[GRASS-SVN] r61456 - grass/branches/releasebranch_7_0/temporal/t.rast.to.rast3
svn_grass at osgeo.org
Wed Jul 30 04:18:59 PDT 2014
Author: huhabla
Date: 2014-07-30 04:18:59 -0700 (Wed, 30 Jul 2014)
New Revision: 61456
grass/branches/releasebranch_7_0/temporal/t.rast.to.rast3/t.rast.to.rast3.py
grass/branches/releasebranch_7_0/temporal/t.rast.to.rast3/test.t.rast.to.rast3.sh
t.rast.to.rast3: Fixed ticket #2366 by applying the patch from Anna; Backport from trunk
Modified: grass/branches/releasebranch_7_0/temporal/t.rast.to.rast3/t.rast.to.rast3.py
--- grass/branches/releasebranch_7_0/temporal/t.rast.to.rast3/t.rast.to.rast3.py 2014-07-30 11:12:39 UTC (rev 61455)
+++ grass/branches/releasebranch_7_0/temporal/t.rast.to.rast3/t.rast.to.rast3.py 2014-07-30 11:18:59 UTC (rev 61456)
@@ -52,6 +52,12 @@
maps = sp.get_registered_maps_as_objects_by_granularity()
num_maps = len(maps)
+ # get datatype of the first map
+ if maps:
+ maps[0][0].select()
+ datatype = maps[0][0].metadata.get_datatype()
+ else:
+ datatype = None
# Get the granularity and set bottom, top and top-bottom resolution
granularity = sp.get_granularity()
@@ -112,7 +118,12 @@
# Create a NULL map to fill the gaps
null_map = "temporary_null_map_%i" % os.getpid()
- grass.mapcalc("%s = null()" % (null_map))
+ if datatype == 'DCELL':
+ grass.mapcalc("%s = double(null())" % (null_map))
+ elif datatype == 'FCELL':
+ grass.mapcalc("%s = float(null())" % (null_map))
+ else:
+ grass.mapcalc("%s = null()" % (null_map))
if maps:
count = 0
Modified: grass/branches/releasebranch_7_0/temporal/t.rast.to.rast3/test.t.rast.to.rast3.sh
--- grass/branches/releasebranch_7_0/temporal/t.rast.to.rast3/test.t.rast.to.rast3.sh 2014-07-30 11:12:39 UTC (rev 61455)
+++ grass/branches/releasebranch_7_0/temporal/t.rast.to.rast3/test.t.rast.to.rast3.sh 2014-07-30 11:18:59 UTC (rev 61456)
@@ -5,12 +5,12 @@
# The region setting should work for UTM and LL test locations
g.region s=0 n=80 w=0 e=120 b=0 t=1 res=10 res3=10 -p3
-r.mapcalc --o expr="prec_1 = 100"
-r.mapcalc --o expr="prec_2 = 200"
-r.mapcalc --o expr="prec_3 = 300"
-r.mapcalc --o expr="prec_4 = 400"
-r.mapcalc --o expr="prec_5 = 500"
-r.mapcalc --o expr="prec_6 = 600"
+r.mapcalc --o expr="prec_1 = 100.0"
+r.mapcalc --o expr="prec_2 = 200.0"
+r.mapcalc --o expr="prec_3 = 300.0"
+r.mapcalc --o expr="prec_4 = 400.0"
+r.mapcalc --o expr="prec_5 = 500.0"
+r.mapcalc --o expr="prec_6 = 600.0"
n1=`g.tempfile pid=1 -d`
