[GRASS-SVN] r61458 - grass/branches/releasebranch_7_0/raster/r.in.gdal
svn_grass at osgeo.org
Wed Jul 30 07:06:09 PDT 2014
Author: neteler
Date: 2014-07-30 07:06:09 -0700 (Wed, 30 Jul 2014)
New Revision: 61458
grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c
r.in.gdal: predefine 300 MiB as default cache size for speed-up; msg cosmetics (trunk, r61362 + r61364)
Modified: grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c
--- grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c 2014-07-30 13:46:53 UTC (rev 61457)
+++ grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c 2014-07-30 14:06:09 UTC (rev 61458)
@@ -102,6 +102,7 @@
parm.memory->type = TYPE_INTEGER;
parm.memory->required = NO;
parm.memory->options = "0-2047";
+ parm.memory->answer = "300";
parm.memory->description = _("Cache size (MiB)");
parm.target = G_define_option();
@@ -209,11 +210,9 @@
if (parm.memory->answer && *parm.memory->answer) {
/* TODO: GDALGetCacheMax() overflows at 2GiB, implement use of GDALSetCacheMax64() */
GDALSetCacheMax(atol(parm.memory->answer) * 1024 * 1024);
- G_verbose_message(_("Using user memory cache size: %.1f MiB"), GDALGetCacheMax()/1024.0/1024.0);
- } else
- G_verbose_message(_("Using default GDAL memory cache size: %.1f MiB"), GDALGetCacheMax()/1024.0/1024.0);
+ G_verbose_message(_("Using memory cache size: %.1f MiB"), GDALGetCacheMax()/1024.0/1024.0);
/* List supported formats and exit. */
/* code from GDAL 1.2.5 gcore/gdal_misc.cpp */
