[GRASS-SVN] r61457 - in grass/trunk/temporal/t.rast.to.rast3: . testsuite
svn_grass at osgeo.org
Wed Jul 30 06:46:53 PDT 2014
Author: huhabla
Date: 2014-07-30 06:46:53 -0700 (Wed, 30 Jul 2014)
New Revision: 61457
Added:
grass/trunk/temporal/t.rast.to.rast3/testsuite/
grass/trunk/temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py
t.rast.to.rast3: Added gunittest framework tests
Added: grass/trunk/temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py
--- grass/trunk/temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py (rev 0)
+++ grass/trunk/temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py 2014-07-30 13:46:53 UTC (rev 61457)
@@ -0,0 +1,350 @@
+"""Test t.rast.to.rast3
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Soeren Gebbert
+import grass.pygrass.modules as pymod
+import subprocess
+from grass.gunittest.case import TestCase
+from grass.gunittest.gmodules import SimpleModule
+class TestSTRDSToRast3(TestCase):
+ def setUp(self):
+ """Create input data
+ self.use_temp_region()
+ self.runModule("g.gisenv", set="TGIS_USE_CURRENT_MAPSET=1")
+ self.runModule("g.region", s=0, n=80, w=0, e=120, b=0, t=50, res=10, res3=10)
+ self.runModule("r.mapcalc", expression="prec_1i = 100")
+ self.runModule("r.mapcalc", expression="prec_2i = 200")
+ self.runModule("r.mapcalc", expression="prec_3i = 300")
+ self.runModule("r.mapcalc", expression="prec_4i = 400")
+ self.runModule("r.mapcalc", expression="prec_5i = 500")
+ self.runModule("r.mapcalc", expression="prec_6i = 600")
+ self.runModule("r.mapcalc", expression="prec_1d = 100.0")
+ self.runModule("r.mapcalc", expression="prec_2d = 200.0")
+ self.runModule("r.mapcalc", expression="prec_3d = 300.0")
+ self.runModule("r.mapcalc", expression="prec_4d = 400.0")
+ self.runModule("r.mapcalc", expression="prec_5d = 500.0")
+ self.runModule("r.mapcalc", expression="prec_6d = 600.0")
+ self.runModule("r.mapcalc", expression="prec_1f = float(100.0)")
+ self.runModule("r.mapcalc", expression="prec_2f = float(200.0)")
+ self.runModule("r.mapcalc", expression="prec_3f = float(300.0)")
+ self.runModule("r.mapcalc", expression="prec_4f = float(400.0)")
+ self.runModule("r.mapcalc", expression="prec_5f = float(500.0)")
+ self.runModule("r.mapcalc", expression="prec_6f = float(600.0)")
+ self.runModule("t.create", type="strds", temporaltype="absolute",
+ output="precip_i", title="A test integer",
+ description="A test integer values")
+ self.runModule("t.register", flags="i", type="rast", input="precip_i",
+ maps="prec_1i,prec_2i,prec_3i,prec_4i,prec_5i,prec_6i",
+ start="2001-01-01", increment="3 months")
+ output="precip_f", title="A test float",
+ description="A test float values")
+ self.runModule("t.register", flags="i", type="rast", input="precip_f",
+ maps="prec_1f,prec_2f,prec_3f,prec_4f,prec_5f,prec_6f",
+ output="precip_d", title="A test float",
+ self.runModule("t.register", flags="i", type="rast", input="precip_d",
+ maps="prec_1d,prec_2d,prec_3d,prec_4d,prec_5d,prec_6d",
+ def tearDown(self):
+ """Remove generated data"""
+ self.runModule("t.remove", flags="rf", type="strds",
+ inputs="precip_i,precip_f,precip_d")
+ self.del_temp_region()
+ def test_3m(self):
+ """Convert STRDS into 3d raster map, granularity 3 months"""
+ self.assertModule("t.rast.to.rast3", input="precip_i", output="precip_i")
+ self.assertModule("t.rast.to.rast3", input="precip_f", output="precip_f")
+ self.assertModule("t.rast.to.rast3", input="precip_d", output="precip_d")
+ univar_string="""n=576
+ null_cells=0
+ cells=576
+ min=100
+ max=600
+ range=500
+ mean=350
+ mean_of_abs=350
+ stddev=170.782512765993
+ variance=29166.6666666667
+ coeff_var=48.7950036474267
+ sum=201600"""
+ self.assertRaster3dFitsUnivar(raster="precip_i", reference=univar_string, precision=2)
+ self.assertRaster3dFitsUnivar(raster="precip_f", reference=univar_string, precision=2)
+ self.assertRaster3dFitsUnivar(raster="precip_d", reference=univar_string, precision=2)
+ tinfo_string="""north=80
+ south=0
+ east=120
+ west=0
+ bottom=1213
+ top=1231
+ nsres=10
+ ewres=10
+ tbres=3
+ rows=8
+ cols=12
+ depths=6
+ datatype="DCELL"
+ timestamp="1 Jan 2001 00:00:00 / 1 Jul 2002 00:00:00"
+ units="none"
+ vertical_units="months" """
+ self.assertRaster3dFitsInfo(raster="precip_i", reference=tinfo_string, precision=2)
+ south=0
+ east=120
+ west=0
+ bottom=1213
+ top=1231
+ nsres=10
+ ewres=10
+ tbres=3
+ rows=8
+ cols=12
+ depths=6
+ datatype="FCELL"
+ units="none"
+ self.assertRaster3dFitsInfo(raster="precip_f", reference=tinfo_string, precision=2)
+ south=0
+ east=120
+ west=0
+ bottom=1213
+ top=1231
+ nsres=10
+ ewres=10
+ tbres=3
+ rows=8
+ cols=12
+ depths=6
+ datatype="DCELL"
+ units="none"
+ self.assertRaster3dFitsInfo(raster="precip_d", reference=tinfo_string, precision=2)
+ def test_3m_gap(self):
+ """Convert STRDS with gaps into 3d raster map, granularity 3 months"""
+ self.runModule("t.unregister", maps="prec_3d,prec_3f,prec_3i")
+ univar_string="""n=480
+ null_cells=96
+ cells=576
+ min=100
+ max=600
+ range=500
+ mean=360
+ mean_of_abs=360
+ stddev=185.472369909914
+ variance=34400
+ coeff_var=51.5201027527539
+ sum=172800"""
+ south=0
+ east=120
+ west=0
+ bottom=1213
+ top=1231
+ nsres=10
+ ewres=10
+ tbres=3
+ rows=8
+ cols=12
+ depths=6
+ datatype="DCELL"
+ units="none"
+ south=0
+ east=120
+ west=0
+ bottom=1213
+ top=1231
+ nsres=10
+ ewres=10
+ tbres=3
+ rows=8
+ cols=12
+ depths=6
+ datatype="FCELL"
+ units="none"
+ south=0
+ east=120
+ west=0
+ bottom=1213
+ top=1231
+ nsres=10
+ ewres=10
+ tbres=3
+ rows=8
+ cols=12
+ depths=6
+ datatype="DCELL"
+ units="none"
+class TestSTRDSToRast3MultiGran(TestCase):
+ def setUp(self):
+ self.runModule("t.remove", flags="rf", type="strds", inputs="precip_d")
+ def test_years(self):
+ """Convert STRDS into 3d raster map, granularity5 years"""
+ start="2000-01-01", increment="5 years")
+ south=0
+ east=120
+ west=0
+ bottom=100
+ top=130
+ nsres=10
+ ewres=10
+ tbres=3
+ rows=8
+ cols=12
+ depths=6
+ datatype="DCELL"
+ timestamp="1 Jan 2000 00:00:00 / 1 Jan 2030 00:00:00"
+ units="none"
+ vertical_units="years" """
+ def test_months(self):
+ """Convert STRDS into 3d raster map, granularity 6 months"""
+ start="2000-01-01", increment="6 months")
+ south=0
+ east=120
+ west=0
+ bottom=1201
+ top=1237
+ nsres=10
+ ewres=10
+ tbres=6
+ rows=8
+ cols=12
+ depths=6
+ datatype="DCELL"
+ timestamp="1 Jan 2000 00:00:00 / 1 Jan 2003 00:00:00"
+ units="none"
+ """Convert STRDS into 3d raster map, granularity 7 days"""
+ start="2000-01-01", increment="7 days")
+ self.runModule("r3.info", map="precip_d")
+ south=0
+ east=120
+ west=0
+ bottom=36524
+ top=36566
+ nsres=10
+ ewres=10
+ tbres=7
+ rows=8
+ cols=12
+ depths=6
+ datatype="DCELL"
+ timestamp="1 Jan 2000 00:00:00 / 12 Feb 2000 00:00:00"
+ units="none"
+ vertical_units="days" """
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
