[GRASS-SVN] r58789 - grass/trunk/misc/m.nviz.image
Mon Jan 27 17:57:55 PST 2014
Author: hamish
Date: 2014-01-27 17:57:55 -0800 (Mon, 27 Jan 2014)
New Revision: 58789
   grass/trunk/misc/m.nviz.image/args.c
   grass/trunk/misc/m.nviz.image/local_proto.h
   grass/trunk/misc/m.nviz.image/main.c
   grass/trunk/misc/m.nviz.image/surface.c
   grass/trunk/misc/m.nviz.image/vector.c
   grass/trunk/misc/m.nviz.image/volume.c
   grass/trunk/misc/m.nviz.image/write_img.c
run grass_indent.sh
Modified: grass/trunk/misc/m.nviz.image/args.c
--- grass/trunk/misc/m.nviz.image/args.c	2014-01-27 19:06:00 UTC (rev 58788)
+++ grass/trunk/misc/m.nviz.image/args.c	2014-01-28 01:57:55 UTC (rev 58789)
@@ -1,17 +1,17 @@
-  \file args.c
-  \brief Parse command
-  (C) 2008, 2010-2011 by the GRASS Development Team
-  This program is free software under the GNU General Public
-  License (>=v2). Read the file COPYING that comes with GRASS
-  for details.
-  \author Martin Landa <landa.martin gmail.com> (Google SoC 2008/2010)
+   \file args.c
+   \brief Parse command
+   (C) 2008, 2010-2011 by the GRASS Development Team
+   This program is free software under the GNU General Public
+   License (>=v2). Read the file COPYING that comes with GRASS
+   for details.
+   \author Martin Landa <landa.martin gmail.com> (Google SoC 2008/2010)
 #include <stdlib.h>
 #include <string.h>
@@ -35,14 +35,14 @@
 static void args_arrow(struct GParams *);
-  \param argc number of arguments
-  \param argv arguments array
-  \param params GRASS parameters
-  \return 1
+   \param argc number of arguments
+   \param argv arguments array
+   \param params GRASS parameters
+   \return 1
 void parse_command(int argc, char *argv[], struct GParams *params)
     params->mode_all = G_define_flag();
@@ -50,7 +50,7 @@
     params->mode_all->description =
 	_("Use draw mode for all loaded surfaces");
     params->mode_all->guisection = _("Surfaces");
     /*** surface attributes ***/
     args_surface(params);
@@ -81,7 +81,7 @@
     /*** north arrow ***/
     args_arrow(params);
     /*** output image ***/
     /* output */
     params->output = G_define_standard_option(G_OPT_F_OUTPUT);
@@ -152,7 +152,7 @@
     params->color_const->label = _("Color value(s)");
     params->color_const->guisection = _("Surfaces");
     params->color_const->answer = NULL;
     /* mask */
     params->mask_map = G_define_standard_option(G_OPT_R_MAP);
     params->mask_map->multiple = YES;
@@ -216,9 +216,7 @@
     params->emit_const->guisection = _("Surfaces");
     params->emit_const->options = "0-255";
-       draw
+    /* draw */
     /* mode */
     params->mode = G_define_option();
     params->mode->key = "mode";
@@ -296,7 +294,7 @@
     params->surface_pos->description = _("Surface position");
     params->surface_pos->guisection = _("Draw");
     params->surface_pos->answer = "0,0,0";
     return;
@@ -312,7 +310,8 @@
     params->vline_layer = G_define_standard_option(G_OPT_V_FIELD);
     params->vline_layer->multiple = YES;
     params->vline_layer->required = NO;
-    params->vline_layer->description = _("Layer number or name for thematic mapping");
+    params->vline_layer->description =
+	_("Layer number or name for thematic mapping");
     params->vline_layer->guisection = _("Vector lines");
     params->vline_layer->key = "vline_layer";
     params->vline_layer->answer = "1";
@@ -404,7 +403,8 @@
     params->vpoint_layer = G_define_standard_option(G_OPT_V_FIELD);
     params->vpoint_layer->multiple = YES;
     params->vpoint_layer->required = NO;
-    params->vpoint_layer->description = _("Layer number or name for thematic mapping");
+    params->vpoint_layer->description =
     params->vpoint_layer->guisection = _("Vector points");
     params->vpoint_layer->key = "vpoint_layer";
     params->vpoint_layer->answer = "1";
@@ -479,7 +479,8 @@
     params->vpoint_marker_column = G_define_standard_option(G_OPT_DB_COLUMN);
     params->vpoint_marker_column->multiple = YES;
     params->vpoint_marker_column->required = NO;
-    params->vpoint_marker_column->label = _("Name of marker definition column");
+    params->vpoint_marker_column->label =
+	_("Name of marker definition column");
     params->vpoint_marker_column->key = "vpoint_marker_column";
     params->vpoint_marker_column->guisection = _("Vector points");
@@ -494,7 +495,7 @@
     params->vpoint_mode->options = "surface,3D";
     params->vpoint_mode->descriptions = _("surface;drape on raster surface;"
 					  "3D;place at 3D point's z-elevation");
-					  /* TODO: "flat", place at a constant elevation */
+    /* TODO: "flat", place at a constant elevation */
     params->vpoint_mode->answer = "3D";
     params->vpoint_mode->guisection = _("Vector points");
@@ -508,7 +509,7 @@
     params->vpoint_pos->description = _("Vector points position");
     params->vpoint_pos->guisection = _("Vector points");
     params->vpoint_pos->answer = "0,0,0";
     return;
@@ -577,9 +578,10 @@
     params->focus->type = TYPE_DOUBLE;
     params->focus->required = NO;
     params->focus->multiple = NO;
-    params->focus->description = _("Focus to point on surface (from SW corner in map units)");
+    params->focus->description =
+	_("Focus to point on surface (from SW corner in map units)");
     params->focus->guisection = _("Viewpoint");
     return;
@@ -624,7 +626,7 @@
     params->volume_pos->description = _("Volume position");
     params->volume_pos->guisection = _("Volumes");
     params->volume_pos->answer = "0,0,0";
     /* resolution  */
     params->volume_res = G_define_option();
     params->volume_res->key = "volume_resolution";
@@ -645,13 +647,14 @@
     params->isosurf_level->multiple = YES;
     params->isosurf_level->description = _("Isosurface level");
     params->isosurf_level->guisection = _("Volumes");
     /* isosurface color map */
     params->isosurf_color_map = G_define_standard_option(G_OPT_R3_MAPS);
     params->isosurf_color_map->key = "isosurf_color_map";
     params->isosurf_color_map->required = NO;
     params->isosurf_color_map->multiple = YES;
-    params->isosurf_color_map->description = _("Name of volume for isosurface color");
+    params->isosurf_color_map->description =
+	_("Name of volume for isosurface color");
     params->isosurf_color_map->guisection = _("Volumes");
     /* isosurface color value */
@@ -678,15 +681,17 @@
     params->isosurf_transp_const->type = TYPE_INTEGER;
     params->isosurf_transp_const->required = NO;
     params->isosurf_transp_const->multiple = YES;
-    params->isosurf_transp_const->description = _("Transparency value(s)for isosurfaces");
+    params->isosurf_transp_const->description =
+	_("Transparency value(s)for isosurfaces");
     params->isosurf_transp_const->guisection = _("Volumes");
     params->isosurf_transp_const->options = "0-255";
     /* isosurface shininess */
     params->isosurf_shine_map = G_define_standard_option(G_OPT_R3_MAP);
     params->isosurf_shine_map->multiple = YES;
     params->isosurf_shine_map->required = NO;
-    params->isosurf_shine_map->description = _("Name of 3D raster map(s) for shininess");
+    params->isosurf_shine_map->description =
+	_("Name of 3D raster map(s) for shininess");
     params->isosurf_shine_map->guisection = _("Volumes");
     params->isosurf_shine_map->key = "isosurf_shininess_map";
@@ -696,7 +701,8 @@
     params->isosurf_shine_const->type = TYPE_INTEGER;
     params->isosurf_shine_const->required = NO;
     params->isosurf_shine_const->multiple = YES;
-    params->isosurf_shine_const->description = _("Shininess value(s) for isosurfaces");
+    params->isosurf_shine_const->description =
+	_("Shininess value(s) for isosurfaces");
     params->isosurf_shine_const->guisection = _("Volumes");
     params->isosurf_shine_const->options = "0-255";
@@ -720,7 +726,8 @@
     params->slice->type = TYPE_STRING;
     params->slice->required = NO;
     params->slice->multiple = YES;
-    params->slice->description = _("Volume slice parallel to given axis (x, y, z)");
+    params->slice->description =
+	_("Volume slice parallel to given axis (x, y, z)");
     params->slice->guisection = _("Volumes");
     /* slice position */
@@ -733,7 +740,7 @@
     params->slice_pos->description = _("Volume slice position");
     params->slice_pos->guisection = _("Volumes");
     params->slice_pos->answer = "0,1,0,1,0,1";
     /* slice transparency */
     params->slice_transp = G_define_option();
     params->slice_transp->key = "slice_transparency";
@@ -767,16 +774,16 @@
     params->light_color->label = _("Light color");
     params->light_color->guisection = _("Lighting");
     params->light_color->answer = "white";
     params->light_bright = G_define_option();
     params->light_bright->key = "light_brightness";
     params->light_bright->type = TYPE_INTEGER;
     params->light_bright->required = NO;
     params->light_bright->multiple = NO;
-    params->light_bright->description =	_("Light brightness");
+    params->light_bright->description = _("Light brightness");
     params->light_bright->guisection = _("Lighting");
     params->light_bright->answer = "80";
-    params->light_bright->options="0-100";
+    params->light_bright->options = "0-100";
     params->light_ambient = G_define_option();
     params->light_ambient->key = "light_ambient";
@@ -786,7 +793,7 @@
     params->light_ambient->description = _("Light ambient");
     params->light_ambient->guisection = _("Lighting");
     params->light_ambient->answer = "20";
-    params->light_ambient->options="0-100";
+    params->light_ambient->options = "0-100";
 void args_cplane(struct GParams *params)
@@ -799,7 +806,7 @@
     params->cplane->multiple = YES;
     params->cplane->description = _("Cutting plane index (0-5)");
     params->cplane->guisection = _("Cutting planes");
     params->cplane_pos = G_define_option();
     params->cplane_pos->key = "cplane_position";
     params->cplane_pos->key_desc = "x,y,z";
@@ -809,7 +816,7 @@
     params->cplane_pos->description = _("Cutting plane x,y,z coordinates");
     params->cplane_pos->guisection = _("Cutting planes");
     params->cplane_pos->answer = "0,0,0";
     params->cplane_rot = G_define_option();
     params->cplane_rot->key = "cplane_rotation";
     params->cplane_rot->key_desc = "value";
@@ -817,10 +824,11 @@
     params->cplane_rot->multiple = YES;
     params->cplane_rot->required = NO;
     params->cplane_rot->guisection = _("Cutting planes");
-    params->cplane_rot->description = _("Cutting plane rotation along the vertical axis");
+    params->cplane_rot->description =
+	_("Cutting plane rotation along the vertical axis");
     params->cplane_rot->answer = "0";
-    params->cplane_rot->options="0-360";
+    params->cplane_rot->options = "0-360";
     params->cplane_tilt = G_define_option();
     params->cplane_tilt->key = "cplane_tilt";
     params->cplane_tilt->key_desc = "value";
@@ -830,8 +838,8 @@
     params->cplane_tilt->guisection = _("Cutting planes");
     params->cplane_tilt->description = _("Cutting plane tilt");
     params->cplane_tilt->answer = "0";
-    params->cplane_tilt->options="0-360";
+    params->cplane_tilt->options = "0-360";
     params->cplane_shading = G_define_option();
     params->cplane_shading->key = "cplane_shading";
     params->cplane_shading->key_desc = "string";
@@ -839,37 +847,37 @@
     params->cplane_shading->multiple = NO;
     params->cplane_shading->required = NO;
     params->cplane_shading->guisection = _("Cutting planes");
-    params->cplane_shading->description = _("Cutting plane color (between two surfaces)");
+    params->cplane_shading->description =
+	_("Cutting plane color (between two surfaces)");
     params->cplane_shading->answer = "clear";
-    params->cplane_shading->options= "clear,top,bottom,blend,shaded";
+    params->cplane_shading->options = "clear,top,bottom,blend,shaded";
 void args_fringe(struct GParams *params)
     char *desc;
     params->fringe = G_define_option();
     params->fringe->key = "fringe";
     params->fringe->type = TYPE_STRING;
     params->fringe->options = "nw,ne,sw,se";
     desc = NULL;
     G_asprintf(&desc,
-	        "nw;%s;ne;%s;sw;%s;se;%s",
-	        _("North-West edge"),
-	        _("North-East edge"),
-	        _("South-West edge"),
-	        _("South-East edge"));
+	       "nw;%s;ne;%s;sw;%s;se;%s",
+	       _("North-West edge"),
+	       _("North-East edge"),
+	       _("South-West edge"), _("South-East edge"));
     params->fringe->descriptions = desc;
     params->fringe->description = _("Fringe edges");
     params->fringe->guisection = _("Fringe");
     params->fringe->multiple = YES;
     params->fringe_color = G_define_standard_option(G_OPT_C_FG);
     params->fringe_color->key = "fringe_color";
     params->fringe_color->label = _("Fringe color");
     params->fringe_color->guisection = _("Fringe");
     params->fringe_color->answer = "grey";
     params->fringe_elev = G_define_option();
     params->fringe_elev->key = "fringe_elevation";
     params->fringe_elev->type = TYPE_INTEGER;
@@ -888,19 +896,21 @@
     params->north_arrow->type = TYPE_INTEGER;
     params->north_arrow->required = NO;
     params->north_arrow->multiple = NO;
-    params->north_arrow->description = _("Place north arrow at given position \
+    params->north_arrow->description =
+	_("Place north arrow at given position \
 	(in screen coordinates from bottom left corner)");
     params->north_arrow->guisection = _("Decoration");
     params->north_arrow_size = G_define_option();
     params->north_arrow_size->key = "arrow_size";
     params->north_arrow_size->key_desc = "value";
     params->north_arrow_size->type = TYPE_DOUBLE;
     params->north_arrow_size->required = NO;
     params->north_arrow_size->multiple = NO;
-    params->north_arrow_size->description = _("North arrow size (in map units)");
+    params->north_arrow_size->description =
+	_("North arrow size (in map units)");
     params->north_arrow_size->guisection = _("Decoration");
     params->north_arrow_color = G_define_standard_option(G_OPT_C_FG);
     params->north_arrow_color->key = "arrow_color";
     params->north_arrow_color->required = NO;
@@ -930,14 +940,14 @@
     G_debug(3, "opt_get_num_answers(): opt=%s num=%d", opt->key, i);
     return i;
-  \brief Check parameters consistency
-  \param params module parameters
+   \brief Check parameters consistency
+   \param params module parameters
 void check_parameters(const struct GParams *params)
@@ -947,7 +957,7 @@
     int nvlines;
     int nvpoints, nvpoints_pos, nvpoints_layer;
     int nvolumes, nisosurf, nslices;
     /* topography */
@@ -1035,25 +1045,28 @@
 			  params->elev_map->key, params->elev_const->key,
 			  nelevs, params->wire_color->key, nconsts);
      * Cutting planes
     ncplanes = opt_get_num_answers(params->cplane);
     ncoords = opt_get_num_answers(params->cplane_pos);
-	if (ncplanes > 0 && ncplanes * 3 != ncoords)
-	    G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d x 3)"),
-			  params->cplane->key, ncplanes, params->cplane_pos->key, ncoords/3);
+    if (ncplanes > 0 && ncplanes * 3 != ncoords)
+	G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d x 3)"),
+		      params->cplane->key, ncplanes, params->cplane_pos->key,
+		      ncoords / 3);
     nconsts = opt_get_num_answers(params->cplane_rot);
     if (ncplanes > 0 && ncplanes != nconsts)
-        G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d)"),
-          params->cplane->key, ncplanes, params->cplane_rot->key, nconsts);
+	G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d)"),
+		      params->cplane->key, ncplanes, params->cplane_rot->key,
+		      nconsts);
     nconsts = opt_get_num_answers(params->cplane_tilt);
-          params->cplane->key, ncplanes, params->cplane_tilt->key, nconsts);
+		      params->cplane->key, ncplanes, params->cplane_tilt->key,
+		      nconsts);
      * vector lines
@@ -1087,7 +1100,7 @@
 		      params->vlines->key, nvlines, params->vline_height->key,
 		      nconsts);
     /* position */
     nconsts = opt_get_num_answers(params->vline_pos);
     if (nvlines > 0 && nconsts != 3 * nvlines)
@@ -1104,15 +1117,17 @@
     if (nvpoints && (nvpoints * 3 != nvpoints_pos))
-		      params->vpoints->key, nvpoints, params->vpoint_pos->key, nvpoints_pos);
+		      params->vpoints->key, nvpoints, params->vpoint_pos->key,
+		      nvpoints_pos);
     if (nvpoints && (nvpoints != nvpoints_layer))
-		      params->vpoints->key, nvpoints, params->vpoint_layer->key, nvpoints_layer);
+		      params->vpoint_layer->key, nvpoints_layer);
     /* TODO */
      * volumes
@@ -1126,7 +1141,8 @@
     if ((nmaps + nconsts > 0) && (nisosurf != nmaps + nconsts))
 	G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d, <%s> %d)"),
-		      params->isosurf_level->key, nisosurf, params->isosurf_transp_map->key, nmaps,
+		      params->isosurf_level->key, nisosurf,
+		      params->isosurf_transp_map->key, nmaps,
 		      params->isosurf_transp_const->key, nconsts);
@@ -1135,20 +1151,23 @@
-			params->isosurf_level->key, nisosurf, params->isosurf_shine_map->key, nmaps,
-			params->isosurf_shine_const->key, nconsts);
+		      params->isosurf_shine_map->key, nmaps,
+		      params->isosurf_shine_const->key, nconsts);
     nconsts = opt_get_num_answers(params->slice_transp);
     if (nslices > 0 && nslices != nconsts)
-			params->slice->key, nslices, params->slice_transp->key, nconsts);
+		      params->slice->key, nslices, params->slice_transp->key,
+		      nconsts);
     ncoords = opt_get_num_answers(params->slice_pos);
     if (nslices > 0 && ncoords != 6 * nslices)
 	G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d x 6)"),
-			  params->slice->key, nslices, params->slice_pos->key, ncoords/6);
+		      params->slice->key, nslices, params->slice_pos->key,
+		      ncoords / 6);
     return;
Modified: grass/trunk/misc/m.nviz.image/local_proto.h
--- grass/trunk/misc/m.nviz.image/local_proto.h	2014-01-27 19:06:00 UTC (rev 58788)
+++ grass/trunk/misc/m.nviz.image/local_proto.h	2014-01-28 01:57:55 UTC (rev 58789)
@@ -10,38 +10,39 @@
     struct Flag *isosurf_toggle_norm_dir;
     struct Flag *draw_volume_box;
-    struct Option
-    /* surface */
-    *elev_map, *elev_const, *color_map, *color_const,
+    struct Option
+	/* surface */
+     *elev_map, *elev_const, *color_map, *color_const,
 	*mask_map, *transp_map, *transp_const, *shine_map, *shine_const,
 	*emit_map, *emit_const,
-    /* surface draw mode */
-	*mode, *res_fine, *res_coarse, *style, *shade, *wire_color, *surface_pos,
-    /* vector lines */
-	*vlines, *vline_width, *vline_color, *vline_mode, *vline_height, *vline_pos,
-	*vline_layer, *vline_color_column, *vline_width_column,
-    /* vector points */
-	*vpoints, *vpoint_size, *vpoint_mode, *vpoint_marker, *vpoint_color,
+	/* surface draw mode */
+     *mode, *res_fine, *res_coarse, *style, *shade, *wire_color, *surface_pos,
+	/* vector lines */
+     *vlines, *vline_width, *vline_color, *vline_mode, *vline_height,
+	*vline_pos, *vline_layer, *vline_color_column, *vline_width_column,
+	/* vector points */
+     *vpoints, *vpoint_size, *vpoint_mode, *vpoint_marker, *vpoint_color,
 	*vpoint_width, *vpoint_pos, *vpoint_layer, *vpoint_size_column,
 	*vpoint_marker_column, *vpoint_color_column, *vpoint_width_column,
-    /* volumes */
-	*volume, *volume_mode, *volume_shade, *volume_pos, *volume_res, *isosurf_level,
-	*isosurf_color_map, *isosurf_color_const, *isosurf_transp_map, *isosurf_transp_const,
-	*isosurf_shine_map, *isosurf_shine_const, *slice_pos, *slice, *slice_transp,
-    /* misc */
-	*exag, *bgcolor,
-    /* cutting planes */
-       *cplane, *cplane_pos, *cplane_rot, *cplane_tilt, *cplane_shading,
-    /* viewpoint */
-	*pos, *height, *persp, *twist, *focus,
-    /* output */
-	*output, *format, *size,
-    /* lighting */
-	*light_pos, *light_color, *light_bright, *light_ambient,
-    /* fringe */
-	*fringe, *fringe_color, *fringe_elev,
-    /* north arrow */
-	*north_arrow, *north_arrow_size, *north_arrow_color;
+	/* volumes */
+     *volume, *volume_mode, *volume_shade, *volume_pos, *volume_res,
+	*isosurf_level, *isosurf_color_map, *isosurf_color_const,
+	*isosurf_transp_map, *isosurf_transp_const, *isosurf_shine_map,
+	*isosurf_shine_const, *slice_pos, *slice, *slice_transp,
+	/* misc */
+     *exag, *bgcolor,
+	/* cutting planes */
+     *cplane, *cplane_pos, *cplane_rot, *cplane_tilt, *cplane_shading,
+	/* viewpoint */
+     *pos, *height, *persp, *twist, *focus,
+	/* output */
+     *output, *format, *size,
+	/* lighting */
+     *light_pos, *light_color, *light_bright, *light_ambient,
+	/* fringe */
+     *fringe, *fringe_color, *fringe_elev,
+	/* north arrow */
+     *north_arrow, *north_arrow_size, *north_arrow_color;
 /* args.c */
Modified: grass/trunk/misc/m.nviz.image/main.c
--- grass/trunk/misc/m.nviz.image/main.c	2014-01-27 19:06:00 UTC (rev 58788)
+++ grass/trunk/misc/m.nviz.image/main.c	2014-01-28 01:57:55 UTC (rev 58789)
@@ -6,9 +6,9 @@
  * AUTHOR(S):    Martin Landa <landa.martin gmail.com> (Google SoC 2008/2010)
  *               Anna Kratochvilova (Google SoC 2011)
- * PURPOSE:      Renders GIS data in 3D space.
+ * PURPOSE:      Renders GIS data in 3D space from the command line.
- * COPYRIGHT:    (C) 2008, 2010-2011 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2008-2014 by the GRASS Development Team
  *               This program is free software under the GNU General
  *               Public License (>=v2). Read the file COPYING that
@@ -39,7 +39,7 @@
     double vp_height, z_exag;	/* calculated viewpoint height, z-exag */
     int width, height;		/* output image size */
     char *output_name;
     nv_data data;
     struct render_window *offscreen;
@@ -79,7 +79,7 @@
     offscreen = Nviz_new_render_window();
     Nviz_init_render_window(offscreen);
     if (Nviz_create_render_window(offscreen, NULL, width, height) == -1)
-        G_fatal_error(_("Unable to render data"));
+	G_fatal_error(_("Unable to render data"));
     Nviz_make_current_render_window(offscreen);
     /* initialize nviz data */
@@ -96,6 +96,7 @@
     /* load raster maps (surface topography) & set attributes (map/constant) */
     load_rasters(params, &data);
     /* set draw mode of loaded surfaces */
     surface_set_draw_mode(params);
@@ -138,8 +139,7 @@
     else {
 	z_exag = Nviz_get_exag();
 	G_verbose_message(_("Vertical exaggeration not given, using calculated "
-			    "value %.0f"),
-			  z_exag);
+			   "value %.0f"), z_exag);
     Nviz_change_exag(&data, z_exag);
@@ -148,10 +148,10 @@
     else {
 	double min, max;
 	Nviz_get_exag_height(&vp_height, &min, &max);
 	G_verbose_message(_("Viewpoint height not given, using calculated "
-			    "value %.0f"),
-			  vp_height);
+			    "value %.0f"), vp_height);
     Nviz_set_viewpoint_height(vp_height);
@@ -159,21 +159,21 @@
 				atof(params->pos->answers[1]));
     Nviz_set_viewpoint_twist(atoi(params->twist->answer));
     Nviz_set_viewpoint_persp(atoi(params->persp->answer));
     if (params->focus->answer) {
-    Nviz_set_focus(&data, atof(params->focus->answers[0]),
-                          atof(params->focus->answers[1]),
-                          atof(params->focus->answers[2]));
+	Nviz_set_focus(&data, atof(params->focus->answers[0]),
+		       atof(params->focus->answers[1]),
+		       atof(params->focus->answers[2]));
     /* set lights */
     Nviz_set_light_position(&data, 1,
 			    atof(params->light_pos->answers[0]),
 			    atof(params->light_pos->answers[1]),
-			    atof(params->light_pos->answers[2]),
-			    0.0);
+			    atof(params->light_pos->answers[2]), 0.0);
     Nviz_set_light_bright(&data, 1,
 			  atoi(params->light_bright->answer) / 100.0);
-    if(G_str_to_color(params->light_color->answer, &red, &grn, &blu) != 1) {
+    if (G_str_to_color(params->light_color->answer, &red, &grn, &blu) != 1) {
 	red = grn = blu = 255;
     Nviz_set_light_color(&data, 1, red, grn, blu);
@@ -183,11 +183,12 @@
     /* define fringes */
     if (params->fringe->answer) {
 	int nw, ne, sw, se;
 	i = 0;
 	nw = ne = sw = se = 0;
-	while(params->fringe->answers[i]) {
+	while (params->fringe->answers[i]) {
 	    const char *edge = params->fringe->answers[i++];
 	    if (strcmp(edge, "nw") == 0)
 		nw = 1;
 	    else if (strcmp(edge, "ne") == 0)
@@ -197,29 +198,33 @@
 	    else if (strcmp(edge, "se") == 0)
 		se = 1;
-	Nviz_new_fringe(&data, -1, Nviz_color_from_str(params->fringe_color->answer),
+	Nviz_new_fringe(&data, -1,
+			Nviz_color_from_str(params->fringe_color->answer),
 			atof(params->fringe_elev->answer), nw, ne, sw, se);
     /* draw north arrow */
     if (params->north_arrow->answer) {
 	if (!params->north_arrow_size->answer)
 	    size = Nviz_get_longdim(&data) / 8.;
 	else
 	    size = atof(params->north_arrow_size->answer);
 	Nviz_set_arrow(&data, atoi(params->north_arrow->answers[0]),
-			      atoi(params->north_arrow->answers[1]),
-			      size, Nviz_color_from_str(params->north_arrow_color->answer));
+		       atoi(params->north_arrow->answers[1]),
+		       size,
+		       Nviz_color_from_str(params->north_arrow_color->
+					   answer));
 	Nviz_draw_arrow(&data);
     GS_clear(data.bgcolor);
-    if(params->cplane->answer)
-        draw_cplane(params, &data);
+    if (params->cplane->answer)
+	draw_cplane(params, &data);
     /* draw */
     Nviz_draw_all(&data);
Modified: grass/trunk/misc/m.nviz.image/surface.c
--- grass/trunk/misc/m.nviz.image/surface.c	2014-01-27 19:06:00 UTC (rev 58788)
+++ grass/trunk/misc/m.nviz.image/surface.c	2014-01-28 01:57:55 UTC (rev 58789)
@@ -1,17 +1,17 @@
-  \file surface.c
-  \brief Surface subroutines
-  (C) 2008, 2010 by the GRASS Development Team
-  for details.
+   \file surface.c
+   \brief Surface subroutines
+   (C) 2008, 2010 by the GRASS Development Team
+   for details.
 #include <stdlib.h>
 #include <string.h>
@@ -20,11 +20,11 @@
 #include "local_proto.h"
-  \brief Load raster maps/constants and set surface attributes
-  \param data nviz data
+   \brief Load raster maps/constants and set surface attributes
+   \param data nviz data
 int load_rasters(const struct GParams *params, nv_data * data)
     const char *mapset;
@@ -52,16 +52,16 @@
 	    id = Nviz_new_map_obj(MAP_OBJ_SURF,
-				  G_fully_qualified_name(params->elev_map->
-							 answers[i], mapset),
-				  0.0, data);
+				  G_fully_qualified_name(params->
+							 elev_map->answers[i],
+							 mapset), 0.0, data);
 	else {
-	    if (i-nelev_map < nelev_const && strcmp(params->elev_const->answers[i-nelev_map], "")) {
-		id = Nviz_new_map_obj(MAP_OBJ_SURF,
-				      NULL,
-				      atof(params->elev_const->answers[i-nelev_map]),
-				      data);
+	    if (i - nelev_map < nelev_const &&
+		strcmp(params->elev_const->answers[i - nelev_map], "")) {
+		id = Nviz_new_map_obj(MAP_OBJ_SURF, NULL,
+				      atof(params->elev_const->
+					   answers[i - nelev_map]), data);
 	    else {
 		G_fatal_error(_("Missing topography attribute for surface %d"),
@@ -70,16 +70,16 @@
 	/* set position */
-    if (opt_get_num_answers(params->surface_pos) != 3 * nelevs){
-        x = atof(params->surface_pos->answers[0]);
-        y = atof(params->surface_pos->answers[1]);
-        z = atof(params->surface_pos->answers[2]);
-    else{
-        x = atof(params->surface_pos->answers[i*3+0]);
-        y = atof(params->surface_pos->answers[i*3+1]);
-        z = atof(params->surface_pos->answers[i*3+2]);
+	if (opt_get_num_answers(params->surface_pos) != 3 * nelevs) {
+	    x = atof(params->surface_pos->answers[0]);
+	    y = atof(params->surface_pos->answers[1]);
+	    z = atof(params->surface_pos->answers[2]);
+	else {
+	    x = atof(params->surface_pos->answers[i * 3 + 0]);
+	    y = atof(params->surface_pos->answers[i * 3 + 1]);
+	    z = atof(params->surface_pos->answers[i * 3 + 2]);
 	GS_set_trans(id, x, y, z);
@@ -109,30 +109,34 @@
 	    Nviz_set_attr(id, MAP_OBJ_SURF, ATT_COLOR, MAP_ATT,
-			  G_fully_qualified_name(params->color_map->
-						 answers[i], mapset), -1.0,
-			  data);
+						 color_map->answers[i],
+						 mapset), -1.0, data);
 	/* check for color value */
-	else if (i-ncolor_map < ncolor_const &&
-		 strcmp(params->color_const->answers[i-ncolor_map], "")) {
+	else if (i - ncolor_map < ncolor_const &&
+		 strcmp(params->color_const->answers[i - ncolor_map], "")) {
 	    Nviz_set_attr(id, MAP_OBJ_SURF, ATT_COLOR, CONST_ATT, NULL,
-			  Nviz_color_from_str(params->color_const->
-					      answers[i-ncolor_map]), data);
+					      color_const->answers[i -
+								   ncolor_map]),
+			  data);
 	else {			/* use by default elevation map for coloring */
-        if (nelev_map > 0){
-            Nviz_set_attr(id, MAP_OBJ_SURF, ATT_COLOR, MAP_ATT,
-                G_fully_qualified_name(params->elev_map->answers[i],
-                            mapset), -1.0, data);
-            G_verbose_message(_("Color attribute not defined, using default <%s>"),
-                                 answers[i], mapset));
-        else{
-            G_fatal_error(_("Missing color attribute for surface %d"),
+	    if (nelev_map > 0) {
+		Nviz_set_attr(id, MAP_OBJ_SURF, ATT_COLOR, MAP_ATT,
+			      G_fully_qualified_name(params->elev_map->
+						     answers[i], mapset),
+			      -1.0, data);
+		G_verbose_message(_("Color attribute not defined, using default <%s>"),
+							 mapset));
+	    else {
+		G_fatal_error(_("Missing color attribute for surface %d"),
 			      i + 1);
 	/* mask */
 	if (i < nmask_map && strcmp(params->mask_map->answers[i], "")) {
@@ -144,27 +148,29 @@
 	/* transparency */
 	if (i < ntransp_map && strcmp(params->transp_map->answers[i], "")) {
 	    Nviz_set_attr(id, MAP_OBJ_SURF, ATT_TRANSP, MAP_ATT,
-			  G_fully_qualified_name(params->transp_map->
-			  data);
+						 transp_map->answers[i],
-	else if (i-ntransp_map < ntransp_const &&
-		 strcmp(params->transp_const->answers[i-ntransp_map], "")) {
+	else if (i - ntransp_map < ntransp_const &&
+		 strcmp(params->transp_const->answers[i - ntransp_map], "")) {
 	    Nviz_set_attr(id, MAP_OBJ_SURF, ATT_TRANSP, CONST_ATT, NULL,
-			  atof(params->transp_const->answers[i-ntransp_map]), data);
+			  atof(params->transp_const->
+			       answers[i - ntransp_map]), data);
 	/* shininess */
 	if (i < nshine_map && strcmp(params->shine_map->answers[i], "")) {
 	    Nviz_set_attr(id, MAP_OBJ_SURF, ATT_SHINE, MAP_ATT,
-			  G_fully_qualified_name(params->shine_map->
-			  data);
+						 shine_map->answers[i],
-	else if (i-nshine_map < nshine_const &&
-		 strcmp(params->shine_const->answers[i-nshine_map], "")) {
+	else if (i - nshine_map < nshine_const &&
+		 strcmp(params->shine_const->answers[i - nshine_map], "")) {
 	    Nviz_set_attr(id, MAP_OBJ_SURF, ATT_SHINE, CONST_ATT, NULL,
-			  atof(params->shine_const->answers[i-nshine_map]), data);
+			  atof(params->shine_const->answers[i - nshine_map]),
+			  data);
 	/* emission */
@@ -173,10 +179,11 @@
 			  G_fully_qualified_name(params->emit_map->answers[i],
-	else if (i-nemit_map < nemit_const &&
-		 strcmp(params->emit_const->answers[i-nemit_map], "")) {
+	else if (i - nemit_map < nemit_const &&
+		 strcmp(params->emit_const->answers[i - nemit_map], "")) {
 	    Nviz_set_attr(id, MAP_OBJ_SURF, ATT_EMIT, CONST_ATT, NULL,
-			  atof(params->emit_const->answers[i-nemit_map]), data);
+			  atof(params->emit_const->answers[i - nemit_map]),
+			  data);
@@ -189,10 +196,10 @@
-  \brief Set draw mode for loaded surfaces
+   \brief Set draw mode for loaded surfaces
 void surface_set_draw_mode(const struct GParams *params)
     int *surf_list, nsurfs;
Modified: grass/trunk/misc/m.nviz.image/vector.c
--- grass/trunk/misc/m.nviz.image/vector.c	2014-01-27 19:06:00 UTC (rev 58788)
+++ grass/trunk/misc/m.nviz.image/vector.c	2014-01-28 01:57:55 UTC (rev 58789)
@@ -1,17 +1,17 @@
-  \file vector.c
-  \brief Vector subroutines
-  (C) 2008-2013 by the GRASS Development Team
+   \file vector.c
-  for details.
+   \brief Vector subroutines
+   (C) 2008-2013 by the GRASS Development Team
+   for details.
 #include <stdlib.h>
 #include <string.h>
@@ -22,18 +22,19 @@
 static int load_vectors(const struct Option *, const struct Option *,
-			const struct Option *, const struct Option *, int, nv_data *);
+			const struct Option *, const struct Option *, int,
+			nv_data *);
 static void error_handler_vector(void *);
 static void error_handler_db(void *);
-  \brief Load vector maps (lines)
-  \return number of loaded vectors
+   \brief Load vector maps (lines)
+   \return number of loaded vectors
 int load_vlines(const struct GParams *params, nv_data * data)
     return load_vectors(params->elev_map, params->elev_const,
@@ -42,13 +43,13 @@
-  \brief Load vector maps (points)
+   \brief Load vector maps (points)
 int load_vpoints(const struct GParams *params, nv_data * data)
@@ -67,7 +68,7 @@
     const char *mapset;
     double x, y, z;
     if ((!elev_map->answer || elev_const->answer) && GS_num_surfs() == 0) {	/* load base surface if no loaded */
 	int *surf_list, nsurf;
@@ -85,13 +86,13 @@
 	    G_fatal_error(_("Vector map <%s> not found"), vect->answers[i]);
 	id = Nviz_new_map_obj(map_obj_type,
-			      G_fully_qualified_name(vect->answers[i], mapset),
-			      0.0, data);
+			      G_fully_qualified_name(vect->answers[i],
 	/* set position */
-	x = atof(position->answers[i*3+0]);
-	y = atof(position->answers[i*3+1]);
-	z = atof(position->answers[i*3+2]);
+	x = atof(position->answers[i * 3 + 0]);
+	y = atof(position->answers[i * 3 + 1]);
+	z = atof(position->answers[i * 3 + 2]);
 	if (map_obj_type == MAP_OBJ_VECT)
 	    GV_set_trans(id, x, y, z);
@@ -105,13 +106,13 @@
-  \brief Set vector lines mode
-  \param params parameters
-  \return 1 on success
-  \return 0 on failure
+   \brief Set vector lines mode
+   \param params parameters
+   \return 1 on success
+   \return 0 on failure
 int vlines_set_attrb(const struct GParams *params)
     int i, layer, color, width, flat, height;
@@ -120,35 +121,36 @@
     char *color_column, *width_column;
     struct Colors colors;
     vect_list = GV_get_vect_list(&nvects);
     for (i = 0; i < nvects; i++) {
 	check_map(params, i, TRUE, &layer, NULL);
 	color = Nviz_color_from_str(params->vline_color->answers[i]);
 	color_column = params->vline_color_column->answers ?
 	    params->vline_color_column->answers[i] : NULL;
 	width = atoi(params->vline_width->answers[i]);
 	width_column = params->vline_width_column->answers ?
 	    params->vline_width_column->answers[i] : NULL;
 	if (strcmp(params->vline_mode->answers[i], "flat") == 0)
 	    flat = 1;
 	else
 	    flat = 0;
 	/* style (mode -- use memory by default) */
 	if (GV_set_style(vect_list[i], TRUE, color, width, flat) < 0)
 	    return 0;
 	/* check for vector color table */
 	have_colors = Vect_read_colors(params->vlines->answers[i], "",
 				       &colors);
 	if (have_colors || color_column || width_column)
 	    if (GV_set_style_thematic(vect_list[i], layer, color_column,
-				      width_column, have_colors ? &colors : NULL) < 0)
+				      width_column,
+				      have_colors ? &colors : NULL) < 0)
 		return 0;
 	/* height */
@@ -161,27 +163,28 @@
-  \brief Set vector points style
+   \brief Set vector points style
 int vpoints_set_attrb(const struct GParams *params)
     int i, layer, have_colors, with_z;
     int *site_list, nsites;
     int marker, color, width;
     float size;
-    char *marker_str, *color_column, *size_column, *width_column, *marker_column;
+    char *marker_str, *color_column, *size_column, *width_column,
+	*marker_column;
     site_list = GP_get_site_list(&nsites);
     for (i = 0; i < nsites; i++) {
-        check_map(params, i, FALSE, &layer, &with_z);
+	check_map(params, i, FALSE, &layer, &with_z);
 	color = Nviz_color_from_str(params->vpoint_color->answers[i]);
 	color_column = params->vpoint_color_column->answers ?
@@ -197,7 +200,7 @@
 	    params->vpoint_marker_column->answers[i] : NULL;
 	marker = GP_str_to_marker(marker_str);
-        if (with_z) {
+	if (with_z) {
 	    if (strcmp(params->vpoint_mode->answers[i], "surface") == 0)
 		GP_set_zmode(site_list[i], FALSE);
 	    else
@@ -210,11 +213,12 @@
 	have_colors = Vect_read_colors(params->vpoints->answers[i], "",
 				       &colors);
 	if (have_colors || color_column || width_column ||
 	    size_column || marker_column) {
 	    if (GP_set_style_thematic(site_list[i], layer, color_column,
-				      width_column, size_column, marker_column,
+				      width_column, size_column,
+				      marker_column,
 		return 0;
@@ -224,18 +228,18 @@
-  \brief Check vector map
+   \brief Check vector map
-  \param index answers array index
-  \param vlines TRUE for lines otherwise points
-  \param[out] field number
-  \param[out] WITH_Z for 3D maps
+   \param index answers array index
+   \param vlines TRUE for lines otherwise points
+   \param[out] field number
+   \param[out] WITH_Z for 3D maps
-  \return 0 on success otherwise 1
+   \return 0 on success otherwise 1
 int check_map(const struct GParams *params, int index, int vlines,
-                   int *field, int *with_z)
+	      int *field, int *with_z)
     int type;
     struct Map_info Map;
@@ -244,98 +248,99 @@
     dbDriver *driver;
     dbColumn *column;
     Fi = NULL;
     driver = NULL;
     if (vlines) {
-	map    = params->vlines->answers[index];
-	layer  = params->vline_layer->answers[index];
-	color  = params->vline_color_column->answers ?
-            params->vline_color_column->answers[index] : NULL;
-	size   = NULL;
-	width  = params->vline_width_column->answers ?
-            params->vline_width_column->answers[index] : NULL;
+	map = params->vlines->answers[index];
+	layer = params->vline_layer->answers[index];
+	color = params->vline_color_column->answers ?
+	    params->vline_color_column->answers[index] : NULL;
+	size = NULL;
+	width = params->vline_width_column->answers ?
+	    params->vline_width_column->answers[index] : NULL;
 	marker = NULL;
     else {
-	map    = params->vpoints->answers[index];
-	layer  = params->vpoint_layer->answers[index];
-	color  = params->vpoint_color_column->answers ?
-            params->vpoint_color_column->answers[index] : NULL;
-	size   = params->vpoint_size_column->answers ?
-            params->vpoint_size_column->answers[index] : NULL;
-	width  = params->vpoint_width_column->answers ?
-            params->vpoint_width_column->answers[index] : NULL;
+	map = params->vpoints->answers[index];
+	layer = params->vpoint_layer->answers[index];
+	color = params->vpoint_color_column->answers ?
+	    params->vpoint_color_column->answers[index] : NULL;
+	size = params->vpoint_size_column->answers ?
+	    params->vpoint_size_column->answers[index] : NULL;
+	width = params->vpoint_width_column->answers ?
+	    params->vpoint_width_column->answers[index] : NULL;
 	marker = params->vpoint_marker_column->answers ?
-            params->vpoint_marker_column->answers[index] : NULL;
+	    params->vpoint_marker_column->answers[index] : NULL;
     if (!map)
-        return 1;
+	return 1;
     if (1 > Vect_open_old(&Map, map, ""))
-        G_fatal_error(_("Unable to open vector map <%s>"), map);
+	G_fatal_error(_("Unable to open vector map <%s>"), map);
     G_add_error_handler(error_handler_vector, &Map);
     if (with_z)
-        *with_z = Vect_is_3d(&Map);
+	*with_z = Vect_is_3d(&Map);
-    *field = -1;
+    *field = -1;
     Fi = Vect_get_field2(&Map, layer);
     if (Fi) {
-        *field = Fi->number;
-        driver = db_start_driver_open_database(Fi->driver, Fi->database);
-        if (!driver)
-            G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
-                          Fi->database, Fi->driver);
-        G_add_error_handler(error_handler_db, driver);
-        if (color) {
-            db_get_column(driver, Fi->table, color, &column);
-            if (!column)
-                G_fatal_error(_("Column <%s> in table <%s> not found"),
-                              color, Fi->table);
-            if (db_column_Ctype(driver, Fi->table, color) != DB_C_TYPE_STRING)
-                G_fatal_error(_("Data type of color column must be character"));
-        if (size) {
-            db_get_column(driver, Fi->table, size, &column);
-            if (!column)
-                              size, Fi->table);
-            type = db_column_Ctype(driver, Fi->table, size);
-            if (type != DB_C_TYPE_INT && type != DB_C_TYPE_DOUBLE)
-                G_fatal_error(_("Data type of size column must be numeric"));
-        if (width) {
-            db_get_column(driver, Fi->table, width, &column);
-            if (!column)
-                              width, Fi->table);
-            type = db_column_Ctype(driver, Fi->table, width);
-                G_fatal_error(_("Data type of width column must be numeric"));
-        if (marker) {
-            db_get_column(driver, Fi->table, marker, &column);
-            if (!column)
-                              marker, Fi->table);
-            type = db_column_Ctype(driver, Fi->table, marker);
-            if (db_column_Ctype(driver, Fi->table, marker) != DB_C_TYPE_STRING)
-                G_fatal_error(_("Data type of marker column must be character"));
-        G_remove_error_handler(error_handler_db, driver);
-        db_close_database_shutdown_driver(driver);
+	*field = Fi->number;
+	driver = db_start_driver_open_database(Fi->driver, Fi->database);
+	if (!driver)
+	    G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+			  Fi->database, Fi->driver);
+	G_add_error_handler(error_handler_db, driver);
+	if (color) {
+	    db_get_column(driver, Fi->table, color, &column);
+	    if (!column)
+		G_fatal_error(_("Column <%s> in table <%s> not found"),
+			      color, Fi->table);
+	    if (db_column_Ctype(driver, Fi->table, color) != DB_C_TYPE_STRING)
+		G_fatal_error(_("Data type of color column must be character"));
+	if (size) {
+	    db_get_column(driver, Fi->table, size, &column);
+	    if (!column)
+			      size, Fi->table);
+	    type = db_column_Ctype(driver, Fi->table, size);
+	    if (type != DB_C_TYPE_INT && type != DB_C_TYPE_DOUBLE)
+		G_fatal_error(_("Data type of size column must be numeric"));
+	if (width) {
+	    db_get_column(driver, Fi->table, width, &column);
+	    if (!column)
+			      width, Fi->table);
+	    type = db_column_Ctype(driver, Fi->table, width);
+		G_fatal_error(_("Data type of width column must be numeric"));
+	if (marker) {
+	    db_get_column(driver, Fi->table, marker, &column);
+	    if (!column)
+			      marker, Fi->table);
+	    type = db_column_Ctype(driver, Fi->table, marker);
+	    if (db_column_Ctype(driver, Fi->table, marker) !=
+		DB_C_TYPE_STRING)
+		G_fatal_error(_("Data type of marker column must be character"));
+	G_remove_error_handler(error_handler_db, driver);
+	db_close_database_shutdown_driver(driver);
     G_remove_error_handler(error_handler_vector, &Map);
     Vect_close(&Map);
@@ -355,7 +360,7 @@
     dbDriver *driver;
-    driver = (dbDriver *)p;
-    if (driver)
+    driver = (dbDriver *) p;
+    if (driver)
Modified: grass/trunk/misc/m.nviz.image/volume.c
--- grass/trunk/misc/m.nviz.image/volume.c	2014-01-27 19:06:00 UTC (rev 58788)
+++ grass/trunk/misc/m.nviz.image/volume.c	2014-01-28 01:57:55 UTC (rev 58789)
@@ -1,17 +1,17 @@
-  \file volume.c
-  \brief Volume subroutines
+   \file volume.c
-  for details.
+   \brief Volume subroutines
+   for details.
 #include <stdlib.h>
 #include <string.h>
@@ -21,19 +21,19 @@
-  \brief Load 3d raster map layers -> volume
+   \brief Load 3d raster map layers -> volume
-  \return number of loaded volumes
-int load_rasters3d(const struct GParams *params, nv_data *data)
+   \return number of loaded volumes
+int load_rasters3d(const struct GParams *params, nv_data * data)
     int i, nvol, id;
     float x, y, z;
     char *mapset;
     nvol = opt_get_num_answers(params->volume);
     for (i = 0; i < nvol; i++) {
@@ -44,9 +44,9 @@
 	id = Nviz_new_map_obj(MAP_OBJ_VOL,
-			      G_fully_qualified_name(params->volume->answers[i],
-						     mapset),
-			      0.0, data);
+			      G_fully_qualified_name(params->volume->
+						     answers[i], mapset), 0.0,
+			      data);
 	/* set position */
 	if (opt_get_num_answers(params->volume_pos) != 3 * nvol) {
@@ -55,11 +55,11 @@
 	    z = atof(params->volume_pos->answers[2]);
 	else {
-	    x = atof(params->volume_pos->answers[i*3+0]);
-	    y = atof(params->volume_pos->answers[i*3+1]);
-	    z = atof(params->volume_pos->answers[i*3+2]);
+	    x = atof(params->volume_pos->answers[i * 3 + 0]);
+	    y = atof(params->volume_pos->answers[i * 3 + 1]);
+	    z = atof(params->volume_pos->answers[i * 3 + 2]);
 	GVL_set_trans(id, x, y, z);
 	if (params->draw_volume_box->answer) {
 	    GVL_set_draw_wire(id, 1);
@@ -70,126 +70,144 @@
-  \brief Add isosurfaces and set their attributes
-  \return number of defined isosurfaces
-int add_isosurfs(const struct GParams *params, nv_data *data)
+   \brief Add isosurfaces and set their attributes
+   \return number of defined isosurfaces
+int add_isosurfs(const struct GParams *params, nv_data * data)
     int i;
     float level;
     int num, nvols, *vol_list, id, nisosurfs;
-    int ncolor_map, ncolor_const, ntransp_map, ntransp_const, nshine_map, nshine_const;
+    int ncolor_map, ncolor_const, ntransp_map, ntransp_const, nshine_map,
+	nshine_const;
     int res, draw_mode;
     char **tokens;
     const char *mapset, *style;
     vol_list = GVL_get_vol_list(&nvols);
     for (i = 0; params->isosurf_level->answers[i]; i++) {
 	tokens = G_tokenize(params->isosurf_level->answers[i], ":");
-	if (G_number_of_tokens(tokens) != 2)
-	    G_fatal_error(_("Error tokenize '%s'"),
+	if (G_number_of_tokens(tokens) != 2)
+	    G_fatal_error(_("Error tokenize '%s'"),
 			  params->isosurf_level->answers[i]);
 	num = atoi(tokens[0]);
 	level = atof(tokens[1]);
 	G_free_tokens(tokens);
 	if (num > nvols) {
-	    G_fatal_error(_("Volume set number %d is not available"),
-			  num);
+	    G_fatal_error(_("Volume set number %d is not available"), num);
-	id = vol_list[num-1];
+	id = vol_list[num - 1];
 	if (GVL_isosurf_add(id) < 0) {
-	    G_fatal_error(_("Unable to add isosurface (volume set %d)"),
-			  id);
+	    G_fatal_error(_("Unable to add isosurface (volume set %d)"), id);
 	nisosurfs = GVL_isosurf_num_isosurfs(id);
 	if (params->isosurf_toggle_norm_dir->answer) {
-	    GVL_isosurf_set_flags(id, nisosurfs-1, 1);
+	    GVL_isosurf_set_flags(id, nisosurfs - 1, 1);
 	/* topography (level) */
-	if (GVL_isosurf_set_att_const(id, nisosurfs-1, ATT_TOPO, level) < 0) {
+	if (GVL_isosurf_set_att_const(id, nisosurfs - 1, ATT_TOPO, level) < 0) {
 	    G_fatal_error(_("Unable to set isosurface (%d) attribute (%d) of volume %d"),
-			  nisosurfs-1, ATT_TOPO, id);
+			  nisosurfs - 1, ATT_TOPO, id);
 	/* color */
 	ncolor_map = opt_get_num_answers(params->isosurf_color_map);
 	ncolor_const = opt_get_num_answers(params->isosurf_color_const);
-	if (i < ncolor_map && strcmp(params->isosurf_color_map->answers[i], "")) {
-	    mapset = G_find_raster3d(params->isosurf_color_map->answers[i], "");
+	if (i < ncolor_map &&
+	    strcmp(params->isosurf_color_map->answers[i], "")) {
+	    mapset =
+		G_find_raster3d(params->isosurf_color_map->answers[i], "");
 	    if (mapset == NULL) {
 		G_fatal_error(_("3d raster map <%s> not found"),
 			      params->isosurf_color_map->answers[i]);
-	    if (GVL_isosurf_set_att_map(id, nisosurfs-1, ATT_COLOR,
-					params->isosurf_color_map->answers[i]) < 0)
+	    if (GVL_isosurf_set_att_map(id, nisosurfs - 1, ATT_COLOR,
+					answers[i]) < 0)
-				nisosurfs-1, ATT_COLOR, id);
+			      nisosurfs - 1, ATT_COLOR, id);
-		 strcmp(params->isosurf_color_const->answers[i-ncolor_map], "")) {
+		 strcmp(params->isosurf_color_const->answers[i - ncolor_map],
-	    if (GVL_isosurf_set_att_const(id, nisosurfs-1, ATT_COLOR,
-			    Nviz_color_from_str(params->isosurf_color_const->answers[i-ncolor_map])) < 0)
+	    if (GVL_isosurf_set_att_const(id, nisosurfs - 1, ATT_COLOR,
+							      isosurf_color_const->
+							      answers[i -
+								      ncolor_map]))
+		< 0)
 	else {			/* use by default 3d raster map for coloring */
-	    GVL_isosurf_set_att_map(id, nisosurfs-1, ATT_COLOR, params->volume->answers[num-1]);
+	    GVL_isosurf_set_att_map(id, nisosurfs - 1, ATT_COLOR,
+				    params->volume->answers[num - 1]);
-				params->volume->answers[num-1]);
 	/* transparency */
 	ntransp_map = opt_get_num_answers(params->isosurf_transp_map);
 	ntransp_const = opt_get_num_answers(params->isosurf_transp_const);
-	if (i < ntransp_map && strcmp(params->isosurf_transp_map->answers[i], "")) {
-	    if (GVL_isosurf_set_att_map(id, nisosurfs-1, ATT_TRANSP,
-					params->isosurf_transp_map->answers[i]) < 0)
+	if (i < ntransp_map &&
+	    strcmp(params->isosurf_transp_map->answers[i], "")) {
+		(id, nisosurfs - 1, ATT_TRANSP,
+		 params->isosurf_transp_map->answers[i]) < 0)
-				nisosurfs-1, ATT_TRANSP, id);
+			      nisosurfs - 1, ATT_TRANSP, id);
-		 strcmp(params->isosurf_transp_const->answers[i-ntransp_map], "")) {
-	    if (GVL_isosurf_set_att_const(id, nisosurfs-1, ATT_TRANSP,
-					  atof(params->isosurf_transp_const->answers[i-ntransp_map])) < 0)
+		 strcmp(params->isosurf_transp_const->
+			answers[i - ntransp_map], "")) {
+		 atof(params->isosurf_transp_const->
+		      answers[i - ntransp_map])) < 0)
 	/* shine */
 	nshine_map = opt_get_num_answers(params->isosurf_shine_map);
 	nshine_const = opt_get_num_answers(params->isosurf_shine_const);
-	if (i < nshine_map && strcmp(params->isosurf_shine_map->answers[i], "")) {
-	    if (GVL_isosurf_set_att_map(id, nisosurfs-1, ATT_SHINE,
-					params->isosurf_shine_map->answers[i]) < 0)
+	if (i < nshine_map &&
+	    strcmp(params->isosurf_shine_map->answers[i], "")) {
+		(id, nisosurfs - 1, ATT_SHINE,
+		 params->isosurf_shine_map->answers[i]) < 0)
-				nisosurfs-1, ATT_SHINE, id);
+			      nisosurfs - 1, ATT_SHINE, id);
-		 strcmp(params->isosurf_shine_const->answers[i-nshine_map], "")) {
-	    if (GVL_isosurf_set_att_const(id, nisosurfs-1, ATT_SHINE,
-					  atof(params->isosurf_shine_const->answers[i-nshine_map])) < 0)
+		 strcmp(params->isosurf_shine_const->answers[i - nshine_map],
+		 atof(params->isosurf_shine_const->answers[i - nshine_map])) <
+		0)
-    /* set draw resolution and shading after isosurfaces are added*/
+    /* set draw resolution and shading after isosurfaces are added */
     for (i = 0; i < nvols; i++) {
 	id = vol_list[i];
@@ -215,71 +233,69 @@
 	else {
 	    draw_mode |= DM_GOURAUD;
 	GVL_isosurf_set_drawmode(id, draw_mode);
     return 1;
-int add_slices(const struct GParams *params, nv_data *data)
+int add_slices(const struct GParams *params, nv_data * data)
     int i;
     int num, nvols, *vol_list, id, nslices, axis;
     int res, draw_mode;
     char **tokens;
-    const char* style;
+    const char *style;
     for (i = 0; params->slice->answers[i]; i++) {
 	tokens = G_tokenize(params->slice->answers[i], ":");
 			  params->slice->answers[i]);
-	if (!strcmp(tokens[1],"x") || !strcmp(tokens[1],"X"))
+	if (!strcmp(tokens[1], "x") || !strcmp(tokens[1], "X"))
 	    axis = 0;
-	else if (!strcmp(tokens[1],"y") || !strcmp(tokens[1],"Y"))
+	else if (!strcmp(tokens[1], "y") || !strcmp(tokens[1], "Y"))
 	    axis = 1;
-	else if (!strcmp(tokens[1],"z") || !strcmp(tokens[1],"Z"))
+	else if (!strcmp(tokens[1], "z") || !strcmp(tokens[1], "Z"))
 	    axis = 2;
 	else
-	    G_fatal_error(_("Wrong name for axis: %s"),
-			  tokens[1]);
+	    G_fatal_error(_("Wrong name for axis: %s"), tokens[1]);
 	if (num > nvols) {
-			  num);
 	if (GVL_slice_add(id) < 0) {
-	    G_fatal_error(_("Unable to add slice (volume set %d)"),
-			  id);
+	    G_fatal_error(_("Unable to add slice (volume set %d)"), id);
 	nslices = GVL_slice_num_slices(id);
-	if (GVL_slice_set_pos(id, nslices-1, atof(params->slice_pos->answers[i*6+0]),
-					     atof(params->slice_pos->answers[i*6+1]),
-					     atof(params->slice_pos->answers[i*6+2]),
-					     atof(params->slice_pos->answers[i*6+3]),
-					     atof(params->slice_pos->answers[i*6+4]),
-					     atof(params->slice_pos->answers[i*6+5]),
-					     axis) < 0)
+	if (GVL_slice_set_pos
+	    (id, nslices - 1, atof(params->slice_pos->answers[i * 6 + 0]),
+	     atof(params->slice_pos->answers[i * 6 + 1]),
+	     atof(params->slice_pos->answers[i * 6 + 2]),
+	     atof(params->slice_pos->answers[i * 6 + 3]),
+	     atof(params->slice_pos->answers[i * 6 + 4]),
+	     atof(params->slice_pos->answers[i * 6 + 5]), axis) < 0)
 	    G_fatal_error(_("Unable to set slice (%d) position of volume %d"),
-			  nslices-1, id);
+			  nslices - 1, id);
 	/* set transparency */
-	if (GVL_slice_set_transp(id, nslices-1, atoi(params->slice_transp->answers[i])) < 0)
+	if (GVL_slice_set_transp
+	    (id, nslices - 1, atoi(params->slice_transp->answers[i])) < 0)
 	    G_fatal_error(_("Unable to set slice (%d) transparency of volume %d"),
-			  nslices-1, id);
+			  nslices - 1, id);
-    /* set draw resolution and shading after slices are added*/
+    /* set draw resolution and shading after slices are added */
 	id = vol_list[i];
Modified: grass/trunk/misc/m.nviz.image/write_img.c
--- grass/trunk/misc/m.nviz.image/write_img.c	2014-01-27 19:06:00 UTC (rev 58788)
+++ grass/trunk/misc/m.nviz.image/write_img.c	2014-01-28 01:57:55 UTC (rev 58789)
@@ -1,31 +1,31 @@
-  \file write_img.c
-  \brief Save current GL screen to image file.
-  for details.
-  Based on visualization/nviz/src/anim_support.c
-  \author Updated/modified by Martin Landa <landa.martin gmail.com>
+   \file write_img.c
+   \brief Save current GL screen to image file.
+   for details.
+   Based on visualization/nviz/src/anim_support.c
+   \author Updated/modified by Martin Landa <landa.martin gmail.com>
 #include <grass/ogsf.h>
-  \brief Save current GL screen to an ppm file.
-  \param name filename
-  \return 0 on failure (unsupported format)
+   \brief Save current GL screen to an ppm file.
+   \param name filename
+   \return 0 on failure (unsupported format)
 int write_img(const char *name, int format)
     if (format == FORMAT_PPM)
