[GRASS-SVN] r58690 - grass/branches/releasebranch_6_4/gui/wxpython/gui_core
svn_grass at osgeo.org
Sun Jan 12 15:04:03 PST 2014
Author: annakrat
Date: 2014-01-12 15:04:03 -0800 (Sun, 12 Jan 2014)
New Revision: 58690
grass/branches/releasebranch_6_4/gui/wxpython/gui_core/prompt.py
wxGUI/prompt: fix #1963 ('ls -' error); improve autocompletion just after command (merge from trunk, r58689)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_core/prompt.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_core/prompt.py 2014-01-12 23:03:05 UTC (rev 58689)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_core/prompt.py 2014-01-12 23:04:03 UTC (rev 58690)
@@ -857,54 +857,51 @@
"""!Determines which part of command (flags, parameters) should
be completed at current cursor position"""
entry = self.GetTextLeft()
- toComplete = dict()
+ toComplete = dict(cmd=None, entity=None)
try:
cmd = entry.split()[0].strip()
except IndexError:
- return None
+ return toComplete
try:
splitted = utils.split(str(entry))
except ValueError: # No closing quotation error
- return None
- if len(splitted) > 1:
- if cmd in globalvar.grassCmd:
- toComplete['cmd'] = cmd
- if entry[-1] == ' ':
- words = entry.split(' ')
- if any(word.startswith('-') for word in words):
- toComplete['entity'] = 'params'
+ return toComplete
+ if len(splitted) > 0 and cmd in globalvar.grassCmd:
+ toComplete['cmd'] = cmd
+ if entry[-1] == ' ':
+ words = entry.split(' ')
+ if any(word.startswith('-') for word in words):
+ toComplete['entity'] = 'params'
+ else:
+ toComplete['entity'] = 'params+flags'
+ else:
+ # get word left from current position
+ word = self.GetWordLeft(withDelimiter = True)
+ if word[0] == '=' and word[-1] == '@':
+ toComplete['entity'] = 'mapsets'
+ elif word[0] == '=':
+ # get name of parameter
+ paramName = self.GetWordLeft(withDelimiter = False, ignoredDelimiter = '=').strip('=')
+ if paramName:
+ try:
+ param = self.cmdDesc.get_param(paramName)
+ except (ValueError, AttributeError):
+ return toComplete
else:
- toComplete['entity'] = 'params+flags'
- else:
- # get word left from current position
- word = self.GetWordLeft(withDelimiter = True)
+ return toComplete
- if word[0] == '=' and word[-1] == '@':
- toComplete['entity'] = 'mapsets'
- elif word[0] == '=':
- # get name of parameter
- paramName = self.GetWordLeft(withDelimiter = False, ignoredDelimiter = '=').strip('=')
- if paramName:
- try:
- param = self.cmdDesc.get_param(paramName)
- except (ValueError, AttributeError):
- return None
- else:
- return None
- if param['values']:
- toComplete['entity'] = 'param values'
- elif param['prompt'] == 'raster' and param['element'] == 'cell':
- toComplete['entity'] = 'raster map'
- elif param['prompt'] == 'vector' and param['element'] == 'vector':
- toComplete['entity'] = 'vector map'
- elif word[0] == '-':
- toComplete['entity'] = 'flags'
- elif word[0] == ' ':
- else:
- return None
+ if param['values']:
+ toComplete['entity'] = 'param values'
+ elif param['prompt'] == 'raster' and param['element'] == 'cell':
+ toComplete['entity'] = 'raster map'
+ elif param['prompt'] == 'vector' and param['element'] == 'vector':
+ toComplete['entity'] = 'vector map'
+ elif word[0] == '-':
+ toComplete['entity'] = 'flags'
+ elif word[0] == ' ':
else:
toComplete['entity'] = 'command'
@@ -954,7 +951,14 @@
self.toComplete = self.EntityToComplete()
try:
if self.toComplete['entity'] == 'command':
- self.autoCompList = self.moduleList[entry.strip()]
+ for command in globalvar.grassCmd:
+ try:
+ if command.find(self.toComplete['cmd']) == 0:
+ dotNumber = list(self.toComplete['cmd']).count('.')
+ self.autoCompList.append(command.split('.',dotNumber)[-1])
+ except UnicodeDecodeError, e: # TODO: fix it
+ sys.stderr.write(DecodeString(command) + ": " + unicode(e))
except (KeyError, TypeError):
return
self.ShowList()
@@ -983,14 +987,13 @@
self.InsertText(pos, '=')
self.CharRight()
- if self.toComplete and 'entity' in self.toComplete:
- if self.toComplete['entity'] == 'raster map':
- self.autoCompList = self.mapList['raster']
- elif self.toComplete['entity'] == 'vector map':
- self.autoCompList = self.mapList['vector']
- elif self.toComplete['entity'] == 'param values':
- param = self.GetWordLeft(withDelimiter = False, ignoredDelimiter='=').strip(' =')
- self.autoCompList = self.cmdDesc.get_param(param)['values']
+ if self.toComplete['entity'] == 'raster map':
+ self.autoCompList = self.mapList['raster']
+ elif self.toComplete['entity'] == 'vector map':
+ self.autoCompList = self.mapList['vector']
+ elif self.toComplete['entity'] == 'param values':
+ param = self.GetWordLeft(withDelimiter = False, ignoredDelimiter='=').strip(' =')
+ self.autoCompList = self.cmdDesc.get_param(param)['values']
self.ShowList()
# complete mapset ('@')
@@ -1000,7 +1003,7 @@
self.CharRight()
- if self.toComplete and self.toComplete['entity'] == 'mapsets':
+ if self.toComplete['entity'] == 'mapsets':
self.autoCompList = self.mapsetList
self.ShowList()
