[GRASS-SVN] r58689 - grass/trunk/gui/wxpython/gui_core
svn_grass at osgeo.org
Sun Jan 12 15:03:05 PST 2014
Author: annakrat
Date: 2014-01-12 15:03:05 -0800 (Sun, 12 Jan 2014)
New Revision: 58689
grass/trunk/gui/wxpython/gui_core/prompt.py
wxGUI/prompt: fix #1963 ('ls -' error); improve autocompletion just after command
Modified: grass/trunk/gui/wxpython/gui_core/prompt.py
--- grass/trunk/gui/wxpython/gui_core/prompt.py 2014-01-12 23:02:41 UTC (rev 58688)
+++ grass/trunk/gui/wxpython/gui_core/prompt.py 2014-01-12 23:03:05 UTC (rev 58689)
@@ -298,54 +298,51 @@
"""!Determines which part of command (flags, parameters) should
be completed at current cursor position"""
entry = self.GetTextLeft()
- toComplete = dict()
+ toComplete = dict(cmd=None, entity=None)
try:
cmd = entry.split()[0].strip()
except IndexError:
- return None
+ return toComplete
try:
splitted = utils.split(str(entry))
except ValueError: # No closing quotation error
- return None
- if len(splitted) > 1:
- if cmd in globalvar.grassCmd:
- toComplete['cmd'] = cmd
- if entry[-1] == ' ':
- words = entry.split(' ')
- if any(word.startswith('-') for word in words):
- toComplete['entity'] = 'params'
- else:
- toComplete['entity'] = 'params+flags'
+ return toComplete
+ if len(splitted) > 0 and cmd in globalvar.grassCmd:
+ toComplete['cmd'] = cmd
+ if entry[-1] == ' ':
+ words = entry.split(' ')
+ if any(word.startswith('-') for word in words):
+ toComplete['entity'] = 'params'
else:
- # get word left from current position
- word = self.GetWordLeft(withDelimiter = True)
- if word[0] == '=' and word[-1] == '@':
- toComplete['entity'] = 'mapsets'
- elif word[0] == '=':
- # get name of parameter
- paramName = self.GetWordLeft(withDelimiter = False, ignoredDelimiter = '=').strip('=')
- if paramName:
- try:
- param = self.cmdDesc.get_param(paramName)
- except (ValueError, AttributeError):
- return None
- else:
- return None
- if param['values']:
- toComplete['entity'] = 'param values'
- elif param['prompt'] == 'raster' and param['element'] == 'cell':
- toComplete['entity'] = 'raster map'
- elif param['prompt'] == 'vector' and param['element'] == 'vector':
- toComplete['entity'] = 'vector map'
- elif word[0] == '-':
- toComplete['entity'] = 'flags'
- elif word[0] == ' ':
+ toComplete['entity'] = 'params+flags'
else:
- return None
+ # get word left from current position
+ word = self.GetWordLeft(withDelimiter = True)
+ if word[0] == '=' and word[-1] == '@':
+ toComplete['entity'] = 'mapsets'
+ elif word[0] == '=':
+ # get name of parameter
+ paramName = self.GetWordLeft(withDelimiter = False, ignoredDelimiter = '=').strip('=')
+ if paramName:
+ try:
+ param = self.cmdDesc.get_param(paramName)
+ except (ValueError, AttributeError):
+ return toComplete
+ else:
+ return toComplete
+ if param['values']:
+ toComplete['entity'] = 'param values'
+ elif param['prompt'] == 'raster' and param['element'] == 'cell':
+ toComplete['entity'] = 'raster map'
+ elif param['prompt'] == 'vector' and param['element'] == 'vector':
+ toComplete['entity'] = 'vector map'
+ elif word[0] == '-':
+ toComplete['entity'] = 'flags'
+ elif word[0] == ' ':
else:
toComplete['entity'] = 'command'
@@ -393,8 +390,6 @@
self.InsertText(pos, '.')
self.CharRight()
self.toComplete = self.EntityToComplete()
- if self.toComplete is None:
- return
try:
if self.toComplete['entity'] == 'command':
for command in globalvar.grassCmd:
@@ -433,14 +428,13 @@
self.InsertText(pos, '=')
self.CharRight()
- if self.toComplete and 'entity' in self.toComplete:
- if self.toComplete['entity'] == 'raster map':
- self.autoCompList = self.mapList['raster']
- elif self.toComplete['entity'] == 'vector map':
- self.autoCompList = self.mapList['vector']
- elif self.toComplete['entity'] == 'param values':
- param = self.GetWordLeft(withDelimiter = False, ignoredDelimiter='=').strip(' =')
- self.autoCompList = self.cmdDesc.get_param(param)['values']
+ if self.toComplete['entity'] == 'raster map':
+ self.autoCompList = self.mapList['raster']
+ elif self.toComplete['entity'] == 'vector map':
+ self.autoCompList = self.mapList['vector']
+ elif self.toComplete['entity'] == 'param values':
+ param = self.GetWordLeft(withDelimiter = False, ignoredDelimiter='=').strip(' =')
+ self.autoCompList = self.cmdDesc.get_param(param)['values']
self.ShowList()
# complete mapset ('@')
@@ -450,7 +444,7 @@
self.CharRight()
- if self.toComplete and self.toComplete['entity'] == 'mapsets':
+ if self.toComplete['entity'] == 'mapsets':
self.autoCompList = self.mapsetList
self.ShowList()
@@ -458,8 +452,6 @@
elif event.GetKeyCode() == wx.WXK_SPACE and event.ControlDown():
self.autoCompList = list()
- return
#complete command
