[GRASS-SVN] r61239 - in grass/trunk/raster/r.series.interp: . testsuite
Sat Jul 12 03:38:53 PDT 2014
Author: huhabla
Date: 2014-07-12 03:38:53 -0700 (Sat, 12 Jul 2014)
New Revision: 61239
Added:
   grass/trunk/raster/r.series.interp/testsuite/
   grass/trunk/raster/r.series.interp/testsuite/infile_2.txt
   grass/trunk/raster/r.series.interp/testsuite/interp_test.py
   grass/trunk/raster/r.series.interp/testsuite/outfile_1.txt
   grass/trunk/raster/r.series.interp/testsuite/outfile_2.txt
   grass/trunk/raster/r.series.interp/testsuite/outfile_corrupt.txt
   grass/trunk/raster/r.series.interp/main.c
Converted shell test script into Python using the gunittest framework.
Fixed command line description.
Modified: grass/trunk/raster/r.series.interp/main.c
--- grass/trunk/raster/r.series.interp/main.c	2014-07-11 17:24:37 UTC (rev 61238)
+++ grass/trunk/raster/r.series.interp/main.c	2014-07-12 10:38:53 UTC (rev 61239)
@@ -80,7 +80,7 @@
     parm.infile = G_define_standard_option(G_OPT_F_INPUT);
     parm.infile->key = "infile";
-    parm.infile->description = _("Input file with an input raster map name and data point position per line,"
+    parm.infile->description = _("Input file with one input raster map name and data point position per line,"
                                " field separator between name and sample point is |");
     parm.infile->required = NO;
@@ -97,7 +97,7 @@
     parm.outfile = G_define_standard_option(G_OPT_F_INPUT);
     parm.outfile->key = "outfile";
-    parm.outfile->description = _("Input infile with an output raster map name and sample point position per line,"
+    parm.outfile->description = _("Input file with one output raster map name and sample point position per line,"
     parm.outfile->required = NO;
Added: grass/trunk/raster/r.series.interp/testsuite/infile_2.txt
--- grass/trunk/raster/r.series.interp/testsuite/infile_2.txt	                        (rev 0)
+++ grass/trunk/raster/r.series.interp/testsuite/infile_2.txt	2014-07-12 10:38:53 UTC (rev 61239)
@@ -0,0 +1,4 @@
+map_10|10
+map_20|20
+map_30|30
+map_40|40
Added: grass/trunk/raster/r.series.interp/testsuite/interp_test.py
--- grass/trunk/raster/r.series.interp/testsuite/interp_test.py	                        (rev 0)
+++ grass/trunk/raster/r.series.interp/testsuite/interp_test.py	2014-07-12 10:38:53 UTC (rev 61239)
@@ -0,0 +1,93 @@
+"""Test to verify r.gwflow calculation, this calculation is based on
+the example at page 133 of the following book:
+author = "Kinzelbach, W. and Rausch, R.",
+title = "Grundwassermodellierung",
+publisher = "Gebr{\"u}der Borntraeger (Berlin, Stuttgart)",
+year = "1995"
+ at author Soeren Gebbert
+from grass.gunittest.case import TestCase
+class Validation7x7Grid(TestCase):
+    @classmethod
+    def setUpClass(cls):
+        """Use temporary region settings"""
+        cls.use_temp_region()
+        cls.runModule("g.region", res=10, n=80, s=0, w=0, e=120)
+        cls.runModule("g.gisenv", set="OVERWRITE=1")
+    @classmethod
+    def tearDownClass(cls):
+        """!Remove the temporary region
+        cls.del_temp_region()
+    def setUp(self):
+        """Generate interpolation data
+        self.runModule("r.mapcalc", expression="prec_1 = 100")
+        self.runModule("r.mapcalc", expression="prec_5 = 500")
+        self.runModule("r.mapcalc", expression="map_10 = 10")
+        self.runModule("r.mapcalc", expression="map_20 = 20")
+        self.runModule("r.mapcalc", expression="map_30 = 30")
+        self.runModule("r.mapcalc", expression="map_40 = 40")
+    def test_commandline(self):
+        self.assertModule("r.series.interp", input="prec_1,prec_5",  datapos=(0.0,1.0),
+            output="prec_2,prec_3,prec_4",  samplingpos=(0.25,0.5,0.75),  method="linear")
+        self.assertRasterMinMax(map="prec_2",  refmin=200,  refmax=200)
+        self.assertRasterMinMax(map="prec_3",  refmin=300,  refmax=300)
+        self.assertRasterMinMax(map="prec_4",  refmin=400,  refmax=400)
+    def test_infile(self):
+            outfile="outfile_1.txt",  method="linear")
+    def test_inoutfiles(self):
+        self.assertModule("r.series.interp", infile="infile_2.txt",
+            outfile="outfile_2.txt",  method="linear")
+        self.assertRasterMinMax(map="map_12",  refmin=12,  refmax=12)
+        self.assertRasterMinMax(map="map_14",  refmin=14,  refmax=14)
+        self.assertRasterMinMax(map="map_16",  refmin=16,  refmax=16)
+        self.assertRasterMinMax(map="map_18",  refmin=18,  refmax=18)
+        self.assertRasterMinMax(map="map_25",  refmin=25,  refmax=25)
+        self.assertRasterMinMax(map="map_35",  refmin=35,  refmax=35)
+    def test_module_failure(self):
+        """ We need tests to check the failure handling, as outputs, file and
+             sampling points  are not handled by the grass parser"""
+        # No outputs
+        self.assertModuleFail("r.series.interp", input="prec_1,prec_5",  datapos=(0.0,1.0),
+             samplingpos=(0.25,0.5,0.75),  method="linear")
+        # No sampling points
+            datapos=(0.0,1.0),  output="prec_2,prec_3,prec_4")
+        # Output and file at once
+            outfile="outfile_1.txt",  output="prec_2,prec_3,prec_4",  samplingpos=(0.25,0.5,0.75),
+            method="linear")
+        # Sampling points and file at once
+            outfile="outfile_1.txt",  samplingpos=(0.25,0.5,0.75), method="linear")
+        # Wrong input file
+            outfile="mo_such_file",  method="linear")
+            outfile="outfile_corrupt.txt",  method="linear")
+if __name__ == '__main__':
+    from grass.gunittest.main import test
+    test()
Added: grass/trunk/raster/r.series.interp/testsuite/outfile_1.txt
--- grass/trunk/raster/r.series.interp/testsuite/outfile_1.txt	                        (rev 0)
+++ grass/trunk/raster/r.series.interp/testsuite/outfile_1.txt	2014-07-12 10:38:53 UTC (rev 61239)
@@ -0,0 +1,9 @@
+prec_2|0.25
+prec_3|0.5
+prec_4|0.75
Added: grass/trunk/raster/r.series.interp/testsuite/outfile_2.txt
--- grass/trunk/raster/r.series.interp/testsuite/outfile_2.txt	                        (rev 0)
+++ grass/trunk/raster/r.series.interp/testsuite/outfile_2.txt	2014-07-12 10:38:53 UTC (rev 61239)
@@ -0,0 +1,6 @@
+map_12|12
+map_14|14
+map_16|16
+map_18|18
+map_25|25
+map_35|35
Added: grass/trunk/raster/r.series.interp/testsuite/outfile_corrupt.txt
--- grass/trunk/raster/r.series.interp/testsuite/outfile_corrupt.txt	                        (rev 0)
+++ grass/trunk/raster/r.series.interp/testsuite/outfile_corrupt.txt	2014-07-12 10:38:53 UTC (rev 61239)
@@ -0,0 +1,3 @@
+prec_2|0.25
+prec_3|0.5
+prec_4
