[GRASS-SVN] r61265 - in grass/trunk/lib/python/gunittest: . testsuite
svn_grass at osgeo.org
Wed Jul 16 20:51:31 PDT 2014
Author: wenzeslaus
Date: 2014-07-16 20:51:31 -0700 (Wed, 16 Jul 2014)
New Revision: 61265
Added:
grass/trunk/lib/python/gunittest/testsuite/test_assertions_rast3d.py
grass/trunk/lib/python/gunittest/testsuite/test_assertions_vect.py
grass/trunk/lib/python/gunittest/case.py
grass/trunk/lib/python/gunittest/main.py
grass/trunk/lib/python/gunittest/testsuite/test_assertions.py
gunittest: 3D raster assert methods (with tests), vector assert methods (v.info-based with tests)
Modified: grass/trunk/lib/python/gunittest/case.py
--- grass/trunk/lib/python/gunittest/case.py 2014-07-16 17:31:15 UTC (rev 61264)
+++ grass/trunk/lib/python/gunittest/case.py 2014-07-17 03:51:31 UTC (rev 61265)
@@ -14,7 +14,6 @@
import os
import subprocess
-import time
import unittest
from unittest.util import safe_repr
@@ -224,9 +223,9 @@
def assertRasterFitsInfo(self, raster, reference,
precision=None, msg=None):
- r"""Test that raster map has the values obtained by v.univar module.
+ r"""Test that raster map has the values obtained by r.univar module.
- The function does not require all values from v.univar.
+ The function does not require all values from r.univar.
Only the provided values are tested.
Typical example is checking minimum, maximum and type of the map::
@@ -243,6 +242,103 @@
reference=reference, msg=msg, sep='=',
precision=precision)
+ def assertRaster3dFitsUnivar(self, raster, reference,
+ precision=None, msg=None):
+ r"""Test that 3D raster map has the values obtained by r3.univar module.
+ The function does not require all values from r3.univar.
+ Only the provided values are tested.
+ Use keyword arguments syntax for all function parameters.
+ Does not -e (extended statistics) flag, use `assertModuleKeyValue()`
+ for the full interface of arbitrary module.
+ self.assertModuleKeyValue(module='r3.univar',
+ map=raster,
+ separator='=',
+ flags='g',
+ reference=reference, msg=msg, sep='=',
+ precision=precision)
+ def assertRaster3dFitsInfo(self, raster, reference,
+ r"""Test that raster map has the values obtained by r3.info module.
+ The function does not require all values from r3.info.
+ This function supports values obtained by -g (info) and -r (range).
+ self.assertModuleKeyValue(module='r3.info',
+ map=raster, flags='gr',
+ def assertVectorFitsTopoInfo(self, vector, reference, msg=None):
+ r"""Test that raster map has the values obtained by ``v.info`` module.
+ This function uses ``-t`` flag of ``v.info`` module to get topology
+ info, so the reference dictionary should contain appropriate set or
+ subset of values (only the provided values are tested).
+ A example of checking number of points::
+ topology = dict(points=10938, primitives=10938)
+ self.assertVectorFitsTopoInfo(map='bridges', reference=topology)
+ Note that here we are checking also the number of primitives to prove
+ that there are no other features besides points.
+ No precision is applied (no difference is required). So, this function
+ is not suitable for testing items which are floating point number
+ (no such items are currently in topological information).
+ self.assertModuleKeyValue(module='v.info',
+ map=vector, flags='t',
+ precision=0)
+ def assertVectorFitsRegionInfo(self, vector, reference,
+ precision, msg=None):
+ This function uses ``-g`` flag of ``v.info`` module to get topology
+ map=vector, flags='g',
+ def assertVectorFitsExtendedInfo(self, vector, reference, msg=None):
+ This function uses ``-e`` flag of ``v.info`` module to get topology
+ The most useful items for testing (considering circumstances of test
+ invocation) are name, title, level and num_dblinks. (When testing
+ storing of ``v.info -e`` metadata, the selection might be different.)
+ is not suitable for testing items which are floating point number.
+ map=vector, flags='e',
+ precision=0)
def assertVectorFitsUnivar(self, map, column, reference, msg=None,
layer=None, type=None, where=None,
precision=None):
@@ -303,6 +399,36 @@
a=actual['max'], r=refmax, m=map, o=actual['min']))
self.fail(self._formatMessage(msg, stdmsg))
+ # TODO: use precision?
+ # TODO: write a test for this method with r.in.ascii
+ # TODO: almost the same as 2D version
+ def assertRaster3dMinMax(self, map, refmin, refmax, msg=None):
+ """Test that 3D raster map minimum and maximum are within limits.
+ Map minimum and maximum is tested against expression::
+ refmin <= actualmin and refmax >= actualmax
+ To check that more statistics have certain values use
+ `assertRaster3DFitsUnivar()` or `assertRaster3DFitsInfo()`
+ stdout = call_module('r3.info', map=map, flags='r')
+ actual = text_to_keyvalue(stdout, sep='=')
+ if refmin > actual['min']:
+ stdmsg = ('The actual minimum ({a}) is smaller than the reference'
+ ' one ({r}) for 3D raster map {m}'
+ ' (with maximum {o})'.format(
+ a=actual['min'], r=refmin, m=map, o=actual['max']))
+ self.fail(self._formatMessage(msg, stdmsg))
+ if refmax < actual['max']:
+ stdmsg = ('The actual maximum ({a}) is greater than the reference'
+ ' (with minimum {o})'.format(
+ a=actual['max'], r=refmax, m=map, o=actual['min']))
def assertFileExists(self, filename, msg=None,
skip_size_check=False, skip_access_check=False):
"""Test the existence of a file.
@@ -387,8 +513,46 @@
s=second))
return diff
+ # TODO: name of map generation is repeted three times
+ # TODO: this method is almost the same as the one for 2D
+ def _compute_difference_raster3d(self, first, second, name_part):
+ """Compute difference of two rasters (first - second)
+ The name of the new raster is a long name designed to be as unique as
+ possible and contains names of two input rasters.
+ :param first: raster to subtract from
+ :param second: raster used as decrement
+ :param name_part: a unique string to be used in the difference name
+ :returns: name of a new raster
+ diff = ('tmp_' + self.id() + '_compute_difference_raster_'
+ + name_part + '_' + first + '_minus_' + second)
+ call_module('r3.mapcalc',
+ stdin='"{d}" = "{f}" - "{s}"'.format(d=diff,
+ f=first,
+ s=second))
+ return diff
+ def _compute_vector_xor(self, ainput, alayer, binput, blayer, name_part):
+ """Compute symmetric difference (xor) of two vectors
+ :returns: name of a new vector
+ diff = ('tmp_' + self.id() + '_compute_difference_vector_'
+ + name_part + '_' + ainput + '_' + alayer
+ + '_minus_' + binput + '_' + blayer)
+ call_module('v.overlay', operator='xor', ainput=ainput, binput=binput,
+ alayer=alayer, blayer=blayer,
+ output=diff, atype='area', btype='area', olayer='')
+ # trying to avoid long reports full of categories by olayer=''
+ # olayer Output layer for new category, ainput and binput
+ # If 0 or not given, the category is not written
+ return diff
def assertRastersNoDifference(self, actual, reference,
- precision, statistics=None, msg=None):
+ precision, statistics=None, msg=None):
"""Test that `actual` raster is not different from `reference` raster
Method behaves in the same way as `assertRasterFitsUnivar()`
@@ -407,14 +571,15 @@
reference=statistics, msg=msg)
finally:
call_module('g.remove', rast=diff)
- # general case
- # TODO: we are using r.info min max and r.univar min max interchangably
- # but they might be different if region is different from map
- # not considered as an huge issue since we expect the tested maps
- # to match with region, however a documentation should containe a notice
- self.assertRastersDifference(actual=actual, reference=reference,
- statistics=statistics,
- precision=precision, msg=msg)
+ else:
+ # general case
+ # TODO: we are using r.info min max and r.univar min max interchangably
+ # but they might be different if region is different from map
+ # not considered as an huge issue since we expect the tested maps
+ # to match with region, however a documentation should containe a notice
+ self.assertRastersDifference(actual=actual, reference=reference,
+ statistics=statistics,
+ precision=precision, msg=msg)
def assertRastersDifference(self, actual, reference,
statistics, precision, msg=None):
@@ -433,6 +598,125 @@
finally:
+ def assertRasters3dNoDifference(self, actual, reference,
+ """Test that `actual` raster is not different from `reference` raster
+ Method behaves in the same way as `assertRasterFitsUnivar()`
+ but works on difference ``reference - actual``.
+ If statistics is not given ``dict(min=-precision, max=precision)``
+ is used.
+ if statistics is None or sorted(statistics.keys()) == ['max', 'min']:
+ if statistics is None:
+ statistics = dict(min=-precision, max=precision)
+ diff = self._compute_difference_raster3d(reference, actual,
+ 'assertRasters3dNoDifference')
+ try:
+ self.assertModuleKeyValue('r3.info', map=diff, flags='r',
+ sep='=', precision=precision,
+ reference=statistics, msg=msg)
+ finally:
+ call_module('g.remove', rast3d=diff)
+ else:
+ # general case
+ self.assertRasters3dDifference(actual=actual, reference=reference,
+ def assertRasters3dDifference(self, actual, reference,
+ statistics, precision, msg=None):
+ """Test statistical values of difference of reference and actual rasters
+ For cases when you are interested in no or minimal difference,
+ use `assertRastersNoDifference()` instead.
+ This method should not be used to test r3.mapcalc or r3.univar.
+ 'assertRasters3dDifference')
+ try:
+ self.assertRaster3dFitsUnivar(raster=diff, reference=statistics,
+ finally:
+ # TODO: this works only in 2D
+ # TODO: write tests
+ def assertVectorIsVectorBuffered(self, actual, reference, precision, msg=None):
+ This method should not be used to test v.buffer, v.overlay or v.select.
+ # TODO: if msg is None: add info specific to this function
+ layer = '-1'
+ module = SimpleModule('v.info', flags='t', map=reference)
+ self.runModule(module)
+ ref_topo = text_to_keyvalue(module.outputs.stdout, sep='=')
+ module = SimpleModule('v.info', flags='g', map=reference)
+ ref_info = text_to_keyvalue(module.outputs.stdout, sep='=')
+ self.assertVectorFitsTopoInfo(vector=actual, reference=ref_topo,
+ msg=msg)
+ self.assertVectorFitsRegionInfo(vector=actual, reference=ref_info,
+ msg=msg, precision=precision)
+ remove = []
+ buffered = reference + '_buffered' # TODO: more unique name
+ intersection = reference + '_intersection' # TODO: more unique name
+ self.runModule('v.buffer', input=reference, layer=layer,
+ output=buffered, distance=precision)
+ remove.append(buffered)
+ try:
+ self.runModule('v.overlay', operator='and', ainput=actual,
+ binput=reference,
+ alayer=layer, blayer=layer,
+ output=intersection, atype='area', btype='area',
+ olayer='')
+ remove.append(intersection)
+ self.assertVectorFitsTopoInfo(vector=intersection, reference=ref_topo,
+ msg=msg)
+ self.assertVectorFitsRegionInfo(vector=intersection, reference=ref_info,
+ finally:
+ call_module('g.remove', vect=remove)
+ def assertVectorsNoAreaDifference(self, actual, reference, precision,
+ layer=1, msg=None):
+ Works only for areas.
+ This method should not be used to test v.overlay or v.select.
+ diff = self._compute_xor_vectors(ainput=reference, binput=actual,
+ name_part='assertVectorsNoDifference')
+ try:
+ module = SimpleModule('v.to.db', map=diff,
+ flags='pc', separator='=')
+ # the output of v.to.db -pc sep== should look like:
+ # 43=98606087.5818323
+ # 44=727592.902311112
+ # total area=2219442027.22035
+ total_area = module.outputs.stdout.splitlines()[-1].split('=')[-1]
+ if total_area > precision:
+ stdmsg = ("Area of difference of vectors <{va}> and <{vr}>"
+ " should be 0"
+ " in the given precision ({p}) not {a}").format(
+ va=actual, vr=reference, p=precision, a=total_area)
+ finally:
+ call_module('g.remove', vect=diff)
@classmethod
def runModule(cls, module, **kwargs):
"""Run PyGRASS module.
Modified: grass/trunk/lib/python/gunittest/main.py
--- grass/trunk/lib/python/gunittest/main.py 2014-07-16 17:31:15 UTC (rev 61264)
+++ grass/trunk/lib/python/gunittest/main.py 2014-07-17 03:51:31 UTC (rev 61265)
@@ -118,6 +118,7 @@
sys.exit(not program.result.wasSuccessful())
+# TODO: makefile rule should depend on the whole build
# TODO: create a full interface (using grass parser or argparse)
if __name__ == '__main__':
if len(sys.argv) == 4:
Modified: grass/trunk/lib/python/gunittest/testsuite/test_assertions.py
--- grass/trunk/lib/python/gunittest/testsuite/test_assertions.py 2014-07-16 17:31:15 UTC (rev 61264)
+++ grass/trunk/lib/python/gunittest/testsuite/test_assertions.py 2014-07-17 03:51:31 UTC (rev 61265)
@@ -73,18 +73,8 @@
# values rounded manually to maximal expected perecision
ELEVATION_MINMAX_DICT = {'min': 55.58, 'max': 156.33}
-V_UNIVAR_BRIDGES_WIDTH_SUBSET = """n=10938
-nmissing=0
-nnull=0
-min=0
-max=1451
-range=1451
-sum=2.6299e+06
-mean=240.437
-class TestAssertCommandKeyValue(grass.gunittest.TestCase):
+class TestAssertModuleKeyValue(grass.gunittest.TestCase):
"""Test usage of `assertModuleKeyValue` method."""
# pylint: disable=R0904
@@ -113,7 +103,7 @@
precision=0.01, sep='=')
def test_direct_parameters(self):
- """Test syntax with module and its parameters as fnction parameters"""
+ """Test syntax with module and its parameters as function parameters"""
self.assertModuleKeyValue('r.info', map='elevation', flags='gr',
reference=dict(min=55.58, max=156.33),
@@ -126,7 +116,7 @@
-class TestRasterMapAssertations(grass.gunittest.TestCase):
+class TestRasterMapAssertions(grass.gunittest.TestCase):
@classmethod
@@ -165,7 +155,9 @@
ELEVATION_MINMAX, precision=0.01)
def test_dict_as_parameter(self):
- # this also tests if we are using r.info -e flag
+ """This also tests if we are using r.info -e flag and that precision is
+ not required for strings.
self.assertRasterFitsInfo('elevation', ELEVATION_MAPSET_DICT)
def test_assertRastersNoDifference(self):
@@ -197,26 +189,9 @@
msg="The difference of different maps should have huge mean")
-class TestVectorMapAssertations(grass.gunittest.TestCase):
+class TestFileAssertions(grass.gunittest.TestCase):
- def test_assertVectorFitsUnivar(self):
- self.assertVectorFitsUnivar(map='bridges', column='WIDTH',
- reference=V_UNIVAR_BRIDGES_WIDTH_SUBSET,
- precision=0.01)
- self.assertRaises(self.failureException,
- self.assertVectorFitsUnivar,
- map='bridges', column='YEAR_BUILT',
- precision=0.01)
- self.assertRaises(ValueError,
- map='bridges', column='WIDTH',
- reference=RANDOM_KEYVALUES)
-class TestFileAssertations(grass.gunittest.TestCase):
- # pylint: disable=R0904
@classmethod
def setUpClass(cls):
# we expect WIND to be always present
Added: grass/trunk/lib/python/gunittest/testsuite/test_assertions_rast3d.py
--- grass/trunk/lib/python/gunittest/testsuite/test_assertions_rast3d.py (rev 0)
+++ grass/trunk/lib/python/gunittest/testsuite/test_assertions_rast3d.py 2014-07-17 03:51:31 UTC (rev 61265)
@@ -0,0 +1,128 @@
+# -*- coding: utf-8 -*-
+Tests assertion methods for 3D rasters.
+from grass.exceptions import CalledModuleError
+import grass.gunittest as gunittest
+class TestRaster3dMapAssertions(gunittest.TestCase):
+ # pylint: disable=R0904
+ constant_map = 'raster3d_assertions_constant'
+ rcd_increasing_map = 'raster3d_assertions_rcd_increasing'
+ @classmethod
+ def setUpClass(cls):
+ cls.use_temp_region()
+ # TODO: here we should actually not call self.runModule but call_module
+ cls.runModule('g.region', n=200, s=100, e=400, w=200,
+ t=500, b=450, res3=1)
+ cls.runModule('r3.mapcalc', expression='%s = 155' % cls.constant_map)
+ expression='%s = row() + col() + depth()' % cls.rcd_increasing_map)
+ @classmethod
+ def tearDownClass(cls):
+ cls.del_temp_region()
+ # TODO: input as list does not work, why?
+ cls.runModule('g.remove',
+ rast3d=','.join([cls.constant_map, cls.rcd_increasing_map]))
+ def test_assertRaster3dFitsUnivar(self):
+ reference = dict(n=1000000,
+ null_cells=0,
+ cells=1000000,
+ min=155,
+ max=155,
+ range=0,
+ mean=155,
+ mean_of_abs=155,
+ stddev=0,
+ variance=0,
+ coeff_var=0,
+ sum=155000000)
+ self.assertRaster3dFitsUnivar(self.constant_map, reference=reference,
+ precision=0.000001)
+ self.assertRaises(self.failureException,
+ self.assertRaster3dFitsUnivar,
+ self.rcd_increasing_map,
+ reference=reference, precision=1)
+ self.assertRaises(ValueError,
+ self.constant_map, reference=dict(a=4, b=5, c=6))
+ self.assertRaises(CalledModuleError,
+ 'does_not_exists', reference=dict(a=4, b=5, c=6))
+ def test_assertRaster3dFitsInfo(self):
+ reference = dict(north=200,
+ south=100,
+ east=400,
+ west=200,
+ bottom=450,
+ top=500,
+ nsres=1,
+ ewres=1,
+ tbres=1,
+ rows=100,
+ cols=200,
+ depths=50)
+ self.assertRaster3dFitsInfo(self.constant_map, reference=reference)
+ reference['north'] = 500
+ self.assertRaster3dFitsInfo,
+ self.constant_map, reference=reference)
+ self.constant_map, reference=dict(a=5))
+ def test_common_values_info_univar(self):
+ minmax = dict(min=3, max=350)
+ self.assertRaster3dFitsUnivar(self.rcd_increasing_map,
+ minmax, precision=0.01)
+ self.assertRaster3dFitsInfo(self.rcd_increasing_map,
+ def test_string_as_parameter(self):
+ reference="max=155", precision=1)
+ reference="n=1000000", precision=0)
+ def test_assertRasters3dNoDifference(self):
+ """Test basic usage of assertRastersNoDifference"""
+ # precision might need to be increased
+ self.assertRasters3dNoDifference(actual=self.rcd_increasing_map,
+ reference=self.rcd_increasing_map,
+ precision=0,
+ msg="The same maps should have no difference")
+ self.assertRasters3dNoDifference,
+ actual=self.constant_map,
+ precision=1,
+ msg="Different maps should have difference")
+ def test_assertRasters3dNoDifference_mean(self):
+ """Test usage of assertRastersNoDifference with mean"""
+ precision=0, # this might need to be increased
+ statistics=dict(mean=0),
+ msg="The difference of same maps should have small mean")
+ precision=1,
+ msg="The difference of different maps should have huge mean")
+if __name__ == '__main__':
+ gunittest.test()
Property changes on: grass/trunk/lib/python/gunittest/testsuite/test_assertions_rast3d.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
Added: grass/trunk/lib/python/gunittest/testsuite/test_assertions_vect.py
--- grass/trunk/lib/python/gunittest/testsuite/test_assertions_vect.py (rev 0)
+++ grass/trunk/lib/python/gunittest/testsuite/test_assertions_vect.py 2014-07-17 03:51:31 UTC (rev 61265)
@@ -0,0 +1,114 @@
+Tests assertion methods for vectors.
+V_UNIVAR_BRIDGES_WIDTH_SUBSET = """n=10938
+nmissing=0
+nnull=0
+min=0
+max=1451
+range=1451
+sum=2.6299e+06
+mean=240.437
+RANDOM_KEYVALUES = """abc=2025000
+aaa=55.5787925720215
+bbb=156.329864501953
+# v.info bridges -t
+V_UNIVAR_BRIDGES_TOPO = dict(
+ nodes=0,
+ points=10938,
+ lines=0,
+ boundaries=0,
+ centroids=0,
+ areas=0,
+ islands=0,
+ primitives=10938,
+ map3d=0,
+# v.info bridges -g and rounded
+V_UNIVAR_BRIDGES_REGION = dict(
+ north=317757,
+ south=14691,
+ east=915045,
+ west=125794,
+ top=0,
+ bottom=0,
+# v.info bridges -g and reduced to minumum
+V_UNIVAR_BRIDGES_EXTENDED = dict(
+ name='bridges',
+ level=2,
+ num_dblinks=1,
+class TestVectorMapAssertions(gunittest.TestCase):
+ """Test assertions of map meta and statistics"""
+ def test_assertVectorFitsUnivar(self):
+ self.assertVectorFitsUnivar(map='bridges', column='WIDTH',
+ reference=V_UNIVAR_BRIDGES_WIDTH_SUBSET,
+ precision=0.01)
+ self.assertVectorFitsUnivar,
+ map='bridges', column='YEAR_BUILT',
+ precision=0.01)
+ map='bridges', column='WIDTH',
+ reference=RANDOM_KEYVALUES)
+ def test_assertVectorFitsTopoInfo(self):
+ self.assertVectorFitsTopoInfo('bridges', V_UNIVAR_BRIDGES_TOPO)
+ self.assertVectorFitsTopoInfo,
+ 'lakes',
+ V_UNIVAR_BRIDGES_TOPO)
+ 'bridges', RANDOM_KEYVALUES)
+ 'bridges', V_UNIVAR_BRIDGES_REGION)
+ def test_assertVectorFitsRegionInfo(self):
+ self.assertVectorFitsRegionInfo('bridges', V_UNIVAR_BRIDGES_REGION, precision=1.0)
+ self.assertVectorFitsRegionInfo,
+ 'lakes', V_UNIVAR_BRIDGES_REGION, precision=1.0)
+ 'bridges', RANDOM_KEYVALUES, precision=1.0)
+ 'bridges', V_UNIVAR_BRIDGES_TOPO, precision=1.0)
+ def test_assertVectorFitsExtendedInfo(self):
+ self.assertVectorFitsExtendedInfo('bridges', V_UNIVAR_BRIDGES_EXTENDED)
+ self.assertVectorFitsExtendedInfo,
+ 'lakes',
+ V_UNIVAR_BRIDGES_EXTENDED)
+ 'bridges',
+ RANDOM_KEYVALUES)
+ 'bridges',
+ gunittest.test()
Property changes on: grass/trunk/lib/python/gunittest/testsuite/test_assertions_vect.py
+ text/x-python
+ native
