[GRASS-SVN] r58672 - grass/trunk/gui/wxpython/gmodeler
svn_grass at osgeo.org
Fri Jan 10 15:21:39 PST 2014
Author: martinl
Date: 2014-01-10 15:21:39 -0800 (Fri, 10 Jan 2014)
New Revision: 58672
grass/trunk/gui/wxpython/gmodeler/model.py
wxGUI/modeler: define UI when exporting to Python
improve _substituteVariable
Modified: grass/trunk/gui/wxpython/gmodeler/model.py
--- grass/trunk/gui/wxpython/gmodeler/model.py 2014-01-10 19:31:24 UTC (rev 58671)
+++ grass/trunk/gui/wxpython/gmodeler/model.py 2014-01-10 23:21:39 UTC (rev 58672)
@@ -2256,11 +2256,26 @@
self.indent = 4
self._writePython()
+ def _getStandardizedOption(self, string):
+ if string == 'raster':
+ return 'G_OPT_R_MAP'
+ elif string == 'vector':
+ return 'G_OPT_V_MAP'
+ elif string == 'mapset':
+ return 'G_OPT_M_MAPSET'
+ elif string == 'file':
+ return 'G_OPT_F_INPUT'
+ elif string == 'region':
+ return 'G_OPT_M_REGION'
+ return ''
def _writePython(self):
"""!Write model to file"""
properties = self.model.GetProperties()
+ # header
self.fd.write(
r"""#!/usr/bin/env python
@@ -2282,8 +2297,31 @@
time.asctime(),
'#' * 77))
+ # UI
self.fd.write(
r"""
+#%%module
+#%% description: %s
+#%%end
+""" % (EncodeString(' '.join(properties['description'].splitlines()))))
+ variables = self.model.GetVariables()
+ for key, data in variables.iteritems():
+ otype = self._getStandardizedOption(data['type'])
+ self.fd.write(
+r"""
+#%%option %s
+#%% key: %s
+#%% required: yes
+""" % (otype, key, data['description']))
+ if 'value' in data:
+ self.fd.write("#%% answer: %s\n" % data['value'])
+ self.fd.write("#% end\n")
+ # import modules
+ self.fd.write(
+r"""
import sys
import os
import atexit
@@ -2317,7 +2355,7 @@
self.fd.write("\ndef main():\n")
for item in self.model.GetItems():
- self._writePythonItem(item)
+ self._writePythonItem(item, variables = self.model.GetVariables())
self.fd.write("\n return 0\n")
@@ -2329,7 +2367,7 @@
sys.exit(main())
- def _writePythonItem(self, item, ignoreBlock = True, variables = []):
+ def _writePythonItem(self, item, ignoreBlock = True, variables = {}):
"""!Write model object to Python file"""
if isinstance(item, ModelAction):
if ignoreBlock and item.GetBlockId(): # ignore items in loops of conditions
@@ -2337,9 +2375,8 @@
self._writePythonAction(item, variables = variables)
elif isinstance(item, ModelLoop) or isinstance(item, ModelCondition):
# substitute condition
- variables = self.model.GetVariables()
cond = item.GetLabel()
- for variable in variables:
+ for variable in self.model.GetVariables():
pattern = re.compile('%' + variable)
if pattern.search(cond):
value = variables[variable].get('value', '')
@@ -2357,8 +2394,10 @@
cond += condText
self.fd.write('%s:\n' % cond)
self.indent += 4
+ variablesLoop = variables.copy()
+ variablesLoop[condVar] = None
for action in item.GetItems(self.model.GetItems(objType=ModelAction)):
- self._writePythonItem(action, ignoreBlock = False, variables = [condVar])
+ self._writePythonItem(action, ignoreBlock = False, variables = variablesLoop)
self.indent -= 4
if isinstance(item, ModelCondition):
self.fd.write('%sif %s:\n' % (' ' * self.indent, cond))
@@ -2377,13 +2416,13 @@
if isinstance(item, ModelComment):
self._writePythonComment(item)
- def _writePythonAction(self, item, variables = []):
+ def _writePythonAction(self, item, variables = {}):
"""!Write model action to Python file"""
- task = GUI(show = None).ParseCommand(cmd = item.GetLog(string = False, substitute = self.model.GetVariables()))
+ task = GUI(show = None).ParseCommand(cmd = item.GetLog(string = False))
strcmd = "%srun_command(" % (' ' * self.indent)
self.fd.write(strcmd + self._getPythonActionCmd(task, len(strcmd), variables) + '\n')
- def _getPythonActionCmd(self, task, cmdIndent, variables = []):
+ def _getPythonActionCmd(self, task, cmdIndent, variables = {}):
opts = task.get_options()
ret = ''
@@ -2404,11 +2443,13 @@
if name and value:
ptype = p.get('type', 'string')
foundVar = False
- for var in variables:
+ for var in sorted(variables, key=len, reverse=True):
+ data = variables[var]
if '%' + var in value:
- value = self._substituteVariable(value, var)
+ value = self._substituteVariable(value, var, data)
foundVar = True
if foundVar or ptype != 'string':
params.append("%s = %s" % (name, value))
else:
@@ -2432,22 +2473,33 @@
for line in item.GetLabel().splitlines():
self.fd.write('#' + line + '\n')
- def _substituteVariable(self, string, variable):
+ def _substituteVariable(self, string, variable, data):
"""!Substitute variable in the string
@param string string to be modified
@param variable variable to be substituted
+ @param data data related to the variable
@return modified string
result = ''
- ss = re.split(r"%"+variable, string)
- if len(ss) == 2:
- return variable
+ ss = re.split("\w*(%"+variable+")w*", string)
+ if not ss[0]:
+ if data:
+ return "options['%s']" % variable
+ else:
+ return variable
for s in ss:
- if not s:
- result += '+%s+' % variable
+ if s == '"':
+ continue
+ if s == '%' + variable:
+ if data:
+ result += "+options['%s']+" % variable
+ else:
+ result += '+%s+' % variable
else:
result += '"' + s + '"'
