[GRASS-SVN] r61269 - grass/trunk/gui/wxpython/wxplot
Thu Jul 17 14:30:53 PDT 2014
Author: annakrat
Date: 2014-07-17 14:30:52 -0700 (Thu, 17 Jul 2014)
New Revision: 61269
   grass/trunk/gui/wxpython/wxplot/profile.py
wxGUI/profile: fix #1787 - wxplot now converts distance from meters to the current units
Modified: grass/trunk/gui/wxpython/wxplot/profile.py
--- grass/trunk/gui/wxpython/wxplot/profile.py	2014-07-17 20:54:41 UTC (rev 61268)
+++ grass/trunk/gui/wxpython/wxplot/profile.py	2014-07-17 21:30:52 UTC (rev 61269)
@@ -43,6 +43,22 @@
 from wxplot.dialogs    import ProfileRasterDialog, PlotStatsFrame
 from core.gcmd         import RunCommand, GWarning, GError, GMessage
+def get_unit_conversion():
+    """Get conversion factor to convert output from r.profile to current units.
+    Module r.profile always outputs distance in meters.
+    .. todo:: create a wrapper for g.proj in grass.core
+    proj = RunCommand(prog='g.proj', read=True, flags='g').strip()
+    if not proj:
+        # TODO put some warning here
+        return 1.
+    proj = grass.parse_key_val(proj, sep='=')
+    return 1 / float(proj.get('meters', 1))
 class ProfileFrame(BasePlotFrame):
     """Mainframe for displaying profile of one or more raster maps. Uses wx.lib.plot.
@@ -59,6 +75,7 @@
             self.SetToolBar(self.toolbar)
         self.SetTitle(_("GRASS Profile Analysis Tool"))
         self._units = units
+        self._conversion = get_unit_conversion()
         # Init variables
@@ -258,7 +275,8 @@
             if dist == None or dist == '' or dist == 'nan' or \
                 elev == None or elev == '' or elev == 'nan':
                 continue
-            dist = float(dist)
+            # remove conversion if one day r.profile starts to output distance in projection units!
+            dist = self._conversion * float(dist)
             elev = float(elev)
             datalist.append((dist,elev))
