[GRASS-SVN] r58811 - grass/trunk/raster/r.category
svn_grass at osgeo.org
Thu Jan 30 10:18:13 PST 2014
Author: annakrat
Date: 2014-01-30 10:18:11 -0800 (Thu, 30 Jan 2014)
New Revision: 58811
grass/trunk/raster/r.category/main.c
grass/trunk/raster/r.category/r.category.html
grass/trunk/raster/r.category/test_rcategory_doctest.txt
r.category: apply separator also for input, more robust input checking, update manual page, doctest (co-author wenzeslaus)
Modified: grass/trunk/raster/r.category/main.c
--- grass/trunk/raster/r.category/main.c 2014-01-30 17:37:59 UTC (rev 58810)
+++ grass/trunk/raster/r.category/main.c 2014-01-30 18:18:11 UTC (rev 58811)
@@ -156,9 +156,12 @@
/* load cats from rules file */
- /* TODO: respect fs= */
if (parm.file->answer) {
FILE *fp;
+ char **tokens;
+ int ntokens;
+ char *e1;
+ char *e2;
if (strcmp("-", parm.file->answer) == 0) {
from_stdin = TRUE;
@@ -174,18 +177,41 @@
Rast_init_cats("", &cats);
for (;;) {
- char buf[1024], label[1024];
+ char buf[1024];
DCELL d1, d2;
+ int parse_error = 0;
if (!G_getl2(buf, sizeof(buf), fp))
break;
- if (sscanf(buf, "%lf:%lf:%[^\n]", &d1, &d2, label) == 3)
- Rast_set_d_cat(&d1, &d2, label, &cats);
- else if (sscanf(buf, "%lf:%[^\n]", &d1, label) == 2)
- Rast_set_d_cat(&d1, &d1, label, &cats);
+ tokens = G_tokenize(buf, fs);
+ ntokens = G_number_of_tokens(tokens);
+ if (ntokens == 3) {
+ d1 = strtod(tokens[0], &e1);
+ d2 = strtod(tokens[1], &e2);
+ if (*e1 == 0 && *e2 == 0)
+ Rast_set_d_cat(&d1, &d2, tokens[2], &cats);
+ else
+ parse_error = 1;
+ else if (ntokens == 2) {
+ if (*e1 == 0)
+ Rast_set_d_cat(&d1, &d1, tokens[1], &cats);
+ else
+ parse_error = 1;
+ else if (!strlen(buf))
+ continue;
+ else
+ parse_error = 1;
+ if (parse_error)
+ G_fatal_error(_("Incorrect format of input rules. "
+ "Check separators. Invalid line is:\n%s"), buf);
+ G_free_tokens(tokens);
Rast_write_cats(name, &cats);
if (!from_stdin)
Modified: grass/trunk/raster/r.category/r.category.html
--- grass/trunk/raster/r.category/r.category.html 2014-01-30 17:37:59 UTC (rev 58810)
+++ grass/trunk/raster/r.category/r.category.html 2014-01-30 18:18:11 UTC (rev 58811)
@@ -39,7 +39,7 @@
The <b>rules</b> option allows the user to assign category labels from values
found in a file. The label can refer to a single category, range of
categories, floating point value, or a range of floating point values.
-The format is given as follows.
+The format is given as follows (when separator is set to colon).
<div class="code"><pre>
cat:Label
val1:val2:Label
@@ -141,7 +141,7 @@
<dl>
<dt>Example defining category labels:
<dd><div class="code"><pre>
-r.category diseasemap rules=- << EOF
+r.category diseasemap separator=: rules=- << EOF
1:potential absence
2:potential presence
EOF
@@ -149,11 +149,7 @@
<p>sets the categoy values 1 and 2 to respective text labels.
</dl>
-<h2>TODO</h2>
-Respect the <b>separator=</b> field separator setting for input rules.
<h2>SEE ALSO</h2>
UNIX Manual entries for <i>awk</i> and <i>sort</i>
Modified: grass/trunk/raster/r.category/test_rcategory_doctest.txt
--- grass/trunk/raster/r.category/test_rcategory_doctest.txt 2014-01-30 17:37:59 UTC (rev 58810)
+++ grass/trunk/raster/r.category/test_rcategory_doctest.txt 2014-01-30 18:18:11 UTC (rev 58811)
@@ -31,7 +31,7 @@
Basic tnput and output
->>> write_command('r.category', map='test', rules='-', stdin="""
+>>> write_command('r.category', map='test', rules='-', separator=':', stdin="""
... 1:trees
... 2:water
@@ -44,8 +44,8 @@
-... 1:trees
-... 2:water
+... 1\ttrees
+... 2\twater
0
>>> read_command('r.category', map='test', separator='tab')
@@ -57,7 +57,7 @@
Category range
->>> write_command('r.category', map='test_14', rules='-', stdin="""
+>>> write_command('r.category', map='test_14', separator=':', rules='-', stdin="""
... 1:trees
... 2:4:buildings
@@ -76,7 +76,7 @@
Floating point maps
->>> write_command('r.category', map='test_d', rules='-', stdin="""
+>>> write_command('r.category', map='test_d', separator=':', rules='-', stdin="""
... 0:1.5:trees
... 1.5:3:buildings
