[GRASS-SVN] r61286 - grass/trunk/raster3d/r3.neighbors/test_suite
    svn_grass at osgeo.org
    Sun Jul 20 08:59:12 PDT 2014
Author: huhabla
Date: 2014-07-20 08:59:12 -0700 (Sun, 20 Jul 2014)
New Revision: 61286
   grass/trunk/raster3d/r3.neighbors/test_suite/test.r3.neighbors.sh
r3.neighbors: testsuite: Better overwrite handling in test script
Modified: grass/trunk/raster3d/r3.neighbors/test_suite/test.r3.neighbors.sh
--- grass/trunk/raster3d/r3.neighbors/test_suite/test.r3.neighbors.sh	2014-07-20 15:55:48 UTC (rev 61285)
+++ grass/trunk/raster3d/r3.neighbors/test_suite/test.r3.neighbors.sh	2014-07-20 15:59:12 UTC (rev 61286)
@@ -1,33 +1,35 @@
 #!/bin/sh
+export GRASS_OVERWRITE=1
 g.region w=0 e=30 s=0 n=30 b=0 t=30 res3=10
-r3.mapcalc --o expr="test_neighbor_float  = float(3)"
-r3.mapcalc --o expr="test_neighbor_double = double(3)"
-r3.mapcalc --o expr="test_neighbor_null = null()"
+r3.mapcalc  expr="test_neighbor_float  = float(3)"
+r3.mapcalc  expr="test_neighbor_double = double(3)"
+r3.mapcalc  expr="test_neighbor_null = null()"
 # First @test with float values with @precision=2
 r3.neighbors input=test_neighbor_float output=test_neighbor_float_average \
-    method=average window=3,3,3 --o
+    method=average window=3,3,3
 r3.out.ascii dp=2 input=test_neighbor_float_average output=test_neighbor_float_average.txt
 r3.neighbors input=test_neighbor_float output=test_neighbor_float_sum \
-    method=sum window=3,3,3 --o
+    method=sum window=3,3,3
 r3.out.ascii dp=2 input=test_neighbor_float_sum output=test_neighbor_float_sum.txt
 # Second @test with double values
 r3.neighbors input=test_neighbor_double output=test_neighbor_double_average \
 r3.out.ascii dp=2 input=test_neighbor_double_average output=test_neighbor_double_average.txt
 r3.neighbors input=test_neighbor_double output=test_neighbor_double_sum \
 r3.out.ascii dp=2 input=test_neighbor_double_sum output=test_neighbor_double_sum.txt
 # Third @test with null values
 r3.neighbors input=test_neighbor_null output=test_neighbor_null_sum \
 r3.out.ascii dp=2 input=test_neighbor_null_sum output=test_neighbor_null_sum.txt
