[GRASS-SVN] r61427 - grass/branches/releasebranch_7_0/lib/python/imaging
svn_grass at osgeo.org
Mon Jul 28 06:35:08 PDT 2014
Author: annakrat
Date: 2014-07-28 06:35:08 -0700 (Mon, 28 Jul 2014)
New Revision: 61427
grass/branches/releasebranch_7_0/lib/python/imaging/images2gif.py
wxGUI/animation: fix GIF export for Pillow, #2177 (merge from trunk, r61417)
Modified: grass/branches/releasebranch_7_0/lib/python/imaging/images2gif.py
--- grass/branches/releasebranch_7_0/lib/python/imaging/images2gif.py 2014-07-28 12:25:42 UTC (rev 61426)
+++ grass/branches/releasebranch_7_0/lib/python/imaging/images2gif.py 2014-07-28 13:35:08 UTC (rev 61427)
@@ -70,6 +70,11 @@
try:
import PIL
from PIL import Image
+ pillow = True
+ try:
+ from PIL import PILLOW_VERSION # test if user has Pillow or PIL
+ except ImportError:
+ pillow = False
from PIL.GifImagePlugin import getheader, getdata
except ImportError:
PIL = None
@@ -404,13 +409,22 @@
""" writeGifToFile(fp, images, durations, loops, xys, disposes)
Given a set of images writes the bytes to the specified stream.
+ Requires different handling of palette for PIL and Pillow:
+ based on https://github.com/rec/echomesh/blob/master/
+ code/python/external/images2gif.py
# Obtain palette for all images and count each occurance
palettes, occur = [], []
for im in images:
- palettes.append( getheader(im)[1] )
+ if not pillow:
+ palette = getheader(im)[1]
+ else:
+ palette = getheader(im)[0][-1]
+ if not palette:
+ palette = im.palette.tobytes()
+ palettes.append(palette)
for palette in palettes:
occur.append( palettes.count( palette ) )
