[GRASS-SVN] r61238 - in grass/trunk/lib/python: docs/src gunittest gunittest/testsuite
Fri Jul 11 10:24:37 PDT 2014
Author: wenzeslaus
Date: 2014-07-11 10:24:37 -0700 (Fri, 11 Jul 2014)
New Revision: 61238
   grass/trunk/lib/python/docs/src/gunittest_testing.rst
   grass/trunk/lib/python/gunittest/case.py
   grass/trunk/lib/python/gunittest/gmodules.py
   grass/trunk/lib/python/gunittest/testsuite/test_assertions.py
   grass/trunk/lib/python/gunittest/testsuite/test_module_assertions.py
gunittest: use PyGRASS for the whole module run (use finish_ and try-except), few updates in doc
Modified: grass/trunk/lib/python/docs/src/gunittest_testing.rst
--- grass/trunk/lib/python/docs/src/gunittest_testing.rst	2014-07-10 23:00:30 UTC (rev 61237)
+++ grass/trunk/lib/python/docs/src/gunittest_testing.rst	2014-07-11 17:24:37 UTC (rev 61238)
@@ -48,7 +48,7 @@
 To run (invoke) all tests in the source tree run::
-    python python -m grass.gunittest.main [gisdbase] location test_data_category
+    python -m grass.gunittest.main [gisdbase] location test_data_category
 All test files in all ``testsuite`` directories will be executed and
 a report will be created in a newly created ``testreport`` directory.
@@ -81,6 +81,10 @@
 Tests of GRASS modules
+This is applicable for both GRASS modules written in C or C++ and
+GRASS modules written in Python since we are testing the whole module
+(which is invoked as a subprocess).
     def test_elevation(self):
@@ -104,38 +108,63 @@
 .. todo::
     Add example of assertions of key-value results.
-.. todo::
-    Add example with module producing a map.
+Especially if a module module has a lot of different parameters allowed
+in different combinations, you should test the if the wrong ones are really
+disallowed and proper error messages are provided (in addition, you can
+test things such as creation and removal of maps in error states).
     from grass.gunittest import SimpleModule
-    class TestRInfoInputHandling(TestCase):
+    class TestRInfoParameterHandling(TestCase):
+        """Test r.info handling of wrong input of parameters."""
         def test_rinfo_wrong_map(self):
+            """Test input of map which does not exist."""
             map_name = 'does_not_exist'
-            rinfo = SimpleModule('r.info', map=, flags='g')
+            # create a module instance suitable for testing
+            rinfo = SimpleModule('r.info', map=map_name, flags='g')
+            # test that module fails (ends with non-zero return code)
             self.assertModuleFail(rinfo)
+            # test that error output is not empty
             self.assertTrue(rinfo.outputs.stderr)
+            # test that the right map is mentioned in the error message
             self.assertIn(map_name, stderr)
+In some cases it might be advantageous to create a module instance
+in `setUp()` method and then modify it in test methods.
+.. note:
+    Test should be (natural) language, i.e. locale, independent
+    to allow testing the functionality under different locale settings.
+    So, if you are testing content of messages (which should be usually
+    translated), use `assertIn()` method (regular expression might be
+    applicable in some cases but in most cases `in` is exactly the
+    operation needed).
 Tests of C and C++ code
 Tests of Python code
+Use `gunittest` for this purpose in the same way as `unittest`_ would be used.
 Testing Python code with doctest
-In Python, the easiest thing to test are functions which performs some computations
-or string manipulations, i.e. they have sum numbers or strings on the input and
-some others on the output.
+.. note::
+    The primary use of ``doctest`` is to ensure that the documentation
+    for functions and classes is valid. Additionally, it can increase
+    the number of tests when executed together with other tests.
+In Python, the easiest thing to test are functions which performs some
+computations or string manipulations, i.e. they have some numbers or strings
+on the input and some other numbers or strings on the output.
 At the beginning you can use doctest for this purpose. The syntax is as follows::
     def sum_list(list_to_sum):
@@ -155,7 +184,6 @@
             import doctest
             doctest.testmod()
         else:
-           grass.parser()
            main()
 No output means that everything was successful. Note that you cannot use all
@@ -163,7 +191,7 @@
 to the dot or dots in the file name. Moreover, it is sometimes required that
 the file is accessible through sys.path which is not true for case of GRASS modules.
-Do not use use doctest for tests of edge cases, for tests which require
+However, do not use use doctest for tests of edge cases, for tests which require
 generate complex data first, etc. In these cases use `gunittest`.
Modified: grass/trunk/lib/python/gunittest/case.py
--- grass/trunk/lib/python/gunittest/case.py	2014-07-10 23:00:30 UTC (rev 61237)
+++ grass/trunk/lib/python/gunittest/case.py	2014-07-11 17:24:37 UTC (rev 61238)
@@ -408,6 +408,10 @@
             finally:
                 call_module('g.remove', rast=diff)
         # general case
+        # TODO: we are using r.info min max and r.univar min max interchangably
+        # but they might be different if region is different from map
+        # not considered as an huge issue since we expect the tested maps
+        # to match with region, however a documentation should containe a notice
         self.assertRastersDifference(actual=actual, reference=reference,
                                      statistics=statistics,
                                      precision=precision, msg=msg)
@@ -446,19 +450,13 @@
         module = _module_from_parameters(module, **kwargs)
         _check_module_run_parameters(module)
-        # do what module.run() with finish_=True would do
-        start = time.time()
-        module.run()
-        stdout, stderr = module.popen.communicate(input=module.stdin)
-        module.outputs['stdout'].value = stdout if stdout else ''
-        module.outputs['stderr'].value = stderr if stderr else ''
-        module.time = time.time() - start
-        if module.popen.poll():
+        try:
+            module.run()
+        except CalledModuleError:
             # here exception raised by run() with finish_=True would be
             # almost enough but we want some additional info to be included
             # in the test report
-            errors = module.outputs['stderr'].value
+            errors = module.outputs.stderr
             # provide diagnostic at least in English locale
             # TODO: standardized error code would be handy here
             import re
@@ -503,18 +501,11 @@
-        module.run()
-        # TODO: these two lines should go to report in some better way
-        print module.outputs['stdout'].value
-        print module.outputs['stderr'].value
+        try:
+            module.run()
+            print module.outputs.stdout
+            print module.outputs.stderr
             # TODO: message format
             # TODO: stderr?
             stdmsg = ('Running <{m.name}> module ended'
@@ -523,10 +514,11 @@
                       'See the folowing errors:\n'
                       '{errors}'.format(
                           m=module, code=module.get_python(),
-                          errors=module.outputs["stderr"].value
+                          errors=module.outputs.stderr
             self.fail(self._formatMessage(msg, stdmsg))
         # log these to final report
         # TODO: always or only if the calling test method failed?
         # in any case, this must be done before self.fail()
@@ -541,18 +533,16 @@
-        module.run()
-        if not module.popen.poll():
+        # note that we cannot use finally because we do not leave except
+        try:
+            module.run()
+            pass
+        else:
             stdmsg = ('Running <%s> ended with zero (successful) return code'
                       ' when expecting module to fail' % module.get_python())
@@ -578,9 +568,9 @@
     # in this case module already run and we would start it again
     if module.run_:
         raise ValueError('Do not run the module manually, set run_=False')
-    if module.finish_:
+    if not module.finish_:
         raise ValueError('This function will always finish module run,'
-                         ' set finish_=None or finish_=False.')
+                         ' set finish_=None or finish_=True.')
     # we expect most of the usages with stdout=PIPE
     # TODO: in any case capture PIPE always?
     if module.stdout_ is None:
Modified: grass/trunk/lib/python/gunittest/gmodules.py
--- grass/trunk/lib/python/gunittest/gmodules.py	2014-07-10 23:00:30 UTC (rev 61237)
+++ grass/trunk/lib/python/gunittest/gmodules.py	2014-07-11 17:24:37 UTC (rev 61238)
@@ -50,7 +50,7 @@
                                  ', it would be overriden' % banned)
         kargs['stdout_'] = subprocess.PIPE
         kargs['stderr_'] = subprocess.PIPE
-        kargs['finish_'] = False
+        kargs['finish_'] = True
         kargs['run_'] = False
         Module.__init__(self, cmd, *args, **kargs)
Modified: grass/trunk/lib/python/gunittest/testsuite/test_assertions.py
--- grass/trunk/lib/python/gunittest/testsuite/test_assertions.py	2014-07-10 23:00:30 UTC (rev 61237)
+++ grass/trunk/lib/python/gunittest/testsuite/test_assertions.py	2014-07-11 17:24:37 UTC (rev 61238)
@@ -85,7 +85,7 @@
 class TestAssertCommandKeyValue(grass.gunittest.TestCase):
-    """Test usage of `.assertModuleKeyValue` method."""
+    """Test usage of `assertModuleKeyValue` method."""
     # pylint: disable=R0904
     @classmethod
@@ -98,9 +98,9 @@
         cls.del_temp_region()
     def test_pygrass_module(self):
-        """Test syntax with Module as module"""
+        """Test syntax with Module and required parameters as module"""
         module = Module('r.info', map='elevation', flags='gr',
-                        run_=False, finish_=False)
+                        run_=False, finish_=True)
         self.assertModuleKeyValue(module,
                                   reference=dict(min=55.58, max=156.33),
                                   precision=0.01, sep='=')
Modified: grass/trunk/lib/python/gunittest/testsuite/test_module_assertions.py
--- grass/trunk/lib/python/gunittest/testsuite/test_module_assertions.py	2014-07-10 23:00:30 UTC (rev 61237)
+++ grass/trunk/lib/python/gunittest/testsuite/test_module_assertions.py	2014-07-11 17:24:37 UTC (rev 61238)
@@ -17,25 +17,25 @@
     def setUp(self):
         """Create two Module instances one correct and one with wrong map"""
         self.rinfo = Module('r.info', map='elevation', flags='g',
-                            stdout_=subprocess.PIPE, run_=False, finish_=False)
+                            stdout_=subprocess.PIPE, run_=False, finish_=True)
         self.rinfo_wrong = copy.deepcopy(self.rinfo)
         self.wrong_map = 'does_not_exists'
         self.rinfo_wrong.inputs['map'].value = self.wrong_map
     def test_runModule(self):
-        """Module used in runModule()"""
+        """Correct and incorrect Module used in runModule()"""
         self.runModule(self.rinfo)
         self.assertTrue(self.rinfo.outputs['stdout'].value)
         self.assertRaises(CalledModuleError, self.runModule, self.rinfo_wrong)
     def test_assertModule(self):
-        """Module used in assertModule()"""
+        """Correct and incorrect Module used in assertModule()"""
         self.assertModule(self.rinfo)
         self.assertRaises(self.failureException, self.assertModule, self.rinfo_wrong)
     def test_assertModuleFail(self):
-        """Module used in assertModuleFail()"""
+        """Correct and incorrect Module used in assertModuleFail()"""
         self.assertModuleFail(self.rinfo_wrong)
         stderr = self.rinfo_wrong.outputs['stderr'].value
         self.assertTrue(stderr)
@@ -56,19 +56,19 @@
-        """SimpleModule used in runModule()"""
+        """Correct and incorrect SimpleModule used in runModule()"""
-        """SimpleModule used in assertModule()"""
+        """Correct and incorrect SimpleModule used in assertModule()"""
-        """SimpleModule used in assertModuleFail()"""
+        """Correct and incorrect SimpleModule used in assertModuleFail()"""
@@ -76,6 +76,5 @@
         self.assertRaises(self.failureException, self.assertModuleFail, self.rinfo)
 if __name__ == '__main__':
     grass.gunittest.test()
