[GRASS-SVN] r61264 - grass-addons/grass7/raster3d/r3.flow
Wed Jul 16 10:31:15 PDT 2014
Author: annakrat
Date: 2014-07-16 10:31:15 -0700 (Wed, 16 Jul 2014)
New Revision: 61264
   grass-addons/grass7/raster3d/r3.flow/flowline.c
   grass-addons/grass7/raster3d/r3.flow/voxel_traversal.c
r3.flow: fix flowaccumulation computation
Modified: grass-addons/grass7/raster3d/r3.flow/flowline.c
--- grass-addons/grass7/raster3d/r3.flow/flowline.c	2014-07-16 15:57:30 UTC (rev 61263)
+++ grass-addons/grass7/raster3d/r3.flow/flowline.c	2014-07-16 17:31:15 UTC (rev 61264)
@@ -98,19 +98,22 @@
             if (!(last_col == col && last_row == row && last_depth == depth)) {
                 value = Rast3d_get_float(flowacc, col, row, depth);
                 Rast3d_put_float(flowacc, col, row, depth, value + 1);
-                coor_diff = (fabs(last_col - col) + fabs(last_row - row) + fabs(last_row - row));
-                /* if not run for the 1. time and previous and next point coordinates
+                if (last_col >= 0) {
+                    coor_diff = (abs(last_col - col) + abs(last_row - row) +
+                                 abs(last_depth - depth));
+                    /* if not run for the 1. time and previous and next point coordinates
                     differ by more than 1 voxel coordinate */
-                if (last_col >= 0 && coor_diff > 1) {
-                    traverse(region, point, new_point, trav_coords, &size, &trav_count);
-                    for (j = 0; j < trav_count; j++) {
-                        value = Rast3d_get_float(flowacc, trav_coords[3 * j + 0],
-                                                 trav_coords[3 * j + 1],
-                                                 trav_coords[3 * j + 2]);
-                        Rast3d_put_float(flowacc, trav_coords[3 * j + 0],
-                                         trav_coords[3 * j + 2],
-                                         value + 1);
+                    if (coor_diff > 1) {
+                        traverse(region, point, new_point, trav_coords, &size, &trav_count);
+                        for (j = 0; j < trav_count; j++) {
+                            value = Rast3d_get_float(flowacc, trav_coords[3 * j + 0],
+                                                     trav_coords[3 * j + 1],
+                                                     trav_coords[3 * j + 2]);
+                            Rast3d_put_float(flowacc, trav_coords[3 * j + 0],
+                                             trav_coords[3 * j + 2],
+                                             value + 1);
                 last_col = col;
Modified: grass-addons/grass7/raster3d/r3.flow/voxel_traversal.c
--- grass-addons/grass7/raster3d/r3.flow/voxel_traversal.c	2014-07-16 15:57:30 UTC (rev 61263)
+++ grass-addons/grass7/raster3d/r3.flow/voxel_traversal.c	2014-07-16 17:31:15 UTC (rev 61264)
@@ -5,7 +5,7 @@
 	      int *coordinates, int *size, int *coor_count)
     double dx, dy, dz;
-    double step_x, step_y, step_z;
+    int step_x, step_y, step_z;
     int x, y, z;
     int x_end, y_end, z_end;
     double t_delta_x, t_delta_y, t_delta_z;
@@ -72,10 +72,6 @@
 		z = z + step_z;
-	coordinates[count * 3 + 0] = x;
-	coordinates[count * 3 + 1] = region->rows - y - 1;
-	coordinates[count * 3 + 2] = z;
-	count++;
 	if ((x == x_end && y == y_end && z == z_end) ||
 	    /* just to make sure it breaks */
 	    (step_x * (x - x_end) > 0 || step_y * (y - y_end) > 0 ||
@@ -83,6 +79,11 @@
 	    break;
+	coordinates[count * 3 + 0] = x;
+	coordinates[count * 3 + 1] = region->rows - y - 1;
+	coordinates[count * 3 + 2] = z;
+	count++;
 	/* reallocation for cases when the steps would be too big */
 	if (*size <= count) {
 	    *size = 2 * (*size);
