */
- /*for each raster row */
+ /*for each raster row */
if (j > 0) {
buf_sup = RLI_get_fcell_raster_row(fd, j - 1 + ad->y, ad);
@@ -928,20 +896,14 @@
Rast_set_f_null_value(&precCell, 1);
for (i = 0; i < ad->cl; i++) { /*for each cell in the row */
corrCell = buf[i + ad->x];
if (((masked) && (mask_buf[i + ad->x] == 0))) {
Rast_set_f_null_value(&corrCell, 1);
if (!(Rast_is_null_value(&corrCell, FCELL_TYPE))) {
area++;
- if (i > 0)
- if (j == 0)
- Rast_set_f_null_value(&supCell, 1);
- else
@@ -1108,12 +1070,13 @@
if (area != 0) {
@@ -1187,14 +1150,18 @@
else
*result = indice;
+ if (masked) {
+ close(mask_fd);
+ G_free(mask_buf);
- if (masked)
- G_free(mask_buf);
-/* TODO: fix if? */
+ G_free(buf_null);
return RLI_OK;
