[GRASS-SVN] r61284 - grass/trunk/raster/r.gwflow/testsuite
svn_grass at osgeo.org
Sun Jul 20 06:52:09 PDT 2014
Author: huhabla
Date: 2014-07-20 06:52:09 -0700 (Sun, 20 Jul 2014)
New Revision: 61284
grass/trunk/raster/r.gwflow/testsuite/validation_7x7_grid.py
grass/trunk/raster/r.gwflow/testsuite/validation_excavation.py
r.gwflow: testsuite: Use class functions to run modules.
Modified: grass/trunk/raster/r.gwflow/testsuite/validation_7x7_grid.py
--- grass/trunk/raster/r.gwflow/testsuite/validation_7x7_grid.py 2014-07-20 00:18:36 UTC (rev 61283)
+++ grass/trunk/raster/r.gwflow/testsuite/validation_7x7_grid.py 2014-07-20 13:52:09 UTC (rev 61284)
@@ -7,7 +7,6 @@
@author Soeren Gebbert
-import grass.script as grass
from grass.gunittest.case import TestCase
class Validation7x7Grid(TestCase):
@@ -15,17 +14,17 @@
@classmethod
def setUpClass(cls):
"""Use temporary region settings"""
- grass.use_temp_region()
+ cls.use_temp_region()
cls.runModule("g.region", res=100, n=700, s=0, w=0, e=700)
@classmethod
def tearDownClass(cls):
"""!Remove the temporary region
- grass.del_temp_region()
+ cls.del_temp_region()
def setUp(self):
- """Set region and create input data for transient groundwater flow computation
+ """Create input data for transient groundwater flow computation
self.runModule("r.mapcalc", expression="phead=50")
self.runModule("r.mapcalc", expression="status=if(col() == 1 || col() == 7 , 2, 1)")
@@ -38,12 +37,12 @@
self.runModule("r.mapcalc", expression="null=0.0")
def test_transient(self):
- #First compute the groundwater flow
+ #First compute the groundwater flow after 500 seconds to have initial conditions
self.assertModule("r.gwflow", flags="f", solver="cholesky", top="top_conf", bottom="bottom", phead="phead",\
status="status", hc_x="hydcond", hc_y="hydcond", q="well", s="s",\
recharge="recharge", output="gwresult_conf", dt=500, type="confined", budget="water_budget", overwrite=True)
- # loop over the timesteps
+ # loop over the timesteps each 500 seconds
for i in range(20):
self.assertModule("r.gwflow", flags="f", solver="cholesky", top="top_conf", bottom="bottom", phead="gwresult_conf",\
Modified: grass/trunk/raster/r.gwflow/testsuite/validation_excavation.py
--- grass/trunk/raster/r.gwflow/testsuite/validation_excavation.py 2014-07-20 00:18:36 UTC (rev 61283)
+++ grass/trunk/raster/r.gwflow/testsuite/validation_excavation.py 2014-07-20 13:52:09 UTC (rev 61284)
@@ -8,7 +8,6 @@
class ValidationExcavation(TestCase):
@@ -16,17 +15,17 @@
@classmethod
cls.runModule("g.region", flags="p", res=50, n=950, s=0, w=0, e=2000)
@classmethod
def setUp(self):
- """Set region and create input data for steady state groundwater flow computation
+ """Create input data for steady state groundwater flow computation
self.runModule("r.mapcalc", expression="phead= if(row() == 19, 5, 3)")
self.runModule("r.mapcalc", expression="status=if((col() == 1 && row() == 13) ||\
