[GRASS-SVN] r61270 - grass/branches/releasebranch_7_0/raster/r.spread
svn_grass at osgeo.org
Thu Jul 17 14:43:32 PDT 2014
Author: annakrat
Date: 2014-07-17 14:43:32 -0700 (Thu, 17 Jul 2014)
New Revision: 61270
grass/branches/releasebranch_7_0/raster/r.spread/main.c
grass/branches/releasebranch_7_0/raster/r.spread/spread.c
r.spread: backport small fixes (r60915, r60916) based on what Coverity Scan found
Modified: grass/branches/releasebranch_7_0/raster/r.spread/main.c
--- grass/branches/releasebranch_7_0/raster/r.spread/main.c 2014-07-17 21:30:52 UTC (rev 61269)
+++ grass/branches/releasebranch_7_0/raster/r.spread/main.c 2014-07-17 21:43:32 UTC (rev 61270)
@@ -232,6 +232,7 @@
parm.init_time->key = "init_time";
parm.init_time->type = TYPE_STRING;
parm.init_time->key_desc = "int (>= 0)"; /* TODO: move to ->options */
+ parm.init_time->answer = "0";
parm.init_time->label =
_("Initial time for current simulation (0) (min)");
parm.init_time->description =
@@ -378,17 +379,13 @@
comp_dens = 0.5;
/*Check the given initial time and simulation time lag, assign the default if needed */
- if (parm.init_time->answer) {
- init_time = atoi(parm.init_time->answer);
- if (init_time < 0) {
- G_warning("Illegal initial time <%s>", parm.init_time->answer);
- G_usage();
- exit(EXIT_FAILURE);
+ init_time = atoi(parm.init_time->answer);
+ if (init_time < 0) {
+ G_warning("Illegal initial time <%s>", parm.init_time->answer);
+ G_usage();
+ exit(EXIT_FAILURE);
- else {
- time_lag = 0;
if (parm.time_lag->answer) {
time_lag = atoi(parm.time_lag->answer);
if (time_lag < 0) {
Modified: grass/branches/releasebranch_7_0/raster/r.spread/spread.c
--- grass/branches/releasebranch_7_0/raster/r.spread/spread.c 2014-07-17 21:30:52 UTC (rev 61269)
+++ grass/branches/releasebranch_7_0/raster/r.spread/spread.c 2014-07-17 21:43:32 UTC (rev 61270)
@@ -68,6 +68,9 @@
struct cell_ptrHa *to_cell, *old_to_cell;
struct costHa *pres_cell;
+ /* initialize using arbitrary value, this value is never used except for debug */
+ min_cost = 0;
ncells = nrows * ncols;
G_message
("Finding spread time - number of cells visited in percentage ... %3d%%",
