[GRASS-SVN] r61285 - grass/trunk/lib/raster3d
Sun Jul 20 08:55:49 PDT 2014
Author: huhabla
Date: 2014-07-20 08:55:48 -0700 (Sun, 20 Jul 2014)
New Revision: 61285
   grass/trunk/lib/raster3d/raster3dlib.dox
raster3dlib: Small doxygen update
Modified: grass/trunk/lib/raster3d/raster3dlib.dox
--- grass/trunk/lib/raster3d/raster3dlib.dox	2014-07-20 13:52:09 UTC (rev 61284)
+++ grass/trunk/lib/raster3d/raster3dlib.dox	2014-07-20 15:55:48 UTC (rev 61285)
@@ -3,7 +3,7 @@
      by M. Neteler 5/2004, 8/2005
-<i>TODO: Update for this page for GRASS 7.</i>
+<i>TODO: Update for this page for GRASS 7, most of the function names have been changed from camel case to gnu underscore style.</i>
 \tableofcontents
@@ -11,9 +11,16 @@
 The 3D Raster Volume Library is used for the <tt>r3.*</tt> and vector
 volume tools. The library uses a tile cache based approach to store
-floating point values in abritrary order in a volume. The coordinate
+floating point values in arbitrary order in a volume. The coordinate
 system of a volume is column and row compatible to the raster library
 and counts from the bottom to the top of the cube.
+<P>
+Random reading and writing is supported until are tiles are flushed to the disk.
+In case the tiles are written to the disk, random reading is still supported.
+<P>
+The size of the tile cache in memory can be set in bytes using the environmental variable  RASTER3D_MAX_CACHE_SIZE.
+Default size is 16777216 bytes.The number of tiles hold in memory can be specified with the environmental variable
+RASTER3D_DEFAULT_CACHE_SIZE. Default is 1000.
 \image html "r3_volume_layout.png" "The volume coordinate system and tile layout of the 3D Raster Library"
@@ -29,7 +36,7 @@
         color file (color)
         categories file (cats)
         range file (range)
-        timestamp file /* not yet implemented */
+        timestamp file
         cell file (cell)
         header file (cellhd)
         a directory containing display files (dsp)
@@ -41,7 +48,7 @@
 <P>
 Note: color, categories, and the range can be used in the same way as in <EM>2d</EM>
-GRASS with the exception of reading and writng. <EM>3d</EM> read and write
+GRASS with the exception of reading and writing. <EM>3d</EM> read and write
 functions have to be used for this purpose.
@@ -100,6 +107,11 @@
 \section Tile_Data_Compression Tile Data Compression
+NOTE: RLE compression was removed because of error-prone implementation.
+De-compression is still available for backward compatibility.
+Default compression is now zip.
 <P>
 There are three methods of compression provided. The compression
 methods can either be those defined by default, set by environment
@@ -107,7 +119,7 @@
 \verbatim
         Precision
-        RLE
+        zlib
 \endverbatim
 <P>
@@ -117,15 +129,9 @@
 effective way to achieve good compression.
 <P>
-RLE takes advantage of possible repetitions of the
-exponents and the NULL-bit structure. Using RLE does not significantly
-increase the running time. If for some tile the non-RLEed version is
-smaller in size, RLE is not used for this tile.
+The default and suggested setting is to use precision and zlib.
 <P>
-The default and suggested setting is to use precision and RLE.
-<P>
 Additional compression is achieved by storing the extra NULL-bit in a
 separate bit-array. Using this scheme NULL-values need not actually be
 represented in the array of cell values. This array is stored together
@@ -159,13 +165,13 @@
 coordinates. The corresponding functions are
 <P>
-int Rast3d_getValue()
+int Rast3d_get_value()
 <P>
 and
 <P>
-int Rast3d_putValue()
+int Rast3d_put_value()
 <P>
 and their corresponding typed versions.
@@ -177,7 +183,7 @@
 explicitly requested.
 <BR>
 <P>
-If the map is new <TT>Rast3d_getValue()</TT> can be used even if the tile which
+If the map is new <TT>Rast3d_get_value()</TT> can be used even if the tile which
 contains the cell has already been flushed to the data file. In this case the
 tile is simply read back into the memory-cache from the data file.
 <BR>
@@ -196,7 +202,7 @@
 <P>
 As an example consider the case where the data is stored in the file with double
 precision and the tiles are stored in memory in single precision.  Then using
-<TT>Rast3d_getValue()</TT> will actually return a double precision number whose precision
+<TT>Rast3d_get_value()</TT> will actually return a double precision number whose precision
 is only 23 bits.  It is therefore a good idea to use the types in the memory
 consistently.
 <BR>
@@ -302,12 +308,12 @@
     double east, west;
     double top, bottom;
-    int rows, cols, depths;/* data dimensions in cells */
+    int rows, cols, depths; // data dimensions in cells
     double ns_res, ew_res, tb_res;
-    int proj;  /* Projection (see gis.h) */
-    int zone;  /* Projection zone (see gis.h) */
+    int proj;  // Projection (see gis.h)
+    int zone;  // Projection zone (see gis.h)
 } RASTER3D_Region;
 \endverbatim
@@ -389,7 +395,7 @@
 \section Include_File Include File
 <P>
-Exported RASTER3D constants and structures can be found in <EM>G3d.h</EM>.
+Exported RASTER3D constants and structures can be found in <EM>raster3d.h</EM>.
 <P>
@@ -478,7 +484,10 @@
 <P>
 \subsection Toggling_RLE_compression Toggling RLE compression
+NOTE: RLE compression is not used any longer, the RLE code is still present to assure backward compatibility.
+G_zlib_write() and G_zlib_read() are used for compression now.
 <P>
 This value specifies whether RLE compression should be used (in addition to
 precision).
@@ -612,15 +621,15 @@
 <P>
 \verbatim
 void Rast3d_set_unit (map, unit)
-        RASTER3d_Map; /* the map */
-        char *unit; /* The data unit description */
+        RASTER3d_Map; // the map
+        char *unit; // The data unit description
 void Rast3d_set_vertical_unit (map, unit)
-        char *unit;  /* Use the standard from units.c in lib/gis */
+        char *unit;  // Use the standard from units.c in lib/gis
 void Rast3d_set_vertical_unit2 (map, unit)
-        int unit; /* defined in gis.h */
+        int unit; // defined in gis.h
 \endverbatim
 \section Error_Handling Error Handling: Setting the error function
@@ -740,7 +749,25 @@
 Returns 1 ... if successful, 0 ...  otherwise.
 <P>
+void *Rast3d_open_new_opt_tile_size(const char *name, int cache, RASTER3D_Region * region, int type, int maxSize)
+Opens new g3d-file with <em>name</em> in the current mapset. This method tries to compute
+optimal tile size based on the number of rows, cols and depths and the maximum allowed tile size in KB.
+Tiles are stored in memory using RASTER3D_TILE_SAME_AS_FILE method. <em>cache</em> specifies the
+cache-mode used and must be either RASTER3D_NO_CACHE, RASTER3D_USE_CACHE_DEFAULT,
+RASTER3D_USE_CACHE_X, RASTER3D_USE_CACHE_Y, RASTER3D_USE_CACHE_Z,
+RASTER3D_USE_CACHE_XY, RASTER3D_USE_CACHE_XZ, RASTER3D_USE_CACHE_YZ,
+RASTER3D_USE_CACHE_XYZ, the result of <tt>Rast3d_cache_size_encode ()</tt>
+(cf.{g3d:G3d.cacheSizeEncode}), or any positive integer which
+specifies the number of tiles buffered in the cache.  <em>region</em> specifies
+the 3d region.
+The map is created using the <em>type</em> which must be of FCELL_TYPE or DCELL_TYPE.
+<P>
+Returns a pointer to the cell structure ... if successful,
+NULL ... otherwise.
+<P>
 \subsection Reading_and_Writing_Tiles Reading and Writing Tiles
 <P>
@@ -960,7 +987,7 @@
 <P>
 If this tile has already been written before the write request is ignored.
-  If the tile was never referred to before the invokation of Rast3d_flushTile, a
+  If the tile was never referred to before the invocation of Rast3d_flushTile, a
   tile filled with NULL-values is written.
 <P>
