[GRASS-SVN] r61480 - grass/trunk/raster/r.in.lidar
svn_grass at osgeo.org
Thu Jul 31 09:53:22 PDT 2014
Author: neteler
Date: 2014-07-31 09:53:22 -0700 (Thu, 31 Jul 2014)
New Revision: 61480
grass/trunk/raster/r.in.lidar/main.c
r.in.lidar: support for intensity values added
Modified: grass/trunk/raster/r.in.lidar/main.c
--- grass/trunk/raster/r.in.lidar/main.c 2014-07-31 16:51:55 UTC (rev 61479)
+++ grass/trunk/raster/r.in.lidar/main.c 2014-07-31 16:53:22 UTC (rev 61480)
@@ -146,7 +146,7 @@
struct Option *input_opt, *output_opt, *percent_opt, *type_opt, *filter_opt;
struct Option *method_opt, *zrange_opt, *zscale_opt;
struct Option *trim_opt, *pth_opt, *res_opt;
- struct Flag *print_flag, *scan_flag, *shell_style, *over_flag, *extents_flag;
+ struct Flag *print_flag, *scan_flag, *shell_style, *over_flag, *extents_flag, *intens_flag;
/* LAS */
LASReaderH LAS_reader;
@@ -277,6 +277,11 @@
shell_style->description =
_("In scan mode, print using shell script style");
+ intens_flag = G_define_flag();
+ intens_flag->key = 'i';
+ intens_flag->description =
+ _("Import intensity values rather than z values");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -761,7 +766,11 @@
x = LASPoint_GetX(LAS_point);
y = LASPoint_GetY(LAS_point);
- z = LASPoint_GetZ(LAS_point);
+ if (intens_flag->answer)
+ /* use z variable here to allow for scaling of intensity below */
+ z = LASPoint_GetIntensity(LAS_point);
+ else
+ z = LASPoint_GetZ(LAS_point);
if (return_filter != LAS_ALL) {
int return_no = LASPoint_GetReturnNumber(LAS_point);
