[GRASS-SVN] r61428 - grass/trunk/lib/python/script
svn_grass at osgeo.org
Mon Jul 28 08:57:23 PDT 2014
Author: glynn
Date: 2014-07-28 08:57:23 -0700 (Mon, 28 Jul 2014)
New Revision: 61428
grass/trunk/lib/python/script/raster.py
Add env= parameter to mapcalc, mapcalc_start, raster_what
Modified: grass/trunk/lib/python/script/raster.py
--- grass/trunk/lib/python/script/raster.py 2014-07-28 13:35:08 UTC (rev 61427)
+++ grass/trunk/lib/python/script/raster.py 2014-07-28 15:57:23 UTC (rev 61428)
@@ -87,7 +87,8 @@
# interface to r.mapcalc
-def mapcalc(exp, quiet = False, verbose = False, overwrite = False, seed = None, **kwargs):
+def mapcalc(exp, quiet = False, verbose = False, overwrite = False,
+ seed = None, env = None, **kwargs):
"""!Interface to r.mapcalc.
@param exp expression
@@ -96,6 +97,7 @@
@param overwrite True to enable overwriting the output (<tt>--o</tt>)
@param seed an integer used to seed the random-number generator for the rand() function,
or 'auto' to generate a random seed
+ @param env dictionary of environment variables for child process
@param kwargs
@@ -106,6 +108,7 @@
e = t.substitute(**kwargs)
if write_command('r.mapcalc', file = '-', stdin = e,
+ env = env,
seed = seed,
quiet = quiet,
verbose = verbose,
@@ -113,7 +116,8 @@
fatal(_("An error occurred while running r.mapcalc"))
-def mapcalc_start(exp, quiet = False, verbose = False, overwrite = False, seed = None, **kwargs):
+def mapcalc_start(exp, quiet = False, verbose = False, overwrite = False,
"""!Interface to r.mapcalc, doesn't wait for it to finish, returns Popen object.
\code
@@ -134,6 +138,7 @@
@param kwargs
@return Popen object
@@ -146,6 +151,7 @@
p = feed_command('r.mapcalc', file = '-',
+ env = env,
seed = seed,
quiet = quiet,
verbose = verbose,
@@ -155,7 +161,7 @@
return p
# interface to r.what
-def raster_what(map, coord):
+def raster_what(map, coord, env = None):
"""!TODO"""
if type(map) in (types.StringType, types.UnicodeType):
map_list = [map]
@@ -173,14 +179,13 @@
# separator '|' not included in command
# because | is causing problems on Windows
# change separator?
- cmdParams = dict(quiet = True,
- flags = 'rf',
- map = ','.join(map_list),
- coordinates = ','.join(coord_list),
- null = _("No data"))
ret = read_command('r.what',
- **cmdParams)
+ flags = 'rf',
+ map = ','.join(map_list),
+ coordinates = ','.join(coord_list),
+ null = _("No data"),
+ quiet = True,
+ env = env)
data = list()
if not ret:
return data
