[GRASS-SVN] r61100 - grass/trunk/raster/r.horizon
svn_grass at osgeo.org
Tue Jul 1 04:18:10 PDT 2014
Author: martinl
Date: 2014-07-01 04:18:10 -0700 (Tue, 01 Jul 2014)
New Revision: 61100
grass/trunk/raster/r.horizon/main.c
r.horizon: label/description cosmetics (description is still too long)
Modified: grass/trunk/raster/r.horizon/main.c
--- grass/trunk/raster/r.horizon/main.c 2014-07-01 09:31:24 UTC (rev 61099)
+++ grass/trunk/raster/r.horizon/main.c 2014-07-01 11:18:10 UTC (rev 61100)
@@ -181,15 +181,15 @@
G_add_keyword(_("solar"));
G_add_keyword(_("sun position"));
module->label =
- _("Horizon angle computation from a digital elevation model.");
+ _("Computes horizon angle height from a digital elevation model.");
module->description =
- _("Computes horizon angle height from a digital elevation model. The module has two"
- " different modes of operation: "
- "1. Computes the entire horizon around a single point whose coordinates are"
- " given with the 'coord' option. The horizon height (in radians). "
- "2. Computes one or more raster maps of the horizon height in a single direction. "
- " The input for this is the angle (in degrees), which is measured "
- " counterclockwise with east=0, north=90 etc. The output is the horizon height in radians.");
+ _("The module has two "
+ "different modes of operation: "
+ "1. Computes the entire horizon around a single point whose coordinates are "
+ "given with the 'coord' option. The horizon height (in radians). "
+ "2. Computes one or more raster maps of the horizon height in a single direction. "
+ "The input for this is the angle (in degrees), which is measured "
+ "counterclockwise with east=0, north=90 etc. The output is the horizon height in radians.");
parm.elevin = G_define_standard_option(G_OPT_R_ELEV);
parm.elevin->guisection = _("Input options");
