[GRASS-SVN] r58810 - grass/trunk/raster/r.category
svn_grass at osgeo.org
Thu Jan 30 09:37:59 PST 2014
Author: wenzeslaus
Date: 2014-01-30 09:37:59 -0800 (Thu, 30 Jan 2014)
New Revision: 58810
Added:
grass/trunk/raster/r.category/test_rcategory_doctest.txt
Removed:
grass/trunk/raster/r.category/test_rcatetgory_doctest.txt
r.category: fix typo in file name from r58809
Copied: grass/trunk/raster/r.category/test_rcategory_doctest.txt (from rev 58809, grass/trunk/raster/r.category/test_rcatetgory_doctest.txt)
--- grass/trunk/raster/r.category/test_rcategory_doctest.txt (rev 0)
+++ grass/trunk/raster/r.category/test_rcategory_doctest.txt 2014-01-30 17:37:59 UTC (rev 58810)
@@ -0,0 +1,140 @@
+Run this test file from command line using
+python -m doctest -v doctest.txt
+>>> from grass.script.core import run_command, read_command, write_command
+Data preparation
+>>> run_command('r.mapcalc', expression='test = rand(1 , 3)')
+0
+>>> print(read_command('r.info', map='test',flags='r'))
+min=1
+max=2
+<BLANKLINE>
+>>> run_command('r.mapcalc', expression='test_14 = rand(1 , 5)')
+0
+>>> print(read_command('r.info', map='test_14',flags='r'))
+min=1
+max=4
+<BLANKLINE>
+>>> run_command('r.mapcalc', expression='test_d = double(rand(0 , 10))/2')
+0
+>>> print(read_command('r.info', map='test_d',flags='r'))
+min=0
+max=4.5
+<BLANKLINE>
+Basic tnput and output
+>>> write_command('r.category', map='test', rules='-', stdin="""
+... 1:trees
+... 2:water
+0
+>>> read_command('r.category', map='test', separator=',')
+'1,trees\n2,water\n'
+Input and output with default separator
+... 1:trees
+... 2:water
+0
+>>> read_command('r.category', map='test', separator='tab')
+'1\ttrees\n2\twater\n'
+Tabs needs a special treatment.
+Category range
+>>> write_command('r.category', map='test_14', rules='-', stdin="""
+... 1:trees
+... 2:4:buildings
+0
+>>> print(read_command('r.category', map='test_14', separator=' ')) # doctest: +NORMALIZE_WHITESPACE
+1 trees
+2 4:buildings
+3
+4
+<BLANKLINE>
+Output has spaces at the end of line.
+More importantly, the output of r.category is wrong but here we are expecting this wrong output.
+Floating point maps
+>>> write_command('r.category', map='test_d', rules='-', stdin="""
+... 0:1.5:trees
+... 1.5:3:buildings
+0
+>>> print(read_command('r.category', map='test_d', separator=' ', vals=[1, 1.1, 2.1, 4])) # doctest: +NORMALIZE_WHITESPACE
+1 trees
+1.1 trees
+2.1 buildings
+4
+<BLANKLINE>
+Separators in output
+Test output first because now we perhaps have data correct.
+>>> print(read_command('r.category', map='test', separator='space'))
+1 trees
+2 water
+<BLANKLINE>
+>>> print(read_command('r.category', map='test', separator=','))
+1,trees
+2,water
+<BLANKLINE>
+>>> print(read_command('r.category', map='test', separator='XYZ'))
+1XYZtrees
+2XYZwater
+<BLANKLINE>
+>>> print(read_command('r.category', map='test', separator='newline'))
+1
+trees
+2
+water
+<BLANKLINE>
+>>> print(read_command('r.category', map='test', separator='\n&\n'))
+1
+trees
+2
+water
+<BLANKLINE>
+Clean the results
+This is useful when test is runned in location which is not deleted
+when test finishes. It could test if everything which was expected
+to be created was created if it would check all outputs properly.
+>>> run_command('g.remove', rast='test')
+0
+>>> run_command('g.remove', rast='test_14')
+0
+>>> run_command('g.remove', rast='test_d')
+0
Deleted: grass/trunk/raster/r.category/test_rcatetgory_doctest.txt
--- grass/trunk/raster/r.category/test_rcatetgory_doctest.txt 2014-01-30 17:36:23 UTC (rev 58809)
+++ grass/trunk/raster/r.category/test_rcatetgory_doctest.txt 2014-01-30 17:37:59 UTC (rev 58810)
@@ -1,140 +0,0 @@
-Run this test file from command line using
-python -m doctest -v doctest.txt
->>> from grass.script.core import run_command, read_command, write_command
-Data preparation
->>> run_command('r.mapcalc', expression='test = rand(1 , 3)')
-0
->>> print(read_command('r.info', map='test',flags='r'))
-min=1
-max=2
-<BLANKLINE>
->>> run_command('r.mapcalc', expression='test_14 = rand(1 , 5)')
-0
->>> print(read_command('r.info', map='test_14',flags='r'))
-min=1
-max=4
-<BLANKLINE>
->>> run_command('r.mapcalc', expression='test_d = double(rand(0 , 10))/2')
-0
->>> print(read_command('r.info', map='test_d',flags='r'))
-min=0
-max=4.5
-<BLANKLINE>
-Basic tnput and output
->>> write_command('r.category', map='test', rules='-', stdin="""
-... 1:trees
-... 2:water
-0
->>> read_command('r.category', map='test', separator=',')
-'1,trees\n2,water\n'
-Input and output with default separator
-... 1:trees
-... 2:water
-0
->>> read_command('r.category', map='test', separator='tab')
-'1\ttrees\n2\twater\n'
-Tabs needs a special treatment.
-Category range
->>> write_command('r.category', map='test_14', rules='-', stdin="""
-... 1:trees
-... 2:4:buildings
-0
->>> print(read_command('r.category', map='test_14', separator=' ')) # doctest: +NORMALIZE_WHITESPACE
-1 trees
-2 4:buildings
-3
-4
-<BLANKLINE>
-Output has spaces at the end of line.
-More importantly, the output of r.category is wrong but here we are expecting this wrong output.
-Floating point maps
->>> write_command('r.category', map='test_d', rules='-', stdin="""
-... 0:1.5:trees
-... 1.5:3:buildings
-0
->>> print(read_command('r.category', map='test_d', separator=' ', vals=[1, 1.1, 2.1, 4])) # doctest: +NORMALIZE_WHITESPACE
-1 trees
-1.1 trees
-2.1 buildings
-4
-<BLANKLINE>
-Separators in output
-Test output first because now we perhaps have data correct.
->>> print(read_command('r.category', map='test', separator='space'))
-1 trees
-2 water
-<BLANKLINE>
->>> print(read_command('r.category', map='test', separator=','))
-1,trees
-2,water
-<BLANKLINE>
->>> print(read_command('r.category', map='test', separator='XYZ'))
-1XYZtrees
-2XYZwater
-<BLANKLINE>
->>> print(read_command('r.category', map='test', separator='newline'))
-1
-trees
-2
-water
-<BLANKLINE>
->>> print(read_command('r.category', map='test', separator='\n&\n'))
-1
-trees
-2
-water
-<BLANKLINE>
-Clean the results
-This is useful when test is runned in location which is not deleted
-when test finishes. It could test if everything which was expected
-to be created was created if it would check all outputs properly.
->>> run_command('g.remove', rast='test')
-0
->>> run_command('g.remove', rast='test_14')
-0
->>> run_command('g.remove', rast='test_d')
-0
