[GRASS-SVN] r58673 - in grass/trunk: gui/wxpython/gui_core gui/wxpython/timeline lib/python/temporal
svn_grass at osgeo.org
Fri Jan 10 17:57:37 PST 2014
Author: huhabla
Date: 2014-01-10 17:57:36 -0800 (Fri, 10 Jan 2014)
New Revision: 58673
grass/trunk/gui/wxpython/gui_core/gselect.py
grass/trunk/gui/wxpython/timeline/frame.py
grass/trunk/lib/python/temporal/core.py
Fixed GUI crash when a fatal error occurs by calling the init() function of the temporal database
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py 2014-01-10 23:21:39 UTC (rev 58672)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py 2014-01-11 01:57:36 UTC (rev 58673)
@@ -51,6 +51,8 @@
import grass.script as grass
from grass.script import task as gtask
+from grass.pygrass import messages
+import grass.temporal as tgis
from gui_core.widgets import ManageSettingsWidget
@@ -334,6 +336,7 @@
self.extraItems = dict()
self.SetFilter(None)
+ self.tgis_error = False
def SetFilter(self, filter):
"""!Set filter for GIS elements, see e.g. VectorSelect"""
@@ -441,8 +444,10 @@
return
if element in ('stds', 'strds', 'str3ds', 'stvds'):
- import grass.temporal as tgis
- filesdict = tgis.tlist_grouped(elementdict[element], element == 'stds')
+ if self.tgis_error is False:
+ filesdict = tgis.tlist_grouped(elementdict[element], element == 'stds')
+ else:
+ filesdict = None
else:
if globalvar.have_mlist:
filesdict = grass.mlist_grouped(elementdict[element],
@@ -662,8 +667,13 @@
if 'type' in kargs:
self.type = kargs['type']
if self.type in ('stds', 'strds', 'str3ds', 'stvds'):
- tgis.init()
+ # Initiate the temporal framework. Catch database error
+ # and set the error flag for the stds listing.
+ try:
+ tgis.init(True)
+ except messages.FatalError, e:
+ sys.stderr.write("Temporal GIS error:\n%s" % e)
+ self.tgis_error = True
if 'mapsets' in kargs:
self.mapsets = kargs['mapsets']
if 'nmaps' in kargs:
Modified: grass/trunk/gui/wxpython/timeline/frame.py
--- grass/trunk/gui/wxpython/timeline/frame.py 2014-01-10 23:21:39 UTC (rev 58672)
+++ grass/trunk/gui/wxpython/timeline/frame.py 2014-01-11 01:57:36 UTC (rev 58673)
@@ -72,7 +72,7 @@
def __init__(self, parent):
wx.Frame.__init__(self, parent, id=wx.ID_ANY, title=_("Timeline Tool"))
- tgis.init()
+ tgis.init(True)
self.datasets = []
self.timeData = {}
self._layout()
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py 2014-01-10 23:21:39 UTC (rev 58672)
+++ grass/trunk/lib/python/temporal/core.py 2014-01-11 01:57:36 UTC (rev 58673)
@@ -267,7 +267,7 @@
raise_on_error = False
def set_raise_on_error(raise_exp=True):
- """!Define behaviour on fatal error, invoked using the tgis messenger
+ """!Define behavior on fatal error, invoked using the tgis messenger
interface (msgr.fatal())
The messenger interface will be restarted using the new error policy
@@ -406,7 +406,7 @@
-def init():
+def init(raise_fatal_error=False):
"""!This function set the correct database backend from GRASS environmental variables
and creates the grass temporal database structure for raster,
vector and raster3d maps as well as for the space-time datasets strds,
@@ -432,6 +432,13 @@
ATTENTION: This functions must be called before any spatio-temporal processing
can be started
+ @param raise_fatal_error Set this True to assure that the init() function
+ does not kill a persistent process like the GUI.
+ If set True a grass.pygrass.messages.FatalError
+ exception will be raised in case a fatal error occurs
+ in the init process, otherwise sys.exit(1) will be called.
# We need to set the correct database backend and several global variables
# from the GRASS mapset specific environment variables of g.gisenv and t.connect
@@ -445,13 +452,14 @@
global current_mapset
global current_location
global current_gisdbase
+ raise_on_error = raise_fatal_error
# We must run t.connect at first to create the temporal database and to
# get the environmental variables
core.run_command("t.connect", flags="c")
kv = core.parse_command("t.connect", flags="pg")
grassenv = core.gisenv()
- raise_on_error = False
# Set the global variable for faster access
current_mapset = grassenv["MAPSET"]
@@ -459,7 +467,7 @@
current_gisdbase = grassenv["GISDBASE"]
# Check environment variable GRASS_TGIS_RAISE_ON_ERROR
- if os.getenv("GRASS_TGIS_RAISE_ON_ERROR") is "True" or os.getenv("GRASS_TGIS_RAISE_ON_ERROR") is "1":
+ if os.getenv("GRASS_TGIS_RAISE_ON_ERROR") == "True" or os.getenv("GRASS_TGIS_RAISE_ON_ERROR") == "1":
raise_on_error = True
# Check if the script library raises on error,
@@ -472,7 +480,7 @@
# Start the C-library interface server
_init_tgis_c_library_interface()
msgr = get_tgis_message_interface()
- msgr.debug(1, "Inititate the temporal database")
+ msgr.debug(1, "Initiate the temporal database")
# Set the mapset check and the timestamp write
if grassenv.has_key("TGIS_DISABLE_MAPSET_CHECK"):
