[GRASS-SVN] r58790 - grass/trunk/misc/m.nviz.image
Mon Jan 27 18:12:14 PST 2014
Author: hamish
Date: 2014-01-27 18:12:14 -0800 (Mon, 27 Jan 2014)
New Revision: 58790
   grass/trunk/misc/m.nviz.image/args.c
try to make the usage error messages a bit easier to follow
Modified: grass/trunk/misc/m.nviz.image/args.c
--- grass/trunk/misc/m.nviz.image/args.c	2014-01-28 01:57:55 UTC (rev 58789)
+++ grass/trunk/misc/m.nviz.image/args.c	2014-01-28 02:12:14 UTC (rev 58790)
@@ -981,7 +981,7 @@
     /* mask */
     nmaps = opt_get_num_answers(params->mask_map);
     if (nmaps > 0 && nelevs != nmaps)
-	G_fatal_error(_("Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"),
+	G_fatal_error(_("Inconsistent number of attributes (<%s/%s>: %d vs. <%s>: %d)"),
 		      params->elev_map->key, params->elev_const->key, nelevs,
 		      params->mask_map->key, nmaps);
@@ -1011,37 +1011,37 @@
     if (!params->mode_all->answer) {	/* use one mode for all surfaces */
 	nconsts = opt_get_num_answers(params->mode);
 	if (nconsts > 0 && nelevs > 0 && nconsts != nelevs)
 			  nelevs, params->mode->key, nconsts);
 	nconsts = opt_get_num_answers(params->res_fine);
 			  nelevs, params->res_fine->key, nconsts);
 	nconsts = opt_get_num_answers(params->res_coarse);
 			  nelevs, params->res_coarse->key, nconsts);
 	nconsts = opt_get_num_answers(params->style);
 			  nelevs, params->style->key, nconsts);
 	nconsts = opt_get_num_answers(params->shade);
 			  nelevs, params->shade->key, nconsts);
 	nconsts = opt_get_num_answers(params->wire_color);
 			  nelevs, params->wire_color->key, nconsts);
@@ -1052,19 +1052,19 @@
     ncplanes = opt_get_num_answers(params->cplane);
     ncoords = opt_get_num_answers(params->cplane_pos);
     if (ncplanes > 0 && ncplanes * 3 != ncoords)
-	G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d x 3)"),
+	G_fatal_error(_("Inconsistent number of attributes (<%s>: %d vs. <%s>: %d x 3)"),
 		      params->cplane->key, ncplanes, params->cplane_pos->key,
 		      ncoords / 3);
     nconsts = opt_get_num_answers(params->cplane_rot);
     if (ncplanes > 0 && ncplanes != nconsts)
-	G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d)"),
+	G_fatal_error(_("Inconsistent number of attributes (<%s>: %d vs. <%s>: %d)"),
 		      params->cplane->key, ncplanes, params->cplane_rot->key,
 		      nconsts);
     nconsts = opt_get_num_answers(params->cplane_tilt);
 		      params->cplane->key, ncplanes, params->cplane_tilt->key,
 		      nconsts);
@@ -1076,35 +1076,35 @@
     /* width */
     nconsts = opt_get_num_answers(params->vline_width);
     if (nvlines > 0 && nconsts != nvlines)
 		      params->vlines->key, nvlines, params->vline_width->key,
 		      nconsts);
     /* color */
     nconsts = opt_get_num_answers(params->vline_color);
 		      params->vlines->key, nvlines, params->vline_color->key,
 		      nconsts);
     /* mode */
     nconsts = opt_get_num_answers(params->vline_mode);
 		      params->vlines->key, nvlines, params->vline_mode->key,
 		      nconsts);
     /* height */
     nconsts = opt_get_num_answers(params->vline_height);
 		      params->vlines->key, nvlines, params->vline_height->key,
 		      nconsts);
     /* position */
     nconsts = opt_get_num_answers(params->vline_pos);
     if (nvlines > 0 && nconsts != 3 * nvlines)
 		      params->vlines->key, nvlines, params->vline_pos->key,
 		      nconsts);
@@ -1116,12 +1116,12 @@
     nvpoints_layer = opt_get_num_answers(params->vpoint_layer);
     if (nvpoints && (nvpoints * 3 != nvpoints_pos))
 		      params->vpoints->key, nvpoints, params->vpoint_pos->key,
 		      nvpoints_pos);
     if (nvpoints && (nvpoints != nvpoints_layer))
 		      params->vpoint_layer->key, nvpoints_layer);
@@ -1140,7 +1140,7 @@
     nconsts = opt_get_num_answers(params->isosurf_transp_const);
     if ((nmaps + nconsts > 0) && (nisosurf != nmaps + nconsts))
-	G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d, <%s> %d)"),
+	G_fatal_error(_("Inconsistent number of attributes (<%s>: %d vs. <%s>: %d, <%s>: %d)"),
 		      params->isosurf_level->key, nisosurf,
 		      params->isosurf_transp_map->key, nmaps,
 		      params->isosurf_transp_const->key, nconsts);
@@ -1150,7 +1150,7 @@
     nconsts = opt_get_num_answers(params->isosurf_shine_const);
 		      params->isosurf_shine_map->key, nmaps,
 		      params->isosurf_shine_const->key, nconsts);
@@ -1158,14 +1158,14 @@
     /* slice transparency */
     nconsts = opt_get_num_answers(params->slice_transp);
     if (nslices > 0 && nslices != nconsts)
 		      params->slice->key, nslices, params->slice_transp->key,
 		      nconsts);
     /* slice position */
     ncoords = opt_get_num_answers(params->slice_pos);
     if (nslices > 0 && ncoords != 6 * nslices)
-	G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d x 6)"),
+	G_fatal_error(_("Inconsistent number of attributes (<%s>: %d vs. <%s>: %d x 6)"),
 		      params->slice->key, nslices, params->slice_pos->key,
 		      ncoords / 6);
@@ -1177,7 +1177,7 @@
 		 const char *map_name, const char *const_name)
     if ((nmaps + nconsts > 0) && (nelevs != nmaps + nconsts))
-	G_fatal_error(_("Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d)"),
+	G_fatal_error(_("Inconsistent number of attributes (<%s/%s>: %d vs. <%s>: %d, <%s>: %d)"),
 		      elev_map, elev_const, nelevs, map_name, nmaps,
 		      const_name, nconsts);
