[GRASS-SVN] r61483 - in grass/branches/releasebranch_7_0: . gui/wxpython/xml scripts scripts/i.pansharpen
svn_grass at osgeo.org
Thu Jul 31 10:22:01 PDT 2014
Author: neteler
Date: 2014-07-31 10:22:01 -0700 (Thu, 31 Jul 2014)
New Revision: 61483
Added:
grass/branches/releasebranch_7_0/scripts/i.colors.enhance/
Removed:
grass/branches/releasebranch_7_0/scripts/i.landsat.rgb/
grass/branches/releasebranch_7_0/gui/wxpython/xml/toolboxes.xml
grass/branches/releasebranch_7_0/scripts/Makefile
grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.html
grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py
i.landsat.rgb renamed to i.colors.enhance (trac #2340) (trunk, r61481)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Added: svn:mergeinfo
+ /grass/trunk:61481
Modified: grass/branches/releasebranch_7_0/gui/wxpython/xml/toolboxes.xml
--- grass/branches/releasebranch_7_0/gui/wxpython/xml/toolboxes.xml 2014-07-31 17:18:35 UTC (rev 61482)
+++ grass/branches/releasebranch_7_0/gui/wxpython/xml/toolboxes.xml 2014-07-31 17:22:01 UTC (rev 61483)
@@ -1495,7 +1495,7 @@
<toolbox name="ManageImageColors">
<label>Manage image colors</label>
<items>
- <module-item name="i.landsat.rgb">
+ <module-item name="i.colors.enhance">
<label>Color balance for RGB</label>
</module-item>
<module-item name="i.his.rgb">
Modified: grass/branches/releasebranch_7_0/scripts/Makefile
--- grass/branches/releasebranch_7_0/scripts/Makefile 2014-07-31 17:18:35 UTC (rev 61482)
+++ grass/branches/releasebranch_7_0/scripts/Makefile 2014-07-31 17:22:01 UTC (rev 61483)
@@ -18,9 +18,9 @@
g.extension \
g.extension.all \
g.manual \
+ i.colors.enhance \
i.image.mosaic \
i.in.spotvgt \
- i.landsat.rgb \
i.oif \
i.pansharpen \
i.spectral \
Modified: grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.html
--- grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.html 2014-07-31 17:18:35 UTC (rev 61482)
+++ grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.html 2014-07-31 17:22:01 UTC (rev 61483)
@@ -74,7 +74,7 @@
but does use an optimized r.mapcalc expression to reduce disk I/O.
<br><br>
The three pan-sharpened output channels may be combined with <em>d.rgb</em> or
-<em>r.composite</em>. Colors may be optionally optimized with <em>i.landsat.rgb</em>.
+<em>r.composite</em>. Colors may be optionally optimized with <em>i.colors.enhance</em>.
While the resulting color image will be at the higher resolution in all cases,
the 3 pan sharpening algorithms differ in terms of spectral response.
@@ -163,7 +163,7 @@
g.gui.mapswipe
# optionally color balancing:
-i.landsat.rgb r=lsat7_2002_ihs_red g=lsat7_2002_ihs_green b=lsat7_2002_ihs_blue
+i.colors.enhance r=lsat7_2002_ihs_red g=lsat7_2002_ihs_green b=lsat7_2002_ihs_blue
</pre></div>
<h2>SEE ALSO</h2>
Modified: grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py
--- grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py 2014-07-31 17:18:35 UTC (rev 61482)
+++ grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py 2014-07-31 17:22:01 UTC (rev 61483)
@@ -334,7 +334,7 @@
grass.message(_("d.rgb r=%s_red g=%s_green b=%s_blue" % (out, out, out)))
grass.message('\n ')
grass.message(_("If desired, combine channels into a single RGB map with 'r.composite'."))
- grass.message(_("Channel colors can be rebalanced using i.landsat.rgb."))
+ grass.message(_("Channel colors can be rebalanced using i.colors.enhance."))
# write cmd history:
for ch in ['red', 'green', 'blue']:
